  4. [gelöst] Installation iobroker auf QNAP 251+ in docker
94 Beiträge 13 Kommentatoren 26.9k Aufrufe 8 Beobachtet
  • P piccobello
    geht auch nicht
    zigbee.0	2019-11-20 20:21:31.321	error	(1404) Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/ttyACM0
    zigbee.0	2019-11-20 20:21:31.310	info	(1404) Starting zigbee-shepherd
    info.0	2019-11-20 20:20:32.256	info	(431) Popup news was read...
    zigbee.0	2019-11-20 20:20:31.309	info	(1404) Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
    zigbee.0	2019-11-20 20:20:31.293	info	(1404) Reset coordinator
    zigbee.0	2019-11-20 20:20:31.249	info	(1404) Queue is: true
    zigbee.0	2019-11-20 20:20:31.248	info	(1404) Start on port: /dev/ttyACM0 channel 11
    zigbee.0	2019-11-20 20:20:31.202	info	(1404) starting. Version 0.11.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.17.0
    host.8862f2d30733	2019-11-20 20:20:29.117	info	instance system.adapter.zigbee.0 started with pid 1404
    host.8862f2d30733	2019-11-20 20:20:27.153	info	instance system.adapter.zigbee.0 terminated with code 156 (156)
    zigbee.0	2019-11-20 20:20:26.623	info	(1388) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2019-11-20 20:20:26.622	info	(1388) terminating
    zigbee.0	2019-11-20 20:20:26.614	info	(1388) Got terminate signal TERMINATE_YOURSELF
    host.8862f2d30733	2019-11-20 20:20:26.604	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.8862f2d30733	2019-11-20 20:20:26.603	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    GlasfaserG Offline
    GlasfaserG Offline
    @piccobello
    Zeige mal :
    ls -l /dev/serial/by-id
    • P Offline
      piccobello
      @Glasfaser said in [gelöst] Installation iobroker auf QNAP 251+ in docker:
      ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefunden
      • P piccobello
        GlasfaserG Offline
        GlasfaserG Offline
        @piccobello
        Sorry
        ls -la /dev/serial/by-id/
        • P Offline
          piccobello
          ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
          • P piccobello
            GlasfaserG Offline
            GlasfaserG Offline
            @piccobello
            Das mußt du mir mal erklären !????
            • P Offline
              piccobello
              mit winscp geht das (aber mit terminal von qnap geht das nicht)
              /$ ls -la /dev/serial/by-id/
              total 0
              drwxr-xr-x 2 admin administrators 60 Nov 20 12:37 .
              drwxr-xr-x 4 admin administrators 80 Nov 20 12:37 ..
              lrwxrwxrwx 1 admin administrators 13 Nov 20 12:37 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE5AB9C-if00 -> ../../ttyACM0
              • P piccobello
                total 0
                GlasfaserG Offline
                GlasfaserG Offline
                @piccobello
                und was kommt bei
                ls -la /dev/ttyACM0
                • P Offline
                  piccobello
                  @piccobello said in [gelöst] Installation iobroker auf QNAP 251+ in docker:
                  ![alt text](cb1c43b2-368e-4b8a-9974-b756e2f4e49e-imagem.png image url)
                  da geht das nicht
                  • P Offline
                    piccobello
                    /$ ls -la /dev/ttyACM0
                    crw-rw---- 1 admin 20 166, 0 Nov 20 12:37 /dev/ttyACM0
                    • P piccobello
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @piccobello
                      mache nochmal :
                      chmod 777 /dev/ttyACM0
                      und dann die Ausgabe nochmal
                      ls -la /dev/ttyACM0
                      • P Offline
                        piccobello
                        ls -la /dev/ttyACM0
                        /$ chmod 777 /dev/ttyACM0
                        crwxrwxrwx 1 admin 20 166, 0 Nov 20 12:37 /dev/ttyACM0
                        • P piccobello
                          ls -la /dev/ttyACM0
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @piccobello
                          und jetzt den Zigbee mit dem Port ttyACM0
                          neu Starten
                          • P Offline
                            piccobello
                            777 /dev/ttyACM0 so ??
                            • P piccobello
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @piccobello
                              Du hast doch ein Auswahlmenue dafür :
                              • P Offline
                                piccobello
                                wieder error
                                zigbee.0	2019-11-20 21:06:13.407	error	(1443) Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/ttyACM0
                                zigbee.0	2019-11-20 21:06:13.398	info	(1443) Starting zigbee-shepherd
                                zigbee.0	2019-11-20 21:05:13.395	info	(1443) Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
                                zigbee.0	2019-11-20 21:05:13.365	info	(1443) Reset coordinator
                                zigbee.0	2019-11-20 21:05:13.320	info	(1443) Queue is: true
                                zigbee.0	2019-11-20 21:05:13.319	info	(1443) Start on port: /dev/ttyACM0 channel 11
                                zigbee.0	2019-11-20 21:05:13.277	info	(1443) starting. Version 0.11.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.17.0
                                host.8862f2d30733	2019-11-20 21:05:11.356	info	instance system.adapter.zigbee.0 started with pid 1443
                                host.8862f2d30733	2019-11-20 21:05:09.352	info	instance system.adapter.zigbee.0 terminated with code 156 (156)
                                zigbee.0	2019-11-20 21:05:08.833	info	(1404) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                zigbee.0	2019-11-20 21:05:08.832	info	(1404) terminating
                                zigbee.0	2019-11-20 21:05:08.828	info	(1404) Got terminate signal TERMINATE_YOURSELF
                                host.8862f2d30733	2019-11-20 21:05:08.824	info	stopInstance system.adapter.zigbee.0 send kill signal
                                host.8862f2d30733	2019-11-20 21:05:08.821	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                info.0	2019-11-20 20:50:32.271	info	(431) Popup news was read...
                                • P piccobello
                                  wieder error
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @piccobello
                                  Letzer Versuch, im Container den Befehl durchführen :
                                  • P Offline
                                    piccobello
                                    im Container macht er das
                                    chmod: Zugriff auf '/dev/ttyACM0' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                    • P piccobello
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #66
                                      @piccobello
                                      Leider kenne ich den Qnap - Container nicht ,
                                      da kann ich dir leider nicht mehr weiterhelfen … Sorry 😌
                                      Da fällt mir noch etwas ein :
                                      Vielleicht muss man es weiterreichen , gibt es soetwas bei dir !?
                                      • P Offline
                                        piccobello
                                        #67
                                        leicht nur so was
                                        ![alt text](2cf27c43-5684-4ef6-8207-94870c134209-imagem.png image url)
                                        • P Offline
                                          piccobello
                                          #68
                                          ![alt text](5bcbfe31-d14b-4eec-acc5-54977bb83587-imagem.png image url)
