  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.4k Aufrufe 59 Beobachtet
  • H hilde0407
    @j_o_e
    Das sollte so zu realisieren sein...
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="oZxI@-Nn(vw):Ij8U5~S" x="12.35671612731096" y="-262.3150654620798">
      <mutation items="1"></mutation>
      <value name="OID0">
        <shadow type="field_oid" id="^|ptuzD_|DsyUk=:@Cvi">
          <field name="oid">javascript.0.Xiaomi.Fensterstatus_Wohnzimmer</field>
        </shadow>
      </value>
      <statement name="STATEMENT">
        <block type="controls_if" id="jvncmmGKmyJ]!@dIJO=6">
          <value name="IF0">
            <block type="logic_compare" id="2YytrLl=an+@0(;QX%#v">
              <field name="OP">GT</field>
              <value name="A">
                <block type="on_source" id="UqbSjlQfz$H?YZH[+[1Y">
                </block>
              </value>
              <value name="B">
                <block type="math_number" id="VEa-.(xRMb.k]6GEesD`">
                  <field name="NUM">0</field>
                </block>
              </value>
            </block>
          </value>
          <statement name="DO0">
            <block type="timeouts_cleartimeout" id="nqB.xy1B;uDn**:,f:4x">
              <next>
                <block type="timeouts_settimeout" id="w4+W7HaKW~wVU[@Ai!xm">
                  <field name="DELAY">5</field>
                  <field name="UNIT">min</field>
                    <block type="controls_if" id="cMhR8DG*x`Dz5-A-#gC|">
                      <value name="IF0">
                        <block type="logic_compare" id="uW`$n:y?B!)Sx.KT{PSt">
                          <value name="A">
                            <block type="get_value" id="x#KuczY$0Xs8t+pMfsV^">
                              <field name="OID">javascript.0.Xiaomi.Fensterstatus_Wohnzimmer</field>
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="0{m=0?j+,F02y`vr57z9">
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="control" id="@w.c$I2#]~tdpIy9(J8n">
                          <mutation delay_input="false"></mutation>
                          <field name="OID">tado.0.371509.Rooms.2.setting.power</field>
                          <value name="VALUE">
                            <block type="text" id="YG)iq#5DeN~kK9FV];^0">
                              <field name="TEXT">OFF</field>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
          <statement name="ELSE">
            <block type="timeouts_cleartimeout" id="eCN2BnBMQ-?@tvQ{K|_6">
            </block>
          </statement>
        </block>
      </statement>
    </block>
    j_o_e
    schrieb am zuletzt editiert von j_o_e
    #191
    Danke, dass muss ich mir morgen mal mit ausgeschlafenem Kopf genauer ansehen. Vielen Dank noch mal für die sehr schnellen Reaktionen und die nette Unterstützung. Gute Nacht!
    • H hilde0407
      @senger1985 Das stimmt, kann man aber auch deaktivieren.
      senger1985
      #192
      @hilde0407 🤣
      Ich hab schon so lange nicht mehr in die App geschaut, weil ich damals alles eingestellt habe, wo ich die ersten Thermostate bekommen habe und habe das tatsächlich nicht mehr gewusst.
      P. S.: Danke, für den Hinweis, denn mein neues Thermostat, was ich letztens für 35 € geschossen habe, war noch auf 15 Minuten eingestellt.
      H 1 Antwort Letzte Antwort
      • S senger1985
        @hilde0407 🤣
        hilde0407
        #193
        @senger1985 Gratulation zum Schnapper und gern geschehen!
        • H hilde0407
          senger1985
          #194
          @hilde0407 merci ;-)
          Bin jetzt aber auch pennen.
          Gute Nacht.
          • S Stormbringer
            @hilde0407 Test grad n bisschen rum. Aber wie machst du das ohne Modusangabe mit dem Boost? Dann kann man ja nicht abbilden ob vor den 25 Grad Manuell oder Auto war. Bzw. bei Nachtansenkung hätte ich dann das gleiche Problem mit Rückkehr zu auto oder manuell.
            Oder hast du dafür und für die Batterieanzeige in % den HAM Adapter noch laufen?
            Aber der Rest wär glaub ich absolut primitiv einfach zu steuern. Da muss man sich nach dem HAM Plugin erst mal wieder dran gewöhnen, dass es ioBroker typisch leicht ist. Absolut genialer Adapter. Top Arbeit bisher 😉👍🏻
            hilde0407
            #195
            @Stormbringer Den Boostmodus schalte ich, indem ich die Zieltemperatur auf 25 °C stelle (das ist der Maximalwert, den die Tados akzeptieren), in dem Fall wird die Heizung auf 100% gefahren, was dann genau das ist, was ich möchte.
            Du hast recht, die Batterieanzeige gibt es leider noch nicht, finde ich aber nicht so schlimm, da mir das die Tado App auch mitteilt, wenn die Batterien leer sind.
            • DutchmanD Dutchman
              @CKMartens sagte in Test Adaper Tado v0.1.x:
              @Dutchman doch bei mir funktioniert es ja... Ein paar Nachrichten weiter hatte da wohl jemand Probleme
              ah ok, dan muss das ne frustre version sein die letzte online hat das alles drin
              hilde0407
              #196
              @Dutchman Ist es möglich in den Tado Adapter noch den Batteriezustand der Thermostate einzubauen?
              CKMartensC 1 Antwort Letzte Antwort
              • H hilde0407
                CKMartensC Offline
                CKMartensC Offline
                CKMartens
                schrieb am zuletzt editiert von CKMartens
                #197
                @hilde0407 sagte in Test Adaper Tado v0.1.x:
                Ist doch schon drinnen.
                Nur zeigt tado da echt den Batterie Zustand seltsam an. Es wird nicht in Prozent angezeigt sondern nur normal und low
                • CKMartensC CKMartens
                  hilde0407
                  #198
                  @CKMartens Ups! Diesen Datenpunkt habe ich bisher übersehen! Vielen Dank für den Tip!
                  • H hilde0407
                    Stormbringer
                    schrieb am zuletzt editiert von Stormbringer
                    #199
                    @hilde0407 Glaub Batteriestatus zeigt der Adapter an. Denk derzeit nur sowas wie LowBat Warnung aber nicht in Prozent 😉 Was bei VIS Umsetzung wiederum schlecht ist.
                    Danke, das mit dem Boost ist mir klar. Hab ich schon länger mit dem HAM Adapter. Nur, wenn ich keinen Modus abfragen kann weiß ich ja nicht ob ich vorher manuell hatte oder auto. Hintergrund ist der, dass er dann bei der Übergangsphase vom heizen (da schalte ich die heizung nur immer bei bedarf kurz ein und nicht nach Zeitplan oder lass den Broker zur bestimmten Zeit kurz heizen) ja auf Automodus schalten würde. Und das wär ein Rückschritt wie zu den Anfangszeit wo man noch über IFTTT steuern hat müssen den ich für meinen Bedarf nicht will 😉 Weißt du was ich meine?
                    Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
                    CKMartensC H 2 Antworten Letzte Antwort
                    • S Stormbringer
                      CKMartensC Offline
                      CKMartensC Offline
                      CKMartens
                      #200
                      @Stormbringer sagte in Test Adaper Tado v0.1.x:
                      Soweit ich die Doku der API im Kopf habe bietet die nicht an das der Batteriestatus in Prozent angezeigt wird. Eben nur "normal" und "low".
                        Stormbringer
                        #201
                        @CKMartens HAM Adapter machts aber ;-)
                        Aber find ich jetzt nicht so wichtig wie Modus Anzeige und Änderung g Ohne der könnte man auch umsteigen von HAM auf tado Adapter
                        S CKMartensC 2 Antworten Letzte Antwort
                        • S Stormbringer
                          senger1985
                          #202
                          @Stormbringer diese Angabe wird meiner Meinung nach nicht korrekt dargestellt.
                          Habe drei Thermostate, wo ich bei mindestens einem Thermostat die Batterien noch nie gewechselt habe und da steht dennoch 100 %.
                          • S Stormbringer
                            CKMartensC Offline
                            CKMartensC Offline
                            CKMartens
                            #203
                            Ne der ham steht auf 100% (="normal") dann geht er auf 15% ("low").
                            Wie gesagt die API liefert da nicht mehr.
                            S DutchmanD 2 Antworten Letzte Antwort
                              senger1985
                              #204
                              @CKMartens das meinte ich ja, der Adapter liefert "nur" diese beiden Werte und nicht die genauen Prozentzahlen.
                              • S Stormbringer
                                hilde0407
                                schrieb am zuletzt editiert von hilde0407
                                #205
                                @Stormbringer Ich erledige das über die Abfrage, ob der Datenpunkt in Tado.Setting.temperature auf 25° C eingestellt ist. Wenn er diese Temperatur hat, ist ja der Boost Modus aktiv (da ich ihn selber auf diese Temperatur eingestellt habe. Alternativ könnte man den Datenpunkt heatingPower (Im Boost Modus hat der 100%) abfragen.
                                  <block type="comment" id="#;!i][akniGuZ),T.k[S" x="-1387" y="-887">
                                    <field name="COMMENT">Xiaomi Button drücken, wechselt den Logik Wert im Datenpunktatenpunk</field>
                                    <next>
                                      <block type="on_ext" id="FDBG.Lax%A959Yb{N`sD">
                                        <field name="CONDITION">true</field>
                                        <value name="OID0">
                                          <shadow type="field_oid" id="`[Hk{(!re~QNZ_Mf-w|b">
                                            <field name="oid">mihome.0.devices.switch_158d00022cbfcd.click</field>
                                          </shadow>
                                        </value>
                                          <block type="toggle" id="dHhe,lrQvb=jlRuf;u]#">
                                            <field name="OID">javascript.0.Xiaomi.Schalter_Heizung</field>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="comment" id="=2K=;vuK[P|Iz[`t=jSV">
                                            <field name="COMMENT">Trigger auf Datenpunkt Boost an / aus</field>
                                            <next>
                                              <block type="on_ext" id="{_e^qy3ezMQcQtpj}]-]">
                                                <value name="OID0">
                                                  <shadow type="field_oid" id="JF/E:mLggz0dhAHx,3Ak">
                                                    <field name="oid">javascript.0.Xiaomi.Schalter_Heizung</field>
                                                  </shadow>
                                                </value>
                                                  <block type="controls_if" id="H[{Y):Y-YD`eBA]zmT^?">
                                                    <value name="IF0">
                                                      <block type="logic_compare" id="Xv`(bYy59VxQ(;vB;GAw">
                                                        <field name="OP">EQ</field>
                                                        <value name="A">
                                                          <block type="on_source" id=")NWuYOo$wRp(xy[[ba_1">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="logic_boolean" id="h#^eb1x+$NZnYsm_Z$;)">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                      <block type="comment" id="S%m5$VV!DyirJK$je7p-">
                                                        <field name="COMMENT">Abfrage, ob Boost Modus inaktiv</field>
                                                        <next>
                                                          <block type="controls_if" id="rMeysmfNvB8|mASpLJn?">
                                                            <value name="IF0">
                                                              <block type="logic_compare" id="d~4)2V|O(H5=VwhDx@P`">
        <field name="OP">LT</field>
        <value name="A">
        <block type="get_value" id="E{IR]EFLFg%w@rgTrH#f">
        <field name="OID">tado.0.371509.Rooms.2.setting.temperature</field>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="|59)w#4t[k4v[+d+_L[F">
        <field name="NUM">25</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                              <block type="comment" id="Z2.2KsU1vD$=LT=:9S6B">
        <field name="COMMENT">Wenn Fenster geschlossen, dann Boost Modus einschalten</field>
        <next>
        <block type="controls_if" id="7LVk)]pOAw%6E0CJACR|">
        <value name="IF0">
        <block type="logic_compare" id="gLAL*+TvI,g(*vLDWD5=">
        <value name="A">
        <block type="get_value" id="u4(tg?eqDUk[OHqFzM:K">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="9oV.IUu9%vih/Dh}(pK%">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="}VSt[syL](ZF%QnR61jY">
        <block type="math_number" id="r%7y^8P?fB.A!`rLN|v,">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <value name="IF1">
                                                      <block type="logic_compare" id="zYT9P6M]]V~/[-8oyUt=">
                                                        <value name="A">
                                                          <block type="get_value" id="[CY)%(KVNHA07[OL-xo,">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="math_number" id="|b}VDQeL6,{FX9[4tTpi">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO1">
                                                      <block type="comment" id="gezIPa?@eS|zVYH,9-[_">
                                                        <field name="COMMENT">Abfrage, ob Boost Modus aktiv, dann Boost Modus ausschalten</field>
                                                        <next>
                                                          <block type="control" id="fD{?KyX$+JlTA3N00ueD">
                                                            <field name="OID">tado.0.371509.Rooms.2.overlay.clearZoneOverlay</field>
                                                              <block type="logic_boolean" id="r53AF+7Ay=VF7z,)afV[">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                                <next>
                                                  <block type="comment" id=":^Bq?InkO?WI_DkKhdn[">
                                                    <field name="COMMENT">Wenn Zieltemperatur erreicht, dann Boost Modus ausschalten (löst den Trigger Schalter_Heizung aus) </field>
                                                    <next>
                                                      <block type="on_ext" id="zmQ5r4A#t9|KFIVn,IQs">
                                                        <value name="OID0">
                                                          <shadow type="field_oid" id="uVXBwD7z{JKLR]0;UR7n">
                                                            <field name="oid">javascript.0.Xiaomi.Temperatur_Wohnzimmer</field>
                                                          </shadow>
                                                        </value>
                                                          <block type="controls_if" id="E%uVxb*s$mNy1b,F9z;m">
                                                            <value name="IF0">
                                                              <block type="logic_compare" id="qJMAa;r9}`M)i(f(aOFV">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="on_source" id="%.(=tLXc,b#C}rh/Q^K7">
        </block>
        </value>
        <value name="B">
        <block type="get_value" id="Xn:@IK%QlaC6k7fS%n!D">
        <field name="OID">javascript.0.FritzDect.WohnzimmerBoostTemperatur</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                              <block type="control" id="d9O:BG^#tdcFHQ5Z=I#f">
        <block type="logic_boolean" id="$Jj;e*w*CNJ`v.%kY,2?">
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </xml>
                                • J j_o_e
                                  @hilde0407
                                  Vielen Dank! Das einzige, was mich noch beschäftigt ist die Frage, wie ich die Prüfung einbaue, ob das Fenster mindestens X Minuten auf war... Will z.B. im Wohnzimmer nicht die Heizung länger ausgeschaltet lassen, wenn jemand nur etwas vom Balkon holt und die Tür nur kurz auf ist...
                                  hilde0407
                                  #206
                                  @j_o_e
                                  Zu Deiner Frage, wie man es realisieren kann, dass die Heizung erst nach einer gewissen Zeit ausgeschaltet wird, wenn das Fenster geöffnet wurde, fand ich ganz interessant und habe es so gelöst. Die Heizung wird nun erst nach 30 Sekunden ausgeschaltet und beim Schließen der Fenster wird die Heizung wieder eingeschaltet (wenn sie aus war). Der Boost Modus wird bei mir dann deaktiviert (ich denke, den zu aktivieren sollte eine bewusste Entscheidung sein und sollte dann auch wieder manuell ausgelöst werden.
                                    <variables>
                                      <variable type="" id="Efy@y-rOPU4?3%#Wlr(}">Fensterstatus</variable>
                                      <variable type="undefined" id="Wohnzimmer_Tür_offen_TimeOut">Wohnzimmer_Tür_offen_TimeOut</variable>
                                      <variable type="undefined" id="Fenster_offen_Timeout">Fenster_offen_Timeout</variable>
                                    </variables>
                                    <block type="comment" id="=3!jd`1|Hy3cqO)+jsgy" x="-1288" y="-1212">
                                      <field name="COMMENT">Datenpunkt Fensterstatus_Wohnzimmer nach offenen Fenstern steuern</field>
                                      <next>
                                        <block type="on_ext" id="^bQq#li?YG^xQ3v8d:^j">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="[c.rI$s!M-LAXx~V/L5s">
                                              <field name="oid">mihome.0.devices.magnet_158d0002750ce5.state</field>
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                            <shadow type="field_oid" id="??3!`$OGv6Z41YQ6]3Xn">
                                              <field name="oid">mihome.0.devices.magnet_158d000277b44f.state</field>
                                            </shadow>
                                          </value>
                                            <block type="variables_set" id="#OgJ{jU-g]Iz*GB~AtrN">
                                              <field name="VAR" id="Efy@y-rOPU4?3%#Wlr(}" variabletype="">Fensterstatus</field>
                                                <block type="math_number" id=")m+~Eyxbu0AZY%,T%Dur">
                                                </block>
                                              </value>
                                              <next>
                                                <block type="controls_if" id="62hjlw]D77L#[X=X_q%L">
                                                  <value name="IF0">
                                                    <block type="logic_compare" id="=y,-Az2HI3*SL{sn%pkp">
                                                      <value name="A">
                                                        <block type="get_value" id="-z{owY$^VF+`o%I^7qMx">
                                                          <field name="OID">mihome.0.devices.magnet_158d0002750ce5.state</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_boolean" id="k6)iLIIOB=T!|FF,r2;r">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="math_change" id="8Vr*!@!Z4{;hMzsi9JV~">
                                                      <value name="DELTA">
                                                        <shadow type="math_number" id="I*~Q{(QK8Z]S~.Hh3];)">
                                                          <field name="NUM">1</field>
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="controls_if" id="sfm=qXTY^-QieP(u9ob%">
                                                      <value name="IF0">
                                                        <block type="logic_compare" id="aI/5Qi2po=l@i-eW*l-+">
                                                          <value name="A">
                                                            <block type="get_value" id="vcwI;f}I8Zf|iN3m_`r@">
                                                              <field name="OID">mihome.0.devices.magnet_158d000277b44f.state</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_boolean" id="YEWb~b)mL}r;+-@KAw%o">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="math_change" id="pDnvp8iTF$m5]b(*{Ze_">
                                                            <shadow type="math_number" id="LGBsTsA9}}7K2eiPB8{*">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                        <block type="update" id="bQx5X}CtO6=UZU:IS{Ny">
                                                            <block type="variables_get" id="3T7#K+hW]_2giP8oo81r">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="comment" id="s9:JqZL~z]@.QK}P%N5|">
                                              <field name="COMMENT">Heizung ein oder ausschalten, wenn Fenster offen oder zu</field>
                                              <next>
                                                <block type="on_ext" id="_|5{4AEHysftVafeW~ol">
                                                  <value name="OID0">
                                                    <shadow type="field_oid" id="hYI,BpxN,~A019[:cO;T">
                                                    </shadow>
                                                  </value>
                                                    <block type="controls_if" id="P9]U*,pX[SeAMt}c3)Z%">
                                                      <value name="IF0">
                                                        <block type="logic_compare" id="N^/iO*[FVDA]QDqr%iJW">
                                                          <value name="A">
                                                            <block type="on_source" id="M6KVQDOYnBGt(KZ_QKe7">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id=".~jb;8n(+EYN8eWl[TSI">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="comment" id="+Y~sU-uxvVKyNI8#bf#M">
                                                          <field name="COMMENT">Heizung ausschalten, wenn die Fenster länger als 30 Sekunden offen sind</field>
                                                          <next>
                                                            <block type="timeouts_cleartimeout" id="J+-4PLR;{].YIe=sXexF">
                                                              <field name="NAME">Fenster_offen_Timeout</field>
                                                              <next>
        <block type="timeouts_settimeout" id="}r:e8aC`i]%nnr.WPe!`">
        <field name="DELAY">30</field>
        <block type="controls_if" id="kw7FQ:@yGD?09-g0a(aM">
        <value name="IF0">
        <block type="logic_compare" id="}F6BXNAKRyZ~-}x0d$7[">
        <value name="A">
        <block type="on_source" id="Nz`_-_IswDpR8[XwXqmx">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="4F7,aPPKE^{QsnhbGvlY">
        </block>
        </value>
        </block>
        </value>
        <block type="controls_if" id="_Or7EB:($CN8ok!#RPW$">
        <value name="IF0">
        <block type="logic_compare" id="I3b5T-+Xu*7lLSNHk::1">
        <value name="A">
        <block type="get_value" id=")I[wYw@!hv+~Y}ab{5;0">
        </block>
        </value>
        <value name="B">
        <block type="text" id="/|=n/Qt)XO32P8_#mEA5">
        <field name="TEXT">ON</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="w;YL4EXO55MGL|p;6rW]">
        <block type="text" id="gl@m)m*tby#sEx~*(7|Z">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                        <block type="timeouts_cleartimeout" id="OK(K3M*1WQ+6Tr?pY`Sc">
                                                          <next>
                                                            <block type="controls_if" id="d1;7:_Dk.l*Jd8|3h|_G">
                                                              <value name="IF0">
        <block type="logic_compare" id="79#9`.M`r^b##6%Pw-K|">
        <value name="A">
        <block type="get_value" id="HT)W|?2cda9J:_eZ*s.l">
        </block>
        </value>
        <value name="B">
        <block type="text" id="}+4PBOmzR.|d-G3Uxua9">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="controls_if" id="/4i(xvh2Sm^!.gsj:{YR">
        <value name="IF0">
        <block type="logic_compare" id="$CH(AwCVZ65NS{;sA!sS">
        <value name="A">
        <block type="get_value" id="A{sU:yG%|FfK37B~@9m_">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="iq$0#mUGtG4K|Z[VqqT(">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="`C$mWfpi,$lm$Q]rt5Bd">
        <block type="logic_boolean" id="q:7;w%xoQ8IrAkQ[pb`o">
        </block>
        </value>
        </block>
        </statement>
        <block type="control" id="z3_@J=Un`)L_:-2CCg0^">
        <block type="logic_boolean" id="xb7=0yRu`oyYKPC4rsQF">
        </block>
        </value>
        </block>
        </statement>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="comment" id="c{*^*)M6YG*I^|e|SXkF">
                                                      <field name="COMMENT">Boost Modus ausschalten, wenn Wohnzimmertür 5 Minuten offen steht</field>
                                                      <next>
                                                        <block type="on_ext" id="~ByS[MJXmarnf`REiOL[">
                                                          <value name="OID0">
                                                            <shadow type="field_oid" id="QxvxguLqEw.bEKJ15r~W">
                                                              <field name="oid">mihome.0.devices.magnet_158d000273da4e.state</field>
                                                            </shadow>
                                                          </value>
                                                            <block type="controls_if" id="5`049RAShcj2ZMP|A_s,">
                                                              <value name="IF0">
        <block type="logic_compare" id="=0_2*0DgpRh`E3T|~zBB">
        <value name="A">
        <block type="on_source" id="H.1zG%y*d+nbq$VQLHC3">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="%*RVD2qSgK0[2LXE4g5@">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="timeouts_settimeout" id="C;mn0L/lQzv+h~@zu3=Q">
        <field name="NAME">Wohnzimmer_Tür_offen_TimeOut</field>
        <field name="DELAY">10</field>
        <block type="controls_if" id="X_|!-{zaH?padLX8*8EX">
        <value name="IF0">
        <block type="logic_compare" id="5tfs;4gRb|`6v1bxjw2C">
        <value name="A">
        <block type="get_value" id="`E7Hf10Wqy+6_5p:ZVB*">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="3m5k(yWr{M2Qz7qp1:(o">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="Z[a8.`i@ylba|0Ctq=Rb">
        <block type="logic_boolean" id="{T+%YTbN::?=UQHq$tc0">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                              </statement>
                                                              <value name="IF1">
        <block type="logic_compare" id="}NT]FTqx!JHW7*_Q.P![">
        <value name="A">
        <block type="on_source" id="jgRW;_%J_jn.eYVtrvef">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="4Qm15j]Gl~/e@9:AWfO/">
        </block>
        </value>
        </block>
                                                              </value>
        <block type="timeouts_cleartimeout" id="}riwxHoGLjq$XyACbQp!">
        </block>
                                                              </statement>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                            <block type="comment" id="o#^:cur]Ep0d%^M3oY!x">
                                                              <field name="COMMENT">Wenn Heizung über Tado eingeschaltet wird, obwohl Fenster offen, dann wieder ausschalten</field>
                                                              <next>
        <block type="on_ext" id="%1n?jrlPaIOu06zxXw-3">
        <value name="OID0">
        <shadow type="field_oid" id="DNHasW|%3hq=}/Bty@=}">
        <field name="oid">tado.0.371509.Rooms.2.setting.power</field>
        </shadow>
        </value>
        <block type="controls_if" id="8_mT-vWL9UIDM,d!1`=P">
        <value name="IF0">
        <block type="logic_compare" id="ioLeA}E]@`.}6a-zY:BL">
        <value name="A">
        <block type="on_source" id="ZpXsuQ6_RhO2quwc`eSf">
        </block>
        </value>
        <value name="B">
        <block type="text" id="zsit@u5j!]h*3b9HQevw">
        </block>
        </value>
        </block>
        </value>
        <block type="controls_if" id="I)*pOL8cCGpO=|x4y`rT">
        <value name="IF0">
        <block type="logic_compare" id="O@TKFIDN_Rtraip}7p1X">
        <value name="A">
        <block type="get_value" id="sS$f|y{Z{}|2N%=4++M4">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="7AEwG0!A(zX-VeQ+nh)/">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="T?Pvq|!4,+YE_`pB:/Q3">
        <block type="text" id="_PS#Xh}suf6E1^B]Hld2">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  • C Coffeelover
                                    (2881) Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 4469
                                    rehmosch
                                    schrieb am zuletzt editiert von rehmosch
                                    #207
                                    Vielen Dank an die Adapter-Ersteller sowie das nette Forum hier.
                                    Habe bisher noch keine Lösung zu folgendem Problem (habe alles durchgelesen) gesehen:
                                    tado.0	2019-11-17 16:15:28.236	error	Send this info to developer !!! { Unhandable information found in DoHome : "usePreSkillsApps" with value : true
                                    Hat jemand schon eine Lösung gefunden?
                                    RP4/Conbee II/Pihilips Hue/HarmonyHub/Sonos/Alexa/Aqara Sensoren/Tradfri/ZigbeeThermostate/Xiaomi Saugroboter/Smarte Türklingel & Briefkasten ...
                                    H CKMartensC DutchmanD 3 Antworten Letzte Antwort
                                    • R rehmosch
                                      hilde0407
                                      #208
                                      @rehmosch Da gibt es keine Lösung, die Du bewerkstelligen kanns! Wie schon im Log steht, ist hier der Entwickler gefragt, da eine im Code noch nicht behandelte Information bearbeitet wird. Als diesen Logeintrag an @Dutchman schicken!
                                      • R rehmosch
                                        CKMartensC Offline
                                        CKMartensC Offline
                                        CKMartens
                                        #209
                                        @rehmosch am besten dazu ein Issue bei Github erstellen und die Informationen aus dem Log dort mit eintragen.
                                        R 1 Antwort Letzte Antwort
                                        • H hilde0407
                                              <next>
                                                  <value name="OID0">
                                                    </shadow>
                                                  </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                      <next>
                                                          <value name="OID0">
                                                            </shadow>
                                                          </value>
                                                              <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                              </statement>
                                                              <value name="IF1">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </statement>
                                                            </block>
                                                          </statement>
                                                          <next>
                                                              <next>
        <value name="OID0">
        </shadow>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </xml>
                                          Stormbringer
                                          #210
                                          @hilde0407 Bin grad noch unterwegs. Kann mir das Blockly nicht anschauen aber glaub wir reden aneinander vorbei. Das ich auf Boost oder Nachtabsenkung geschalten habe ist klar. Aber woher soll das System wissen ob vorm Boost Manuell oder Auto war, wenns keinen DP gibt? 😉
