  4. Raspberry Pi4 läuft!
    6.7k
pi4 buster
138 Beiträge 32 Kommentatoren 30.8k Aufrufe 22 Beobachtet
  • DenisMD DenisM
    Also bei mir geht da nix mit dem Pi 4: 😢
    pi@raspberrypi4:~ $ npm -v
    6.10.1
    pi@raspberrypi4:~ $ node -v
    v10.16.0
    pi@raspberrypi4:~ $ nodejs -v
    v10.16.0
        Installing ioBroker (3/4)
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:190:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.57-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v5.0.2
    gyp ERR! not ok
    In file included from ../node_modules/nan/nan.h:190,
                     from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
    ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
       return obj->ForceSet(GetCurrentContext(), key, value, attribs);
    In file included from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from ../node_modules/nan/nan.h:47,
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
    ../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
    ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../node_modules/nan/nan.h:1706:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    In file included from /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:26,
                     from /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:63,
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:63,
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: At global scope:
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/10.16.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/pi/.cache/node-gyp/10.16.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../node_modules/nan/nan_object_wrap.h:66:61:   required from here
    /home/pi/.cache/node-gyp/10.16.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    make: *** [unix_dgram.target.mk:99: Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
    gyp ERR! not ok
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #117
    @DenisM Macht er da nicht weiter oder was? Bis dahin sieht alles mehr oder weniger normal aus. unix-dgram kannste ignorieren.
      DerS
      #118
      Der Backupit Adapter funzt tadellos beim Pi 4, getestet mit minimal Backup und auf dem Pi 3 erstellt. Kein Image verwendet und Node 10 installliert.
      Der Umzug ist vollbracht. ;-)
        @Solear sagte in Raspberry Pi4 läuft!:
        USB-Boot wird jedoch noch nicht vom RPI4 mit Buster unterstützt.
        ich weiß!
        gibt aber noch genug anderes
        Markus Faltermeier
        #119
        @Homoran
        Hallo
        Weiß jemand zufällig wie bzgl. usb Boot der Zeitplan aussieht.
        Also reden wir von Wochen oder eher Monaten?
        Ich frage deshalb weil mein pi3 an der Grenze ist und ich jetzt den pi4 mit 4GB aufsetzten möchte.
        Ich möchte gerne wissen, ob ich noch auf den Support für usb Boot warten kann oder ob ich erst mal auf SD installiere und nachher nochmal umziehe. 😃
        Vielen Dank schonmal
        LG Markus
        • M Markus Faltermeier
          @Homoran
          Hallo
          LG Markus
          #120
          @Markus-Faltermeier sagte in Raspberry Pi4 läuft!:
          Das musst du bei raspberrypi.org fragen.
          Da haben wir keinen Einfluss.
            Markus Faltermeier
            #121
            @Homoran
            Ok Danke für die info
              @Homoran
              Hallo
              LG Markus
              #122
              @Markus-Faltermeier sagte:
              Was bei allen RasPi-Varianten möglich sein sollte: Booten des Systems (root fs) auf USB-Stick / SSD von der SD Card. Von der SD Card wird nur die Bootpartition verwendet. Das mache ich mit meinem RasPi 2 so.
              • F Offline
                Fab296
                #123
                Darf ich mal fragen welche Vorteile der USB boot hat im Vergleich zum SD-Karten boot?
                Also wenn ich mir die gängigen USB 3.0 Sticks anschaue haben sie ja die gleiche Geschwindigkeit wie die SD-Karten?! Oder beherrscht der Raspberry schon USB 3.1?
                • F Fab296
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #124
                  @Fab296
                  Der Vorteil liegt darin das du weniger empfindliche Speichersysteme als die standard SD Karten verwenden kannst. Der RPi hat den Ruf weg, die Speicherkarten gerne mal zu töten, insbesondere bei einem Stromausfall.
                  A.
                  F 1 Antwort Letzte Antwort
                  • AsgothianA Asgothian
                    @Fab296
                    A.
                    Fab296
                    #125
                    @Asgothian
                    Danke für die Antwort. Was wäre den das beste Speichersystem für den RPI? Stick, exteren USB Festplatte?
                    • F Fab296
                      @Asgothian
                      #126
                      @Fab296
                      Ich bevorzuge SLC-USB-Sticks MX-ES (160 MB/s schnell, hohe Schreib-Belastbarkeit, geringe Stromaufnahme). Da es offenbar nur noch einen Anbieter in DE gibt, sind die Preise gestiegen. Deshalb ist eine externe USB-3.0-SSD eine gute Alternative.
                        @Fab296
                        Fab296
                        #127
                        danke für die Tipps!
                        • F Fab296
                          Jan1
                          #128
                          @Fab296
                          Dann noch den Tip, keine "normalen" USB Sticks verwenden, denn die sind unter Umständen sogar schnell hin als ne gute SD Karte.
                          • opossumO Offline
                            opossumO Offline
                            opossum
                            #129
                            ich habe jetzt mein Testsystem mit dem PI4 fertig. Buster lite genommen, dann alle Updates und config. MariaDB installiert. Dann iobroker installiert, Standard-Backup zurückgespielt und dann alle Adapter, die nicht auf Anhieb liefen, nochmals von GIT installiert und konfiguriert. Alle Adapter sind am Laufen, auch die vis ist mit allen Seiten ok. Lediglich das Verzeichnis mit meinen .png von Prod. nach Test kopiert. Dann habe ich mal die Temperatur kontrolliert, lag bei 77°C. PI ist einem normalen PI-Gehäuse untergebracht. Das war mir zu viel. Habe dann den Tip von hier befolgt. Ich hatte noch einen Einschub für eine Wechselfestplatte liegen, da war ein kleiner Lüfter verbaut. Den habe ich ausgebaut und in den Deckel des PI-Gehäuses eingebaut. Angeschlossen an die PINs 2 und 4 . Der Lüfter läuft mit 5V und ist nicht zu hören. Hoffe, dass das der PI mir das nicht übel nimmt. Zusätzlich den RPI-Adapter installiert, um die Temperatur auslesen zu können. Der Lüfter schaufelt die Luft ins Gehäuse. Jetzt liegt die Temperatur bei 58°C. Das erscheint mir als annehmbar.
                            https://www.schlepper-petersdorf.de
                            • C Offline
                              Christian.B
                              #130
                              Hallo Leute,
                              kann mir bitte jemand sagen, ob ich den zweiten Eintag von redis auf file umstellen kann? Und falls das geht, wie ich das machen kann?
                              Seit Freitag versuche ich meinen aktuellen iobroker von raspi 3 auf den Raspi 4 umziehen, was immer beim Eispielen des Backups scheitert. Ich denke, dass es an redis liegt, da bei neuem iobroker auf dem raspi4 auf beiden Positionen "file" steht.
                              viele Grüße
                              Christian
                              • C Christian.B
                                Hallo Leute,
                                #131
                                @Christian-B sagte in Raspberry Pi4 läuft!:
                                hast du das Readme dazu gelesen?
                                Installation von Redis
                                Diese Images enthalten nicht mehr die Datenbank Redis um die States zu speichern. Bei schwachen Rechnern und geringem RAM erhöht die Verwendung von Redis die Performance teilweise erheblich. Bei schnelleren Rechnern reduziert es die Schreibzugriffe und verlängert so das Leben der SD-Karte.
                                Sollte Redis installiert werden sollen muss bei den aktuellen Images wie folgt vorgegangen werden.
                                • C Offline
                                  Christian.B
                                  #132
                                  @Homoran sagte in Raspberry Pi4 läuft!:
                                  edis
                                  nein habe ich nicht und ich muss auch gestehen, dass ich mit diesen Informationen im Moment etwas überfordert bin. Bis heute Morgen habe ich noch nie etwas von redis gehört. Was sagt das im Klartext aus? das ich auf dem neuen raspi 4 auch redis nutzen soll oder, dass der der Umzug von Raspi 3 mit redis auf Raspi 4 nicht klappt.
                                  Sorry, dass ich mich so anstelle, das ich nicht meide Welt, dennoch habe ich mit iobroker es hinbekommen ein ausgewachsenes smarthome aufzubauen. Jetzt drehe ich mich seit 3 Tagen im Kreis und komme nicht weiter.
                                  viele Grüße
                                  Christian
                                  • C Christian.B
                                    edis
                                    #133
                                    kein Problem, das schaffen wir.
                                    Redis ist eine Datenbank, die für einen effektiveren und damit ressourcenschonenderen Umgang mit den States sorgt.
                                    es hat schon seine Vorteile:
                                    Wenn du kein Redis nutzen willst musst du VOR dem Backup auf dem alten Raspi dieses über iobroker setup custom deaktivieren. indem du alle states auf file stellst.
                                    Dann kannst du das Backup auch ohne Redis einspielen.
                                    C 1 Antwort Letzte Antwort
                                      Christian.B
                                      #134
                                      Boaaahhh @Homoran ... das hat jetzt mit deinem Hinweis und 3 Tagen Quälerei ENDLICH geklappt. Raspi 4 mit dem "alten" iObroker läuft! Hab wieder was gelernt und es geht weiter.
                                      Suuuper, vielen Dank und Grüße
                                      Christian
                                      viele Grüße
                                      Christian
                                      • C Offline
                                        Christian.B
                                        #135
                                        iot und zigbee laufen noch nicht. Darum werde ich mich später kümmern.
                                        Was mir viel mehr Sorgen macht ist, dass der iObroker den Status der GPIO Anschlüße nicht erkennt. Ich hebe im gesamten Haus reedkontakte an Fenstern und Türen, die per Kabel mit den GPIOs des raspis angeschlossen sind. Darüber laufen viele wichtige Smarthome-"Geschichten". Schon mit dem Raspi 3+ konnte ich "nur" 11 gpio´s abfragen, was mir schon zuwenig war. Mit dem raspi 4 ist es kein einziger.
                                        Was kann ich machen?
                                        viele Grüße
                                        Christian
                                        • C Offline
                                          Christian.B
                                          #136
                                          konnte schon jemand testen, ob die GPIOs auf dem Rasperry 4 ansprechbar sind? Ich würde gerne wissen, ob das nur an meinem System liegt oder generell mit Raspi4 noch glatt gezogen werden muss. Woran könnte es liegen, dass der rpi Adapter die gpio nicht sieht?
                                          viele Grüße
                                          Christian
