  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 562.8k Aufrufe 72 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    #426
    @StrathCole
    Im Laufe des heutigen Abends stürzt der Adapter immer wieder mit folgenden Logzeilen ab:
    2020-03-19 23:05:59.566 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
    2020-03-19 23:05:59.567 - error: host.BT3-PRO Caught by controller[1]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
    2020-03-19 23:05:59.568 - error: host.BT3-PRO Caught by controller[2]: 2: 0x8fa0dc [io.plenticore.0]
    2020-03-19 23:05:59.568 - error: host.BT3-PRO Caught by controller[3]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
    2020-03-19 23:05:59.568 - error: host.BT3-PRO Caught by controller[4]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
    2020-03-19 23:05:59.568 - error: host.BT3-PRO Caught by controller[5]: 5: 0xef4c72 [io.plenticore.0]
    2020-03-19 23:05:59.568 - error: host.BT3-PRO Caught by controller[6]: 6: 0xecc7b9 [io.plenticore.0]
    2020-03-19 23:05:59.569 - error: host.BT3-PRO Caught by controller[7]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
    2020-03-19 23:05:59.569 - error: host.BT3-PRO Caught by controller[8]: 8: 0xe7c8ff [io.plenticore.0]
    2020-03-19 23:05:59.569 - error: host.BT3-PRO Caught by controller[9]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
    2020-03-19 23:05:59.569 - error: host.BT3-PRO Caught by controller[9]: 10: 0x39381f4dbe1d
    2020-03-19 23:05:59.569 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
    Habe noch keine Lösung gefunden es wieder zu stabilisieren.
    ..:: So long! Tom ::..
    • DiginixD Diginix
      @StrathCole
      tp1de
      #427
      @Diginix sagte in IOBroker Anbindung an einen Kostal Plenticore:
      @StrathCole
      Auch bei mir gibt es seit 22 Uhr diese Abstürze
      • StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #428
        Oha. Ich habe sie nicht. Vielleicht müsst ihr doch mal die aktuelle Version aus dem git installieren?
        SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
          StrathColeS Offline
          StrathCole
          #429
          Und schaut mal in /Pfad/zu/ioBroker/iobroker-data/plenticore.0
          Da sind .json Dateien. Ist davon vielleicht eine sehr groß?
            StrathColeS Offline
            StrathCole
            schrieb am zuletzt editiert von StrathCole
            #430
            Vielleicht vor einem Update mal debug Log Einschalten, dass ich sehe was genau vor diesem Fehler passiert. Danke.
            • StrathColeS StrathCole
              DiginixD Offline
              DiginixD Offline
              Diginix
              #431
              @StrathCole
              Die JSON sind alle klein.
              -rw-rwxr--+ 1 iobroker iobroker 8279 Mär 19 22:37 fcast.json
              -rw-rwxr--+ 1 iobroker iobroker  838 Mär 19 22:37 pwrcons.json
              -rw-rwxr--+ 1 iobroker iobroker   54 Mär 19 22:37 pwrgen.json
              Ich deaktiviere den Adapter jetzt erstmal bis morgen. Sonst explodiert das Log und ich bekomme Mails wenn Adapter nicht grün sind.
              GIT Version teste ich morgen falls er nach Restart dann weiterhin abstürzt.
                tp1de
                schrieb am zuletzt editiert von tp1de
                #432
                @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
                Der Adapter stürtzt mit eingeschalteteter Prognose ab. Auch die aktuelle GIT-Version.
                Es werden keine Werte mehr übertragen. Folgende Einträge im Log:
                host.iob	2020-03-20 07:33:57.999	info	Restart adapter system.adapter.plenticore.0 because enabled
                host.iob	2020-03-20 07:33:57.999	info	instance system.adapter.plenticore.0 terminated with code NaN ()
                host.iob	2020-03-20 07:33:57.999	warn	instance system.adapter.plenticore.0 terminated due to SIGABRT
                host.iob	2020-03-20 07:33:57.998	error	Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
                plenticore.0	2020-03-20 07:32:15.382	debug	(11691) 2nd Panel surface: 16.65m²
                plenticore.0	2020-03-20 07:32:15.381	debug	(11691) 2nd Panel efficiency: 19.6%
                plenticore.0	2020-03-20 07:32:15.381	debug	(11691) 2nd Panel direction: 325°
                plenticore.0	2020-03-20 07:32:15.380	debug	(11691) 2nd Panel tilt: 40°
                plenticore.0	2020-03-20 07:32:15.380	debug	(11691) Panel surface: 24.6m²
                plenticore.0	2020-03-20 07:32:15.379	debug	(11691) Panel efficiency: 19.6%
                plenticore.0	2020-03-20 07:32:15.379	debug	(11691) Panel direction: 145°
                plenticore.0	2020-03-20 07:32:15.378	debug	(11691) Panel tilt: 40°
                plenticore.0	2020-03-20 07:32:15.367	info	(11691) [START] Starting adapter plenticore v2.1.0.6
                plenticore.0	2020-03-20 07:32:15.333	info	(11691) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
                host.iob	2020-03-20 07:32:13.025	info	instance system.adapter.plenticore.0 started with pid 11691
                plenticore.0	2020-03-20 07:31:44.769	info	(11648) [START] Starting adapter plenticore v2.1.0.6
                plenticore.0	2020-03-20 07:31:44.709	info	(11648) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
                Ich habe die Prognose erst einmal deaktiviert, damit die Plenticore-Werte ausgelesen werden.
                Der Fehler trat zum ersten Mal Gestern um 22:05 Uhr auf !
                  tp1de
                  #433
                  @StrathCole
                  Jetzt läuft auch ohne Prognose gar nichts mehr:
                  host.iob	2020-03-20 07:42:18.626	info	Restart adapter system.adapter.plenticore.0 because enabled
                  host.iob	2020-03-20 07:42:18.625	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
                  host.iob	2020-03-20 07:42:18.049	info	instance system.adapter.plenticore.0 started with pid 12003
                  host.iob	2020-03-20 07:41:48.023	info	Restart adapter system.adapter.plenticore.0 because enabled
                  host.iob	2020-03-20 07:41:48.023	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
                  host.iob	2020-03-20 07:41:47.452	info	instance system.adapter.plenticore.0 started with pid 11963
                  host.iob	2020-03-20 07:41:17.420	info	Restart adapter system.adapter.plenticore.0 because enabled
                  host.iob	2020-03-20 07:41:17.419	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
                  host.iob	2020-03-20 07:41:16.884	info	instance system.adapter.plenticore.0 started with pid 11947
                  host.iob	2020-03-20 07:40:46.865	info	Restart adapter system.adapter.plenticore.0 because enabled
                  host.iob	2020-03-20 07:40:46.864	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
                  host.iob	2020-03-20 07:40:46.284	info	instance system.adapter.plenticore.0 started with pid 11928
                  host.iob	2020-03-20 07:40:16.250	info	Restart adapter system.adapter.plenticore.0 because enabled
                    StrathColeS Offline
                    StrathCole
                    #434
                    Gibt's ja nicht …
                    Kannst du den Adapter einmal stoppen, dann die json Dateien löschen, nur die pwrcons.json nicht. Dann neu starten.
                      Gibt's ja nicht …
                      tp1de
                      #435
                      Json-Dateien gelöscht. Dann Läuft er wieder, aber nur ohne Leistungsprognose.
                      Mit Prognose kommt wieder der Fehler
                      ost.iob	2020-03-20 08:12:52.459	warn	instance system.adapter.plenticore.0 terminated due to SIGABRT
                      host.iob	2020-03-20 08:12:52.458	error	Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
                      und es werden keine Werte ausgelesen.
                      Gehe erst mal frühstücken ...
                      StrathColeS 1 Antwort Letzte Antwort
                      • T tp1de
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #436
                        @tom57 Danke für die Tests. Das ist echt erstaunlich, vor allem, weil ich den Fehler hier nicht bekomme.
                        Hast du den Debug-Modus noch angeschaltet in der Adapter-Liste? Mich wundert, dass direkt vor dem Fehler keinerlei Logmeldung kam weiter oben. Irgendwas muss doch direkt vor dem Fehler ausgeführt werden :-/
                          StrathColeS Offline
                          StrathCole
                          #437
                          Und vielleicht bitte gerade noch einmal vom git aktualisieren. Habe ein Problem beim Parsen von Kachelmann gefunden und behoben. Vielleicht führt das ja bei euch zum Absturz und bei mir nur zu ner Warnung, warum auch immer.
                          • DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #438
                            Hab jetzt von GIT (2.1.0.6, Dateien von 08:23 Uhr) aktualisiert und die fcast.json + pwrgen.json gelöscht.
                            Sonst alles aktiv im Adapter.
                            Adapter stürzt direkt nach Start ab und bleibt rot:
                            2020-03-20 08:37:22.886 - info: plenticore.0 (807) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
                            2020-03-20 08:37:22.950 - info: plenticore.0 (807) [START] Starting adapter plenticore v2.1.0.6
                            2020-03-20 08:37:22.994 - debug: plenticore.0 (807) Panel tilt: 23°
                            2020-03-20 08:37:22.996 - debug: plenticore.0 (807) Panel direction: 180°
                            2020-03-20 08:37:22.997 - debug: plenticore.0 (807) Panel efficiency: 19.3%
                            2020-03-20 08:37:22.997 - debug: plenticore.0 (807) Panel surface: 39m²
                            2020-03-20 08:37:24.431 - info: plenticore.0 (807) got weather data from met.no with 229 elements.
                            2020-03-20 08:38:44.965 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
                            2020-03-20 08:38:44.966 - error: host.BT3-PRO Caught by controller[1]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
                            2020-03-20 08:38:44.966 - error: host.BT3-PRO Caught by controller[2]: 2: 0x8fa0dc [io.plenticore.0]
                            2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[3]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
                            2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[4]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
                            2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[5]: 5: 0xef4c72 [io.plenticore.0]
                            2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[6]: 6: 0xecc7b9 [io.plenticore.0]
                            2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[7]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
                            2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[8]: 8: 0xe7c8ff [io.plenticore.0]
                            2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[9]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
                            2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[9]: 10: 0x1c3d1905be1d
                            2020-03-20 08:38:44.968 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
                            • DiginixD Diginix
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #439
                              Könntest du noch einmal vom git aktualisieren? Irgendwie muss ich nach und nach Logmeldungen einfügen :-/
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #440
                                @StrathCole 2.0.1.7 stürzt ebenso ab:
                                2020-03-20 09:00:19.268 - info: plenticore.0 (4530) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
                                2020-03-20 09:00:19.317 - info: plenticore.0 (4530) [START] Starting adapter plenticore v2.1.0.7
                                2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel tilt: 23°
                                2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel direction: 180°
                                2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel efficiency: 19.3%
                                2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel surface: 39m²
                                2020-03-20 09:00:22.368 - info: plenticore.0 (4530) got weather data from met.no with 229 elements.
                                2020-03-20 09:02:58.471 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
                                2020-03-20 09:02:58.472 - error: host.BT3-PRO Caught by controller[0]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
                                2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[0]: 2: 0x8fa0dc [io.plenticore.0]
                                2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[1]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
                                2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[2]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
                                2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[3]: 5: 0xef4c72 [io.plenticore.0]
                                2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[4]: 6: 0xecc7b9 [io.plenticore.0]
                                2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[5]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
                                2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 8: 0xe7c8ff [io.plenticore.0]
                                2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
                                2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 10: 0x33b7e975be1d
                                2020-03-20 09:02:58.474 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
                                • DiginixD Diginix
                                  StrathColeS Offline
                                  StrathColeS Offline
                                  StrathCole
                                  #441
                                  @Diginix ich versuche gerade herauszufinden, an welcher Stelle genau er abstürzt. Mich irritiert, dass nach dem "met.no" keine weiteren Meldungen kommen. Eigentlich müssten da im Debug-Modus viel mehr kommen. Ich teste ein paar Dinge und gebe Bescheid, wenn du noch mal aktualisieren kannst.
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #442
                                    Stehe in den Startlöchern, aber kein Stress! ;-)
                                    Loglevel Debug ist dauerhaft aktiv für deinen Adapter.
                                    • DiginixD Diginix
                                      StrathColeS Offline
                                      StrathColeS Offline
                                      StrathCole
                                      #443
                                      @Diginix so. Bitte einmal aus dem git laden. Ich habe mal met.no auskommentiert. Wird jetzt sicher Warnungen oder Fehler werfen, aber so sehe ich, ob es ggf. daran liegt.
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #444
                                        @StrathCole Läuft wieder!
                                        • DiginixD Diginix
                                          StrathColeS Offline
                                          StrathColeS Offline
                                          StrathCole
                                          #445
                                          @Diginix Nicht gut.
