  4. JavaScript
  5. http request error Spotify-script
    2.0k
    2.5k
javascriptmultimedia
3 Beiträge 2 Kommentatoren 662 Aufrufe 2 Beobachtet
    M.Siemens
    Moin zusammen,
    ich bekomme bei Benutzung eines meiner Scripte immer folgende Meldung:
    2019-11-23 14:51:58.232 - warn: spotify-premium.0 (5848) http request error not handled, please debug
    2019-11-23 14:51:58.233 - warn: spotify-premium.0 (5848) Error
    at sendRequest (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\main.js:154:21)
    at Object.listenOnPlay [as func] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\main.js:1688:5)
    at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\lib\cache.js:225:19
    at Array.forEach ()
    at trigger (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\lib\cache.js:219:11)
    at Adapter.setExternal (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\lib\cache.js:258:2)
    at Adapter.emit (events.js:198:13)
    at Immediate.setImmediate [as _onImmediate] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.js-controller\lib\adapter.js:4748:38)
    at runCallback (timers.js:705:18)
    at tryOnImmediate (timers.js:676:5)
    at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\main.js:262:38
    at tryCallOne (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\node_modules\promise\lib\core.js:37:12)
    at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\node_modules\promise\lib\core.js:123:15
    at flush (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.spotify-premium\node_modules\asap\raw.js:50:29)
    at process._tickCallback (internal/process/next_tick.js:61:11)
    2019-11-23 14:51:58.233 - error: spotify-premium.0 (5848) erron in request: 403
    ich konnte es auf folgende Zeile eingrenzen:
    setStateDelayed("spotify-premium.0.playlists.playlistList", getState("Haus.0.Spotify.Malte.Playlist").val, 1000, false);
    das Script tut was es soll, spukt aber zusätzlich diesen Fehler aus.
    ich fütter den selben Datenpunkt sonst über Vis direkt mit diesen Daten und da gibts keine Probleme.
    Hoffe ihr erkennt den Fehler und könnt mir helfen
    • J.A.R.V.I.S.J Offline
      J.A.R.V.I.S.
      Hey,
      das scheint aber ein Problem vom Adpater zu sein, bzw. vom Wert des Datenpunktes. Was steht denn in deinen Datenpunkten drin und was lässt du über die VIS eintragen?
      J.A.R.V.I.S.
      • J.A.R.V.I.S.J J.A.R.V.I.S.
        Hey,
        J.A.R.V.I.S.
        M.Siemens
        @J-A-R-V-I-S Ich hole in beiden fällen die Daten aus dem Datenpunkt "spotify-premium.0.playlists.playlistListIds".
        Unter Vis direkt per Selcet ValueList aus "premium.0.playlists.playlistListIds" in "premium.0.playlists.playlistList".
        Bei dem Script werden die Daten aus "premium.0.playlists.playlistListIds" erst per Selcet ValueList in einen anderen Datenpunkt geschrieben (als vorauswahl, zum automatischen Starten per Script) und dann mit dem Script in "spotify-premium.0.playlists.playlistList" geschrieben.
        Die Playlist wir ja auch abgespielt nur
        83.2k
