  4. Wasserzähler - Selfmade
    6.3k
wasser wasserzählerhow-to
1.1k Beiträge 48 Kommentatoren 492.6k Aufrufe 72 Beobachtet
  • AtifanA Offline
    AtifanA Offline
    Atifan
    #713
    @jomjol : Bei mir ist in der Config die ich durch dein Tool erstellt hab die 4. und 5. digital Ziffer vertauscht.
    Hab ich da irgnendwo nen Fehler gemacht?
    In der Config waren die Daten verdreht, also habe ich es geändert, aber die Anzeige ist immer noch verdreht Oo
    [Imagesource]
    timeoutloadimage = 30
    #ip durch die ip des esp32 ersetzen!
    urlimagesource = http://192.168.178.238/capture_with_flashlight
    #logimagelocation=logimagelocation
    #logonlyfalsepictures=false
    [ConsistencyCheck]
    enabled = True
    #stores the last value in a file for the case of a restart (e.g. docker container after update)
    readprevaluefromfileatstartup = True
    #maximum time spanning since last startup for use of prevalue from filestorage in minutes
    readprevaluefromfilemaxage = 30
    allownegativerates = False
    #maximum change of new to old value (+ or -)
    maxratevalue = 0.1
    #return in case of error: value = oldvalue or newvalue
    #                         errormessage = return text with problem (seperated by tabstopp) if nothing, then no error message
    #                         readout = real readout without corrections (newvalue)
    errorreturn = OldValue, ErrorMessage, Readout
    [AnalogReadOut]
    #if enabled analog counters will be read, if disabled only digital counters will be read.
    enabled = True
    [alignment]
    initial_rotation_angle = 0.0
    [alignment.ref0]
    image = ./config/ref0.jpg
    pos_x = 335
    pos_y = 260
    [alignment.ref1]
    image = ./config/ref1.jpg
    pos_x = 499
    pos_y = 186
    [alignment.ref2]
    image = ./config/ref2.jpg
    pos_x = 365
    pos_y = 445
    [Digital_Digit]
    names = ziffer1, ziffer2, ziffer3, ziffer5, ziffer4
    modelfile = ./config/neuralnets/Train_CNN_Digital-Readout_Version_5.0.0.h5
    #logimagelocation=
    #lognames=
    [Analog_Counter]
    names = zeiger1, zeiger2, zeiger3, zeiger4
    modelfile = ./config/neuralnets/CNN_Analog-Readout_Version-5.0.0.h5
    #logimagelocation=
    #lognames=
    [Analog_Counter.zeiger1]
    pos_x = 536
    pos_y = 286
    dx = 123
    dy = 123
    [Analog_Counter.zeiger2]
    pos_x = 481
    pos_y = 416
    dx = 122
    dy = 122
    [Analog_Counter.zeiger3]
    pos_x = 349
    pos_y = 468
    dx = 122
    dy = 122
    [Analog_Counter.zeiger4]
    pos_x = 208
    pos_y = 408
    dx = 123
    dy = 123
    [Digital_Digit.ziffer1]
    pos_x = 251
    pos_y = 197
    dx = 28
    dy = 50
    [Digital_Digit.ziffer2]
    pos_x = 298
    pos_y = 197
    dx = 28
    dy = 50
    [Digital_Digit.ziffer3]
    pos_x = 344
    pos_y = 197
    dx = 28
    dy = 50
    [Digital_Digit.ziffer5]
    pos_x = 438
    pos_y = 197
    dx = 28
    dy = 50
    [Digital_Digit.ziffer4]
    pos_x = 392
    pos_y = 197
    dx = 28
    dy = 50
    • AtifanA Offline
      AtifanA Offline
      Atifan
      #714
      Ah hat sich erledigt, habe den Fehler gefunden in der config.
      • AtifanA Atifan
        jomjol
        #715
        @Atifan Die Reihenfolge wird im Parameter :
        [Digital_Digit]
        festgelegt. Vielleicht hast du die Reihenfolge geändert, indem du aus Versehen auf "Move Next" / "Move Previous" geklickt hast.
        Sehe schon, ich muss in die Applikation noch einen "Life Test" mit einem Demobild einbauen.
        • AtifanA Offline
          AtifanA Offline
          Atifan
          #716
          Ja so wird es passiert sein.
          Ich habe jetzt die durch dein Tool neu erstellten Rererenzbilder + Konfigurationsdateien + den Ordner neuralnets mit Inhalt auf meinen Server kopieren und den Server neu gestartet, aber irgendwie funktioniert es dann nicht mehr.
          Muss ich da noch irgendwas beachten wenn ich die Konfigs austauschen möchte?
          • AtifanA Atifan
            jomjol
            #717
            @Atifan Eigentlich nicht. Bei mir hat es auch so funktioniert. Vergleich mal deine beiden Config.ini. Wenn z.B. die IP vom ESP32 nicht mehr stimmt, dann gibt es noch keine sinnvolle Fehlermeldung. Muss ich mal einbauen.
            • KnallochseK Offline
              KnallochseK Offline
              Knallochse
              #718
              Weil bei mir gerade wieder die m3 Zahl sich zwischen 2 Werten bewegt, habe ich nachgeschaut, was erkannt wird.
              192.168.178.86:1905/wasserzaehler.html?usePrevalue gibt aus
              Richtig wäre 315,9350
              Nur zur Info
              Auswertung unter Docker mit aktuellem rolling auf Synology.
              PS.: mit meiner Berechnung (Blockly hier im Thread) mit hochrechnen des m3 Wertes funktioniert das seit 2 Monaten ohne Fehler
              • AtifanA Offline
                AtifanA Offline
                Atifan
                #719
                Hi, wie meinst du denn mit hochrechnen des M3 Wertes?
                Wie rechnest du denn hoch?
                Man könnte natürlich entweder nur die digitalen Ziffern auswerten, dann fehlen einem aber genauere Zwischenwerte.
                Oder man zählt den den kleinsten analogen Zähler hoch, da müsste man dann aber sehr viele Bilder machen und sehr genau hochrechnen, bzw. braucht ein hohes Abtastintervall, damit das funktioniert.
                Wie hast du es denn gelöst?
                KnallochseK 1 Antwort Letzte Antwort
                • KnallochseK Knallochse
                  Nur zur Info
                  jomjol
                  #720
                  Hallo @Knallochse,
                  das Problem kenne ich und es liegt daran, dass bevor "NAN" kam, er die verschobene 5 als 9 erkannt hat und dann diesen Wert in "PreValue" gespeichert hat. Das tritt eigentlich nur beim Überang von 5 auf 6 auf und ich habe vor kurzem mein CNN nochmals besser trainiert. Aber es läuft noch nicht lange genug, um sicher zu sein, dass es hilft.
                  • AtifanA Atifan
                    KnallochseK Offline
                    KnallochseK Offline
                    Knallochse
                    #721
                    @Atifan Meine Lösung (Blockly) hatte ich hier beschrieben
                    https://forum.iobroker.net/post/340650
                    Und @sissiwup hatte hier
                    https://forum.iobroker.net/post/360651
                    auch ein JavaScript veröffentlicht .
                    Dieses Script hatte ich bisher nicht getestet.
                      jomjol
                      #722
                      @Knallochse sagte in Wasserzähler - Selfmade:
                      Wenn ich darüber nachdenke, dürfte das eigentlich nicht passieren, denn einen solchen Sprung sollte der Parameter MaxRateValue (typsicherweise 0.1) verhindern. Ich schaue bei Gelegenheit nochmal in den Quellcode.
                      • J jomjol
                        Hallo @Knallochse,
                        KnallochseK Offline
                        KnallochseK Offline
                        Knallochse
                        schrieb am zuletzt editiert von Knallochse
                        #723
                        @jomjol Guten Morgen.
                        Ich habe gerade nochmal in meine config.ini geschaut.
                        Ich hatte den ConsistencyCheck auf FALSE.
                        Ich hatte damals das Problem, dass (selbst bei nur Wasserzaehler.html / ohne ?usePrevalue) manchmal der alte Zählerwert bei der Ausgabe an erster Stelle stand. (also auch da - ohne "?usePrevalue" die Prüfung stattfand).
                        Mittlerweile ist aber mein Zählerstand auf 6 gewandert (wird auch als 6 erkannt), so dass ich leider gerade nicht prüfen kann, was mit ConsistencyCheck = TRUE erkannt wird.
                        Also muss der Fehler nicht in deinem Code liegen.
                        Meine Beobachtungen der Ausgabewerte hatte ergeben, dass ich mich nur auf die Erkennung der Analogzeiger verlassen kann. Deshalb mein Blockly, welches den String nach Digital (5 Stellen) und Analog (4 Stellen) zerlegt. Dann wird bei Aktualisierung des Zählerwertes (Parser - 5min) der neue Analogwert von vorhergehenden subtrahiert und wenn das Ergebnis größer 0,5 (500 Liter) ist, wird Digital/M³ um 1 erhöht.
                        @sissiwup hat ja was ähnliches in sein Javascript eingebaut. Könnte man sich ja auch genauer anschauen.
                        Wenn man die ausgegebenen Werte protokolliert und auswertet, muss man sich auf deren Richtigkeit verlassen können.
                        Schon ein falscher Wert (falsche m³ Zahl / 1000 Liter) verfälscht die Auswertung gewaltig.
                        Ich werde heute mal einen 2. Docker einrichten, damit ich die Daten vergleichen kann.
                        Ich bin nach wie vor von deinem Projekt begeistert, und danke Dir vielmals, dass du es mit uns teilst. 👍
                          jomjol
                          #724
                          @Knallochse Guten Morgen,
                          danke für den Input - Code ist okay, aber ich hatte folgendes Phänomen: falsche erkannte letzte Ziffer (3 --> 9), das wurde mit RateTooHigh auch korrekt gemeldet. Die richtige Ziffer kam erst 150 Liter weiter (wieder zurück zur 3). Aber dann wurde sie auch nicht mehr gemeldet, da jetzt wieder RateTooHigh aufgrund der 150 Liter! Offensichtlich dauert es bei meiner Wasseruhr ca. 150 Liter bis die letzte Ziffer wieder korrekt im Bild ist.
                          Ich habe jetzt erstmal den MaxRateValue auf 0.2 gesetzt (auch in den Default Settings - v5.5.2)
                          Habe auch schonmal überlegt, ob ich deinen Algo zur Berechnung der Ziffern implementieren soll. Dann wird es halt für Aussenstehende echt schwierig, das zu verstehen und einzustellen. Andererseits wenn nur richtige Werte komme ist es auch egal, was im Inneren läuft.
                          @all: Was ist eure Meinung?
                          P.S.: versuche gerade Tensorflow 2.1 für die Synology zu kompilieren. Hatte auch schon geklappt aber nur mit Python 3.6, brauche aber Python 3.7. Mal sehen, vielleicht klappt es ja irgendwann demnächst (Run dauert immer etwas, da 10h+ kompiliert wird - gutes Argument für einen neuen Rechner - versuche es gerade meiner Frau schmackhaft zu machen 😊)
                          Gruß,
                          jomjol
                          KnallochseK sissiwupS 2 Antworten Letzte Antwort
                          • J jomjol
                            Gruß,
                            jomjol
                            KnallochseK Offline
                            KnallochseK Offline
                            Knallochse
                            #725
                            @jomjol Ich habe auch nochmal intensiv überlegt.
                            Sollte bei meiner Methode die ESP-Cam mal über einen längeren Zeitraum nicht erreichbar sein (ist noch nicht vorgekommen) , dann würde aber meine Auswertung auch durcheinander kommen, da die Erkennung Digitalzahlen nicht mehr berücksichtigt werden.
                            Ich habe auch schon einen 2. Docker am laufen, mit dem ConsistencyCheck und MaxRateValue auf 0.2. Ich zeichne die Daten der zwei Container mit dem SQL-Adapter auf und werde vergleichen.
                            Vielleicht schaust du dir auch nochmal das Script von @sissiwup an, was der mit den Daten anstellt. (Ich versteh den Javascript-Code leider nicht - habe keine Programmierkenntnisse)
                            Vielleicht meldet sich @sissiwup selbst nochmal zu dem Thema.
                              jomjol
                              #726
                              @Knallochse er macht es ähnlich. Wenn die letzte Ziffer nicht stimmt, wird sie errechnet.
                              Ist ein Grundsatzproblem: du kannst die Ziffern errechnen, dann bist du unabhängig von Erkennungsfehlern ABER: wenn du dich verzählst/verrechnest, steht dein Wert total im Wald und du merkst es nicht.
                              Das läßt sich nie ganz lösen. Es kann nur durch eine zweite Logik-Ebene verbessert werden. Erstmal umwandeln und auf Konsistentz prüfen. Ist dort ein Problem, den Wert errechnen (gibt es mehrer Optionen).
                              Und in einer zweiten Ebene mitnotieren, dass es jetzt gerade errechnet wurde und wenn das zu oft / zu lange der Fall ist, dann Meldung an den Nutzer.
                              • J jomjol
                                KnallochseK Offline
                                KnallochseK Offline
                                Knallochse
                                #727
                                @jomjol stimme dir in jedem Punkt zu. Vielleicht kannst du ja einen Adapter Programmierer dazu bewegen, einen IoBroker Adapter zu erstellen. (dann würde auch der Weg über Parser entfallen) .
                                Wenn der Adapter einen Datenpunkt "Fehler" mit True/False steuert, dann könnte man darauf reagieren mit z.Bsp. Message per Telegramm; VIS Ausgabe etc.
                                Mit der Meldung müsste man dann wieder manuell (SetpreValue) nachjustieren.
                                • AtifanA Offline
                                  AtifanA Offline
                                  Atifan
                                  schrieb am zuletzt editiert von Atifan
                                  #728
                                  Ich habe um die Fehlerquote zu verringern und genauere Werte zu erhalten die config angepasst.
                                  alt -> MaxRateValue=0.1
                                  neu-> MaxRateValue=0.01
                                  1m³=1000L
                                  0,1m³=100L
                                  0,01m³=10L
                                  0,001m³=1L
                                  0,0001m³=100mL
                                  Das ganze muss natürlich auch auf die Abtastrate passen.
                                  Bei mir ist diese 60 Sekunden.
                                  Werde testen ob es ausreicht.
                                  Man könnte die MaxRateValue natürlich auch noch erhöhen auf z.B. 0.02 was dann 20L/min entsprechen.
                                  PS: Es gibt aber ein Problem, dass mir gerade eingefallen ist. Wenn der Wasserzähler Server mal offline ist und in dieser Zeit mehr als 10-20L Wasser verbraucht werden, geht der Zähler der Uhr ja höher und der Bildvergleichsserver spuckt dann zukünftig nur noch Fehler raus, weil der Abstand zu groß ist. Dann müsste man den Docker Container manuell stoppen den aktuellen Wert in die prevalue.ini schreiben und dann den Container wieder starten.
                                  KnallochseK pfriedP 2 Antworten Letzte Antwort
                                  • AtifanA Atifan
                                    1m³=1000L
                                    0,1m³=100L
                                    0,01m³=10L
                                    0,001m³=1L
                                    0,0001m³=100mL
                                    KnallochseK Offline
                                    KnallochseK Offline
                                    Knallochse
                                    #729
                                    @Atifan den Wert kannst du mit
                                    IPServer:Port/setPreValue.html?value=
                                    mitgeben. Ohne stoppen oder Starten des Servers
                                    • AtifanA Offline
                                      AtifanA Offline
                                      Atifan
                                      #730
                                      Ah super, Danke für die Info!
                                      Dann kann man im Notfall ja schnell korrigieren.
                                      • AtifanA Atifan
                                        1m³=1000L
                                        0,1m³=100L
                                        0,01m³=10L
                                        0,001m³=1L
                                        0,0001m³=100mL
                                        pfriedP Offline
                                        pfriedP Offline
                                        pfried
                                        #731
                                        @Atifan Hi Atfian, Dein MaxRateValue=0.01 wird nicht funktionieren, da bei einem Wechsel von einer zur anderen Ziffer bei mir circa 130 Liter "vergehen". Ich habe mit MaxRateValue=0.15 gute Erfahrungen gemacht. Weiter oben im Thread gibt es von mir auch eine Berechnung wieviel Liter maximal pro Sekunde über eine Wasseruhr laufen können. Die multiplizierst Du dann mit Deiner Abtastrate, aber wie schon von @jomjol und @Knallochse geschrieben, wäre eine zweite Auswertelogikschicht sicher das optimale Auswerteverfahren.
                                        @jomjol Auf Deine Frage weiter oben, es sollte niemanden stören wie der Wert zustande kommt, da die gesamte SW eh in einem Docker läuft und damit eh nicht mehr editierbar / lesbar ist.
                                        • AtifanA Offline
                                          AtifanA Offline
                                          Atifan
                                          #732
                                          Hi, ja habe es schon gemerkt. Beim Duschen wurde ca. 0.3 pro Minute geändert. Wenn dann noch jemand nebenbei Wasser zapft hat man noch höheren Verbrauch. Habe es bei mir jetzt auf 0.5 angepasst.
