  4. FHEM [gelöst] Adapter Readings direkt beschreiben
    6.5k
fhem adapterreading
31 Beiträge 2 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • L Offline
    LHBL2003
    schrieb am zuletzt editiert von LHBL2003
    schon mal Danke.
    aber ich glaube da passt etwas nicht oder?
    host.JDD-HomePi 2020-03-15 00:26:29.700 info Restart adapter system.adapter.fhem.0 because enabled
    host.JDD-HomePi 2020-03-15 00:26:29.699 info instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
    host.JDD-HomePi 2020-03-15 00:26:29.697 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.JDD-HomePi 2020-03-15 00:26:29.696 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.JDD-HomePi 2020-03-15 00:26:29.696 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.JDD-HomePi 2020-03-15 00:26:29.696 error Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
    host.JDD-HomePi 2020-03-15 00:26:29.695 error Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
    host.JDD-HomePi 2020-03-15 00:26:29.695 error Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:553:69)
    host.JDD-HomePi 2020-03-15 00:26:29.694 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
    fhem.0 2020-03-15 00:26:28.982 info (1876) Terminated (NO_ERROR): Without reason
    fhem.0 2020-03-15 00:26:28.980 info (1876) terminating
    fhem.0 2020-03-15 00:26:28.879 error (1876) TypeError: Cannot read property 'val' of null at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:553:69) at states.getStates (/opt/iobroker/node_modules/iobro
    fhem.0 2020-03-15 00:26:28.878 error (1876) uncaught exception: Cannot read property 'val' of null
    fhem.0 2020-03-15 00:26:28.863 warn (1876) Exception: TypeError: Cannot read property 'val' of null
    fhem.0 2020-03-15 00:26:28.850 info (1876) > detected 110 state(s) of "wolf.0"
    fhem.0 2020-03-15 00:26:28.786 info (1876) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
    fhem.0 2020-03-15 00:26:28.774 info (1876) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
    fhem.0 2020-03-15 00:26:28.772 info (1876) > LOG "ignore FHEM device ....." ignored Devices from FHEM (info.Configurations) - info.Settings.logIgnoreConfigurations (true)
    fhem.0 2020-03-15 00:26:28.763 info (1876) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
    fhem.0 2020-03-15 00:26:28.760 info (1876) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
    fhem.0 2020-03-15 00:26:28.756 info (1876) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
    fhem.0 2020-03-15 00:26:28.755 info (1876) > LOG "Delete channel ....." - info.Settings.logDeleteChannel (true)
    fhem.0 2020-03-15 00:26:28.710 info (1876) > LOG "Create channel ....." - info.Settings.logCreateChannel (true)
    fhem.0 2020-03-15 00:26:28.694 info (1876) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
    fhem.0 2020-03-15 00:26:28.691 info (1876) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
    fhem.0 2020-03-15 00:26:28.684 info (1876) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
    fhem.0 2020-03-15 00:26:28.638 info (1876) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
    fhem.0 2020-03-15 00:26:28.624 info (1876) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
    fhem.0 2020-03-15 00:26:28.541 info (1876) > SYNC - allowed objects send2FHEM - info.Configurations.allowedIOBin (wolf.0)
    fhem.0 2020-03-15 00:26:28.489 info (1876) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
    fhem.0 2020-03-15 00:26:28.487 info (1876) > 56 objects fhem.0.info OK
    fhem.0 2020-03-15 00:26:28.402 info (1876) > check old objects and delete
    fhem.0 2020-03-15 00:26:28.147 info (1876) > check new/update objects
    fhem.0 2020-03-15 00:26:28.141 info (1876) STEP 01 ===== buildDate 14.03.20 - check objects fhem.0.info
    fhem.0 2020-03-15 00:26:27.977 info (1876) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.fhem, node: v10.19.0
    Hatte vorher die Stabile Version 1.3.0 aber auch die 1.4.1 funktioniert ohne Probleme.
    Das Problem besteht also in der neuen 1.4.2.
    Gruß Denis
    • LausiDL Offline
      LausiDL Offline
      LausiD
      @LHBL2003
      Jo hängt mit der Änderung zusammen.
      Sind states ohne Wert dabei?
      Mach noch eine Änderung
      Doku zum FHEM Adapter
      Aktuelles zum FHEM Adapter
      Test FHEM Adapter
      L 1 Antwort Letzte Antwort
      • LausiDL LausiD
        @LHBL2003
        LHBL2003
        @LausiD
        Ich sehe gerade das er Einträge erzeugt hat.
        Leider ist die Version 1.4.2 nicht mehr online, kann also nicht prüfen ob sich etwas bessert wenn ich noch eine Änderung mache.
        Aber ja von der Schnittstelle kommen auch Objekte ohne Werte.
        • LausiDL Offline
          LausiDL Offline
          LausiD
          @LHBL2003
          Kannst nochmal mit 1.4.2 von github testen
          Bei Objekten ohne Wert wird jetzt "no value" übertragen
          Test FHEM Adapter
          • L Offline
            LHBL2003
            1.4.2 steht scheinbar nicht zur Verfügung
            Gruß Denis
            • LausiDL Offline
              LausiDL Offline
              LausiD
              @LHBL2003
              Die Version 1.4.2 ist nur unter github verfügbar.
              Nur in dieser Version kann ich kurzfristig Änderungen durchführen.
              Bei mir werden bei Adapterstart jetzt alle Objekte an FHEM übertragen.
              Ist der Wert "leer" wird in FHEM "no value" gesetzt.
              Also den Adapter nochmal von github aktualisieren und testen...
              Test FHEM Adapter
              • L Offline
                LHBL2003
                Nein ist leider noch nicht besser:
                Man kann auch aktuell aus dem log nicht erkennen um welche Variable es sich handelt.
                Nachfolgend das Log und Screens der Wolf.0 Variablen:
                host.JDD-HomePi 2020-03-15 10:54:00.532 info instance system.adapter.fhem.0 started with pid 5133
                host.JDD-HomePi 2020-03-15 10:53:30.501 info Restart adapter system.adapter.fhem.0 because enabled
                host.JDD-HomePi 2020-03-15 10:53:30.500 info instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
                host.JDD-HomePi 2020-03-15 10:53:30.499 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                host.JDD-HomePi 2020-03-15 10:53:30.499 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                host.JDD-HomePi 2020-03-15 10:53:30.498 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                host.JDD-HomePi 2020-03-15 10:53:30.497 error Caught by controller[0]: at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
                host.JDD-HomePi 2020-03-15 10:53:30.497 error Caught by controller[0]: at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
                host.JDD-HomePi 2020-03-15 10:53:30.496 error Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:549:36)
                host.JDD-HomePi 2020-03-15 10:53:30.494 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                fhem.0 2020-03-15 10:53:29.937 info (5116) Terminated (NO_ERROR): Without reason
                fhem.0 2020-03-15 10:53:29.935 info (5116) terminating
                fhem.0 2020-03-15 10:53:29.876 error at process._tickCallback (internal/process/next_tick.js:68:7)
                fhem.0 2020-03-15 10:53:29.876 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                fhem.0 2020-03-15 10:53:29.876 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                fhem.0 2020-03-15 10:53:29.876 error at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:619:13)
                fhem.0 2020-03-15 10:53:29.876 error at states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5922:17)
                fhem.0 2020-03-15 10:53:29.876 error at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:549:36)
                fhem.0 2020-03-15 10:53:29.876 error (5116) TypeError: Cannot read property 'val' of null
                fhem.0 2020-03-15 10:53:29.875 error (5116) uncaught exception: Cannot read property 'val' of null
                fhem.0 2020-03-15 10:53:29.861 warn (5116) Exception: TypeError: Cannot read property 'val' of null
                fhem.0 2020-03-15 10:53:29.850 info (5116) > detected 110 state(s) of "wolf.0"
                fhem.0 2020-03-15 10:53:29.808 info (5116) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
                fhem.0 2020-03-15 10:53:29.803 info (5116) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
                fhem.0 2020-03-15 10:53:29.801 info (5116) > LOG "ignore FHEM device ....." ignored Devices from FHEM (info.Configurations) - info.Settings.logIgnoreConfigurations (true)
                fhem.0 2020-03-15 10:53:29.800 info (5116) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
                fhem.0 2020-03-15 10:53:29.758 info (5116) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
                fhem.0 2020-03-15 10:53:29.757 info (5116) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
                fhem.0 2020-03-15 10:53:29.756 info (5116) > LOG "Delete channel ....." - info.Settings.logDeleteChannel (true)
                fhem.0 2020-03-15 10:53:29.754 info (5116) > LOG "Create channel ....." - info.Settings.logCreateChannel (true)
                fhem.0 2020-03-15 10:53:29.695 info (5116) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
                fhem.0 2020-03-15 10:53:29.693 info (5116) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                fhem.0 2020-03-15 10:53:29.690 info (5116) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
                fhem.0 2020-03-15 10:53:29.640 info (5116) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
                fhem.0 2020-03-15 10:53:29.581 info (5116) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
                fhem.0 2020-03-15 10:53:29.514 info (5116) > SYNC - allowed objects send2FHEM - info.Configurations.allowedIOBin (wolf.0)
                fhem.0 2020-03-15 10:53:29.500 info (5116) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
                fhem.0 2020-03-15 10:53:29.497 info (5116) > 56 objects fhem.0.info OK
                fhem.0 2020-03-15 10:53:29.409 info (5116) > check old objects and delete
                fhem.0 2020-03-15 10:53:29.226 info (5116) > check new/update objects
                fhem.0 2020-03-15 10:53:29.220 info (5116) STEP 01 ===== buildDate 15.03.20 - check objects fhem.0.info
                fhem.0 2020-03-15 10:53:29.082 info (5116) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.fhem, node: v10.19.0
                Bildschirmfoto 2020-03-15 um 11.00.13.png Bildschirmfoto 2020-03-15 um 11.00.18.png Bildschirmfoto 2020-03-15 um 11.00.23.png Bildschirmfoto 2020-03-15 um 11.00.28.png Bildschirmfoto 2020-03-15 um 11.00.36.png Bildschirmfoto 2020-03-15 um 11.00.41.png Bildschirmfoto 2020-03-15 um 11.00.47.png Bildschirmfoto 2020-03-15 um 11.00.07.png
                Gruß Denis
                • LausiDL Offline
                  LausiDL Offline
                  LausiD
                  @LHBL2003
                  Ok ein "leerer" Wert ist nicht schuld.
                  Bitte nochmal Update von github.
                  Unter Step 6 werden jetzt alle ausgewählten Objekte als Warnmeldung angezeigt.
                  Alternativ:
                  Test mit Einschränken unter allowedIOBin zB wolf.0.bm3
                  LausiD
                  Test FHEM Adapter
                  • L Offline
                    LHBL2003
                    Also bei wolf.0.bm3 kommt der Fehler auch.
                    Ich habe also mal den ersten leeren von wolf.0.bm3 genommen, da dieser ein Umlaut im Namen hat. Dort hatte ich dann den Fehler wieder. Aber wolf.0.bm3.82 hat keine Umlaute, ist aber auch leer. Dort bekomme ich den Fehler auch.
                    wolf.0.bm3.81 besitz einen Wert. Dort bekomme ich keinen Fehler.
                    Bildschirmfoto 2020-03-15 um 17.00.02.png Bildschirmfoto 2020-03-15 um 16.59.50.png Bildschirmfoto 2020-03-15 um 16.59.30.png Bildschirmfoto 2020-03-15 um 16.58.52.png
                     "common": {
                       "name": "Warmwassersolltemperatur",
                       "role": "Value_Temp",
                       "type": "boolean",
                       "unit": "°C",
                       "enabled": false
                     "native": {
                       "rw": "rw"
                     "acl": {
                       "object": 1638,
                       "owner": "system.user.admin",
                       "state": 1638
                     "_id": "wolf.0.bm3.82",
                     "type": "state"
                     "type": "state",
                     "common": {
                       "name": "Raumtemperatur",
                       "type": "state",
                       "unit": "°C",
                       "enabled": false
                     "native": {
                       "rw": "r"
                     "_id": "wolf.0.bm3.81",
                     "acl": {
                       "object": 1638,
                       "state": 1638
                    Gruß Denis
                    • L Offline
                      LHBL2003
                      Ich habe mal den Adapter und alle Variablen abgelöscht.
                      Interessanterweise kommt der Fehler dennoch beim start.
                      Dabei ist check fhem.0.info.Configurations.allowedIOBin aktuell nicht gesetzt.
                      evtl. Schlummert irgendwo einen tiefergründigeres Problem.
                      fhem.0 2020-03-15 23:04:27.054 info (18165) END ===== Synchronised FHEM in 7033 ms :-)
                      fhem.0 2020-03-15 23:04:27.052 warn (18165) > more info FHEM Adapter visit https://github.com/iobroker-community-adapters/ioBroker.fhem/blob/master/docs/de/README.md
                      fhem.0 2020-03-15 23:04:27.043 info (18165) > lastIOBout = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastIOBout
                      fhem.0 2020-03-15 23:04:27.041 info (18165) > lastSend2ioB = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastSend2ioB
                      fhem.0 2020-03-15 23:04:27.038 info (18165) > lastInfo = > dummy fhem.0.alive - use to check alive FHEM Adapter in FHEM - fhem.0.info.Info.lastInfo
                      fhem.0 2020-03-15 23:04:26.992 info (18165) > lastError = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastError
                      fhem.0 2020-03-15 23:04:26.978 info (18165) > lastWarn = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastWarn
                      fhem.0 2020-03-15 23:04:26.977 info (18165) > Number devices of FHEM (ignored) = 2 - fhem.0.info.Info.numberDevicesFHEMignored
                      fhem.0 2020-03-15 23:04:26.977 info (18165) > FHEM alive = false - fhem.0.info.Info.alive
                      fhem.0 2020-03-15 23:04:26.976 info (18165) > Number of objects IOB in = 130 - fhem.0.info.Info.numberObjectsIOBin
                      fhem.0 2020-03-15 23:04:26.976 info (18165) > Number of objects IOB out (possible) = 0 - fhem.0.info.Info.numberObjectsIOBoutSub
                      fhem.0 2020-03-15 23:04:26.975 info (18165) > Number of objects IOB out (detected) = 0 - fhem.0.info.Info.numberObjectsIOBout
                      fhem.0 2020-03-15 23:04:26.974 info (18165) > Number devices of FHEM (synchronized) = 9 - fhem.0.info.Info.numberDevicesFHEMsync
                      fhem.0 2020-03-15 23:04:26.974 info (18165) > Number devices of FHEM (jsonlist2) = 321 - fhem.0.info.Info.numberDevicesFHEM
                      fhem.0 2020-03-15 23:04:26.973 info (18165) > room of fhem.x.info.Configurations.onlySyncRoom exist = true - fhem.0.info.Info.roomioBroker
                      fhem.0 2020-03-15 23:04:26.972 info (18165) > Date of main.js = 15.03.20 - fhem.0.info.Info.buildDate
                      fhem.0 2020-03-15 23:04:26.946 info (18165) STEP 15 ==== info Synchro
                      fhem.0 2020-03-15 23:04:26.938 info (18165) event FHEM: ---- | dummy fhem.0.alive on | state > fhem.0.alive (getAlive)
                      fhem.0 2020-03-15 23:04:26.933 info (18165) > processed 1 event(s) of FHEM saved during synchro
                      fhem.0 2020-03-15 23:04:26.932 info (18165) STEP 14 ==== processed saved event(s) of FHEM
                      fhem.0 2020-03-15 23:04:26.756 info (18165) stateChange: fhem.0.info.Commands.sendFHEM | save > save
                      fhem.0 2020-03-15 23:04:26.733 info (18165) stateChange: fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      fhem.0 2020-03-15 23:04:26.711 info (18165) stateChange: fhem.0.info.Commands.sendFHEM | deleteattr fhem.0.alive event-on-change-reading > deleteattr fhem.0.alive event-on-change-reading
                      fhem.0 2020-03-15 23:04:26.707 info (18165) > processed 3 stateChange(s) of ioBroker saved during synchro
                      fhem.0 2020-03-15 23:04:26.707 info (18165) STEP 13 ==== processed saved stateChange(s) of ioBroker
                      fhem.0 2020-03-15 23:04:26.706 info (18165) > save FHEM: Wrote configuration to fhem.cfg
                      fhem.0 2020-03-15 23:04:26.705 info (18165) > activate fhem.0.alive room ioB_System every 5 minutes
                      fhem.0 2020-03-15 23:04:26.704 info (18165) STEP 12 ==== activate alive and save FHEM
                      fhem.0 2020-03-15 23:04:26.703 info (18165) > dummy fhem.0.alive - use to check alive FHEM Adapter in FHEM
                      fhem.0 2020-03-15 23:04:26.702 info (18165) > dummy fhem.0.send2ioB - use to set objects/states of ioBroker from FHEM
                      fhem.0 2020-03-15 23:04:26.702 info (18165) STEP 11 ==== check/create FHEM dummy Devices in room ioB_System
                      fhem.0 2020-03-15 23:04:26.699 info (18165) > delete unused objects () > delete 0 channel(s) and 0 state(s)
                      fhem.0 2020-03-15 23:04:26.616 info (18165) STEP 10 ===== check delete unused objects
                      fhem.0 2020-03-15 23:04:26.383 info (18165) > check update/create 121 state(s) / 121 state(s) to sync
                      fhem.0 2020-03-15 23:04:26.381 info (18165) > check update/create 0 function(s) - fhem.0.info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:04:26.375 info (18165) > check update/create 1 room(s) - fhem.0.info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:04:26.090 info (18165) > check update/create 130 object(s) / 9 channel(s) and 121 state(s)
                      fhem.0 2020-03-15 23:04:26.089 info (18165) STEP 09 ===== Synchro objects, rooms, functions, states
                      fhem.0 2020-03-15 23:04:26.089 info (18165) > check channel - 9 Device(s) of FHEM synchronized
                      fhem.0 2020-03-15 23:04:26.088 info (18165) > 0 objects to send FHEM detected (ioBout)
                      fhem.0 2020-03-15 23:04:25.989 info (18165) > no sync device(s) with Internals:NAME = info - fhem.0.info.Configurations.ignoreObjectsInternalsNAME (info)
                      fhem.0 2020-03-15 23:04:25.988 info (18165) > only sync device(s) from room(s) = ioBroker,ioB_OUT - fhem.0.info.Info.roomioBroker (true)
                      fhem.0 2020-03-15 23:04:25.988 info (18165) STEP 08 ===== parse Objects - check 321 Device(s) of FHEM detected
                      fhem.0 2020-03-15 23:04:25.974 info (18165) > get 321 Device(s) of FHEM
                      fhem.0 2020-03-15 23:04:25.832 info (18165) > result of jsonlist2 OK
                      fhem.0 2020-03-15 23:04:22.272 info (18165) > Connected FHEM telnet 127.0.0.1:7072 - send telnet "jsonlist2"
                      fhem.0 2020-03-15 23:04:22.271 info (18165) STEP 07 ===== connect FHEM telnet
                      fhem.0 2020-03-15 23:04:22.269 info (18165) > no sync - fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:04:22.267 info (18165) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:04:22.263 info (18165) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
                      fhem.0 2020-03-15 23:04:22.259 info (18165) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
                      fhem.0 2020-03-15 23:04:22.218 info (18165) > LOG "event FHEM(s) ....." events state from FHEM - info.Settings.logEventFHEMstate (true)
                      fhem.0 2020-03-15 23:04:22.217 info (18165) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
                      fhem.0 2020-03-15 23:04:22.215 info (18165) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
                      fhem.0 2020-03-15 23:04:22.155 info (18165) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
                      fhem.0 2020-03-15 23:04:22.152 info (18165) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                      fhem.0 2020-03-15 23:04:22.151 info (18165) > FUNCTION - auto create read,write,min,max,unit of object - info.Configurations.autoRest (true)
                      fhem.0 2020-03-15 23:04:22.150 info (18165) > FUNCTION - auto create states of object - info.Configurations.autoStates (true)
                      fhem.0 2020-03-15 23:04:22.147 info (18165) > FUNCTION - auto create type of object - info.Configurations.autoType (true)
                      fhem.0 2020-03-15 23:04:22.146 info (18165) > FUNCTION - auto create name of object - info.Configurations.autoName (true)
                      fhem.0 2020-03-15 23:04:22.145 info (18165) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
                      fhem.0 2020-03-15 23:04:22.143 info (18165) > FUNCTION - allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
                      fhem.0 2020-03-15 23:04:22.101 info (18165) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:04:22.099 info (18165) > FUNCTION - auto create function of object (use Adapter Material) - info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:04:22.097 info (18165) > FUNCTION - auto create role of object (use Adapter Material) - info.Configurations.autoRole (true)
                      fhem.0 2020-03-15 23:04:22.089 info (18165) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
                      fhem.0 2020-03-15 23:04:22.028 info (18165) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
                      fhem.0 2020-03-15 23:04:22.025 info (18165) > 56 objects fhem.0.info OK
                      fhem.0 2020-03-15 23:04:21.948 info (18165) > check old objects and delete
                      fhem.0 2020-03-15 23:04:21.727 info (18165) > check new/update objects
                      fhem.0 2020-03-15 23:04:21.721 info (18165) STEP 01 ===== buildDate 15.03.20 - check objects fhem.0.info
                      fhem.0 2020-03-15 23:04:21.574 info (18165) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.fhem, node: v10.19.0
                      host.JDD-HomePi 2020-03-15 23:04:19.210 info instance system.adapter.fhem.0 started with pid 18165
                      host.JDD-HomePi 2020-03-15 23:04:19.188 info "system.adapter.fhem.0" enabled
                      host.JDD-HomePi 2020-03-15 23:04:18.100 info instance system.adapter.fhem.0 terminated with code 156 (156)
                      fhem.0 2020-03-15 23:04:17.565 info (18144) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      fhem.0 2020-03-15 23:04:17.561 info (18144) terminating
                      fhem.0 2020-03-15 23:04:17.551 info (18144) Got terminate signal TERMINATE_YOURSELF
                      host.JDD-HomePi 2020-03-15 23:04:17.543 info stopInstance system.adapter.fhem.0 send kill signal
                      host.JDD-HomePi 2020-03-15 23:04:17.540 info stopInstance system.adapter.fhem.0 (force=false, process=true)
                      host.JDD-HomePi 2020-03-15 23:04:17.537 info "system.adapter.fhem.0" disabled
                      fhem.0 2020-03-15 23:02:57.977 info (18144) END ===== Synchronised FHEM in 7244 ms :-)
                      fhem.0 2020-03-15 23:02:57.977 warn (18144) > more info FHEM Adapter visit https://github.com/iobroker-community-adapters/ioBroker.fhem/blob/master/docs/de/README.md
                      fhem.0 2020-03-15 23:02:57.976 info (18144) > lastIOBout = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastIOBout
                      fhem.0 2020-03-15 23:02:57.975 info (18144) > lastSend2ioB = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastSend2ioB
                      fhem.0 2020-03-15 23:02:57.974 info (18144) > lastInfo = > check update/create 121 state(s) / 121 state(s) to sync - fhem.0.info.Info.lastInfo
                      fhem.0 2020-03-15 23:02:57.974 info (18144) > lastError = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastError
                      fhem.0 2020-03-15 23:02:57.973 info (18144) > lastWarn = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastWarn
                      fhem.0 2020-03-15 23:02:57.973 info (18144) > Number devices of FHEM (ignored) = 2 - fhem.0.info.Info.numberDevicesFHEMignored
                      fhem.0 2020-03-15 23:02:57.972 info (18144) > FHEM alive = false - fhem.0.info.Info.alive
                      fhem.0 2020-03-15 23:02:57.972 info (18144) > Number of objects IOB in = 130 - fhem.0.info.Info.numberObjectsIOBin
                      fhem.0 2020-03-15 23:02:57.971 info (18144) > Number of objects IOB out (possible) = 0 - fhem.0.info.Info.numberObjectsIOBoutSub
                      fhem.0 2020-03-15 23:02:57.971 info (18144) > Number of objects IOB out (detected) = 0 - fhem.0.info.Info.numberObjectsIOBout
                      fhem.0 2020-03-15 23:02:57.970 info (18144) > Number devices of FHEM (synchronized) = 9 - fhem.0.info.Info.numberDevicesFHEMsync
                      fhem.0 2020-03-15 23:02:57.969 info (18144) > Number devices of FHEM (jsonlist2) = 321 - fhem.0.info.Info.numberDevicesFHEM
                      fhem.0 2020-03-15 23:02:57.921 info (18144) > room of fhem.x.info.Configurations.onlySyncRoom exist = true - fhem.0.info.Info.roomioBroker
                      fhem.0 2020-03-15 23:02:57.919 info (18144) > Date of main.js = 15.03.20 - fhem.0.info.Info.buildDate
                      fhem.0 2020-03-15 23:02:57.893 info (18144) STEP 15 ==== info Synchro
                      fhem.0 2020-03-15 23:02:57.888 info (18144) event FHEM: ---- | dummy fhem.0.alive on | state > fhem.0.alive (getAlive)
                      fhem.0 2020-03-15 23:02:57.883 info (18144) > processed 1 event(s) of FHEM saved during synchro
                      fhem.0 2020-03-15 23:02:57.882 info (18144) STEP 14 ==== processed saved event(s) of FHEM
                      fhem.0 2020-03-15 23:02:57.696 info (18144) stateChange: fhem.0.info.Commands.sendFHEM | save > save
                      fhem.0 2020-03-15 23:02:57.678 info (18144) stateChange: fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      fhem.0 2020-03-15 23:02:57.653 info (18144) stateChange: fhem.0.info.Commands.sendFHEM | deleteattr fhem.0.alive event-on-change-reading > deleteattr fhem.0.alive event-on-change-reading
                      fhem.0 2020-03-15 23:02:57.649 info (18144) > processed 3 stateChange(s) of ioBroker saved during synchro
                      fhem.0 2020-03-15 23:02:57.648 info (18144) STEP 13 ==== processed saved stateChange(s) of ioBroker
                      fhem.0 2020-03-15 23:02:57.647 info (18144) > save FHEM: Wrote configuration to fhem.cfg
                      fhem.0 2020-03-15 23:02:57.646 info (18144) > activate fhem.0.alive room ioB_System every 5 minutes
                      fhem.0 2020-03-15 23:02:57.645 info (18144) STEP 12 ==== activate alive and save FHEM
                      fhem.0 2020-03-15 23:02:57.644 info (18144) > dummy fhem.0.alive - use to check alive FHEM Adapter in FHEM
                      fhem.0 2020-03-15 23:02:57.643 info (18144) > dummy fhem.0.send2ioB - use to set objects/states of ioBroker from FHEM
                      fhem.0 2020-03-15 23:02:57.643 info (18144) STEP 11 ==== check/create FHEM dummy Devices in room ioB_System
                      fhem.0 2020-03-15 23:02:57.640 info (18144) > delete unused objects (
                      fhem.0 2020-03-15 23:02:57.566 info (18144) STEP 10 ===== check delete unused objects
                      fhem.0 2020-03-15 23:02:57.185 info (18144) > check update/create 121 state(s) / 121 state(s) to sync
                      fhem.0 2020-03-15 23:02:57.183 info (18144) > check update/create 0 function(s) - fhem.0.info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:02:57.176 info (18144) > check update/create 1 room(s) - fhem.0.info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:02:56.845 info (18144) > check update/create 130 object(s) / 9 channel(s) and 121 state(s)
                      fhem.0 2020-03-15 23:02:56.845 info (18144) STEP 09 ===== Synchro objects, rooms, functions, states
                      fhem.0 2020-03-15 23:02:56.844 info (18144) > check channel - 9 Device(s) of FHEM synchronized
                      fhem.0 2020-03-15 23:02:56.843 info (18144) > 0 objects to send FHEM detected (ioBout)
                      fhem.0 2020-03-15 23:02:56.725 info (18144) > no sync device(s) with Internals:NAME = info - fhem.0.info.Configurations.ignoreObjectsInternalsNAME (info)
                      fhem.0 2020-03-15 23:02:56.725 info (18144) > only sync device(s) from room(s) = ioBroker,ioB_OUT - fhem.0.info.Info.roomioBroker (true)
                      fhem.0 2020-03-15 23:02:56.724 info (18144) STEP 08 ===== parse Objects - check 321 Device(s) of FHEM detected
                      fhem.0 2020-03-15 23:02:56.711 info (18144) > get 321 Device(s) of FHEM
                      fhem.0 2020-03-15 23:02:56.570 info (18144) > result of jsonlist2 OK
                      fhem.0 2020-03-15 23:02:53.003 info (18144) > Connected FHEM telnet 127.0.0.1:7072 - send telnet "jsonlist2"
                      fhem.0 2020-03-15 23:02:53.002 info (18144) STEP 07 ===== connect FHEM telnet
                      fhem.0 2020-03-15 23:02:53.000 info (18144) > no sync - fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:02:52.998 info (18144) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:02:52.991 info (18144) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
                      fhem.0 2020-03-15 23:02:52.988 info (18144) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
                      fhem.0 2020-03-15 23:02:52.984 info (18144) > LOG "event FHEM(s) ....." events state from FHEM - info.Settings.logEventFHEMstate (true)
                      fhem.0 2020-03-15 23:02:52.982 info (18144) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
                      fhem.0 2020-03-15 23:02:52.941 info (18144) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
                      fhem.0 2020-03-15 23:02:52.925 info (18144) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
                      fhem.0 2020-03-15 23:02:52.919 info (18144) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                      fhem.0 2020-03-15 23:02:52.918 info (18144) > FUNCTION - auto create read,write,min,max,unit of object - info.Configurations.autoRest (true)
                      fhem.0 2020-03-15 23:02:52.917 info (18144) > FUNCTION - auto create states of object - info.Configurations.autoStates (true)
                      fhem.0 2020-03-15 23:02:52.915 info (18144) > FUNCTION - auto create type of object - info.Configurations.autoType (true)
                      fhem.0 2020-03-15 23:02:52.914 info (18144) > FUNCTION - auto create name of object - info.Configurations.autoName (true)
                      fhem.0 2020-03-15 23:02:52.879 info (18144) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
                      fhem.0 2020-03-15 23:02:52.878 info (18144) > FUNCTION - allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
                      fhem.0 2020-03-15 23:02:52.876 info (18144) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:02:52.872 info (18144) > FUNCTION - auto create function of object (use Adapter Material) - info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:02:52.870 info (18144) > FUNCTION - auto create role of object (use Adapter Material) - info.Configurations.autoRole (true)
                      fhem.0 2020-03-15 23:02:52.860 info (18144) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
                      fhem.0 2020-03-15 23:02:52.769 info (18144) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
                      fhem.0 2020-03-15 23:02:52.767 info (18144) > 56 objects fhem.0.info OK
                      fhem.0 2020-03-15 23:02:52.692 info (18144) > check old objects and delete
                      fhem.0 2020-03-15 23:02:52.523 info (18144) > check new/update objects
                      fhem.0 2020-03-15 23:02:52.517 info (18144) STEP 01 ===== buildDate 15.03.20 - check objects fhem.0.info
                      fhem.0 2020-03-15 23:02:52.328 info (18144) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.fhem, node: v10.19.0
                      host.JDD-HomePi 2020-03-15 23:02:49.907 info instance system.adapter.fhem.0 started with pid 18144
                      host.JDD-HomePi 2020-03-15 23:02:19.883 info Restart adapter system.adapter.fhem.0 because enabled
                      host.JDD-HomePi 2020-03-15 23:02:19.882 info instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
                      host.JDD-HomePi 2020-03-15 23:02:19.882 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                      host.JDD-HomePi 2020-03-15 23:02:19.881 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      host.JDD-HomePi 2020-03-15 23:02:19.881 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      host.JDD-HomePi 2020-03-15 23:02:19.880 error Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
                      host.JDD-HomePi 2020-03-15 23:02:19.879 error Caught by controller[0]: at adapter.getObject (/opt/iobroker/node_modules/iobroker.fhem/main.js:2937:131)
                      host.JDD-HomePi 2020-03-15 23:02:19.878 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                      fhem.0 2020-03-15 23:02:19.334 info (18123) Terminated (NO_ERROR): Without reason
                      fhem.0 2020-03-15 23:02:19.332 info (18123) terminating
                      fhem.0 2020-03-15 23:02:19.306 error at process._tickCallback (internal/process/next_tick.js:68:7)
                      fhem.0 2020-03-15 23:02:19.306 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      fhem.0 2020-03-15 23:02:19.306 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      fhem.0 2020-03-15 23:02:19.306 error at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
                      fhem.0 2020-03-15 23:02:19.306 error at adapter.getObject (/opt/iobroker/node_modules/iobroker.fhem/main.js:2937:131)
                      fhem.0 2020-03-15 23:02:19.306 error (18123) TypeError: Cannot read property 'val' of null
                      fhem.0 2020-03-15 23:02:19.305 error (18123) uncaught exception: Cannot read property 'val' of null
                      fhem.0 2020-03-15 23:02:19.290 warn (18123) Exception: TypeError: Cannot read property 'val' of null
                      fhem.0 2020-03-15 23:02:19.285 info (18123) > lastIOBout = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastIOBout
                      fhem.0 2020-03-15 23:02:19.284 info (18123) > lastSend2ioB = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastSend2ioB
                      fhem.0 2020-03-15 23:02:19.284 info (18123) > lastInfo = > check update/create 121 state(s) / 121 state(s) to sync - fhem.0.info.Info.lastInfo
                      fhem.0 2020-03-15 23:02:19.283 info (18123) > lastError = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastError
                      fhem.0 2020-03-15 23:02:19.283 info (18123) > lastWarn = ----- start FHEM Adapter Instanz fhem.0 - fhem.0.info.Info.lastWarn
                      fhem.0 2020-03-15 23:02:19.282 info (18123) > Number devices of FHEM (ignored) = 2 - fhem.0.info.Info.numberDevicesFHEMignored
                      fhem.0 2020-03-15 23:02:19.281 info (18123) > Number of objects IOB in = 130 - fhem.0.info.Info.numberObjectsIOBin
                      fhem.0 2020-03-15 23:02:19.281 info (18123) > Number of objects IOB out (possible) = 0 - fhem.0.info.Info.numberObjectsIOBoutSub
                      fhem.0 2020-03-15 23:02:19.280 info (18123) > Number of objects IOB out (detected) = 0 - fhem.0.info.Info.numberObjectsIOBout
                      fhem.0 2020-03-15 23:02:19.279 info (18123) > Number devices of FHEM (synchronized) = 9 - fhem.0.info.Info.numberDevicesFHEMsync
                      fhem.0 2020-03-15 23:02:19.236 info (18123) > Number devices of FHEM (jsonlist2) = 321 - fhem.0.info.Info.numberDevicesFHEM
                      fhem.0 2020-03-15 23:02:19.234 info (18123) > room of fhem.x.info.Configurations.onlySyncRoom exist = true - fhem.0.info.Info.roomioBroker
                      fhem.0 2020-03-15 23:02:19.233 info (18123) > Date of main.js = 15.03.20 - fhem.0.info.Info.buildDate
                      fhem.0 2020-03-15 23:02:19.215 info (18123) STEP 15 ==== info Synchro
                      fhem.0 2020-03-15 23:02:19.211 info (18123) event FHEM: ---- | dummy fhem.0.alive on | state > fhem.0.alive (getAlive)
                      fhem.0 2020-03-15 23:02:19.201 info (18123) > processed 3 event(s) of FHEM saved during synchro
                      fhem.0 2020-03-15 23:02:19.200 info (18123) STEP 14 ==== processed saved event(s) of FHEM
                      fhem.0 2020-03-15 23:02:19.018 info (18123) stateChange: fhem.0.info.Commands.sendFHEM | save > save
                      fhem.0 2020-03-15 23:02:19.003 info (18123) stateChange: fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      fhem.0 2020-03-15 23:02:18.983 info (18123) stateChange: fhem.0.info.Commands.sendFHEM | deleteattr fhem.0.alive event-on-change-reading > deleteattr fhem.0.alive event-on-change-reading
                      fhem.0 2020-03-15 23:02:18.979 info (18123) > processed 3 stateChange(s) of ioBroker saved during synchro
                      fhem.0 2020-03-15 23:02:18.978 info (18123) STEP 13 ==== processed saved stateChange(s) of ioBroker
                      fhem.0 2020-03-15 23:02:18.978 info (18123) > save FHEM: Wrote configuration to fhem.cfg
                      fhem.0 2020-03-15 23:02:18.977 info (18123) > activate fhem.0.alive room ioB_System every 5 minutes
                      fhem.0 2020-03-15 23:02:18.976 info (18123) STEP 12 ==== activate alive and save FHEM
                      fhem.0 2020-03-15 23:02:18.975 info (18123) > dummy fhem.0.alive - use to check alive FHEM Adapter in FHEM
                      fhem.0 2020-03-15 23:02:18.974 info (18123) > dummy fhem.0.send2ioB - use to set objects/states of ioBroker from FHEM
                      fhem.0 2020-03-15 23:02:18.974 info (18123) STEP 11 ==== check/create FHEM dummy Devices in room ioB_System
                      fhem.0 2020-03-15 23:02:18.971 info (18123) > delete unused objects (*) > delete 0 channel(s) and 0 state(s)
                      fhem.0 2020-03-15 23:02:18.926 info (18123) STEP 10 ===== check delete unused objects
                      fhem.0 2020-03-15 23:02:18.091 info (18123) > check update/create 121 state(s) / 121 state(s) to sync
                      fhem.0 2020-03-15 23:02:18.088 info (18123) > check update/create 0 function(s) - fhem.0.info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:02:18.077 info (18123) > check update/create 1 room(s) - fhem.0.info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:02:13.777 info (18123) > check update/create 130 object(s) / 9 channel(s) and 121 state(s)
                      fhem.0 2020-03-15 23:02:13.777 info (18123) STEP 09 ===== Synchro objects, rooms, functions, states
                      fhem.0 2020-03-15 23:02:13.776 info (18123) > check channel - 9 Device(s) of FHEM synchronized
                      fhem.0 2020-03-15 23:02:13.776 info (18123) > 0 objects to send FHEM detected (ioBout)
                      fhem.0 2020-03-15 23:02:13.684 info (18123) > no sync device(s) with Internals:NAME = info - fhem.0.info.Configurations.ignoreObjectsInternalsNAME (info)
                      fhem.0 2020-03-15 23:02:13.683 info (18123) > only sync device(s) from room(s) = ioBroker,ioB_OUT - fhem.0.info.Info.roomioBroker (true)
                      fhem.0 2020-03-15 23:02:13.683 info (18123) STEP 08 ===== parse Objects - check 321 Device(s) of FHEM detected
                      fhem.0 2020-03-15 23:02:13.670 info (18123) > get 321 Device(s) of FHEM
                      fhem.0 2020-03-15 23:02:13.528 info (18123) > result of jsonlist2 OK
                      fhem.0 2020-03-15 23:02:09.940 info (18123) > Connected FHEM telnet 127.0.0.1:7072 - send telnet "jsonlist2"
                      fhem.0 2020-03-15 23:02:09.939 info (18123) STEP 07 ===== connect FHEM telnet
                      fhem.0 2020-03-15 23:02:09.937 info (18123) > no sync - fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:02:09.935 info (18123) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
                      fhem.0 2020-03-15 23:02:09.921 info (18123) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
                      fhem.0 2020-03-15 23:02:09.918 info (18123) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
                      fhem.0 2020-03-15 23:02:09.917 info (18123) > LOG "event FHEM(s) ....." events state from FHEM - info.Settings.logEventFHEMstate (true)
                      fhem.0 2020-03-15 23:02:09.913 info (18123) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
                      fhem.0 2020-03-15 23:02:09.908 info (18123) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
                      fhem.0 2020-03-15 23:02:09.835 info (18123) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
                      fhem.0 2020-03-15 23:02:09.833 info (18123) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                      fhem.0 2020-03-15 23:02:09.832 info (18123) > FUNCTION - auto create read,write,min,max,unit of object - info.Configurations.autoRest (true)
                      fhem.0 2020-03-15 23:02:09.831 info (18123) > FUNCTION - auto create states of object - info.Configurations.autoStates (true)
                      fhem.0 2020-03-15 23:02:09.830 info (18123) > FUNCTION - auto create type of object - info.Configurations.autoType (true)
                      fhem.0 2020-03-15 23:02:09.829 info (18123) > FUNCTION - auto create name of object - info.Configurations.autoName (true)
                      fhem.0 2020-03-15 23:02:09.818 info (18123) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
                      fhem.0 2020-03-15 23:02:09.817 info (18123) > FUNCTION - allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
                      fhem.0 2020-03-15 23:02:09.816 info (18123) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
                      fhem.0 2020-03-15 23:02:09.814 info (18123) > FUNCTION - auto create function of object (use Adapter Material) - info.Configurations.autoFunction (true)
                      fhem.0 2020-03-15 23:02:09.770 info (18123) > FUNCTION - auto create role of object (use Adapter Material) - info.Configurations.autoRole (true)
                      fhem.0 2020-03-15 23:02:09.747 info (18123) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
                      fhem.0 2020-03-15 23:02:09.636 info (18123) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
                      fhem.0 2020-03-15 23:02:09.633 info (18123) > 56 objects fhem.0.info OK
                      fhem.0 2020-03-15 23:02:09.577 info (18123) > check old objects and delete
                      fhem.0 2020-03-15 23:02:09.575 info (18123) > create fhem.0.info.Settings.logIgnoreConfigurations - LOG "ignore FHEM device ....." ignored Devices from FHEM (info.Configurations) (NEW)
                      fhem.0 2020-03-15 23:02:09.574 info (18123) > create fhem.0.info.Settings.logUpdateChannel - LOG "Update channel ....." (NEW)
                      fhem.0 2020-03-15 23:02:09.572 info (18123) > create fhem.0.info.Settings.logUnhandledEventFHEM - LOG "unhandled event FHEM ....." all events unhandled from FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.571 info (18123) > create fhem.0.info.Settings.logEventIOB - LOG "stateChange: ....." all events ioBroker to FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.569 info (18123) > create fhem.0.info.Settings.logEventFHEMstate - LOG "event FHEM(s) ....." events state from FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.568 info (18123) > create fhem.0.info.Settings.logEventFHEMreading - LOG "event FHEM(r) ....." events readings from FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.566 info (18123) > create fhem.0.info.Settings.logEventFHEMglobal - LOG "event FHEM(g) ....." events global from FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.565 info (18123) > create fhem.0.info.Settings.logEventFHEM - LOG "event FHEM ....." all events from FHEM over telnet) (NEW)
                      fhem.0 2020-03-15 23:02:09.563 info (18123) > create fhem.0.info.Settings.logDeleteChannel - LOG "Delete channel ....." (NEW)
                      fhem.0 2020-03-15 23:02:09.561 info (18123) > create fhem.0.info.Settings.logCreateChannel - LOG "Create channel ....." (NEW)
                      fhem.0 2020-03-15 23:02:09.551 info (18123) > create fhem.0.info.Settings.logCheckObject - LOG "check channel ....." (NEW)
                      fhem.0 2020-03-15 23:02:09.549 info (18123) > create fhem.0.info.Debug.logDevelop - More info debug" (NEW)
                      fhem.0 2020-03-15 23:02:09.548 info (18123) > create fhem.0.info.Configurations.logNoInfo - FUNCTION - no LOG info (NEW)
                      fhem.0 2020-03-15 23:02:09.547 info (18123) > create fhem.0.info.Configurations.oldState - FUNCTION - old version of state with true/false (NEW)
                      fhem.0 2020-03-15 23:02:09.546 info (18123) > create fhem.0.info.Configurations.deleteUnusedObjects - FUNCTION - delete unused objects automatically (NEW)
                      fhem.0 2020-03-15 23:02:09.543 info (18123) > create fhem.0.info.Configurations.autoRest - FUNCTION - auto create read,write,min,max,unit of object (NEW)
                      fhem.0 2020-03-15 23:02:09.542 info (18123) > create fhem.0.info.Configurations.autoStates - FUNCTION - auto create states of object (NEW)
                      fhem.0 2020-03-15 23:02:09.541 info (18123) > create fhem.0.info.Configurations.autoType - FUNCTION - auto create type of object (NEW)
                      fhem.0 2020-03-15 23:02:09.540 info (18123) > create fhem.0.info.Configurations.autoName - FUNCTION - auto create name of object (NEW)
                      fhem.0 2020-03-15 23:02:09.539 info (18123) > create fhem.0.info.Configurations.autoSmartName - FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) (NEW)
                      fhem.0 2020-03-15 23:02:09.537 info (18123) > create fhem.0.info.Configurations.autoRole - FUNCTION - auto create role of object (use Adapter Material) (NEW)
                      fhem.0 2020-03-15 23:02:09.536 info (18123) > create fhem.0.info.Configurations.autoRoom - FUNCTION - auto create room of channel (use Adapter Material) (NEW)
                      fhem.0 2020-03-15 23:02:09.535 info (18123) > create fhem.0.info.Configurations.autoFunction - FUNCTION - auto create function of object (use Adapter Material) (NEW)
                      fhem.0 2020-03-15 23:02:09.534 info (18123) > create fhem.0.info.Configurations.autoConfigFHEM - FUNCTION - allow special configurations FHEM (NEW)
                      fhem.0 2020-03-15 23:02:09.439 info (18123) > create fhem.0.info.Info.lastIOBout - lastIOBout (NEW)
                      fhem.0 2020-03-15 23:02:09.437 info (18123) > create fhem.0.info.Info.lastSend2ioB - lastSend2ioB (NEW)
                      fhem.0 2020-03-15 23:02:09.436 info (18123) > create fhem.0.info.Info.lastInfo - lastInfo (NEW)
                      fhem.0 2020-03-15 23:02:09.434 info (18123) > create fhem.0.info.Info.lastError - lastError (NEW)
                      fhem.0 2020-03-15 23:02:09.433 info (18123) > create fhem.0.info.Info.lastWarn - lastWarn (NEW)
                      fhem.0 2020-03-15 23:02:09.431 info (18123) > create fhem.0.info.Info.numberDevicesFHEMignored - Number devices of FHEM (ignored) (NEW)
                      fhem.0 2020-03-15 23:02:09.430 info (18123) > create fhem.0.info.Info.alive - FHEM alive (NEW)
                      fhem.0 2020-03-15 23:02:09.428 info (18123) > create fhem.0.info.Info.numberObjectsIOBin - Number of objects IOB in (NEW)
                      • LausiDL Offline
                        LausiDL Offline
                        LausiD
                        Danke für die Infos.
                        Gleiches Problem aber an anderer Stelle.
                        Schau ich mir die Tage nochmal in Ruhe an..
                        LausiD
                        Test FHEM Adapter
                        • LausiDL Offline
                          LausiDL Offline
                          LausiD
                          @LHBL2003
                          Update über github und neuer Versuch :-)
                          States ohne value werden jetzt ignoriert
                          Test FHEM Adapter
                          • L Offline
                            LHBL2003
                            @LausiD
                            Also der FHEM Adapter bleibt am laufen.
                            Allerdings werden die Propertys mit den NULLs nicht in FHEM als dummys angelegt.
                            Für ein Error ist es etwas hart. Ich würde es maximal als Warnung einstufen.
                            Denn es wird sicherlich immer mal Propertys geben die nicht initialisiert sind.
                            Schön wäre es wenn diese dann in FHEM einfach mit einem Empty angelegt werden.
                            Denn für den leihen sieht er ja im ioBroker auch nur ein leeren Wert fürs Property.
                            Oder wie siehts du das?
                            Gruß Denis
                            • LausiDL Offline
                              LausiDL Offline
                              LausiD
                              schrieb am zuletzt editiert von LausiD
                              @LHBL2003
                              Ok, gebe dir Recht......Warnung reicht vollkommen:-)
                              Ein Übertrag in FHEM macht für mich keinen Sinn. Sollte sich irgendwann an den States mal was ändern erfolgt ja ein Übertrag.
                              Ok so?
                              LausiD
                              Test FHEM Adapter
                              • L Offline
                                LHBL2003
                                @LausiD
                                Ich glaube das sollte ok sein (mit der Warnung ohne den leeren Import). Wenn da nichts drinn steht, dann werden die von der Heizung scheinbar nicht gemeldet und die Einstellbaren Parameter der Heizung sollten von Haus aus einen Wert besitzen.
                                So nun sollte sich bei mir noch der gedankliche keis schließen.
                                Gehen wir mal davon aus, dass einer dieser Propertys gelesen und geschrieben werden kann. Wie z.B. eine Sollwertkorrektur oder ein Betriebsmodus.
                                Dann kann ich mit den dummys die Werte ja nur lesen richtig?
                                Wie hast du dir das schreiben aus FHEM auf den selben Paramet gedacht.
                                Mir würde jetzt nur einfallen, dass ich in FHEM im Dummy oder co. ein UserReading erzeuge den ich dann im ioBroker auslese und mit node Red in die eigentliche Variable der Heizung bei Änderung umschifte.
                                Gruß Denis
                                • LausiDL Offline
                                  LausiDL Offline
                                  LausiD
                                  @LHBL2003
                                  Richtig, dummys im Raum ioB_IN sind nur lesbar.
                                  FHEM Raum ioB_System gibt es ein dummy fhem.0.send2ioB.
                                  Hier gibst du Objektname und den wert ein zB "wolf.0.bm.82 off"
                                  Test FHEM Adapter
                                  • L Offline
                                    LHBL2003
                                    @LausiD
                                    Also ich wollte gerade mal den rückkanal ausprobieren.
                                    Leider erhalte ich dieses Warnung:
                                    fhem.0 2020-03-17 18:50:06.107 warn (1307) unhandled event FHEM: ---- | dummy fhem.0.send2ioB wolf.0.bm1.65 1 > no sync - object "wolf.0.bm1.65" common.write not true
                                    "type": "state",
                                    "common": {
                                    "name": "Sollwertkorrektur",
                                    "role": "Tempd",
                                    "type": "state",
                                    "unit": "K",
                                    "enabled": false
                                    "native": {
                                    "rw": "rw"
                                    "_id": "wolf.0.bm1.65",
                                    "acl": {
                                    "object": 1638,
                                    "state": 1638
                                    Hast du eine Idee was ich falsch mache?
                                    Gruß Denis
                                    • LausiDL Offline
                                      LausiDL Offline
                                      LausiD
                                      @LHBL2003
                                      Sagt die Meldung schon aus:
                                      Dein verwendetes Objekt hat keine Berechtigung zum Schreiben.
                                      common.write = true wird überprüft.
                                      Bsp:
                                        "user": "system.user.admin",
                                        "ts": 1575997759830,
                                        "common": {
                                          "name": "test:test",
                                          "role": "",
                                          "type": "string",
                                          "desc": "Manuell erzeugt",
                                          "def": "",
                                          "read": true,
                                          "write": true
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636
                                        "_id": "0_userdata.0.test:test",
                                        "type": "state"
                                      LausiD
                                      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                                      Hier gehts zur Hilfe.
                                      Test FHEM Adapter
                                      • L Offline
                                        LHBL2003
                                        @LausiD
                                        Habe "write": true in der RAW Konfiguration für Common hinzugefügt, damit ich die beschreibbaren Variablen des ioBroker Wolf Adapters von FHEM aus beschreiben kann.
                                        Ich dachte immer das "rw": "rw" dies schon aussagt.
                                        Aber in diesen Fall sollte ich sicherlich mal den Entwikler @smiling_Jack vom ioBroker.Wolf Adapter darum bitten dies in die default Einstellungen zu übernehmen.
                                        Vielleicht liest er diesen Eintrag und die zwei Einträge zuvor ja ;)
                                        Gruß Denis
                                        LausiDL 1 Antwort Letzte Antwort
                                        • L LHBL2003
                                          @LausiD
                                          Gruß Denis
                                          LausiDL Offline
                                          LausiDL Offline
                                          LausiD
                                          @LHBL2003
                                          So geht es, oder?
                                          Einträge unter native haben meiner Meinung nach keine Funktion, sondern dienen nur zur Info.
                                          Du kannst die Objekte im admin auch nicht manuel ändern, oder?
                                          Test FHEM Adapter
