  4. [Aufruf] G-Homa Adapter testen
    apollon77A
177 Beiträge 27 Kommentatoren 64.1k Aufrufe 3 Beobachtet
  • R
    R
    RichieXX
    schrieb am zuletzt editiert von RichieXX
    #167
    @AlCalzone sagte in [Aufruf] G-Homa Adapter testen:
    DEBUG=g-homa node main.js --force --logs
    root@iobroker:~# cd /opt/iobroker/node_modules/iobroker.g-homa/build
    root@iobroker:/opt/iobroker/node_modules/iobroker.g-homa/build# DEBUG=g-homa node main.js --force --logs
    starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.g-homa, node: v8.16.0
    enumerating known plugs...
    found plug with id 85215c (offline)
    starting server...
    server started on port 55555
    searching plugs
      g-homa connection from ::ffff:192.168.253.39 +0ms
      g-homa connection from ::ffff:192.168.253.39 +2s
      g-homa invalid data in the receive buffer +27s
      g-homa ff000e8146000080005f00012a07055c63fe +0ms
    Error: invalid data in the receive buffer
        at parseMessage (/opt/iobroker/node_modules/g-homa/build/server.js:62:15)
        at Socket.<anonymous> (/opt/iobroker/node_modules/g-homa/build/server.js:210:26)
        at emitOne (events.js:116:13)
        at Socket.emit (events.js:211:7)
        at addChunk (_stream_readable.js:263:12)
        at readableAddChunk (_stream_readable.js:250:11)
        at Socket.Readable.push (_stream_readable.js:208:10)
        at TCP.onread (net.js:601:20)
    unhandled exception:invalid data in the receive buffer
    > stack: Error: invalid data in the receive buffer
    Das kommt, wenn der Plug im WLAN erreichbar ist:
    starting server...
    searching plugs
      g-homa connection from ::ffff:192.168.253.25 +573ms
      g-homa unknown plug type detected. triggercode is 0x346b +164ms
      g-homa the full payload was: 0x010ac0346b85215c01ff +1ms
      g-homa connection from ::ffff:192.168.253.39 +1s
    Added plug with ID 85215c
      g-homa got update: 010ae0346b85215cfffe01811100000100000000 +889ms
    Got updated info for Plug 85215c:
      state: off
      switched from: local
      type: undefined
    extendPlug: type = undefined, energyMeasurement != null: true
    current != null: false
    powerFactor != null: false
    power != null: false
    voltage != null: false
    voltage in plug.energyMeasurement => false
    current in plug.energyMeasurement => false
    power in plug.energyMeasurement => false
    powerFactor in plug.energyMeasurement => false
      g-homa invalid data in the receive buffer +49s
      g-homa ff00020103feff000e8146000080005f00012a07055c63fe +1ms
    • R RichieXX
      starting server...
      searching plugs
      starting server...
      searching plugs
        state: off
        type: undefined
      AlCalzoneA
      AlCalzoneA
      AlCalzone
      #168
      @RichieXX Danke. Ich habe die Vermutung, dass es hier Konflikte mit einem anderen Gerät gibt. Du kannst mir helfen, heraus zu finden, wie das reagiert, damit ich die automatische Erkennung im Adapter verbessern kann.
      Dazu tue bitte folgendes:
      1. Konsole öffnen, cd /opt/iobroker/node_modules/g-homa/build
      2. node serial.js
      3. Gebe eine der IPs ein: 192.168.253.39 oder 192.168.253.25, [ENTER]
      4. Gebe ein: HF-A11ASSISTHREAD, dann [ENTER]
      5. Wenn eine Antwort kommt, gebe (relativ zügig) ein +ok, dann [ENTER]
      6. Gebe bitte nacheinander die folgenden Kommandos ein, jeweils gefolgt von [ENTER]. Wenn eine Antwort kommt, bitte hier posten:
        • AT+MID\r
        • AT+VER\r
        • AT+LVER\r
      7. Wiederhole das ganze für die andere IP-Adresse. Das Programm kannst du jeweils per STRG+C beenden.
      • R
        R
        RichieXX
        #169
        AT+LVER\r
        Aber gerne!
        Vorab als Info: Die IP ..39 ist ein MiLight LED Controller (YL5)
        root@iobroker:~# cd /opt/iobroker/node_modules/g-homa/build
        root@iobroker:/opt/iobroker/node_modules/g-homa/build# node serial.js
        G-Homa command line serial interface ready...
        Which IP to talk to? [default: Broadcast IP] 192.168.253.39
        talking to 192.168.253.39. enter "QUIT" to return to IP selection
        192.168.253.39 > HF-A11ASSISTHREAD
        192.168.253.39: 192.168.253.39,98D863080AB0,HF-LPT230
        192.168.253.39 > +ok
        192.168.253.39 > AT+MID\r
        192.168.253.39: +ok=HF-LPT230
        192.168.253.39 > AT+VER\r
        192.168.253.39: +ok=4.12.15 (2018-12-04 13:30 1M)
        192.168.253.39 > AT+LVER\r
        192.168.253.39 >
        Mit der ..25 (Das ist der einzige G-Home Plug den ich habe):
        Which IP to talk to? [default: Broadcast IP] 192.168.253.25
        talking to 192.168.253.25. enter "QUIT" to return to IP selection
        192.168.253.25 > HF-A11ASSISTHREAD
        192.168.253.25: 192.168.253.25,F0FE6B85215C,G-Homa
        192.168.253.25 > +ok
        192.168.253.25 > AT+MID\r
        192.168.253.25: +ok=G-Homa
        192.168.253.25 > AT+VER\r
        192.168.253.25: +ok=GAO,Outdoor,1.8.26
        192.168.253.25 > AT+LVER\r
        192.168.253.25: +ok=08 (2015-06-05 11:12 16B)
        Wenn ich das also richtig verstehen, wird irgendwie der MiLight hier versuch mit einzubinden und dabei kommt es verständlicherweise zu Kommunikationsproblemen. Korrekt?
        • R RichieXX
          AT+LVER\r
          Aber gerne!
          192.168.253.39 >
          AlCalzoneA
          AlCalzoneA
          AlCalzone
          #170
          @RichieXX Genau da liegt der Hase im Pfeffer. Bisher hatte nur noch keiner den Fall, dass gleich beides im selben Netzwerk hängt.
          Ich versuche bei Gelegenheit nochmal zu schauen, wie sich meine schon etwas ältere Dose ausgibt. Dann kann ich hoffentlich vermeiden, dass das MiLight mit dem G-Homa-Adapter spricht.
          Du wirst dich leider ein paar Tage gedulden müssen.
          • R
            R
            RichieXX
            #171
            Kein Problem. Mit dem Plug wird der Weihnachtsbaum geschaltet... 😁
            • R RichieXX
              AlCalzoneA
              AlCalzoneA
              AlCalzone
              #172
              @RichieXX Probiere bitte mal die Version 0.5.0. Es kann sein, dass du dein MiLight vorher zurücksetzen musst.
              • R
                R
                RichieXX
                #173
                Das ging dann doch schneller, wie ich erwartet habe 🙂
                Hab die 0.5.0 installiert und der Fehler tritt weiterhin auf (ohne Reset des Milight).
                Warum muss ich den Milight zurücksetzen? Reicht es wenn, ich dem eine neue IP verpasse?
                Das ist die Ausgabe mit 0.5.0 (Ich hab nach dem "ERR" nicht weitergemacht):
                192.168.253.39: +ERR=-1
                192.168.253.39 >
                starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.g-homa, node: v8.16.0
                starting server...
                searching plugs
                  g-homa connection from ::ffff:192.168.253.25 +0ms
                  g-homa unknown plug type detected. triggercode is 0x346b +220ms
                  g-homa the full payload was: 0x010ac0346b85215c01ff +0ms
                  g-homa connection from ::ffff:192.168.253.39 +206ms
                  g-homa got update: 010ae0346b85215cfffe01811100000100000000 +2s
                  state: off
                  type: undefined
                  g-homa connection from ::ffff:192.168.253.25 +972ms
                  g-homa unknown plug type detected. triggercode is 0x346b +43ms
                  state: off
                  type: undefined
                  g-homa ff00020103feff000e814600008000000000000705d299fe +0ms
                    at parseMessage (/opt/iobroker/node_modules/iobroker.g-homa/node_modules/g-homa/build/server.js:62:15)
                    at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.g-homa/node_modules/g-homa/build/server.js:210:26)
                • R RichieXX
                  192.168.253.39 >
                  starting server...
                  searching plugs
                    state: off
                    type: undefined
                    state: off
                    type: undefined
                  AlCalzoneA
                  AlCalzoneA
                  AlCalzone
                  #174
                  @RichieXX sagte in [Aufruf] G-Homa Adapter testen:
                  Weil der weiterhin denkt, er muss mit dem G-Homa-Adapter reden. Die Einstellung bekommst du nur mit einem Reset wieder weg.
                  • R
                    R
                    RichieXX
                    #175
                    Tut mie leid. Auch ein Reset hat keine Wirkung (ich habe angenommen, dass das drücken der Taste SET für 3s - Wiedereinbinden ins WLAN, ein Reset bedeutet, was anderes konnte ich nicht finden)
                    • R RichieXX
                      AlCalzoneA
                      AlCalzoneA
                      AlCalzone
                      #176
                      @RichieXX Schau mal hier:
                      1. Mi-Light WLAN Controller mit Spannung versorgen, die LED SYS blinkt. Der Mi-Light WLAN Controller arbeitet in den Werkseinstellungen als Access-Point Ein Werksreset kann durchgeführt werden, in dem der Reset Knopf 10 Sekunden lang gedrückt wird bis die beiden LEDs Link und SYS blinken.
                      2. Mit dem Smart Phone nach dem WLAN Netz milight suchen und verbinden. Wird das WLAN milight nicht gefunden, muss ein Werksreset durchgeführt werden.
                      3. App starten und die Systemkonfiguration durchführen (Einbindung in eigenes WLAN).
                      • R
                        R
                        RichieXX
                        #177
                        Es betrifft nicht die iBox2 sondern den neuen Milight Controller (https://milight.pro/manuals/YL5_EN.pdf) und ich denke ich habe den richtig zurückgesetzt. Ich habe leider auch nicht mehr so viel Zeit, denn das Teil geht wieder zurück (der iobroker-milight-adapter unterstützt den YL5 nicht). Ich verwende dann den gleichen Controller ohne WLAN. Dieser wird dann an die iBox2 angebunden. Davon habe ich zwei Stück im WLAN und die machen keine Probleme mit dem g-homa Adapter.
                        84.0k
