  5. Script Hilfe licht über Xiaomi Switch anschalten.
    5.7k
blocklymonitoringcommunication
40 Beiträge 3 Kommentatoren 5.2k Aufrufe 1 Beobachtet
  • iomountainI iomountain
    Wenn du was lernen willst, als Anfang zum einarbeiten:
     <block type="comment" id="@cY?z8Mo[rp~6*xjYRB9" x="88" y="-462">
       <field name="COMMENT">Taster XIAOMI  Nr. 3</field>
       <next>
         <block type="on_ext" id="PB-24CkO9W+A,wx(U/~p">
           <mutation items="6"></mutation>
           <field name="CONDITION">gt</field>
           <field name="ACK_CONDITION">true</field>
           <value name="OID0">
             <shadow type="field_oid" id=")Qi*F{:XZIsphth0IP^H">
             </shadow>
             <block type="field_oid" id="rgjNSi2xzP32`iFTE[Zr">
               <field name="oid">zigbee.0.00158d0002b02f86.click</field>
             </block>
           </value>
           <value name="OID1">
             <shadow type="field_oid" id="iaF=)P=-;PAAd,)/4%vi">
             </shadow>
             <block type="field_oid" id="ea3t6_MlYEPR}*?yzCqA">
               <field name="oid">zigbee.0.00158d0002b02f86.double_click</field>
             </block>
           </value>
           <value name="OID2">
             <shadow type="field_oid" id="^US+uZxi^vOuQI|KuALq">
             </shadow>
             <block type="field_oid" id="Ro15Nv;8Sl9+.0nGHq^%">
               <field name="oid">zigbee.0.00158d0002b02f86.triple_click</field>
             </block>
           </value>
           <value name="OID3">
             <shadow type="field_oid" id="R2Lb}B~M^5V1#^vXl,xw">
             </shadow>
             <block type="field_oid" id="=?EUmg0.O3+z.RryC=xB">
               <field name="oid">zigbee.0.00158d0002b02f86.quad_click</field>
             </block>
           </value>
           <value name="OID4">
             <shadow type="field_oid" id="9i}=7+CVZh@d7@#)C3;}">
             </shadow>
             <block type="field_oid" id="?ojg03%rW]}Gl-_0!`1x">
               <field name="oid">zigbee.0.00158d0002b02f86.many_click</field>
             </block>
           </value>
           <value name="OID5">
             <shadow type="field_oid" id="?EarP}N#oxmuZYcD#w?A">
             </shadow>
             <block type="field_oid" id="Qn6/h8f3[DP`d@i5_M`8">
               <field name="oid">zigbee.0.00158d0002b02f86.long_click</field>
             </block>
           </value>
           <statement name="STATEMENT">
             <block type="debug" id="r/YqCq!4BPo^D%562f@H">
               <value name="TEXT">
                 <shadow type="text" id="5hv99z~G`)`/zHUNWPf~">
                   <field name="TEXT">es wurde geklickt</field>
                 </shadow>
               </value>
               <next>
                 <block type="controls_if" id="^%rfwf,9(7^?Gd1W(2rH">
                   <mutation elseif="5"></mutation>
                   <value name="IF0">
                     <block type="logic_compare" id="B7oHd]+ob+83AYT#!UOR">
                       <field name="OP">EQ</field>
                       <value name="A">
                         <block type="get_value" id="%l[Ebz+^3abG+/nZ_|%6">
                           <field name="OID">zigbee.0.00158d0002b02f86.click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="*ciW[o-HOq!fpNWr0GQx">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="debug" id="7`7)Pc:(kqD!l@AdFktg">
                       <value name="TEXT">
                         <shadow type="text" id="?D:soVS]Ik_MSh,2sepk">
                           <field name="TEXT">click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="i*jra%1wLggjCGzi/q{W">
                           <field name="COMMENT">je nach click</field>
                           <next>
                             <block type="controls_if" id="EG3ol;@J!t^@8`umkneD">
                               <value name="IF0">
                                 <block type="logic_operation" id="K{W%]KSw7P4gp:O[*UgD">
                                   <field name="OP">OR</field>
                                   <value name="A">
                                     <block type="logic_compare" id="h^93g38,nk?n5B7-T|-2">
                                       <value name="A">
                                         <block type="get_value" id="{LHVnt1Z}O9p}y;p9yW)">
                                           <field name="OID">zigbee.0.00158d0001978f3b.state</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_boolean" id="i]3e]XF.PqOq6jySU-7A">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_compare" id="`Q_d6K+s7Xy3z=yM8JKI">
                                       <value name="A">
                                         <block type="get_value" id="N:?5:-:R9O-Gf(9;Y4*4">
                                           <field name="OID">zigbee.0.00158d00018029dd.state</field>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_boolean" id="[2d@d1(/KA:U_9qBxzt|">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                 <block type="comment" id="5{]Wn0u@#w@rdTXb)SiY">
                                   <field name="COMMENT">Wenn eine Lampe an dann alle aus</field>
                                   <next>
                                     <block type="debug" id="D1jJ!hg8?416.fo8A]Ig">
                                       <value name="TEXT">
                                         <shadow type="text" id="EQV5T+^(Oc^%jddr?Ed/">
                                           <field name="TEXT">ausschalten</field>
                                         </shadow>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                               <statement name="ELSE">
                                 <block type="comment" id=":x2uA2sM^Tb!]7~%Y@3.">
                                   <field name="COMMENT">Objekt schalten, bitte anpassen</field>
                                   <next>
                                     <block type="control" id="79;%-wMLM(l4pnH}_Ug?">
                                       <mutation delay_input="false"></mutation>
                                       <value name="VALUE">
                                         <block type="logic_boolean" id="OqQ-6Zdl=qm``H}c+r`1">
                                         </block>
                                       </value>
                                       <next>
                                         <block type="comment" id="L?|+,b8)F9%Bpv]ZlSK/">
                                           <field name="COMMENT">Sonst lampe an</field>
                                           <next>
                                             <block type="debug" id="[7.r]`dibVzq:nExle;C">
                                               <value name="TEXT">
                                                 <shadow type="text" id="AjqibEkM(*A`Uc-I[Fh.">
                                                   <field name="TEXT">einschalten</field>
                                                 </shadow>
                                               </value>
                                               <next>
                                                 <block type="comment" id="khXz:g:a01UL0NVB(/0A">
                                                   <next>
                                                     <block type="control" id="i4iv,I2$L*`g=Y3`hXGM">
                                                         <block type="logic_boolean" id="$7ncThkUUTn~-05X$uEg">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF1">
                     <block type="logic_compare" id="{RB1T]6_|We%X^x8y,e3">
                       <value name="A">
                         <block type="get_value" id="]Jqp`odS[1k}8wvU%ljY">
                           <field name="OID">zigbee.0.00158d0002b02f86.double_click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="D({5v+n5fghCkGs68}ch">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO1">
                     <block type="debug" id="]OGemcpFY;b;lh4Z[aK/">
                       <value name="TEXT">
                         <shadow type="text" id="fO(2D5-!_m|U:zj[5fsa">
                           <field name="TEXT">double click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="B7Y#DekBTX23lCB-|,L]">
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF2">
                     <block type="logic_compare" id="Awyl1ugjhBcRcUAJOL+l">
                       <value name="A">
                         <block type="get_value" id="l4xIsUA`ecIpJqodgO-4">
                           <field name="OID">zigbee.0.00158d0002b02f86.triple_click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="g]#YKK0GlZp*2U(E|G|(">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO2">
                     <block type="debug" id="gr9O^S~?R+-0b:S-sb!L">
                       <value name="TEXT">
                         <shadow type="text" id="1[hmvn+t^pr2j.fEi2rb">
                           <field name="TEXT">tripple click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="0,;Y]y4[u[]+Bs1s=Epw">
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF3">
                     <block type="logic_compare" id="5Ultno,QEkbPOIz4+`x=">
                       <value name="A">
                         <block type="get_value" id="^,!TJk?QHXNhp0f24SIM">
                           <field name="OID">zigbee.0.00158d0002b02f86.quad_click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="^0tE{Uw^Aw9]{aM4v%#,">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO3">
                     <block type="debug" id="uM,~`ogj7YUW+_9GH@qK">
                       <value name="TEXT">
                         <shadow type="text" id="vf-TRBU!EW^99MhKz-^D">
                           <field name="TEXT">vierfach click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="_b)`rKt;`?q#O/WQ!S8W">
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF4">
                     <block type="logic_compare" id="5P6jpTQ+SQg)Z-ZWuBCK">
                       <value name="A">
                         <block type="get_value" id="LPfGX2rys@=v3mC2^-73">
                           <field name="OID">zigbee.0.00158d0002b02f86.many_click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="ris=X#TgK=1+0COq?uuC">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO4">
                     <block type="debug" id="Br~kIi5^8x!xr.94.PB:">
                       <value name="TEXT">
                         <shadow type="text" id="Zrcd`R6T{YcUD=]O;S+-">
                           <field name="TEXT">viele click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="@d7VxOC1QmAoaKcahHk3">
                         </block>
                       </next>
                     </block>
                   </statement>
                   <value name="IF5">
                     <block type="logic_compare" id="Gt2b(|.gt?d1z,%g%99I">
                       <value name="A">
                         <block type="get_value" id="4[`vb;-7^8ow]IE0ZF~[">
                           <field name="OID">zigbee.0.00158d0002b02f86.long_click</field>
                         </block>
                       </value>
                       <value name="B">
                         <block type="logic_boolean" id="ay}{%b(r.^GlnijvJuN^">
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO5">
                     <block type="debug" id="OU:gQT3@u=HQrMl8Hq+%">
                       <value name="TEXT">
                         <shadow type="text" id="M(F:?:]%Jg?msY]k^F)n">
                           <field name="TEXT">lang click</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="comment" id="8R^HYo2yE!:l@set_:4i">
                           <field name="COMMENT">je nach click </field>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    Nito33N Offline
    Nito33N Offline
    Nito33
    @iomountain Dankeschön. Aber wieso ist oben Quad und many Klick? ich probiere mal meine Werte einzusetzen und zu verstehen wie alles funktioniert. Ist das aber nicht auch nur für einen Switch?
    • iomountainI Offline
      iomountainI Offline
      iomountain
      meiner ist über einen Zigbee Stick angebunden und in den Objekten gibt es
      Wobei vierfach und many Click für mich schwer zu treffen sind.
      Zeig mal wie deiner in den Objekten aussieht.
      Nito33N 1 Antwort Letzte Antwort
        Nito33N Offline
        Nito33N Offline
        Nito33
        @iomountain Opera Momentaufnahme_2019-07-11_120711_192.168.178.93.png Opera Momentaufnahme_2019-07-11_120646_192.168.178.93.png
        So sieht es bei mir bei den Objekten aus. Ich habe jetzt einfach mal probiert über einen Klick das Licht anzuschalten, leider funktioniert es nicht. Muss ich noch irgendwo was ändern in dem Script?
          iomountainI Offline
          iomountain
          Kümmern wir uns erst mal um den simple click.
          Über den Falls Teil fragst du ob das Licht schon an ist
          Bei mir sogar zwei Lampen.
          Denke da müsste dein Licht Power rein
            Nito33N Offline
            Nito33N Offline
            Nito33
            Dann muss dort der Power State von dem Sonoff rein oder? Licht wird ja über einen Sonoff ein und aus geschaltet.
              iomountainI Offline
              iomountain
              sieht gut aus, jetzt an diesen debug Baustein
              einen steuere Baustein mit false anhängen.
                Nito33N Offline
                Nito33N Offline
                Nito33
                @iomountain Wo soll ich da einen Baustein anhängen?
                  iomountainI Offline
                  iomountain
                    Nito33N Offline
                    Nito33N Offline
                    Nito33
                    so also? Welches Objekt kommt dort rein?
                      iomountainI Offline
                      iomountain
                      das, welches dein Licht an aus schaltet
                        Nito33N Offline
                        Nito33N Offline
                        Nito33
                        @iomountain Hab ich jetzt drin. Passiert leider nichts.
                          iomountainI Offline
                          iomountain
                          mach mal einen Export von deinem Code
                          Nito33N 2 Antworten Letzte Antwort
                            Nito33N Offline
                            Nito33N Offline
                            Nito33
                            @iomountain <xml xmlns="http://www.w3.org/1999/xhtml">
                            <block type="comment" id="@cY?z8Mo[rp~6xjYRB9" x="88" y="-462">
                            <next>
                            <value name="OID0">
                            F{:XZIsphth0IP^H">
                            </shadow>
                            <block type="field_oid" id="rgjNSi2xzP32iFTE[Zr"> <field name="oid">mihome.0.devices.switch_158d0001e5c139.click</field> </block> </value> <value name="OID1"> <shadow type="field_oid" id="iaF=)P=-;PAAd,)/4%vi"> <field name="oid">default</field> </shadow> <block type="field_oid" id="ea3t6_MlYEPR}*?yzCqA"> <field name="oid">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="OID2"> <shadow type="field_oid" id="^US+uZxi^vOuQI|KuALq"> <field name="oid">default</field> </shadow> <block type="field_oid" id="Ro15Nv;8Sl9+.0nGHq^%"> <field name="oid">zigbee.0.00158d0002b02f86.triple_click</field> </block> </value> <value name="OID3"> <shadow type="field_oid" id="R2Lb}B~M^5V1#^vXl,xw"> <field name="oid">default</field> </shadow> <block type="field_oid" id="=?EUmg0.O3+z.RryC=xB"> <field name="oid">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="OID4"> <shadow type="field_oid" id="9i}=7+CVZh@d7@#)C3;}"> <field name="oid">default</field> </shadow> <block type="field_oid" id="?ojg03%rW]}Gl-_0!1x">
                            </block>
                            </value>
                            <value name="OID5">
                            </shadow>
                            <block type="field_oid" id="Qn6/h8f3[DPd@i5_M8">
                            </block>
                            </value>
                            <value name="TEXT">
                            <shadow type="text" id="5hv99z~G)/zHUNWPf~">
                            </shadow>
                            </value>
                            <next>
                            <value name="IF0">
                            <value name="A">
                            </block>
                            </value>
                            <value name="B">
                            <block type="logic_boolean" id="ciW[o-HOq!fpNWr0GQx">
                            </block>
                            </value>
                            </block>
                            </value>
                            <block type="debug" id="77)Pc:(kqD!l@AdFktg"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="?D:soVS]Ik_MSh,2sepk"> <field name="TEXT">click</field> </shadow> </value> <next> <block type="comment" id="i*jra%1wLggjCGzi/q{W"> <field name="COMMENT">je nach click</field> <next> <block type="controls_if" id="EG3ol;@J!t^@8umkneD">
                            <value name="IF0">
                            <block type="logic_operation" id="K{W%]KSw7P4gp:O[UgD">
                            <value name="A">
                            <value name="A">
                            <field name="OID">sonoff.0.Licht.POWER</field>
                            </block>
                            </value>
                            <value name="B">
                            </block>
                            </value>
                            </block>
                            </value>
                            <value name="B">
                            <block type="logic_compare" id="Q_d6K+s7Xy3z=yM8JKI"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="N:?5:-:R9O-Gf(9;Y4*4"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Licht.POWER</field> </block> </value> <value name="B"> <block type="logic_boolean" id="[2d@d1(/KA:U_9qBxzt|"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="comment" id="5{]Wn0u@#w@rdTXb)SiY"> <field name="COMMENT">Wenn eine Lampe an dann alle aus</field> <next> <block type="debug" id="D1jJ!hg8?416.fo8A]Ig"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="EQV5T+^(Oc^%jddr?Ed/"> <field name="TEXT">ausschalten</field> </shadow> </value> <next> <block type="control" id="QyX=!8$VR$)D=UhC1sa1"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="V2End:lo3Xwl#Gp^:9ne"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="comment" id=":x2uA2sM^Tb!]7~%Y@3."> <field name="COMMENT">Objekt schalten, bitte anpassen</field> <next> <block type="control" id="79;%-wMLM(l4pnH}_Ug?"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="OqQ-6Zdl=qm``H}c+r1">
                            </block>
                            </value>
                            <next>
                            <next>
                            <block type="debug" id="[7.r]dibVzq:nExle;C"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="AjqibEkM(*AUc-I[Fh.">
                            </shadow>
                            </value>
                            <next>
                            <next>
                            g=Y3hXGM">
                            </block>
                            </value>
                            </block>
                            </next>
                            </block>
                            </next>
                            </block>
                            </next>
                            </block>
                            </next>
                            </block>
                            </next>
                            </block>
                            </statement>
                            </block>
                            </next>
                            </block>
                            </next>
                            </block>
                            </statement>
                            <value name="IF1">
                            <value name="A">
                            <block type="get_value" id="]JqpodS[1k}8wvU%ljY"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="D({5v+n5fghCkGs68}ch"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="debug" id="]OGemcpFY;b;lh4Z[aK/"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="fO(2D5-!_m|U:zj[5fsa"> <field name="TEXT">double click</field> </shadow> </value> <next> <block type="comment" id="B7Y#DekBTX23lCB-|,L]"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF2"> <block type="logic_compare" id="Awyl1ugjhBcRcUAJOL+l"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="l4xIsUAecIpJqodgO-4">
                            </block>
                            </value>
                            <value name="B">
                            2U(E|G|(">
                            </block>
                            </value>
                            </block>
                            </value>
                            <value name="TEXT">
                            </shadow>
                            </value>
                            <next>
                            </block>
                            </next>
                            </block>
                            </statement>
                            <value name="IF3">
                            <block type="logic_compare" id="5Ultno,QEkbPOIz4+x="> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="^,!TJk?QHXNhp0f24SIM"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="^0tE{Uw^Aw9]{aM4v%#,"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO3"> <block type="debug" id="uM,~ogj7YUW+_9GH@qK">
                            <value name="TEXT">
                            </shadow>
                            </value>
                            <next>
                            <block type="comment" id="b)rKt;?q#O/WQ!S8W">
                            </block>
                            </next>
                            </block>
                            </statement>
                            <value name="IF4">
                            <value name="A">
                            </block>
                            </value>
                            <value name="B">
                            </block>
                            </value>
                            </block>
                            </value>
                            <value name="TEXT">
                            <shadow type="text" id="ZrcdR6T{YcUD=]O;S+-"> <field name="TEXT">viele click</field> </shadow> </value> <next> <block type="comment" id="@d7VxOC1QmAoaKcahHk3"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF5"> <block type="logic_compare" id="Gt2b(|.gt?d1z,%g%99I"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="4[vb;-7^8ow]IE0ZF~[">
                            </block>
                            </value>
                            <value name="B">
                            </block>
                            </value>
                            </block>
                            </value>
                            <value name="TEXT">
                            </shadow>
                            </value>
                            <next>
                            :4i">
                            </block>
                            </next>
                            </block>
                            </statement>
                            </block>
                            </next>
                            </block>
                            </statement>
                            </block>
                            </next>
                            </block>
                            </xml>
                              Nito33N Offline
                              Nito33N Offline
                              Nito33
                              @iomountain Wie mache ich das denn eigentlich in so nem Kasten :D ?
                              iomountainI 1 Antwort Letzte Antwort
                              • Nito33N Nito33
                                iomountainI Offline
                                iomountainI Offline
                                iomountain
                                @Noé1237
                                erst auf Spoiler drücken, dann auf Code, dann einfügen
                                hab's mal ein wenig gekürzt und aufgeräumt
                                 <block type="comment" id="@cY?z8Mo[rp~6xjYRB9" x="788" y="-837">
                                   <next>
                                     <block type="on_ext" id="IM=K$r`vCMSq5Ry?s:~7">
                                       <value name="OID0">
                                         <shadow type="field_oid" id=")QiF{:XZIsphth0IP^H">
                                         </shadow>
                                         <block type="field_oid" id="^ipDGr0w*ura!}49qCL#">
                                         </block>
                                       </value>
                                       <value name="OID1">
                                         </shadow>
                                         <block type="field_oid" id="fJwFo$^m7N2ojv]3p/QM">
                                         </block>
                                       </value>
                                       <value name="OID2">
                                         </shadow>
                                         <block type="field_oid" id="Qh2HV$lcJ,ank8t8VYl|">
                                         </block>
                                       </value>
                                         <block type="debug" id="eMyo{0+~BA^+F_j)nF!q">
                                           <value name="TEXT">
                                             <shadow type="text" id="aEIbF.mX|@FSE)x~u`Pc">
                                             </shadow>
                                           </value>
                                           <next>
                                             <block type="controls_if" id="LwYwYyELzNmNsP12(PJ9">
                                               <mutation elseif="2"></mutation>
                                               <value name="IF0">
                                                 <block type="logic_compare" id="oY/OwE$,$:B-LaqyH+uG">
                                                   <value name="A">
                                                     <block type="get_value" id="Y]Shb09a[-~$9jg9CvFp">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="logic_boolean" id="!Nsd[-FkW{f-Tafh(di?">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="debug" id="`L|)(C=-?JEKZQ=/y_p3">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="{9ywGmI{lky~86n;CK;M">
                                                       <field name="TEXT">simple click</field>
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                     <block type="comment" id="84wWuU*|2E#eVDJ[;xSq">
                                                       <next>
                                                         <block type="controls_if" id="cI_ZQ:;t@XJ.sKY,duG{">
                                                           <value name="IF0">
                                                             <block type="logic_compare" id="447cil7dkU}qdikEWF{o">
                                                               <value name="A">
        <block type="get_value" id="j}kI`?]x)Voq(g2^Deg`">
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="logic_boolean" id="+]Ky-zdx$#O7G75!3nmC">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                             <block type="comment" id="Ui*|-IIZkk~5qp]Sh{iC">
                                                               <next>
        <block type="debug" id="MYATXbE=nd]`P]]#|cWS">
        <value name="TEXT">
        <shadow type="text" id="-jjSMw/F|x(P^.`}y_+8">
        </shadow>
        </value>
        <next>
        <block type="control" id="s^37|2Q;*n^+1Su)jr2z">
        <block type="logic_boolean" id="X6hC`)c~pbK95M;IEo8w">
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                             <block type="comment" id="3XBp0.uai|Z,MxtnS79B">
                                                               <next>
        <block type="debug" id="~88$c[[;d*mtS/?zDuZ}">
        <value name="TEXT">
        <shadow type="text" id="KFK}kt7RygKz6PX7(H+a">
        </shadow>
        </value>
        <next>
        <block type="comment" id="#w=#88#QYefI9D=uW$12">
        <next>
        <block type="control" id=".bhIw.73p9H[$2iZ,pil">
        <block type="logic_boolean" id="atYDubn5(IL[[E?W[=.f">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <value name="IF1">
                                                 <block type="logic_compare" id="?y[}1Aa[MJMYV]rNUt6B">
                                                   <value name="A">
                                                     <block type="get_value" id="RW~%WAZEGn:M5I=~{nRf">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="logic_boolean" id="v4yf~+u+*SQ(Bnr^0dWO">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="debug" id="FKC@ddUdUG._U.3*PW%u">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="QIHNuvl;%2Ko|N^xigHb">
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                     <block type="comment" id="-Gm=B3%WG4-0.ShL9sC8">
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <value name="IF2">
                                                 <block type="logic_compare" id="q_b/zN!56q)s0J8+Yjos">
                                                   <value name="A">
                                                     <block type="get_value" id="/K{7E}+T7K$})pS6=2md">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="logic_boolean" id="EG?~N7wx*d-optI47WLe">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="debug" id="t1[K}FImd-EU6r@$-Ok*">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="p:D!*b]*bXZ`-i%bu/H=">
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                     <block type="comment" id="%zhWT=pM5@yWuU2aBQ)#">
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                                </xml>
                                Nito33N iomountainI 2 Antworten Letzte Antwort
                                  @Noé1237
                                     <next>
                                         <value name="OID0">
                                           </shadow>
                                           </block>
                                         </value>
                                         <value name="OID1">
                                           </shadow>
                                           </block>
                                         </value>
                                         <value name="OID2">
                                           </shadow>
                                           </block>
                                         </value>
                                             <value name="TEXT">
                                               </shadow>
                                             </value>
                                             <next>
                                                 <value name="IF0">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                         <next>
                                                             <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                               </block>
                                                             </value>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <value name="IF1">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <value name="IF2">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  Nito33N Offline
                                  Nito33N Offline
                                  Nito33
                                  @iomountain achso okey, danke. Weißt du woran es liegt?
                                  • Nito33N Nito33
                                    iomountainI Offline
                                    iomountainI Offline
                                    iomountain
                                    @Noé1237 sagte in Script Hilfe licht über Xiaomi Switch anschalten.:
                                    was?
                                    funktioniert dein "simple click"
                                      was?
                                      Nito33N Offline
                                      Nito33N Offline
                                      Nito33
                                      @iomountain Ne ich frage ja ob du weißt wieso es nicht funktioniert. Aktuell passiert gar nichts wenn ich drücke.
                                        iomountainI Offline
                                        iomountain
                                        so ist das Script gestoppt.
                                        was sagt das Log?
                                        Das was in den Debug Baustein steht müsste im LOG auftauchen.
                                          was sagt das Log?
                                          Nito33N Offline
                                          Nito33N Offline
                                          Nito33
                                          @iomountain Script ist an. Opera Momentaufnahme_2019-07-11_134121_192.168.178.93.png
                                          so sieht mein log aus
