  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 529.3k Aufrufe 93 Beobachtet
  • liv-in-skyL liv-in-sky
    @thewhobox
    10:37:35.317	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
    10:37:35.319	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:35.318	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:35.324	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:35.335	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:35.335	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
    10:37:35.335	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
    10:37:35.608	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: login war erfolgreich! Mit Cookies
    10:37:35.616	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
    10:37:35.616	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: undefined
    10:37:37.334	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
    10:37:37.373	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:37.391	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
    10:37:37.391	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
    10:37:37.391	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
    10:37:37.646	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: login war erfolgreich! Mit Cookies
    10:37:37.656	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
    10:37:37.656	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: undefined
    thewhoboxT Offline
    thewhoboxT Offline
    thewhobox
    #411
    @liv-in-sky Boah ich hasse es, dass da keine Fehlermeldungen kommen.....
    Glaub aber hab den Fehler gefunden. Kurz die Zeilen ergenzen.
    dlog("got response " + JSON.stringify(resp));
    dlog(typeof resp);
    resp = JSON.parse(resp);
    dlog(resp.meta);
    dlog(resp.meta.rc);
    Meine Adapter: emby | discovery
      @thewhobox
      dslraserD Offline
      dslraserD Offline
      dslraser
      #412
      @liv-in-sky
      ich spare mir jetzt die gleichen Logs, sieht bei mir genau so aus. Nur wenn ich andere Ergebnisse bekomme sage ich Bescheid
      • thewhoboxT thewhobox
        dlog(typeof resp);
        dlog(resp.meta);
        dlog(resp.meta.rc);
        dslraserD Offline
        dslraserD Offline
        dslraser
        #413
        @thewhobox
        javascript.0 script.js.Heiko.Unifi.unifi_wifi: WLAN ist: an
        • dslraserD dslraser
          @thewhobox
          liv-in-skyL Offline
          liv-in-skyL Offline
          #414
          @dslraser dito
            @thewhobox
            liv-in-skyL Offline
            liv-in-skyL Offline
            #415
            @dslraser
            schalten sich bei dir auch alle netzwerke ab und an - nicht nur das gäste netzwerk - es scheint. als ob unifi einen restart macht nach dem setting
            schalte ich mit script gästenetzwerk ein - werden beide netze restartet und das gästenetzwerk ist an - hauptnetz ist an
            schalte ich mit script gästenetzwerk aus- werden beide netze restartet und das gästenetzwerk ist aus - hauptnetz ist an
              @dslraser
              dslraserD Offline
              dslraserD Offline
              dslraser
              #416
              @liv-in-sky
              ja, das ist leider so, weil dann komplett neu Provisioniert wird.
                @dslraser
                dslraserD Offline
                dslraserD Offline
                dslraser
                #417
                @liv-in-sky sagte in Adapter: ioBroker.unifi:
                achso, wenn ich ein WLAN, egal welches an oder ausschalte wird neu provisioniert, aber das nicht ausgeschaltete kommt dann nach dem provisionieren wieder. Nur verlieren alle Geräte kurz die Verbindung...zu mindestens der Rechner an dem ich gerade binn, dauert nur immer einen Moment
                • liv-in-skyL Offline
                  liv-in-skyL Offline
                  #418
                  @thewhobox
                  vielen vielen dank für deine zeit, die du investiert hast - wenn es deine zeit und lust erlaubt wäre noch ein zusätzliche info hilfreich:
                  wäre es möglich eine liste der angemeldeten geräte zu bekommen
                  mehr info würde ich garnicht brauchen
                  wenn das zu unverschämt ist, auch kein thema - bin froh, dass das was wir jetzt haben, funktioniert
                  thewhoboxT 1 Antwort Letzte Antwort
                  • dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #419
                    @thewhobox
                    Ja, von mir auch ein herzlichen Dank für Deine Mühe.
                    Dem Wunsch von @liv-in-sky würde ich mich anschließen. Das sind bei mir auch alle Daten die ich bräuchte.
                      @thewhobox
                      thewhoboxT Offline
                      thewhoboxT Offline
                      thewhobox
                      #420
                      @liv-in-sky Gerne doch.
                      Ich schau mir nachher mal das verlinkte Skript an ob die das haben. Wenn ja, dann kann ich das mit einbauen.
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #421
                        @thewhobox
                        @liv-in-sky
                        ich habe noch eine Frage, für Euch wahrscheinlich simpel. Wie bekomme ich jetzt den Status des WLAN aus dem Log in einen eigenen Datenpunkt ?
                        Ich habe mir drei Datenpunkte in das Script eingebaut. Schalten funktioniert.👍
                        Aber wie mache ich das mit dem Status aus dem Log
                        on({id:'javascript.0.Eigene_Datenpunkte.25Unifi_Wifi.02wifi_an'/*Unifi Wifi an*/, val: true, change: 'any'}, wifi_an);
                        on({id:'javascript.0.Eigene_Datenpunkte.25Unifi_Wifi.03wifi_aus'/*Unifi Wifi aus*/, val: true, change: 'any'}, wifi_aus);
                        //Datenpunkt für Wifi Status erstellen
                        createState("Eigene_Datenpunkte.25Unifi_Wifi.01wifi_Status",'nicht bekannt', {
                            name: 'Unifi Wifi Status',
                            role: 'string',
                            read:  true,
                            write: true,
                        //Datenpunkt Button für Wifi an erstellen
                        createState("Eigene_Datenpunkte.25Unifi_Wifi.02wifi_an", {
                            name: 'Unifi Wifi an',
                            role: 'button',
                            read:  true,
                            write: true,
                            type: "boolean",
                            "smartName": {
                            "de": "02Gäste Wlan an",
                            "smartType": "SWITCH"
                        //Datenpunkt Button für Wifi aus erstellen
                        createState("Eigene_Datenpunkte.25Unifi_Wifi.03wifi_aus", {
                            name: 'Unifi Wifi aus',
                            role: 'button',
                            read:  true,
                            write: true,
                            type: "boolean",
                            "smartName": {
                            "de": "03Gäste Wlan aus",
                        const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                        const unifi_username = "xxx";
                        const unifi_password = "xxx";
                        const unifi_controller = "https://192.168.xxx.xxx:xxx";
                        const wifi_id = "xxxxxxxxxxxx";
                        let cookies = [];
                        let loggedIn = false;
                        let debug = true;
                        function dlog(message) {
                           if(debug)
                               console.log(message);
                        async function login() {
                           return new Promise(async (resolve, reject) => {
                               let resp = await request.post({
                                   resolveWithFullResponse: true,
                                   url: unifi_controller + "/api/login",
                                   body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                                   headers: { 'Content-Type': 'application/json' }
                               }).catch((e) => { dlog("login: reject"), reject(e) });
                               if(resp != null) {
                                   dlog("login: login war erfolgreich! " + ((resp.headers && resp.headers.hasOwnProperty("set-cookie")) ? "Mit Cookies":"Ohne Cookies"));
                                   if(resp.headers && resp.headers.hasOwnProperty("set-cookie")) {
                                       let set_cookies = resp.headers["set-cookie"];
                                       for(i = 0; i < set_cookies.length; i++) {
                                           let cookie = set_cookies[i];
                                           cookie = cookie.split(";")[0];
                                           cookies.push(cookie);
                                   } else {
                                       dlog("login: no cookies to set!")
                                   loggedIn = true;
                                   resolve();
                               } else {
                                   dlog("login: rejected")
                                   reject("resp = null");
                        async function getStatus() {
                                dlog("nur mal so");
                                if(!loggedIn) await login().catch((e) => reject(e));
                                let resp = await request.get({
                                    url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                                    headers: { Cookie: cookies.join("; ") }
                                }).catch((e) => { dlog("getStatus reject " + e); reject(e) });
                                dlog(typeof resp);
                                dlog(resp.meta);
                                dlog(resp.meta.rc);
                                let wlanOn = resp.data[0].enabled;
                                dlog("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                if(resp != null && resp.meta && resp.meta.rc == "ok") {
                                    dlog("Status erfolgreich geholt!");
                                    dlog(resp);
                                    resolve(wlanOn);
                                } else {
                                    dlog("nicht ok...")
                                    reject(JSON.stringify(resp));
                        async function setWifi(enabled) {
                               dlog("setWifi: start set wifi");
                               if(!loggedIn) { dlog("need to login"); await login().catch((e) => reject(e)); }
                               dlog("setWifi: now setting wifi");
                               let resp = request.post({
                                   url: unifi_controller + "/api/s/default/upd/wlanconf/" + wifi_id,
                                   body: JSON.stringify({ enabled }),
                                   headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                               }).catch((e) => { dlog("setWifi: rejected: " + e); reject(e) });
                               dlog("setWifi: got response")
                               if(resp != null) {
                                   dlog("setWifi: Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                   dlog(resp);
                                   resolve();
                               } else {
                                   dlog("setWifi: rejetced")
                                   dlog("resp: " + JSON.stringify(resp));
                                   reject("msg: " + JSON.parse(resp.body).meta.msg);
                        async function wifi_an() {
                            dlog("starting wifi_an");
                            await setWifi(true).catch((e) => dlog("reject1: " + e));
                            dlog("getting status");
                            let wlan = await getStatus().catch((e) => dlog("reject2: " + e));
                            console.log("fin")
                            console.log(wlan);
                        async function wifi_aus() {
                            dlog("starting wifi_aus");
                            await setWifi(false).catch((e) => dlog("reject1: " + e));
                            console.log("fin")
                            console.log(wlan);
                        //wifi_an();
                        //wifi_aus();
                        getStatus();
                        Hier die Datenpunkte, die Zahlen sind nur drinn, damit es zu meiner "Struktur" passt.
                        thewhoboxT liv-in-skyL 2 Antworten Letzte Antwort
                          @thewhobox
                          @liv-in-sky
                              role: 'string',
                              read:  true,
                              write: true,
                              role: 'button',
                              read:  true,
                              write: true,
                              type: "boolean",
                              "smartName": {
                              role: 'button',
                              read:  true,
                              write: true,
                              type: "boolean",
                              "smartName": {
                          let cookies = [];
                          let debug = true;
                             if(debug)
                                 if(resp != null) {
                                     } else {
                                     loggedIn = true;
                                     resolve();
                                 } else {
                                  dlog("nur mal so");
                                  dlog(typeof resp);
                                  dlog(resp.meta);
                                  dlog(resp.meta.rc);
                                      dlog(resp);
                                      resolve(wlanOn);
                                  } else {
                                      dlog("nicht ok...")
                                 if(resp != null) {
                                     dlog(resp);
                                     resolve();
                                 } else {
                              console.log("fin")
                              console.log(wlan);
                              console.log("fin")
                              console.log(wlan);
                          //wifi_an();
                          //wifi_aus();
                          getStatus();
                          thewhoboxT Offline
                          thewhoboxT Offline
                          thewhobox
                          #422
                          @dslraser Für Status wäre ein Intervall gut:
                          setInterval(async () => {
                              let state = await getStatus();
                              setState("Eigene_Datenpunkte.25Unifi_Wifi.01wifi_Status", state, true);
                          }, 10000); // Aktualisiert alle 10 Sekunden.
                          Und für die Buttons:
                          on("Eigene_Datenpunkte.25Unifi_Wifi.02wifi_an", (state) => {
                              setWifi(true);
                          on("Eigene_Datenpunkte.25Unifi_Wifi.02wifi_aus", (state) => {
                              setWifi(false);
                            @thewhobox
                            @liv-in-sky
                                role: 'string',
                                read:  true,
                                write: true,
                                role: 'button',
                                read:  true,
                                write: true,
                                type: "boolean",
                                "smartName": {
                                role: 'button',
                                read:  true,
                                write: true,
                                type: "boolean",
                                "smartName": {
                            let cookies = [];
                            let debug = true;
                               if(debug)
                                   if(resp != null) {
                                       } else {
                                       loggedIn = true;
                                       resolve();
                                   } else {
                                    dlog("nur mal so");
                                    dlog(typeof resp);
                                    dlog(resp.meta);
                                    dlog(resp.meta.rc);
                                        dlog(resp);
                                        resolve(wlanOn);
                                    } else {
                                        dlog("nicht ok...")
                                   if(resp != null) {
                                       dlog(resp);
                                       resolve();
                                   } else {
                                console.log("fin")
                                console.log(wlan);
                                console.log("fin")
                                console.log(wlan);
                            //wifi_an();
                            //wifi_aus();
                            getStatus();
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #423
                            @dslraser
                            mensch seit ihr schnell - wollte gerade beginnen ein eigenes script zu machen - werd wohl das von dir klauen :-)
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #424
                              falls Jemand Interesse an dem Script hat, hier geht es damit weiter.
                              https://forum.iobroker.net/topic/24737/unifi-wlan-script
                                aikonflo
                                #425
                                wie habt ihr das gemacht das der Adapter bei euch läuft ?
                                Oder liegt das wirklich nur am USG und das habt Ihr nicht ?
                                mfg Flo
                                • I Offline
                                  I Offline
                                  ikkerus
                                  #426
                                  Moin zusammen,
                                  Danke für dieses Tolle Projekt, diesen Adapter zu entwickeln. Bin gerade dabei, mir meinen ersten iobroker aufzusetzen und erstmal die Adapter zu verbinden. Beim UniFi Adapter scheitere ich damit.
                                  Leider erhalte trotz Eingabe der korrekten Zugangsdaten eine Fehlermeldung:
                                  unifi.0	2019-10-10 11:18:45.806	info	ERROR: api.err.Invalid
                                  unifi.0	2019-10-10 11:18:44.062	info	controller = 10.7.1.25:8443
                                  unifi.0	2019-10-10 11:18:44.062	info	update_interval = 60
                                  unifi.0	2019-10-10 11:18:44.061	info	Starting UniFi-Controller query
                                  unifi.0	2019-10-10 11:18:44.037	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v10.16.0
                                  CloudKey Gen1 Firmware: 1.1.0
                                  Controller Software: 5.11.46-12723-1
                                  Somit werden natürlich die UniFi-Devices nicht erkannt. Hat jemand eine Idee?
                                  Danke!
                                  BBTownB SunshinemakerS 2 Antworten Letzte Antwort
                                  • I ikkerus
                                    Moin zusammen,
                                    Danke!
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    schrieb am zuletzt editiert von BBTown
                                    #427
                                    Moin @ikkerus,
                                    ich habe zwar keine direkte Hilfe für dein Problem, jedoch fand ich immer, dass der Adapter derartig viele Informationen liefert, dass ich diesen für mich als eher hinderlich und weniger nützlich empfand.
                                    Ich würde dir daher alternativ empfehlen einmal in diesem Thread zur UniFi-Steuerung mitzulesen
                                    • I Offline
                                      I Offline
                                      ikkerus
                                      #428
                                      Moin @BBTown ,
                                      Danke für deinen Tipp. Ich möchte ja auch nicht alle Informationen auf dem iPad, was ich an die Wand hänge Visualisieren. Mir würde es letztlich reichen, den max. Downstream/Upstream (der von UniFi regelmäßig getestet wird) anzugeben und anzuzeigen, ob ich online oder offline bin.
                                      Ich habe nach der Image-Installation noch kein Betriebssystem-Update gemacht. Kann es daran liegen?
                                      BBTownB liv-in-skyL 3 Antworten Letzte Antwort
                                      • I ikkerus
                                        Moin @BBTown ,
                                        BBTownB Offline
                                        BBTownB Offline
                                        BBTown
                                        #429
                                        @ikkerus
                                        Mit dem Adapter würdest Du - je nach Umfang deiner UniFi Umgebung tausende Datenpunkte erhalten .... ob allerdings der Up/downstream dabei war, weiss ich nicht mehr.
                                        Das System sollte natürlich aktuell sein.
                                        was spucken denn diese Befehle auf der Konsole aus?
                                        nodejs -v
                                        npm -v
                                        node zeigt bei dir in deinem Post zumindest schon mal die aktuell empfohlene Version v10.16.0 an
                                        • I ikkerus
                                          Moin @BBTown ,
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          #430
                                          @ikkerus und den "fixer" solltest Du auch einmal drüber laufen lassen
                                          curl -sL https://iobroker.net/fix.sh | bash -
