  4. Node-Red
  5. Temperaturen über Node RED und Alexa abfragen!
    6.4k
109 Beiträge 15 Kommentatoren 21.6k Aufrufe 15 Beobachtet
  • FenianF Fenian
    Und während ich hier so mit Screenshots um mich schmeisse, fällt mir wieder ein, dass es einfacher gewesen wäre den Flow zu exportieren und hier zu posten.
            "id": "3ff22dd8.7fec9a",
            "type": "tab",
            "label": "Temperaturansagen",
            "disabled": false,
            "info": ""
            "id": "ffc59ffe.a9a58",
            "type": "amazon-echo-hub",
            "z": "3ff22dd8.7fec9a",
            "port": "80",
            "enableinput": false,
            "x": 100,
            "y": 64,
            "wires": [
                    "60cd043e.a012ec"
            "id": "60cd043e.a012ec",
            "type": "amazon-echo-device",
            "name": "Temperatur Schlafzimmer",
            "topic": "",
            "x": 330,
            "y": 64,
            "wires": [
                    "880ed474.c7dfb8",
                    "7cb2ff99.6c53d"
            "id": "880ed474.c7dfb8",
            "type": "ioBroker get",
            "name": "serialNumber",
            "topic": "alexa2.0.History.serialNumber",
            "attrname": "payload",
            "payloadType": "value",
            "x": 565,
            "y": 64,
            "wires": [
                    "af872fed.2e36d"
            "id": "7cb2ff99.6c53d",
            "name": "Raumklima Schlafzimmer temperature",
            "topic": "deconz.0.Sensors.39.temperature",
            "x": 633.5,
            "y": 111,
            "wires": [
                    "af872fed.2e36d"
            "id": "af872fed.2e36d",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "array",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": false,
            "timeout": "",
            "count": "2",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 880,
            "y": 65,
            "wires": [
                    "5517ab3.6b2e7d4"
            "id": "5517ab3.6b2e7d4",
            "type": "function",
            "name": "Temperatur auslesen",
            "func": "var device = msg.payload[0]\nvar str = msg.payload[1];\nvar res = str.substr(0, 5);\nmsg.payload = Math.round(res);\nmsg.payload = \"Es sind \" + msg.payload + \" Grad im Schlafzimmer\";\nmsg.url = \"\";\nvar command = \"alexa2.0.Echo-Devices.\" + device + \".Commands.speak\"\nmsg.topic = command;\nreturn msg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 1053,
            "y": 65,
            "wires": [
                    "90bca55d.0d3348"
            "id": "90bca55d.0d3348",
            "type": "ioBroker out",
            "name": "speak",
            "topic": "",
            "ack": "false",
            "autoCreate": "false",
            "x": 1224.5,
            "y": 65,
            "wires": []
    Naja, manchmal hat man ein Brett vorm Kopf 😕
    LaBamba
    schrieb am zuletzt editiert von LaBamba
    @Fenian
    danke für die Arbeit. Vor einigen Tagen hatte ich dieses Thema begonnen.
    Ich habe jetzt deinen Flow eingefügt.
    Ich bekomme immer von Alexa die Antwort ECHO2 Schlafzimmer unterstützt das nicht!
    An was könnte dies liegen?
    Ich nehme an du hast einen der ECHO3???
    Zudem bekomme ich folgende Fehlermeldung!
    FenianF 1 Antwort Letzte Antwort
    • ostseereiterO ostseereiter
      @Fenian ich habe erst mal dein Flow übernommen soweit läuft es auch nur manchmal wenn ich im Wohnzimmer frage antwortet der Echo im Flur oder fare ich die Küche antwortet das Wohnzimmer. Erst wenn ich zb zu erst eine andere Frage stelle und dann die Temperaturabfrage starte wird es vom gleichen Echo bearbeitet.
      FenianF Offline
      FenianF Offline
      Fenian
      @ostseereiter
      Das Problem hatte ich zwar nicht, aber dann habe ich mal 2 Echos nebeneinander gestellt.
      Dabei zeigte sich, dass in der History des Alexa2-Adapters alle Echos die reagieren, da auch der Reihe nach auftauchen.
      Ich habe jetzt eine Verzögerung eingebaut (2000 ms). Das reichte bei mir um aus 3 reagierend Echos tatsächlich den eigentlich angesprochenen Echo für die Sprachausgabe zu nutzen.
      Kannst ja mal mit der Verzögerung spielen, vielleicht geht es ja auch kürzer.
              "type": "tab",
              "disabled": false,
              "info": ""
              "port": "80",
              "x": 100,
              "y": 64,
              "wires": [
                      "60cd043e.a012ec"
              "topic": "",
              "x": 330,
              "y": 64,
              "wires": [
                      "844e7934.014538"
              "x": 740,
              "y": 65,
              "wires": [
                      "af872fed.2e36d"
              "name": "Temperature",
              "x": 732.5,
              "y": 111,
              "wires": [
                      "af872fed.2e36d"
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "array",
              "key": "topic",
              "joiner": "\\n",
              "timeout": "",
              "count": "2",
              "reduceExp": "",
              "reduceInit": "",
              "reduceFixup": "",
              "x": 901,
              "y": 65,
              "wires": [
                      "5517ab3.6b2e7d4"
              "type": "function",
              "outputs": 1,
              "noerr": 0,
              "x": 1077,
              "y": 65,
              "wires": [
                      "90bca55d.0d3348"
              "name": "speak",
              "topic": "",
              "ack": "false",
              "x": 1257.5,
              "y": 65,
              "wires": []
              "id": "844e7934.014538",
              "type": "delay",
              "name": "",
              "pauseType": "delay",
              "timeout": "2000",
              "timeoutUnits": "milliseconds",
              "rate": "1",
              "nbRateUnits": "1",
              "rateUnits": "second",
              "randomFirst": "1",
              "randomLast": "5",
              "randomUnits": "seconds",
              "drop": false,
              "x": 540,
              "y": 64,
              "wires": [
                      "880ed474.c7dfb8",
                      "7cb2ff99.6c53d"
      ostseereiterO L 3 Antworten Letzte Antwort
      • FenianF Fenian
        @ostseereiter
                "type": "tab",
                "disabled": false,
                "info": ""
                "port": "80",
                "x": 100,
                "y": 64,
                "wires": [
                        "60cd043e.a012ec"
                "topic": "",
                "x": 330,
                "y": 64,
                "wires": [
                        "844e7934.014538"
                "x": 740,
                "y": 65,
                "wires": [
                        "af872fed.2e36d"
                "x": 732.5,
                "y": 111,
                "wires": [
                        "af872fed.2e36d"
                "type": "join",
                "name": "",
                "mode": "custom",
                "build": "array",
                "key": "topic",
                "joiner": "\\n",
                "timeout": "",
                "count": "2",
                "reduceExp": "",
                "reduceInit": "",
                "reduceFixup": "",
                "x": 901,
                "y": 65,
                "wires": [
                        "5517ab3.6b2e7d4"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "x": 1077,
                "y": 65,
                "wires": [
                        "90bca55d.0d3348"
                "name": "speak",
                "topic": "",
                "ack": "false",
                "x": 1257.5,
                "y": 65,
                "wires": []
                "type": "delay",
                "name": "",
                "timeout": "2000",
                "rate": "1",
                "nbRateUnits": "1",
                "randomFirst": "1",
                "randomLast": "5",
                "drop": false,
                "x": 540,
                "y": 64,
                "wires": [
                        "880ed474.c7dfb8",
                        "7cb2ff99.6c53d"
        ostseereiterO Offline
        ostseereiter
        @Fenian ok werde ich probieren nach der Nachtschicht, Danke
        Gruß OSR
        Plattform
        • L LaBamba
          @Fenian
          FenianF Offline
          FenianF Offline
          Fenian
          @LaBamba sagte in Temperaturen über Node RED und Alexa abfragen!:
          @Fenian
          Ich schätze mal du sagst "Alexa, Temperatur Schlafzimmer". Versuche es mal mit "Alexa, schalte Temperatur Schlafzimmer an" oder "Alexa, Temperatur Schlafzimmer an"
          Alexa muss wissen, was du tun möchtest. Da hier eine Lampe emuliert wird eben an oder aus.
          Eleganter ist es natürlich, sich in der Alexa-App eine Routine anzulegen die "Temperatur Schlafzimmer" schaltet, so dass du dann z.B. "Alexa, wie ist die Temperatur im Schlafzimmer" sagen kannst.
          Ich habe es mit Echo dot 2. und 3. Generation, Echo 2.Generation, Echo Plus 1. Generation und einem Echo Show 5 probiert. Der Flow funktioniert auf allen Geräten.
          Und was dein Problem mit dem Port angeht.
          Irgendetwas blockiert den Port 1880.
          Zuerst würde ich mal den Adapter neu starten.
          Wenn das nicht hilft, per ssh auf den Host zugreifen und mal
          sudo netstat -tulpen
          aufrufen. Dann kannst du sehen, welcher Prozess den Port belegt und dann entsprechend handeln.
          Sollte da node-red stehen, prüfe mal ob du evtl. mehrere node-red Instanzen laufen hast
          L 1 Antwort Letzte Antwort
          • FenianF Fenian
            @ostseereiter
                    "type": "tab",
                    "disabled": false,
                    "info": ""
                    "port": "80",
                    "x": 100,
                    "y": 64,
                    "wires": [
                            "60cd043e.a012ec"
                    "topic": "",
                    "x": 330,
                    "y": 64,
                    "wires": [
                            "844e7934.014538"
                    "x": 740,
                    "y": 65,
                    "wires": [
                            "af872fed.2e36d"
                    "x": 732.5,
                    "y": 111,
                    "wires": [
                            "af872fed.2e36d"
                    "type": "join",
                    "name": "",
                    "mode": "custom",
                    "build": "array",
                    "key": "topic",
                    "joiner": "\\n",
                    "timeout": "",
                    "count": "2",
                    "reduceExp": "",
                    "reduceInit": "",
                    "reduceFixup": "",
                    "x": 901,
                    "y": 65,
                    "wires": [
                            "5517ab3.6b2e7d4"
                    "type": "function",
                    "outputs": 1,
                    "noerr": 0,
                    "x": 1077,
                    "y": 65,
                    "wires": [
                            "90bca55d.0d3348"
                    "name": "speak",
                    "topic": "",
                    "ack": "false",
                    "x": 1257.5,
                    "y": 65,
                    "wires": []
                    "type": "delay",
                    "name": "",
                    "timeout": "2000",
                    "rate": "1",
                    "nbRateUnits": "1",
                    "randomFirst": "1",
                    "randomLast": "5",
                    "drop": false,
                    "x": 540,
                    "y": 64,
                    "wires": [
                            "880ed474.c7dfb8",
                            "7cb2ff99.6c53d"
            ostseereiter
            @Fenian
            Super mit der Verzögerung klappte es. Danke.
            Gruß OSR
            Plattform
            • FenianF Fenian
              @Fenian
              LaBamba
              @Fenian
              Ich habe die Eingabe so gemacht wie du beschrieben hast.
              Jedoch ist immer die Antwort ECHO2 Schlafzimmer unterstützt das nicht!
              Mit der Verzögerung habe ich auch einmal experimentiert.
              Das mit dem Port 1880 schein tatsächlich durch zwei offene Node-Red Fenster entstanden zu sein.
              Die Fehlermeldung ist jetzt jedenfalls weg.
              Ich habe momentan zwei Echo Dot2 und zwei Echo (2. Generation) im Einsatz.
              Kann es sein, das nur ein neuerer Echo im System eingebunden sein muss?
                @Fenian
                LaBamba
                @ostseereiter
                Welche Geräte hast du im System?
                ostseereiterO 1 Antwort Letzte Antwort
                • L LaBamba
                  @ostseereiter
                  ostseereiter
                  @LaBamba
                  Ich habe xiaomi Sensoren wenn Du das meinst
                  Gruß OSR
                  Plattform
                    @LaBamba
                    LaBamba
                    @ostseereiter
                    Meinte welche Alexa Modelle?
                    • L LaBamba
                      @ostseereiter
                      ostseereiter
                      @LaBamba
                      3 Echo Dot 2 Generation, 1einen echo Spot einen Echo Show 5 und in meinem Auto einen echo input.
                      Gruß OSR
                      Plattform
                      • L LaBamba
                        @Fenian
                        FenianF Offline
                        FenianF Offline
                        Fenian
                        @LaBamba
                        Das mit dem neueren Gerät glaube ich eher nicht.
                        Hast du auf allen 4 Geräten das Problem?
                        ECHO2 Schlafzimmer ist der Name des Echo Dot?
                        Funktioniert das Gerät "Temperatur Schlafzimmer" wenn du die Alexa-App nutzt?
                        • FenianF Fenian
                          @LaBamba
                          LaBamba
                          @Fenian
                          Jetzt bekomme ich "Provider hat momentan leider Schwierigkeiten!"
                          Ich habe es an unterschiedlichen Geräten probiert und immer die gleiche Antwort erhalten.
                          Update nach einer halben Stunde!
                          Ich bekomme übrigen 2 Geräte in Alexa angezeigt.
                          Jetzt akzeptiert der Provider meine Anfrage. Jedoch bekomme ich nur den Ton des Schaltens ausgegeben.
                          In Node-RED wird aber jetzt alles schon einmal richtig angezeigt. Unter speak steht auch z.B. Es sind 25 Grad im Wohnzimmer. Nur die Sprachausgabe fehlt jetzt noch!
                          Habe ich hier noch eine falsche Einstellung?
                          Eine Vermutung habe ich noch. Es könnte an den Einstellungen des Alexa 2.0 Adapter liegen. Welche Einstellungen habt ihr hier vorgenommen?
                          Danke im voraus!
                          • L LaBamba
                            @Fenian
                            Danke im voraus!
                            FenianF Offline
                            FenianF Offline
                            Fenian
                            Danke im voraus!
                            Naja, ich hatte mal das Problem, dass ein Gerät immer nur sehr leise geantwortet hat.
                            Damals hatte ich eine sehr niedrige Lautstärke im Adapter eingetragen- Ich bin von 1 bis 10 ausgegangen, die Angabe im Adapter ist allerdings in %.
                            Nachdem ich da nichts mehr drin stehen hatte, war die Ansage laut und deutlich.
                            Aber ob das gleich bei allen 4 Geräten der Fall ist?
                            Ansonsten hänge mal ein Debug-Element hinter "Temperatur auslesen" und stelle "complete msg object" ein. Unter topic soltte so etwas wie: "alexa2.0.Echo-Devices.XXXXXXX.Commands.speak" stehen.
                            • FenianF Fenian
                              Danke im voraus!
                              LaBamba
                              @Fenian
                              Vielen, Vielen danke, es funktioniert! Für das xxxxxxx in alexa2.0.Echo-Devices.XXXXXXX.Commands.speak habe ich die Alexa ID Nummer eingesetzt.
                              Jetzt habe ich nur noch eine Frage. Gibt es eine Möglichkeit sich nur von der angesprochenen Alexa die Antwort nach der Temperatur geben zu lassen?
                              • L LaBamba
                                @Fenian
                                Apropo
                                @LaBamba Den Flow dafür hatte ostseereiter oben schon gepostet
                                • A Apropo
                                  LaBamba
                                  @Apropo
                                  Denn habe ich ja verwendet. Jedoch spricht immer nur eine Alexa zu mir. Also immer die Gleiche. Egal wo ich es abfrage.
                                  • FenianF Fenian
                                    @ostseereiter
                                            "type": "tab",
                                            "disabled": false,
                                            "info": ""
                                            "port": "80",
                                            "x": 100,
                                            "y": 64,
                                            "wires": [
                                                    "60cd043e.a012ec"
                                            "topic": "",
                                            "x": 330,
                                            "y": 64,
                                            "wires": [
                                                    "844e7934.014538"
                                            "x": 740,
                                            "y": 65,
                                            "wires": [
                                                    "af872fed.2e36d"
                                            "x": 732.5,
                                            "y": 111,
                                            "wires": [
                                                    "af872fed.2e36d"
                                            "type": "join",
                                            "name": "",
                                            "mode": "custom",
                                            "build": "array",
                                            "key": "topic",
                                            "joiner": "\\n",
                                            "timeout": "",
                                            "count": "2",
                                            "reduceExp": "",
                                            "reduceInit": "",
                                            "reduceFixup": "",
                                            "x": 901,
                                            "y": 65,
                                            "wires": [
                                                    "5517ab3.6b2e7d4"
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "x": 1077,
                                            "y": 65,
                                            "wires": [
                                                    "90bca55d.0d3348"
                                            "name": "speak",
                                            "topic": "",
                                            "ack": "false",
                                            "x": 1257.5,
                                            "y": 65,
                                            "wires": []
                                            "type": "delay",
                                            "name": "",
                                            "timeout": "2000",
                                            "rate": "1",
                                            "nbRateUnits": "1",
                                            "randomFirst": "1",
                                            "randomLast": "5",
                                            "drop": false,
                                            "x": 540,
                                            "y": 64,
                                            "wires": [
                                                    "880ed474.c7dfb8",
                                                    "7cb2ff99.6c53d"
                                    LaBamba
                                    @Fenian
                                    Wie kann ich in deiner Programmierung
                                    var res = str.substr(0,5);
                                    msg.payload = "Es sind " + msg.payload + " Grad in der Küche";
                                    msg.url = "";
                                    var command = "alexa2.0.Echo-Devices." + device + ".Commands.speak"
                                    return msg;
                                    Die Genauigkeit mit einer Nachkommastelle aufrufen?
                                    • L LaBamba
                                      @Apropo
                                      Apropo
                                      @LaBamba Bei mir antwortet damit die Alexa die ich auch anspreche. Habe eine Verzögerung von 1000 eingestellt.
                                      • A Apropo
                                        LaBamba
                                        @Apropo
                                        Ich habe es schon mit verschiedenen Verzögerungen probiert. Jedoch antwortet immer nur eine Alexa.
                                        • L LaBamba
                                          @Fenian
                                          msg.url = "";
                                          return msg;
                                          TorbenNW
                                          @LaBamba
                                          Nachkommastellen: Die Zeile mit Math.round löschen und mit "msg.payload = msg.payload.replace('.', ',');" ersetzen.
