  4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    6.8k
248 Beiträge 26 Kommentatoren 72.0k Aufrufe 10 Beobachtet
    m76
    #82
    habe versucht meine iobroker Instanz umzuziehen auf den neuen raspberry pi4, der Adapter scheint aber Probleme zu haben:
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:190:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.57-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-arm"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
    gyp ERR! node -v v10.15.2
    gyp ERR! node-gyp -v v5.0.2
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-arm' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:970:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.57-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
    node-pre-gyp ERR! node -v v10.15.2
    node-pre-gyp ERR! node-pre-gyp -v v0.6.38
    node-pre-gyp ERR! not ok
    # Release/obj/gen/sqlite-autoconf-3150000/sqlite3.c: At top level:
    Release/obj/gen/sqlite-autoconf-3150000/sqlite3.c:199451:1: fatal error: opening dependency file ./Release/.deps/Release/obj.target/sqlite3/gen/sqlite-autoconf-3150000/sqlite3.o.d.raw: No such file or directory
    Liegt es an den installierten Versionen?:
    Node.js: v10.15.2
    NPM: 6.10.1
    • Rene_HMR Rene_HM
      @burningV@web.de:
      ich würde mich hier auch mal einklinken.
      Habe ein ioBroker Multihost System. Bei den Wechselrichtern ist ein Raspberry als ioBroker Slave der die Daten entgegen nimmt und die Datenbank befüllt. Das kann ich mir auf der Kommandozeile entsprechend ansehen.
      Der ioBroker Adapter (auf dem Raspberry Host installiert) verabschiedet sich mit der Fehlermeldung, das der das sqlite3 Modul nicht finden kann.
      Hat jemand eine Ahnung an was das liegt.
      Auf der Kommandozeile greife ich ja via sqlite3 auf die Datenbank zu… !?!
      So sehen die Log-Einträge aus:
      Bildschirmfoto 2019-01-17 um 17.57.33.png `
      Wie installierst du den Adapter? Die Fehlermeldung besagt, dass das npm-Modul sqlite3 fehlt. Normalerweise wird das bei der Installation des Adapters mit installiert. Es kann aber sein, dass sqlite3 gebaut werden muss, weil die binaries für dein System nicht geladen werden können (das passiert auf meine A10 bzw. A20-Systemen mit armbian genau so). Wenn nun das Bauen schief geht, bekommst du genau diese Meldung.
      Probier mal folgendes
      cd /opt/iobroker/node_modules/iobroker.sbfspot
      sudo npm install
      Wenn hier beim sqlite3-Bauen etwas schief geht, solltest du das geloggt bekommen…
      Außerdem solltest du den Adapter auf dem gleichen System installieren, auf dem auch sbfspot inkl. der Datenbank installiert ist. Wenn du eh schon ein Multihost-System hast, sollte das ja kein Problem sein.
      martinschm
      schrieb am zuletzt editiert von martinschm
      #83
      @Rene_HM said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
      Hi, habe bei meiner Neuinstallation (Debian unter Proxmox) auch das Problem, das sqllite nicht gefunden wird
      sbfspot.0	2019-10-13 06:30:00.582	error	exception catch after ready [Error: Cannot find module 'sqlite3']
      sbfspot.0	2019-10-13 06:30:00.562	info	starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v10.16.3
      sudo npm install
      Ich habe das mal probiert und bekomme jede Menge Fehler, die ich aber nicht deuten kann bzw nicht weiß wie ich sie behebe.:
      npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sur                                            e to switch over as this distribution is no longer supported and may contain bug                                            s and critical security issues.
      npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance                                             with the hapi support policy (hapi.im/support). Please upgrade to the latest ver                                            sion to get the best features, bug fixes, and security patches. If you are unabl                                            e to upgrade at this time, paid support is available for older versions (hapi.im                                            /commercial).
      npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance                                             with the hapi support policy (hapi.im/support). Please upgrade to the latest ver                                            sion to get the best features, bug fixes, and security patches. If you are unabl                                            e to upgrade at this time, paid support is available for older versions (hapi.im                                            /commercial).
      npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accorda                                            nce with the hapi support policy (hapi.im/support). Please upgrade to the latest                                             version to get the best features, bug fixes, and security patches. If you are u                                            nable to upgrade at this time, paid support is available for older versions (hap                                            i.im/commercial).
      npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sur                                            e to switch over as this distribution is no longer supported and may contain bug                                            s and critical security issues.
      > sqlite3@3.1.13 install /opt/iobroker/node_modules/iobroker.sbfspot/node_module                                            s/sqlite3
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaw                                            s.com/sqlite3/v3.1.13/node-v64-linux-x64.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.13 and node@10.16                                            .3 (node-v64 ABI) (falling back to source compile with node-gyp)
      node-pre-gyp ERR! Tried to download(undefined): https://mapbox-node-binary.s3.am                                            azonaws.com/sqlite3/v3.1.13/node-v64-linux-x64.tar.gz
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/roo                                            t/.node-gyp/10.16.3"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modul                                            es/iobroker.sbfspot/node_modules/sqlite3/build'
      gyp ERR! System Linux 5.0.15-1-pve
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy                                            p/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/nod                                            e_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-x64/n                                            ode_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node                                            _modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-x64"
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mo                                            dules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --                                            module=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/bind                                            ing/node-v64-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_pat                                            h=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/n                                            ode-v64-linux-x64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modu                                            les/iobroker.sbfspot/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/com                                            pile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chi                                            ld_process.js:259:5)
      node-pre-gyp ERR! System Linux 5.0.15-1-pve
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.s                                            bfspot/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallbac                                            k-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/s                                            qlite3
      node-pre-gyp ERR! node -v v10.16.3
      gypFailed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-                                            gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_mo                                            dules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-x64/node_                                            sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules                                            /iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v64-linux-x64' (1)
       ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/                                            iobroker.sbfspot/node_modules/sqlite3/build'
      gyp ERR! not ok
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fse                                            vents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                            1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}                                            )
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@3.1.13 (node_modules/sql                                            ite3):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@3.1.13 install: `node-pr                                            e-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      added 340 packages from 708 contributors and audited 6811 packages in 27.063s
      found 18 vulnerabilities (1 low, 10 moderate, 7 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      Sehe auch grade, dass da mehrere Vulnerabilities angemerkt werden. Kann ich da einfach den Fix laufen lassen ?
      Rene_HMR 1 Antwort Letzte Antwort
        martinschm
        #84
        Ich hab mich heute nochmal dran gemacht, bekomme aber immer noch die Meldung
        Sqlite3 läuft aber auf dem Rechner, ich kann mich mit sqlite3 SBFspot.db in die Datenbank einloggen. Nur unter node scheint es mit sqlite nicht zu klappen.
        @Rene_HM: kannst du hier evtl helfen ?
          martinschm
          #85
          Hab jetzt aus
          /iobroker/node_modules den sqlite3 Ordner nach /iobroker/node_modules/iobroker.sbfspot/node_modules kopiert. Jetzt läuft der Adapter.
          Also Problem gelöst. Ursache unbekannt.
          • M martinschm
            sudo npm install
            gyp ERR! not ok
            gyp ERR! not ok
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #86
            @martinschm sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
            Für mich sieht das eher nach einem Rechte-Problem aus...
            • Rene_HMR Rene_HM
              martinschm
              #87
              Hab den Adapter heute noch einmal komplett deinstalliert, das Fix Skript über iobroker laufen lassen und dann den Adapter neu installiert. Das Problem trat trotzdem auf.
                martinschm
                #88
                Ich hatte jetzt im Nachgang noch das Problem, das für den sbfspot Adapter die Datenbank Read only war und es immer eine Fehlermeldung im log gab. Hab zwar gedacht, das der Adapter eh nur liest, aber trotzdem kam eine solche Meldung. Hab die Datenbankdatei dann per chown an den iobroker User übertragen, danach hat der Adapter funktioniert.
                Leider kann jetzt sbfspot nicht mehr drauf zugreifen.
                Bin da leider Linuxlaie, wie muß ich das ganze umsetzen, das der Adapter und sbfspot auf die Datenbank zugreifen können ?
                Ciao
                Martin
                  martinschm
                  #89
                  hab die Datenbank Datei gestern wieder an den User verschoben mit dem ich SBFSport installiert habe. Plötzlich lief der Adapter und hat Daten abgefragt.
                  Das ganze lief dann bis 13:15 und seit dem kommt
                  2019-11-20 13:15:00.830 - error: sbfspot.0 Error while performing Query in GetInverter. Error: SQLITE_READONLY: attempt to write a readonly database
                  2019-11-20 13:15:06.814 - warn: sbfspot.0 force terminate in connect
                  @Rene_HM: Der Adapter list doch nur Daten aus, oder ? Da sollte Read only ja eigentlich kein Problem sein, oder ?
                  • M martinschm
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    #90
                    @martinschm der Adapter liest normalerweise nur. Ich habe nochmal nachgeschaut, es gibt nur "select ..." queries. Außnahme: wenn der Adapter keinerlei Daten in der Datenbank findet, schreibt er einmalig Dummy-Daten. Das würde man am log "no inverter data found" sehen.
                    Zum anderen weiß ich nicht, was SQLITE selbst macht. Ich glaube, es gab schon mal ein Feedback hier, dass man Schreibrechte auf den ganzen Ordner benötigt. (hatte ich mir in den Quellen vermerkt ;-) ) Ich selbst verwende MariaDB, somit habe ich wenig Erfahrung mit SQLITE. quick 'n'dirty würde ich wohl
                    sudo chmod -R 777 db_folder
                    probieren. Besser wäre natürlich, den usern die entsprechenden Rechte zu geben... aber eben auf den Ordner, nicht nur die Datei...
                      martinschm
                      #91
                      Hi @Rene_HM
                      danke für dein Feedback.
                      Interessanterweise hat sich die Fehlermeldung jetzt geändert
                      error: sbfspot.0 Error while performing Query / connection ... Error: SQLITE_CANTOPEN: unable to open database file
                      Läuft wohl schon seit ein paar Tagen so. Weiß leider nicht mehr, was ich da geändert habe. Ich habe jetzt mal deinen Rat mit dem chmod 777 befolgt, bisher noch kein Erfolg Die Fehlermeldung von oben kommt noch.
                      Problem hat sich (vorerst) erledigt. Daten werden jetzt gelesen.
                      Johannes BauerstatterJ 1 Antwort Letzte Antwort
                      • M martinschm
                        Hi @Rene_HM
                        Johannes BauerstatterJ Offline
                        #92
                        Ich habe das automatische Script von: link text auf meinem Raspi 4 mit SQL installieren lassen. Das funktioniert soweit fehlerfrei, aber ich bekomme folgenden Fehler vom Adapter:
                        sbfspot.0	2019-12-10 13:32:01.745	error	(10617) exception catch after ready [Error: Cannot find module 'sqlite3']
                        sbfspot.0	2019-12-10 13:32:01.706	info	(10617) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v10.17.0
                        sbfspot.0	2019-12-10 13:32:01.094	debug	(10617) States connected to redis: 127.0.0.1:9000
                        sbfspot.0	2019-12-10 13:32:01.072	debug	(10617) statesDB connected
                        sbfspot.0	2019-12-10 13:32:01.071	debug	(10617) States create PubSub Client
                        sbfspot.0	2019-12-10 13:32:01.065	debug	(10617) Objects connected to redis: 127.0.0.1:9001
                        sbfspot.0	2019-12-10 13:32:01.062	debug	(10617) Redis States: Use Redis connection: 127.0.0.1:9000
                        sbfspot.0	2019-12-10 13:32:01.060	debug	(10617) objectDB connected
                        sbfspot.0	2019-12-10 13:32:01.045	debug	(10617) Objects client initialize lua scripts
                        sbfspot.0	2019-12-10 13:32:01.043	debug	(10617) Objects create PubSub Client
                        sbfspot.0	2019-12-10 13:32:01.039	debug	(10617) Objects client ready ... initialize now
                        sbfspot.0	2019-12-10 13:32:01.002	debug	(10617) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        Hat jemand einen Tip für mich?
                        • Johannes BauerstatterJ Johannes Bauerstatter
                          martinschm
                          #93
                          @Johannes-Bauerstatter said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                          Schau mal ein paar Posts weiter oben. Hatte das gleiche Problem. sqllite lag da an der falschen Stelle, habs umkopiert und dann ging es.
                          • M martinschm
                            #94
                            @martinschm Danke. Hat geholfen.
                            Zur Info: Ich musste alle Ordner von /home/pi/smadata nach /iobroker/node_modules/iobroker.sbfspot/node_modules kopieren und dann noch die Rechte vergeben
                            sudo chmod -R 777 /home/pi/smadata
                              Tottbeck
                              #95
                              Habe dummerweise auf sbfspot V2.40 aktualisiert.
                              Danach kam auch diese Meldung "exception catch after ready [Error: Cannot find module 'sqlite3']"
                              Nach einem Downgrade auf 2.3.0 hat es dann aber komischerweise auch nicht mehr funktioniert.
                              sqlite geht in der Kommandozeile, habe es dann aber mit "sudo npm install" versucht per node das sqlite zu installieren. Vorher ging es ohne "node_modules"-Ordner im iobroker.sbfspot prima, aber egal.
                              "sudo npm install" schmeißt etliche Warnungen, ist aber scheinbar durchgelaufen.
                              Jetzt erscheint beim sbfspot-start
                              "exception catch after ready [Error: Cannot find module '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node']"
                              Das Update auf sbfspot 2.4.0 klappt auch nicht mehr.
                              $ ./iobroker upgrade sbfspot
                              Update sbfspot from @2.3.0 to @2.4.0
                              NPM version: 6.9.0
                              npm install iobroker.sbfspot@2.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
                              npm
                               ERR! path /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/@types/nodenpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
                              npm
                               ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/@types/node'npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/@types/node'npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/@types/node\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path: '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/@types/node' }
                              npm
                               ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm
                               ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
                              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-01-11T12_14_21_443Z-debug.log
                              ERROR: host.raspberrypi Cannot install iobroker.sbfspot@2.4.0: 243
                              Irgendwie sind diese ganzen Abhängigkeiten kaum noch zu durchblicken.
                              • T Tottbeck
                                NPM version: 6.9.0
                                npm
                                npm
                                npm
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                #96
                                @Tottbeck sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                                versuche das mal mehrfach hintereinander (bei mir waren drei Versuche notwendig), bei jedem Versuch wurden weitere Abhängigkeiten augelöst...
                                sudo npm install
                                • W Offline
                                  W Offline
                                  wm20320
                                  #97
                                  Ich bekomme das Widget nicht zum Laufen - merkwürdigerweise weder auf meinem Rasp, noch auf dem NUC....
                                  • Die Datenbank funktioniert, die sbfspot.0-Instanz läuft eigentlich auch fehlerfrei und versorgt die Objekte im iobroker mit Werten.
                                  • Die Eigenschaften des Widgets werden angezeigt, das Widget ansich in der View allerdings nicht, nicht mal ein Rahmen, wenn's ausgewählt ist.. Als Instanz ist sbfspot.0 eingetragen, die OID's passen auch ...
                                    Hm. Was könnte da sein?
                                  • Rene_HMR Rene_HM
                                    sudo npm install
                                    Tottbeck
                                    schrieb am zuletzt editiert von Tottbeck
                                    #98
                                    sudo npm install>
                                    Beim 1. mal gab es zwar viele Warnungen, beim 2. Aufruf schien es aber OK
                                    Habe es nochmal ausgeführt. Das muß doch zwingend im iobroker.sbfsport-Verzeichnis sein, oder ?
                                    pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.sbfspot
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.sbfspot $ sudo npm install
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    audited 6728 packages in 21.032s
                                    found 0 vulnerabilities
                                    • W wm20320
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #99
                                      @wm20320 schau mal, was im browser in der web-console steht, vielleicht hilft das...
                                      W 1 Antwort Letzte Antwort
                                      • T Tottbeck
                                        sudo npm install>
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #100
                                        Das muß doch zwingend im iobroker.sbfsport-Verzeichnis sind, oder ?
                                        ja.
                                        • Rene_HMR Rene_HM
                                          ja.
                                          Tottbeck
                                          #101
                                          @Rene_HM
                                          2020-01-12T14_53_55_158Z-debug.log
                                          Habe versucht npm nochmal zu installieren, klappt aber nicht.
                                          root@raspberrypi:/opt/iobroker/node_modules/iobroker.sbfspot# sudo npm clean-install
                                          npm WARN prepare removing existing node_modules/ before installation
                                          > sqlite3@4.1.1 install /opt/iobroker/node_modules/iobroker.sbfspot/node_module/sqlite3
                                          node-pre-gyp info it worked if it ends with ok
                                          node-pre-gyp info using node-pre-gyp@0.11.0
                                          node-pre-gyp info using node@8.16.0 | linux | arm
                                          node-pre-gyp WARN Using request for node-pre-gyp https download
                                          node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.sbfspo/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" (not fond)
                                          node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
                                          node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
                                          node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonas.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
                                          node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.1 and node@8.16. (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                                          node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binar.s3.amazonaws.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
                                          gyp info using node-gyp@3.8.0
                                          gyp info ok
                                          gyp info spawn /usr/bin/python2
                                          gyp info spawn args [ '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_ain.py',
                                          gyp info spawn args   'binding.gyp',
                                          gyp info spawn args   '-f',
                                          gyp info spawn args   'make',
                                          gyp info spawn args   '-I',
                                          gyp info spawn args   '/opt/iobroker/node_modules/iobroker.sbfspot/node_modulessqlite3/build/config.gypi',
                                          gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gyi',
                                          gyp info spawn args   '/root/.node-gyp/8.16.0/include/node/common.gypi',
                                          gyp info spawn args   '-Dlibrary=shared_library',
                                          gyp info spawn args   '-Dvisibility=default',
                                          gyp info spawn args   '-Dnode_root_dir=/root/.node-gyp/8.16.0',
                                          gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/noe-gyp',
                                          gyp info spawn args   '-Dnode_lib_file=/root/.node-gyp/8.16.0/<(target_arch)/noe.lib',
                                          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.sbspot/node_modules/sqlite3',
                                          gyp info spawn args   '-Dnode_engine=v8',
                                          gyp info spawn args   '--depth=.',
                                          gyp info spawn args   '--no-parallel',
                                          gyp info spawn args   '--generator-output',
                                          gyp info spawn args   'build',
                                          gyp info spawn args   '-Goutput_dir=.' ]
                                          gyp info ok
                                          gyp info spawn make
                                          gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                                          make: Entering directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_modues/sqlite3/build'
                                            ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/bj/gen/sqlite-autoconf-3300100/sqlite3.c
                                            TOUCH Release/obj.target/deps/action_before_build.stamp
                                            CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o
                                          cc: internal compiler error: Killed (program cc1)
                                          Please submit a full bug report,
                                          with preprocessed source if appropriate.
                                          See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
                                          deps/sqlite3.target.mk:129: recipe for target 'Release/obj.target/sqlite3/gen/slite-autoconf-3300100/sqlite3.o' failed
                                          make: *** [Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o] Eror 4
                                          make: Leaving directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_moduls/sqlite3/build'
                                          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_moduls/node-gyp/lib/build.js:262:23)
                                          gyp ERR! stack     at emitTwo (events.js:126:13)
                                          gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces.js:198:12)
                                          gyp ERR! System Linux 4.14.98-v7+
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_mdules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/nodesqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_moules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm" "--npi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_labe=node-v57"
                                          gyp ERR! node -v v8.16.0
                                          gyp ERR! not ok
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mdules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --modle=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/bindingnode-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/pt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/nodev57-linux-arm --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --noe_napi_label=node-v57' (1)
                                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modles/iobroker.sbfspot/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
                                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
                                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chld_process.js:209:5)
                                          node-pre-gyp ERR! System Linux 4.14.98-v7+
                                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.bfspot/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/qlite3
                                          node-pre-gyp ERR! node -v v8.16.0
                                          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                          Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gy/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/obroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroer.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=4--node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the sqlite3@4.1.1 install script.
                                          npm ERR! This is probably not a problem with npm. There is likely additional loging output above.
                                          npm ERR!     /root/.npm/_logs/2020-01-12T14_53_55_158Z-debug.log
