  4. [Aufruf] Neuer Adapter für den Wiffi-wz, den Weatherman und den Rainyman von Stall.biz bereit zum testen
109 Beiträge 20 Kommentatoren 21.4k Aufrufe 12 Beobachtet
  • P Offline
    passuff
    schrieb am zuletzt editiert von passuff
    #96
    Hat noch jemand ein Problem mit dem Adapter seit dem Update des JS Controllers?
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	info	Restart adapter system.adapter.wiffi-wz.0 because enabled
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	instance system.adapter.wiffi-wz.0 terminated with code 0 (OK)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1584:35)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at that.getEnums (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1705:21)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:99:9
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.440	error	Caught by controller[0]: at checkAndSubscribe (/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:565:60)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.439	error	Caught by controller[0]: at cleanid (/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:560:13)
    host.IoBroker-VM-Debian	2019-07-20 01:20:48.438	error	Caught by controller[0]: TypeError: Cannot read property 'replace' of undefined
    wiffi-wz.0	2019-07-20 01:20:48.291	info	starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.wiffi-wz, node: v8.15.0
    EDIT: Instanz gelöscht, upload vom Adapter, Instanz wieder hinzugefügt- alles läuft wieder....
    • X x4tlaoguo
      Ein neuer Adapter für den Wiffi-wz, den Weatherman und den Rainyman von Stall.biz ist bereit zum testen.
      Vielleicht hat jemand eins von diesen Geräten und kann Feedback geben?
      Ich habe nur den WIffi-wz und dieser funktioniert.
      SegwayS Offline
      SegwayS Offline
      Segway
      #97
      @x4tlaoguo sagte in [Aufruf] Neuer Adapter für den Wiffi-wz, den Weatherman und den Rainyman von Stall.biz bereit zum testen:
      Hallo @x4tlaoguo ,
      es gibt auch im Weatherman einen Wert, wo man sieht dass die Heizung auch angegangen ist. Ich finde diesen Datenpunkt nicht. Kannst du das noch aufnehmen oder bin ich blind ??
      Gruß Dirk
      • C Offline
        Christian.B
        #98
        Die Heizung wird leider nicht ausgelesen.
        Die Daten der letzten 24h sowie 28Tagen wären auch schön.
        Seit der letzten FW 122 werden zusätzlich auch die Temp. sowie Feuchtigkeit bei intern eingebauten BMP(BME)280 angezeigt.
        Dies dient zur Kontrolle von Wassereinbrüchen ins Gehäuse. Wenn dieser Wert auch ausgelesen werden könnte, könnte man eine schöne, automatische Warnung bei Wassereinbruch skripten.
        viele Grüße
        Christian
        SegwayS 1 Antwort Letzte Antwort
        • C Christian.B
          SegwayS Offline
          SegwayS Offline
          Segway
          #99
          @Christian-B
          Ja, nur leider scheint der User @x4tlaoguo schon länger nicht online gewesen zu sein :-( Schade. Evtl. man ein Issue aufmachen ?!
          Gruß Dirk
          • W Offline
            W Offline
            weimaraner
            #100
            Ich habe seit geraumer Zeit das Problem, daß die Werte des Regenmengenmessers nicht in iobroker ankommen. Im weathermann werden sie richtig dargestellt.
            Ein update des Weatherman auf FW 107 und ein update des Adapters auf Version 2.1.4. haben leider kein Ergebnis gebracht.
            Hat jemand eine Idee?
            C 1 Antwort Letzte Antwort
            • W weimaraner
              Christian.B
              #101
              @weimaraner
              Mittlerweile gibt es die FW122.
              Ich hatte mit dieser FW anfangs das Problem, dass sich der WM regelmäßig um 6:30 aufgehangen hat.
              Nach downgrade auf FW121 und drei Tage später wieder update auf FW122 läuft das sehr stabil und es werden auch alle Werte ausgelesen und auch zu iobroker übertragen.
              viele Grüße
              Christian
                Sandmanyz
                schrieb am zuletzt editiert von Sandmanyz
                #102
                Ich habe die aktuelle Version 2.1.4 installiert und erhalte die Meldung "Could not create state null" obwohl das, lt. Änderungsprotokoll, behoben sein soll...
                Habe dann den Adapter nochmal entfernt und wieder hinzugefügt. Diese Einträge drei finde ich merkwürdig...
                Hat Jemand eine Idee was bei mir falsch läuft? Meine Weatherman Firmware ist 122.
                  Stefan Hanke
                  schrieb am zuletzt editiert von Stefan Hanke
                  #103
                  ...ich hatte das Problem mit den Datenpunkt im ioBroker auch. Bei irgendeinem Versionswechsel des WM sind die Datenpunkte 5 und 28 verändert, umbenannt worden.
                  Ich habe dann alle Datenpunkte (vom WM) im ioBroker gelöscht und nochmals neu aus dem WM über den Adapter (Version 2.1.4) geholt.
                  Seit dem sind die Datenpunkte so vorhanden, damit funktioniert das bei mir...
                    Sandmanyz
                    #104
                    Das funktioniert bei mir nicht. Folgendes habe ich getestet.
                    Erst einmal habe ich das getan...
                    1. Instanz "wiffi-wz.0" gestoppt
                    2. Alle Datenpunkte gelöscht
                    3. Instanz "wiffi-wz.0" gestartet
                    4. Es sieht wieder genauso aus wie in meinem Screenshot
                    Weil das keine Änderung gebracht hat, nochmal das hier...
                    3. Instanz "wiffi-wz.0" gelöscht
                    4. Adapter "wiffi-wz 2.1.4" gelöscht
                    5. Raspberry neu gestartet
                    6. Adapter wiffi-wz 2.1.4 installiert
                    7. IP vom Weatherman eingegeben (Port steht schon drin)
                    8. Einstellung gespeichert
                    9. Instanz "wiffi-wz.0" gestartet
                    10. Es sieht wieder genauso aus wie in meinem Screenshot
                    Liegt irgendwo im Dateisystem noch etwas was gelöscht werden muss/kann?
                    • S Sandmanyz
                      Stefan Hanke
                      #105
                      @Sandmanyz ...was mir noch einfällt, ich habe beim Weatherman ein Komplett-Update auf die 122 gemacht, kein Teil-Update...
                        Sandmanyz
                        #106
                        Ich habe auch das Komplett-Update (Methode 2) gemacht. Jetzt habe ich noch einmal das Komplett-Update gemacht und siehe da, es ist wie es soll. Die Meldung "Could not create state null" erscheint im Moment auch nicht mehr.
                        @Stefan-Hanke
                        Danke für deine Hilfe!👍
                        • S Sandmanyz
                          @Stefan-Hanke
                          Stefan Hanke
                          #107
                          @Sandmanyz
                          Gerne - perfekt, dass es jetzt passt...
                          • E Offline
                            ein.michael
                            #108
                            Hallo, hab seit kurzem den Weatherman im Betrieb, gleichzeitig auch direkt mit ioBroker verbunden.
                            Mir ist allerdings aufgefallen, dass das Aufrufen der Webseite des Weathermans teilweise extrem lange dauert.
                            Teilweise kommt es auch vor, dass sich der Weatherman scheinbar aufhängt, sprich über mehrere Stunden keine Daten an ioBroker liefert und die Übersicht des Weathermans nicht aufrufbar ist. Wenn ich dann vermehrt versuche auf die Übersicht zuzugreifen, dann fängt sich der Weatherman scheinbar irgendwann und liefert dann auch sofort Daten an ioBroker und mir wird die Übersicht angezeigt. Ein Neustart des Weatherman ist nicht erforderlich. Hab das Gefühl, als wenn der Controller in eine Art Ruhemodus geht, die wlan Verbindung wird allerdings dauerhaft beibehalten. Hat jemand ein ähnliches Problem und kann mir eventuell helfen?
                            • E ein.michael
                              SegwayS Offline
                              SegwayS Offline
                              Segway
                              #109
                              @ein-michael
                              Also bei mir läuft der Weatherman seit fast einem halben Jahr ohne Probleme. Habe die Version 104 am laufen.
                              Wiffi-wz Adapter läuft auch einwandfrei ohne Lücken (Version 2.1.4)
                              Daten werden in SQL gespeichert.
                              7Tage:
                              Gruß Dirk
