  5. Fernseher Zeitverzögert ausschalten
    5.7k
21 Beiträge 7 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • liv-in-skyL liv-in-sky
    @Freakezoid
    damit gehts: test ausschaltzeit war eine minute (roter pfeil)
    • die debug-blocklies dienen nur zur sichtbarmachung im log - kann man später deaktivieren
    für import - datenpunkt angleichen !
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="HXhV]8:d}^}K8?b7[Va(" x="1262" y="812">
    <mutation items="1"></mutation>
    <value name="OID0">
    <shadow type="field_oid" id="w_hUg12Mk9RBlmbIE}m]">
    <field name="oid">controll-own.0.AAATEST.TestZahl</field>
    </shadow>
    </value>
    <statement name="STATEMENT">
    <block type="debug" id="7-R(y3)A3b}Hhn9qAYDm">
    <field name="Severity">warn</field>
    <value name="TEXT">
    <shadow type="text" id="ab1lbd(L}AEA2!pALw="> <field name="TEXT">an</field> </shadow> </value> <next> <block type="variables_set" id="6vFjV?lvMLG}1,c7y=[y"> <field name="VAR" id="$M8UD=r,/^k]3im{HLX-" variabletype="">warten</field> <value name="VALUE"> <block type="math_number" id="=$Ypv6$E---iUC28RaG6"> <field name="NUM">0</field> </block> </value> <next> <block type="timeouts_setinterval" id="afmm(8JY;`vG1/!b}?:">
    <field name="NAME">Intervall</field>
    <field name="INTERVAL">1</field>
    <field name="UNIT">min</field>
    <block type="math_change" id="o?49A.tCKj3ZAg=#.xr">
    <value name="DELTA">
    <shadow type="math_number" id="tdp}A{~=x$5aJI{h]n9~">
    <field name="NUM">1</field>
    </shadow>
    <block type="math_number" id="b8799A{f$2K,=i}Qw)N">
    </block>
    </value>
    <next>
    <block type="timeouts_settimeout" id="T{!QPpX
    K^Vn9INQU^)]">
    <field name="DELAY">250</field>
    <field name="UNIT">ms</field>
    <block type="controls_if" id="a5vt2QtIR{@LCs].ZYdk">
    <value name="IF0">
    <block type="logic_compare" id="Z(aoX
    Ofc%|BJdTHxc)U">
    <field name="OP">GTE</field>
    <value name="A">
    <block type="variables_get" id="z4fTTUwL.Ul{+K=!G8[n">
    </block>
    </value>
    <value name="B">
    <block type="get_value" id="b[xuuAE53{j-],U%=cGv">
    <field name="OID">controll-own.0.AAATEST.TestZahl</field>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="debug" id=";C#;8fDH%Zr^@ZpsM_mk">
    <value name="TEXT">
    <shadow type="text" id="9p,6fgZrY%-.e0W75F57">
    <field name="TEXT">jetzt aus</field>
    </shadow>
    </value>
    <next>
    <block type="control" id="vSche)0SB-C1%{#gMX1." disabled="true">
    <mutation delay_input="false"></mutation>
    <block type="text" id="$#+B8L[CSMq?^RuxQqX^">
    <field name="TEXT">hier tv ausschalten</field>
    </block>
    </value>
    <next>
    <block type="timeouts_settimeout" id="}wkr+3XbUwV.5kJx/7e%">
    <field name="NAME">timeout2</field>
    <field name="DELAY">500</field>
    <block type="timeouts_clearinterval" id="T,1W]N,o1kIAguqnPXP$">
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    @liv-in-sky
    Die beiden timeout sind überflüssig.
    Variante mit "count down":
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      danke für den hinweis - ich wollte nur sicher gehen - ich dachte das läuft alles "parallel" ab oder hab ich da noch was falsches im kopf (asynchrones synchrones - javascript) ?
      • liv-in-skyL Offline
        liv-in-skyL Offline
        hier die version ohne timeouts - paul hat natürlich recht
        <value name="OID0">
        </shadow>
        </value>
        <value name="TEXT">
        <block type="math_change" id="o?49A.*tCKj3ZAg=#.xr">
        </shadow>
        </block>
        </value>
        <next>
        <value name="IF0">
        Ofc%|BJdTHxc)U">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
          @liv-in-sky sagte:
          Nein, die meisten Befehle werden nacheinander abgearbeitet. Nur Funktionen mit Callback, wie Trigger, setState(), createState() ... arbeiten asynchron.
            @liv-in-sky sagte:
            liv-in-skyL Offline
            liv-in-skyL Offline
            @paul53 danke dir- seit 2 jahren falsch gedacht :-(
              @liv-in-sky sagte:
              liv-in-skyL Offline
              liv-in-skyL Offline
              @paul53 darf ich dir noch eine frage stellen?
              gibt es ein tool oder etwas, dass ausgeschriebene zahlen (fünf, drei, dreiundzwanzig,...) in ein integer verwandelt (5,3,23,...oder muss man da mit einer eigenen tabelle arbeiten ?
              if ( x=="fünf" ) { y=5;};
                @liv-in-sky sagte:
                gibt es ein tool ?
                Mir ist kein Tool bekannt. Wie weit soll es denn reichen ?
                Ich würde die Texte in ein Array schreiben und den Index als Ergebnis verwenden.
                const texte = ['null','eins','zwei',...];
                  @liv-in-sky sagte:
                  gibt es ein tool ?
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @paul53 eigentlich bis 90
                  im moment nutze ich noch die tabelle und habe halt gängige werte gemacht - es geht um den alexa timer - im summery macht alexa bei: alexa timer 3 minuten -> timer drei minuten
                  habe einfach 1-20 und dann in 5er schritten bis 60 - dabei geht es eigentlich um minutentimer beim kochen - da reicht das erstmal
                  werd mal über das array nachdenken
                  vielen dank
                  • F Offline
                    Freakezoid
                    Vielen Dank für die Hilfe jetzt geht es aber jetzt habe ich das Problem das mein Fernseher den Adapter irgendwie nicht frisst :-(
                    habe nen Samsung MU8009
                    • F Freakezoid
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Freakezoid
                      Welchen Adapter nutzt du denn ???
                      • F Offline
                        Freakezoid
                        den samsung adapter
                        GlasfaserG 4 2 Antworten Letzte Antwort
                        • F Freakezoid
                          den samsung adapter
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Freakezoid
                          Wäre schon gewesen welcher Samsung Adapter ;) , da es mehrere Version bzw. Anbieter gibt .
                          Den Adapter habe ich , Version 0.0.2 und er funktioniert.
                          Link Text
                          • F Freakezoid
                            den samsung adapter
                            4 Offline
                            4 Offline
                            4-Real
                            @Freakezoid glaube der ist nicht mehr sehr zuverlässig.
                            habe auch nichts mehr mit dem adapter steuern können.
                            glaube da bleibt dir nur der umweg mit nen harmony hub oder broadlink.
                            • F Offline
                              Freakezoid
                              will eigentlich nur nen timer für den fernseher bauen wer will ich garnicht
                              BBTownB 1 Antwort Letzte Antwort
                              • F Freakezoid
                                BBTownB Offline
                                BBTownB Offline
                                BBTown
                                schrieb am zuletzt editiert von BBTown
                                @Freakezoid
                                Wäre für deine Anforderung eine einfache "Schaltverzögrung" im Blocky-Element des TV denn nicht ausreichend?
                                Wenn Du zufällig auch einen "Broadlink" hast (für Fernbedienungssignale?), dann hätte ich eine Alternative für dich zum Ausschalten des SAMSUNG, sofern der Sasmsung Adapter nicht zuverlässig funktioniert.
                                Brroadlink-Code zum Eiinschalten von SAMSUNG TVs
                                2600d200949413371237133712121213121212131212123713371238121212121213121212121337121212131138123812121213113812131138123812121212123812381212120006009494123713371238121212121213121212121238123713371212121312121213121212371312121212381237121311131238121212371238121213121237123812121200060094941238123713371212121312121212121312371238123713121212121311131212123812121213113812381212121212381212123812371312121212381237121312000d050000000000000000
                                Brroadlink-Code zum Ausschalten von SAMSUNG TVs
                                2600d200969413361337123812121212131211131113123812381237131210141212121310141113121311131136153712131014123713371238133612131113123712381212120006009494123813361436121311131212121310141237133712381311121212131113121211141113121212381238131111131139123713371337111311131139123713121200060094941336123813361411121212131113121212381237133712121213111312121312111312131113123712381311121311381238123713371212121311381337121212000d050000000000000000
