  3. Cloud Dienste
  4. Temperatur mit Alexa abfragen
    5.7k
81 Beiträge 23 Kommentatoren 25.7k Aufrufe 8 Beobachtet
  • sigi234S sigi234
    @TorbenNW
    Kannst du den Flow hochladen?
    TorbenNW
    @sigi234
            "id": "6910cfca.38536",
            "type": "tab",
            "label": "Temperaturansagen",
            "disabled": false,
            "info": ""
            "id": "ccf94307.cb036",
            "type": "amazon-echo-hub",
            "z": "6910cfca.38536",
            "port": "80",
            "enableinput": false,
            "x": 100,
            "y": 60,
            "wires": [
                    "213bb398.a065cc"
            "id": "213bb398.a065cc",
            "type": "amazon-echo-device",
            "name": "Temperatur Schlafzimmer",
            "topic": "",
            "x": 330,
            "y": 60,
            "wires": [
                    "f927e866.ddff48"
            "id": "f927e866.ddff48",
            "type": "ioBroker get",
            "name": "Lese Temperatur Schlafzimmer",
            "topic": "zigbee.0.00158d000323059c.temperature",
            "attrname": "payload",
            "payloadType": "value",
            "x": 590,
            "y": 60,
            "wires": [
                    "946af687.5b5738"
            "id": "946af687.5b5738",
            "type": "function",
            "name": "Temperatur auslesen",
            "func": "var str = msg.payload;\nvar res = str.substr(0, 5);\nmsg.payload = Math.round(res);\nmsg.payload = \"Es sind \" + msg.payload + \" Grad im Schlafzimmer\";\nmsg.url = \"\";\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "x": 840,
            "y": 60,
            "wires": [
                    "d111d86b.a19228",
                    "2815dbba.74d3a4"
            "id": "2815dbba.74d3a4",
            "type": "ioBroker out",
            "name": "speak",
            "topic": "alexa2.0.Echo-Devices.G090U6109186088H.Commands.speak",
            "ack": "false",
            "autoCreate": "false",
            "x": 1030,
            "y": 60,
            "wires": []
            "id": "d111d86b.a19228",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "x": 1040,
            "y": 140,
            "wires": []
    Nutze das ganze mit dem "node-red-contrib-amazon-echo" Node
    • T TorbenNW
      @sigi234
              "type": "tab",
              "disabled": false,
              "info": ""
              "port": "80",
              "x": 100,
              "y": 60,
              "wires": [
                      "213bb398.a065cc"
              "topic": "",
              "x": 330,
              "y": 60,
              "wires": [
                      "f927e866.ddff48"
              "x": 590,
              "y": 60,
              "wires": [
                      "946af687.5b5738"
              "type": "function",
              "outputs": 1,
              "noerr": 0,
              "x": 840,
              "y": 60,
              "wires": [
                      "d111d86b.a19228",
                      "2815dbba.74d3a4"
              "name": "speak",
              "ack": "false",
              "x": 1030,
              "y": 60,
              "wires": []
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "x": 1040,
              "y": 140,
              "wires": []
      sigi234S Online
      sigi234S Online
      #66
      @TorbenNW
      Danke, irgendwie sagt er mir die Temp nicht an..................
      • sigi234S sigi234
        @TorbenNW
        TorbenNW
        #67
        @sigi234
        Hast du die entsprechenden Datenpunkte geändert?
        Was steht rechts im Debug-Fenster?
        • T TorbenNW
          @sigi234
          sigi234S Online
          sigi234S Online
          #68
          @TorbenNW sagte in Temperatur mit Alexa abfragen:
          @sigi234
          • Ja
          • Nichts
          • sigi234S sigi234
            @sigi234
            • Ja
            • Nichts
            TorbenNW
            #69
            @sigi234
            Temperatur Bad findet Alexa aber als neues Gerät?
            Und eine Routine zu dem Gerät hast du auch erstellt?
            • T TorbenNW
              @sigi234
              sigi234S Online
              sigi234S Online
              #70
              @sigi234
              Ja, Ja, aber in der App ist es als Licht drinnen?
              • sigi234S sigi234
                @sigi234
                TorbenNW
                #71
                @sigi234
                Das ist normal da der Local Node eine Philips Hue bridge imitiert
                • T TorbenNW
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  #72
                  @sigi234
                  Aha, danke wieder was gelernt..........
                  • AphofisA Aphofis
                    @BBTown
                    Habe ich geändert!
                    nur wenn ich den wert im Sonoff Sensor von State auf number oder float ändere ist in der übersicht die Temperatur verschwunden. Setzte ich es zurück auf State ist die Temperatur wieder da.
                    Alles weitere teste ich Morgen.
                    MyMeyer
                    #73
                    @Aphofis sagte in Temperatur mit Alexa abfragen:
                    @BBTown
                    Habe ich geändert!
                    Hi @BBTown , konntest Du dein Problem lösen , weil aktuell stehe ich bei dem gleichen Problem !
                    Alexa sagt das das Gerät Temperatur nicht unterstützt, obwohl im Objekt der der Wert "18Grad" steht.
                    Hier im Thread habe ich keine Lösung von Dir gefunden,deswegen meine Nachfrage. 😉
                    MyMeyer
                    >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                    >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                    BBTownB 1 Antwort Letzte Antwort
                    • M MyMeyer
                      @BBTown
                      Habe ich geändert!
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      schrieb am zuletzt editiert von BBTown
                      #74
                      @MyMeyer
                      Du hast ein Zitat von mir zitiert, ich habe gar keine "Sonoff Sensoren", sondern ausschließlich HomeMatic :-)
                      Mit denen kann ich allerdings die Temperaturen abfragen (Datenpunkt ACTUAL_TEMPERATURE)
                      "Alexa, wie ist die Temperatur in <RaumName>"
                      Folgendes muss hierzu unter anderem im Datenpunkt (RAW) gesetzt sein:
                      "type":  "number"
                      "unit": "°C"
                      "role": "value.temperature"
                      "min": -10
                      "max": 56
                      "write": "true"
                      "read": "true"
                      "smartName": {
                          "de": "RaumName",
                          "smartType": "THERMOSTAT"
                      • K karstent
                        Also ich habe meine Xiaomi Temperatur Sensoren einfach nur im Cloud-Adapter hinzugefügt ,bei "Typ" Thermostat ausgewählt, dem einen smarten Namen verpasst ( z.B. Temperatur Wohnzimmer ) Und nach einem neuem Device update konnte ich meine Alexa fragen "wie ist die temperatur im Wohnzimmer" und bekam daraufhin die Antwort " die temperatur im Wohnzimmer beträgt 20 Grad".
                        So habe ich das nun mit all meinen Xiaomi Sensoren gemacht. Was so nicht funktioniert ist die Abfrage der Luftfeuchtigkeit.
                        Greg-nrw
                        #75
                        @karstent sagte in Temperatur mit Alexa abfragen:
                        danke
                        Jetzt funktioniert die Abfrage der Temperatur zu hause.
                        • dslraserD dslraser
                          Temperaturen kann der iot / cloud Adapter eigentlich auch ohne Script (nur Luftfeuchtigkeit nicht)
                          Aber das hier, so in der Art als Vorschlag, sollte dann auch Minus ansagen. Ich konnte es noch nicht mit einem richtigen Sensor prüfen, da es bei mir heute keine Minusgrade sind.
                          (ich habe mal einen eigenen Datenpunkt mit negativen Temperaturdaten erstellt, da funktioniert es)
                          Ralf
                          #76
                          @dslraser sagte in Temperatur mit Alexa abfragen:
                          ich krieg´s nicht hin, dass Alexa mir das Komma bei der Temp.-Ansage nennt. Sie sagt : Es sind einundzwanzig sechs Grad. Könntest du mir bitte auf die Sprünge helfen ?
                          Mein Blockly :
                          sigi234S dslraserD 2 Antworten Letzte Antwort
                          • R Ralf
                            Mein Blockly :
                            sigi234S Online
                            sigi234S Online
                            #77
                            @Ralf sagte in Temperatur mit Alexa abfragen:
                            https://forum.iobroker.net/topic/27583/pop-up-an-tv-senden-via-alexa/9
                            • R Ralf
                              Mein Blockly :
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #78
                              @Ralf
                              Ich nutze aktuell ssml für meine Ansagen. Aus dem Kopf weiß ich gerade nicht was bei speak geändert werden muss. Es könnte sein das es nur ein Leerzeichen vor und nach dem Temperaturwert ist. Also hinter Garten und vor Grad.
                              Ansonsten hier ssml
                              https://forum.iobroker.net/post/273896
                              R 1 Antwort Letzte Antwort
                                @Ralf
                                Ansonsten hier ssml
                                Ralf
                                #79
                                @dslraser Super, mit speak und den beiden Leerstellen funktioniert es. Wenn ich allerdings statt "Speak" "SSML" wähle, sagt Alexa nichts. Hast du eine Idee, was ich da ändern müsste ?
                                • R Ralf
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #80
                                  Ja, das ganze Blockly 😀
                                  Siehe meinen Link.
                                    Siehe meinen Link.
                                    Ralf
                                    #81
                                    Siehe meinen Link.
                                    Das überfordert mich im Moment etwas. Muss ich mich mal in Ruhe mit beschäftigen. Aber vielen Dank erstmal für deinen Tipp mit der Komma Ansage.
