Драйвер ioBroker MySensors
npm install https://github.com/DJONvl/iobroker.myse … all/master так должно поставить
в ридми на гите можно не читать, там осталось от шаблона описание...
надо будет убрать...
НА RASPI
задал:
npm install https://github.com/DJONvl/iobroker.myse ... all/masterrebootтеперь вижу:
933_2016-02-19_13_32_17-iobroker.admin.jpg -
только после сохранения configuration в mysensor и ребута он стал показывать СОМ порты
но потом в ЛОГЕ стоит это и COM USB port в setting пропадает:
host-raspberrypi 2016-02-19 13:44:19 warn instance system.adapter.mysensors.0 already running with pid 2567 host-raspberrypi 2016-02-19 13:44:17 info instance system.adapter.mysensors.0 started with pid 2567 host-raspberrypi 2016-02-19 13:44:17 info object change system.adapter.mysensors.0 host-raspberrypi 2016-02-19 13:43:49 info Restart adapter system.adapter.mysensors.0 because enabled host-raspberrypi 2016-02-19 13:43:49 error instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception) mysensors-0 2016-02-19 13:43:49 info cleaned everything up... TypeError: 2016-02-19 13:43:48 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9 TypeError: 2016-02-19 13:43:48 error at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20) TypeError: 2016-02-19 13:43:48 error at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20) TypeError: 2016-02-19 13:43:48 error at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12) TypeError: 2016-02-19 13:43:48 error at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13) TypeError: 2016-02-19 13:43:48 error at Array.forEach (native) TypeError: 2016-02-19 13:43:48 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17 TypeError: 2016-02-19 13:43:48 error at SerialPort.EventEmitter.emit (events.js:95:17) TypeError: 2016-02-19 13:43:48 error at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:291:24) TypeError: 2016-02-19 13:43:48 error at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23) TypeError: 2016-02-19 13:43:48 error Cannot read property 'id' of undefined uncaught 2016-02-19 13:43:48 error exception: Cannot read property 'id' of undefined mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0 mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete. mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta) mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:47 debug Communication port:/dev/ttyUSB0 mysensors-0 2016-02-19 13:43:47 debug statesDB connected mysensors-0 2016-02-19 13:43:47 debug objectDB connected -
mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0 mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete. mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta) mysensors-0 2016-02-19 13:43:48 debug количество сообщений 0 mysensors-0 2016-02-19 13:43:47 debug Communication port:/dev/ttyUSB0все отлично порт видит шлюз тоже, теперь необходимо включить любую Ноду чтобы она выдала презентацию
упс пардон ошибку не увидел…
mysensors-0 2016-02-19 13:43:48 debug __0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta)2.0.0-beta это библиотека?
презентация идёт!!!
см:
0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta) 0;255;3;0;14;Gateway startup complete. 0;255;3;0;11;ETHduino by JR 0;255;3;0;12;1.0 255 0 0;0;0;0;255;RX 0;0;1;0;77;for Warnings 255 1 0;1;0;0;255;TX 0;1;1;0;77;for Warnings ...a LOG= empty!
host-raspberrypi 2016-02-19 14:19:30 info instance system.adapter.mysensors.0 started with pid 4281 host-raspberrypi 2016-02-19 14:19:28 info instance system.adapter.mysensors.0 terminated with code 0 (OK) mysensors-0 2016-02-19 14:19:28 info terminating mysensors-0 2016-02-19 14:19:28 info cleaned everything up... host-raspberrypi 2016-02-19 14:19:28 info stopInstance system.adapter.mysensors.0 killing pid 4265 host-raspberrypi 2016-02-19 14:19:28 info stopInstance system.adapter.mysensors.0 host-raspberrypi 2016-02-19 14:19:28 info object change system.adapter.mysensors.0 mysors-0 2016-02-19 14:19:07 info obj.callback...ToDo выслать список СОМ портов admin-0 2016-02-19 14:19:06 info sendTo "list_uart" to system.adapter.mysensors.0 from system.adapter.admin.0: null mysensors-0 2016-02-19 14:18:57 error setObject id missing!! mysensors-0 2016-02-19 14:18:57 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors host-raspberrypi 2016-02-19 14:18:53 info instance system.adapter.mysensors.0 started with pid 4234 host-raspberrypi 2016-02-19 14:18:51 info instance system.adapter.mysensors.0 terminated with code 0 (OK) mysensors-0 2016-02-19 14:18:51 info terminatingensors-0 2016-02-19 14:19:20 error setObject id missing!! mysensors-0 2016-02-19 14:19:20 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors host-raspberrypi 2016-02-19 14:19:16 info instance system.adapter.mysensors.0 started with pid 4265 host-raspberrypi 2016-02-19 14:19:14 info instance system.adapter.mysensors.0 terminated with code 0 (OK) mysensors-0 2016-02-19 14:19:14 info terminating host-raspberrypi 2016-02-19 14:19:14 info stopInstance system.adapter.mysensors.0 killing pid 4234 host-raspberrypi 2016-02-19 14:19:14 info stopInstance system.adapter.mysensors.0 host-raspberrypi 2016-02-19 14:19:14 info object change system.adapter.mysensors.0 mysensors-0 2016-02-19 14:19:14 info cleaned everything up... mysensors-0 2016-02-19 14:19:07 info sendTo "list_uart" to system.adapter.admin.0 from system.adapter.mysensors.0: [{"comName":"ttyAMA0","vendorId":"0xundefined","productId":"0xundefined"},{"comName":"/dev/ttyUSB0","manufacturer":"1a86" mysensТы на 1.6 или 1.5 от Mysesnors?
cm my .ino
933_mysensors_serial_work_v1.rar -
0;255;3;0;12;1.0 255 -? 0 -? 0;0;0;0;255;RX 0;0;1;0;77;for Warnings 255 -? 1 -? 0;1;0;0;255;TX 0;1;1;0;77;for Warningsна них парсер отваливается это не стандартная посылка mysensors, у меня 1.5.1 и 1.5.4 библиотеки
1.5.4 сегодня скачал ,порадовала , теперь платы на китайском клоне Si24R1 опять видятся в сети с nRF24
cm my .ino `
MYSENSORS_SERIAL_WORK_V1.ino:131:22: fatal error: Ethernet.h: No such file or directoryне компилируется…
все разобрался с твоими сообщениями, нода шлюза не прописывается в таблицу и поэтому не отображается, загрузи стандартный скетч шлюза из примеров библиотеки...
Да… Я на 1.6 от mysensor, так как только там работает MQTT, signing и многое другое...
Можешь пожалуйста и для 1.6 доработать? Тогда легче будет для MQTT и для шифрования трафика.
Могу помочь тестировать!
К стати, на счёт шлюза не понимаю... В логе же стоит что он начало всё читает. Я даже одну строчку с считаной температурой в логе видел...
Можешь у себя залить и уувидишь что serial всё посылает...
Log:
0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta) 0;255;3;0;14;Gateway startup complete. 0;255;3;0;11;ETHduino by JR 0;255;3;0;12;1.0 0;0;0;0;255;RX 0;0;1;0;77;for Warnings 0;1;0;0;255;TX 0;1;1;0;77;for Warnings 0;7;0;0;4;Test PWM 0;7;1;0;77;for Warnings 0;8;0;0;3;RELAY D8 0;8;1;0;77;for Warnings 0;10;0;0;255;W5100 0;10;1;0;77;for Warnings 0;11;0;0;0;Digital Ein 0;11;1;0;77;for Warnings 0;13;0;0;4;Test PWM 0;13;1;0;77;for Warnings 0;16;0;0;255;LEDS_BLINKING_FEATURE 0;16;1;0;77;for Warnings 0;18;0;0;4;Pumpe1_T5 0;18;1;0;77;for Warnings 0;20;0;0;4;Pumpe2_T3 0;20;1;0;77;for Warnings 0;22;0;0;3;RELAY D8 0;22;1;0;77;for Warnings 0;23;0;0;3;RELAY D8 0;23;1;0;77;for Warnings 0;24;0;0;3;RELAY D8 0;24;1;0;77;for Warnings 0;25;0;0;3;RELAY D8 0;25;1;0;77;for Warnings 0;26;0;0;3;RELAY D8 0;26;1;0;77;for Warnings 0;27;0;0;3;RELAY D8 0;27;1;0;77;for Warnings 0;28;0;0;3;RELAY D8 0;28;1;0;77;for Warnings 0;29;0;0;3;RELAY D8 0;29;1;0;77;for Warnings 0;30;0;0;3;RELAY D8 0;30;1;0;77;for Warnings 0;31;0;0;3;RELAY D8 0;31;1;0;77;for Warnings 0;32;0;0;3;RELAY D8 0;32;1;0;77;for Warnings 0;33;0;0;3;RELAY D8 0;33;1;0;77;for Warnings 0;34;0;0;3;RELAY D8 0;34;1;0;77;for Warnings 0;35;0;0;3;RELAY D8 0;35;1;0;77;for Warnings 0;36;0;0;3;RELAY D8 0;36;1;0;77;for Warnings 0;37;0;0;3;RELAY D8 0;37;1;0;77;for Warnings 0;38;0;0;255;MAX31855 0;38;1;0;77;for Warnings 0;39;0;0;255;MAX31855 0;39;1;0;77;for Warnings 0;42;0;0;6;dallas 0;42;1;0;77;for Warnings 0;50;0;0;255;W5100 0;50;1;0;77;for Warnings 0;51;0;0;255;W5100 0;51;1;0;77;for Warnings 0;52;0;0;255;W5100 0;52;1;0;77;for Warnings ... 0;255;3;0;9;Init complete, id=0, parent=0, distance=0 Current State of PIN: 11 changes to: 1 0;11;1;1;15;1 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 27.48 0;58;1;1;0;27.48 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 35.45 0;58;1;1;0;35.450;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 37.26 0;58;1;1;0;37.26 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 38.81 0;58;1;1;0;38.81 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 37.57 0;58;1;1;0;37.57 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 38.08 0;58;1;1;0;38.08 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 39.02 0;58;1;1;0;39.02 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 37.67 0;58;1;1;0;37.67 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 38.50 0;58;1;1;0;38.50 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 39.34 0;58;1;1;0;39.34 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 -
у тебя как я понял, шлюз и нода с сенсорами все в одном? а к сети через ESP цепляешь?
скинь мне лог из терминала общения твоего шлюза с другими нодами, и минут через 5(счас залью) переустанови драйвер, чуть поправил чтоб шлюз в таблицу заносился. `
да…всё в одном
а остальное через NRF24L01
но пока не юзаю, т.к. ВСЁ В ОДНОМ :-)
0;255;3;0;9;Init complete, id=0, parent=0, distance=0 Current State of PIN: 11 changes to: 1 0;11;1;1;15;1 Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 27.48 0;58;1;1;0;27.48 0;42;1;1;0;-127.00 tempNTC of Pin 58 is 35.45 0;58;1;1;0;35.45вот это все прям в ком порт шлюз шлет (Temperature for the sensor 42 is -127.00),
скинь ссылку на 1.6 библиотеку
смотри
а потом всё пропадает!!!!
host-raspberrypi 2016-02-19 19:50:09 info instance system.adapter.mysensors.0 started with pid 3189
host-raspberrypi 2016-02-19 19:49:46 info Restart adapter system.adapter.mysensors.0 because enabled
host-raspberrypi 2016-02-19 19:49:46 error instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
mysensors-0 2016-02-19 19:49:46 info cleaned everything up…
TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
TypeError: 2016-02-19 19:49:46 error at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
TypeError: 2016-02-19 19:49:46 error at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
TypeError: 2016-02-19 19:49:46 error at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
TypeError: 2016-02-19 19:49:46 error at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
TypeError: 2016-02-19 19:49:46 error at Array.forEach (native)
TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
TypeError: 2016-02-19 19:49:46 error at SerialPort.EventEmitter.emit (events.js:95:17)
TypeError: 2016-02-19 19:49:46 error at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
TypeError: 2016-02-19 19:49:46 error at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
TypeError: 2016-02-19 19:49:46 error Cannot read property 'id' of undefined
uncaught 2016-02-19 19:49:46 error exception: Cannot read property 'id' of undefined
mysensors-0 2016-02-19 19:49:46 info Rx-Raw 255
mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_VERSION|_1.0
mysensors-0 2016-02-19 19:49:46 debug количество сообщений 3
mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;12;1.0
mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_NAME|_ETHduino by JR
mysensors-0 2016-02-19 19:49:46 debug количество сообщений 2
mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;11;ETHduino by JR
mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_GATEWAY_READY|_Gateway startup complete.
mysensors-0 2016-02-19 19:49:46 debug количество сообщений 1
mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;14;Gateway startup complete.
mysensors-0 2016-02-19 19:49:46 info _Temperature for the sensor 42 is0|255|internal|false|I_LOG_MESSAGE|_Starting gateway (R-NGA-, 2.0.0-beta)
mysensors-0 2016-02-19 19:49:46 debug количество сообщений 0
mysensors-0 2016-02-19 19:49:46 info Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
log from Arduino:
Temperature for the sensor 42 is -127.00 0;42;1;1;0;-127.00mysensors-0 2016-02-19 19:49:45 debug Communication port:/dev/ttyUSB0
mysensors-0 2016-02-19 19:49:45 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
mysensors-0 2016-02-19 19:49:45 debug statesDB connected
mysensors-0 2016-02-19 19:49:45 debug objectDB connected
host-raspberrypi 2016-02-19 19:49:41 info instance system.adapter.mysensors.0 started with pid 3156
host-raspberrypi 2016-02-19 19:49:39 info Restart adapter system.adapter.mysensors.0 because enabled
after a new reset ардуины:
the LOG:
[color]host-raspberrypi 2016-02-19 19:53:16 info Restart adapter system.adapter.mysensors.0 because enabled host-raspberrypi 2016-02-19 19:53:16 error instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception) mysensors-0 2016-02-19 19:53:16 info cleaned everything up... TypeError: 2016-02-19 19:53:16 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9 TypeError: 2016-02-19 19:53:16 error at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20) TypeError: 2016-02-19 19:53:16 error at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20) TypeError: 2016-02-19 19:53:16 error at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12) TypeError: 2016-02-19 19:53:16 error at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13) TypeError: 2016-02-19 19:53:16 error at Array.forEach (native) TypeError: 2016-02-19 19:53:16 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17 TypeError: 2016-02-19 19:53:16 error at SerialPort.EventEmitter.emit (events.js:95:17) TypeError: 2016-02-19 19:53:16 error at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8) TypeError: 2016-02-19 19:53:16 error at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23) TypeError: 2016-02-19 19:53:16 error Cannot read property 'id' of undefined uncaught 2016-02-19 19:53:16 error exception: Cannot read property 'id' of undefined mysensors-0 2016-02-19 19:53:16 info Rx-Raw 255 mysensors-0 2016-02-19 19:53:16 info __0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0 mysensors-0 2016-02-19 19:53:16 debug количество сообщений 3 mysensors-0 2016-02-19 19:53:16 info Rx-Raw 0;255;3;0;12;1.0 mysensors-0 2016-02-19 19:53:16 info __0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR mysensors-0 2016-02-19 19:53:16 debug количество сообщений 2 mysensors-0 2016-02-19 19:53:16 info Rx-Raw 0;255;3;0;11;ETHduino by JR mysensors-0 2016-02-19 19:53:16 info __0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete. mysensors-0 2016-02-19 19:53:16 debug количество сообщений 1 mysensors-0 2016-02-19 19:53:16 info Rx-Raw 0;255;3;0;14;Gateway startup complete. mysensors-0 2016-02-19 19:53:16 info __Temperature for the sensor 42 is0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta) mysensors-0 2016-02-19 19:53:16 debug количество сообщений 0 mysensors-0 2016-02-19 19:53:16 info Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta) mysensors-0 2016-02-19 19:53:15 debug Communication port:/dev/ttyUSB0 mysensors-0 2016-02-19 19:53:15 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors mysensors-0 2016-02-19 19:53:14 debug statesDB connected mysensors-0 2016-02-19 19:53:14 debug objectDB connected[/color]3822_bildschirmfoto_2019-01-28_um_17.43.58.png
3822_bildschirmfoto_2019-01-28_um_18.06.00.png -
Console LOG:
root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
npm http GET https://registry.npmjs.org/sensors
npm http GET https://registry.npmjs.org/serialport
npm http 304 https://registry.npmjs.org/sensors
npm http 304 https://registry.npmjs.org/serialport
npm http GET https://registry.npmjs.org/optimist
npm http GET https://registry.npmjs.org/nan
npm http GET https://registry.npmjs.org/bindings/1.2.1
npm http GET https://registry.npmjs.org/sf/0.1.7
npm http GET https://registry.npmjs.org/async/0.9.0
npm http GET https://registry.npmjs.org/debug
npm http 304 https://registry.npmjs.org/nan
npm http 304 https://registry.npmjs.org/debug
npm http 304 https://registry.npmjs.org/sf/0.1.7
npm http 200 https://registry.npmjs.org/optimist
npm http 304 https://registry.npmjs.org/bindings/1.2.1
npm http 304 https://registry.npmjs.org/async/0.9.0
npm http GET https://registry.npmjs.org/ms/0.7.1
npm http 304 https://registry.npmjs.org/ms/0.7.1
npm http GET https://registry.npmjs.org/wordwrap
npm http GET https://registry.npmjs.org/minimist
npm http 304 https://registry.npmjs.org/wordwrap
npm http 304 https://registry.npmjs.org/minimist
serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
node-pre-gyp install --fallback-to-build
node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
COPY Release/serialport.node
COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
├── sensors@0.1.0
└── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
