  4. [Aufruf] Countdown Adapter testen
adaptercountdowntester
97 Beiträge 6 Kommentatoren 16.9k Aufrufe 12 Beobachtet
  • jackblacksonJ jackblackson
    @sigi234 So - gut Ding braucht Weile - Version 0.5 ist online, und das mit dem Datum sollte nun funktionieren - hab deine Werte geteste, und es hat funktioniert.
    liv-in-skyL Offline
    liv-in-skyL Offline
    @jackblackson
    kuck mal da
    web.1 2019-07-04 15:24:08.720 info <==Disconnect system.user.admin from ::ffff:192.168.178.26
    host.raspberry3 2019-07-04 15:24:05.247 info Restart adapter system.adapter.countdown.0 because enabled
    host.raspberry3 2019-07-04 15:24:05.247 error instance system.adapter.countdown.0 terminated with code 7 (Adapter already running)
    host.raspberry3 2019-07-04 15:24:04.906 info instance system.adapter.countdown.0 started with pid 29421
    web.1 2019-07-04 15:23:53.852 info <==Disconnect system.user.admin from ::ffff:192.168.178.42 vis.0
    web.1 2019-07-04 15:23:48.391 info <==Disconnect system.user.admin from ::ffff:192.168.178.26 vis.0
    host.raspberry3 2019-07-04 15:23:34.871 info Restart adapter system.adapter.countdown.0 because enabled
    host.raspberry3 2019-07-04 15:23:34.871 error instance system.adapter.countdown.0 terminated with code 7 (Adapter already running)
    host.raspberry3 2019-07-04 15:23:34.482 info instance system.adapter.countdown.0 started with pid 29380
    host.raspberry3 2019-07-04 15:23:04.465 info Restart adapter system.adapter.countdown.0 because enabled
    host.raspberry3 2019-07-04 15:23:04.465 error instance system.adapter.countdown.0 terminated with code 7 (Adapter already running)
    host.raspberry3 2019-07-04 15:23:04.117 info instance system.adapter.countdown.0 started with pid 29341
    web.1 2019-07-04 15:22:43.180 info ==>Connected system.user.admin from ::ffff:192.168.178.26
    web.1 2019-07-04 15:22:41.870 info <==Disconnect system.user.admin from ::ffff:192.168.178.26
    host.raspberry3 2019-07-04 15:22:34.101 info Restart adapter system.adapter.countdown.0 because enabled
    host.raspberry3 2019-07-04 15:22:34.101 error instance system.adapter.countdown.0 terminated with code 7 (Adapter already running)
    host.raspberry3 2019-07-04 15:22:33.734 info instance system.adapter.countdown.0 started with pid 29298
    countdown.0 2019-07-04 15:22:30.699 info received message!
    die instanz geht immer mal wieder auf rot, dann grün, dann rot
    der fehler kam, als ich dass folgende blockly Image 3.png einfach nochmal mit einem anderem datum ausführte
      liv-in-skyL Offline
      liv-in-skyL Offline
      @jackblackson habe die instanz mal gestoppt - htop sagt aber etwas anderes
        liv-in-skyL Offline
        liv-in-skyL Offline
        @jackblackson
        hätte noch eine frage:
        auf githaub schreibst du, dass datum muss folgendermaßen angegebene werden
        der obere pfeil mit den punkten funktioniert nicht- also nur mit bindestrichen getrennt ?
        wäre es nicht möglich, dass datum in deutsch einzugeben: jetzt ist es eine mischung aus amerikanisch und deutsch (jahr am anfang (amerikanisch) aber dann monat und tag (deutsch)
        schöner wäre 31.12.2020 24:00
        wie kann ich die alarme löschen ? geht das über ein sendto oder muss ich datenpunkte löschen ?
        sieht im moment so aus!
        jackblacksonJ 1 Antwort Letzte Antwort
        • P Offline
          PatrickFro
          Hallo jackblackson,
          super, dass Du diesen Adapter entwickelst.
          Wenn es schon ein Countdown ist, könnte man nicht alternativ zu einem bestimmten Datum auch ein Countdown für bestimmte Zeit, z.b. 30 Tage, hinzufügen?
          • P PatrickFro
            Hallo jackblackson,
            jackblacksonJ Offline
            jackblackson
            @PatrickFro Hallo! Würdest du das als "heute + 30 Tage" sehen? Oder welchen Anwendungsfall hättest du hier?
            P 1 Antwort Letzte Antwort
            • liv-in-skyL liv-in-sky
              @jackblackson
              jackblackson
              @liv-in-sky Das mit dem deutschen Datumsformat ist eine gute Idee. Soweit ich das bisher gesehen hab, sind eh die meisten Nutzer von ioBroker hier in Europa. Ich hab auch nachgedacht, ob ich das Datumsformat als Parameter im Setup konfigurierbar mache..ich werd mir das nochmal ansehen.
              Aktuell kann der Datenpunkt nur manell gelöscht werden, oder er läuft ab und man hat im Setup das automatische löschen aktiv. Hier könnte ich eine Möglichkeit sehen, das wenn du mir per SendTo nur einen Namen ohne sonstige Parameter schickst, das es "löschen" bedeutet. Was meinst du dazu?
                liv-in-skyL Offline
                liv-in-skyL Offline
                @jackblackson wär cool - namen eingeben und als zweiten parameter löschen/delete
                welche datenpunkte muss ich löschen - auch etwas unter setup? sollte die instanz gestoppt sein?
                ich habe dir mal ein im ersten post ein link gesendet - darin habe ich so eine verwandlung von amerikanischen in deutsches datum gemacht - in der beschreibung sieht man auch welche formate möglich sind - vielleicht hilft es ja
                if (deadline)  var str = getState("javascript.0.Countdown.Termin.Datum").val;
                if (logging) log(str.indexOf("."));
                if (str.indexOf(".") > 0) {
                    var dmyall = str.split(" ");
                    if (logging)   log(dmyall[0] + '  ' + dmyall[1]);
                    var dmy = dmyall[0].split(".");
                    if (logging)   log(dmy[0] + dmy[1] + dmy[2] + dmyall[0] + dmyall[1]);
                if (typeof(dmyall[1]) != 'undefined') {deadline = new Date(dmy[1] +'.'+ dmy[0] + '.' + dmy[2] + ' ' + dmyall[1]);if (logging) log("mit Zeit")} else { deadline = new Date(dmy[1] +'.'+ dmy[0] + '.' + dmy[2]);if (logging) log("keine Zeit")}} else
                {deadline = new Date(getState(idTerminDatum).val);if (logging) log("altes Datumsformat)"); }
                https://forum.iobroker.net/topic/22574/vorlage-zeit-herunterzählen-bis-googletermin-eintritt
                bei dem fehler von oben - evtl habe ich auch ein falsches datum eingegeben - und dann ist der adapter abgestürtzt - und iobroker wollte ihn neustarten und dann kam der fehler , dass erschon läuft - hast du falscheingaben abgefragt
                das mit dem sendto ist ein echter mehrwert - wäre/ist/wird ein super adapter
                  PatrickFro
                  @jackblackson Genau. Ich sehe dafür einige Anwendungsmöglichkeiten. Ich suche z.b. gerade einen Countdown, durch den ich an die Reinigung der Kaffeemaschine erinnert werde (alle 30 Tage). Über ical lohnt sich das meiner Meinung nach nicht. Erinnerungen zum Nachkauf von Verbrauchsartikeln wäre damit auch möglich...
                  • P PatrickFro
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @PatrickFro wenn es schnell gehen soll funktioniert das damit - der eigentliche countdown ist das 2te script (javascript) .
                    aber ich hoffe, es wird in diesem adapter integriert - da tolle idee - dann einfach warten
                    hier steuer-blockly zum import
                      <block type="on" id="Yu_[ga/s]Hyeh8nsx^+:" x="88" y="112">
                        <field name="OID">javascript.0.Countdown.Termin.inTagen</field>
                        <statement name="STATEMENT">
                          <block type="control" id="4Wm(ATbrtz9$IE;YViQ.">
                            <mutation delay_input="false"></mutation>
                            <field name="OID">javascript.0.Countdown.Termin.Datum</field>
                            <value name="VALUE">
                              <block type="convert_from_date" id="N?=6!uE55(IgDv+~R@+h">
                                <mutation format="true" language="false"></mutation>
                                <field name="OPTION">custom</field>
                                <field name="FORMAT">TT.MM.JJJJ SS:mm</field>
                                  <block type="math_arithmetic" id="0zHp1C{=1+0BqMb^]Wve">
                                    <field name="OP">ADD</field>
                                    <value name="A">
                                      <shadow type="math_number" id=";rfh%LBqSCHmgS?Lu8gC">
                                        <field name="NUM">1</field>
                                      </shadow>
                                      <block type="time_get" id="x3FH1{1qx{mjE^G`7[;J">
                                        <mutation format="false" language="false"></mutation>
                                        <field name="OPTION">object</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="8*zEGo+u^A}wgHE0*w:!">
                                      </shadow>
                                      <block type="math_arithmetic" id="l]S_I1TT{S1/QP^qOCt$">
                                        <field name="OP">MULTIPLY</field>
                                        <value name="A">
                                          <shadow type="math_number" id="9(cDBM/2W$P,k8.keSSI">
                                          </shadow>
                                          <block type="math_number" id="8TC2R-FAd;R(5`=?/vC+">
                                            <field name="NUM">86400000</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="rgP;5M:c9HlgZF.R9RxU">
                                          </shadow>
                                          <block type="get_value" id="9+DRg;F3gTh$C}J~1uq2">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                      <block type="schedule" id="1J7D1Q/))cpAR,$0[,Y/" x="62" y="362">
                        <field name="SCHEDULE">* * * * *</field>
                          <block type="controls_if" id="Vz9CXtmz#C$?=DIhBrtx">
                            <value name="IF0">
                              <block type="logic_compare" id="2iy?B56Y^Qr#XQYNW-}Z">
                                <field name="OP">EQ</field>
                                <value name="A">
                                  <block type="get_value" id="MC^AXX]95vxPW?KN#}Il">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="text" id="`/DK+W6T6BxE}D+xQ#e`">
                                    <field name="TEXT">FERTIG</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO0">
                              <block type="control" id="txCpapjXf9C}|TaeuAFk">
                                  <block type="convert_from_date" id="(.4KE[dPnOZR+]OBlgiX">
                                      <block type="math_arithmetic" id="2([b[!X#}^f])9rC!s(^">
                                        <value name="A">
                                          </shadow>
                                          <block type="time_get" id="|zV9MwctrO5Ln,,,z5N3">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          <block type="math_arithmetic" id="]a#l{:!#GH*I`%PitXWq">
                                            <value name="A">
                                              </shadow>
                                              <block type="math_number" id="(u53CEM{S@x9y~yafF$#">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                              <block type="get_value" id="B3Wz6T/T?1}z$.eZ7Yj@">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    und als grundscript den countdown hier zum import
                    // Termin Skript zählt bis Termin runter   erstellt: 26.01.2016 von Pix
                    // weiterverarbeitet 26-2-2019 von liv-in-sky
                    //moegliche formate fur das datum - uhrzeit optional
                    // 9.4.2019 10:00
                    // 9.4.2019
                    // 9 May 2019 10:00   - (Monat 3 Buchstaben engl. Abkuerzung)
                    // 9 May 2019 - (Monat 3 Buchstaben engl. Abkuerzung)
                    var instanz = 'javascript.0'; var logging = false;
                    // ab hier nix mehr ändern
                    createState('Countdown.Termin.Datum', '9/4/2019', { name: 'Termin Datum', desc: 'Datum des Termins (als Objekt)', type: 'string' });
                    createState('Countdown.Termin.Datum.String', '3.12.2019', { name: 'Termin Datum (als String)', desc: 'Datum des Termins als Zeichenkette', type: 'string' });
                    createState('Countdown.Termin.Name', 'Name des Termins', { name: 'Termin Name', desc: 'Bezeichnung des Termins', type: 'string' });
                    createState('Countdown.Termin.Rest.TotalText', 'Termingesamt', { name: 'TotalText', desc: 'TotalText', type: 'string' });
                    createState('Countdown.Termin.Rest.Total', { name: 'Millisekunden bis zum Termin', desc: 'Restliche Millisekunden bis zum Datum des Termins', type: 'number', unit: 'ms' });
                    createState('Countdown.Termin.Rest.Tage', { name: 'Tage bis zum Termin', desc: 'Restliche Tage bis zum Datum des Termins', type: 'number', unit: 'Tage' });
                    createState('Countdown.Termin.inTagen', { name: 'Start in Tagen', desc: 'Start in Tagen', type: 'number', unit: 'Tage' });
                    createState('Countdown.Termin.Rest.Minuten', { name: 'Minuten bis zum Termin', desc: 'Restliche Tage bis zum Datum des Termins', type: 'number', unit: 'Minuten' });
                    createState('Countdown.Termin.Rest.Stunden', { name: 'Stunden bis zum Termin', desc: 'Restliche Tage bis zum Datum des Termins', type: 'number', unit: 'Stunden' });
                    createState('Countdown.Termin.Rest.Wochen', { name: 'Wochen bis zum Termin', desc: 'Restliche Wochen bis zum Datum des Termins', type: 'number', unit: 'Wochen' });
                    createState('Countdown.Termin.Rest.Alarm', { name: 'Alarm', desc: 'Alarm bis zum Datum des Termins', type: 'boolean' });
                    createState('Countdown.Termin.Rest.Fertig', { name: 'Fertig', desc: 'Fertig', type: 'boolean' });
                    var idFertig = instanz + '.Countdown.Termin.Rest.Fertig', idAlarm = instanz + '.Countdown.Termin.Rest.Alarm', idStunden = instanz + '.Countdown.Termin.Rest.Stunden', idMinuten = instanz + '.Countdown.Termin.Rest.Minuten', idTotalText = instanz + '.Countdown.Termin.Rest.TotalText', idTerminDatum = instanz + '.Countdown.Termin.Datum', idTerminDatumString = instanz + '.Countdown.Termin.Datum.String', idTerminName = instanz + '.Countdown.Termin.Name', idTotal = instanz + '.Countdown.Termin.Rest.Total', idTage = instanz + '.Countdown.Termin.Rest.Tage', idWochen = instanz + '.Countdown.Termin.Rest.Wochen';
                    var deadline;
                    function getTimeRemaining(endtime) {
                    var virttime = new Date();
                    var virt2time=formatDate(virttime);
                    var t = Date.parse(endtime) - Date.parse(virttime);
                    if (virttime.getTimezoneOffset() == -60 && virttime.getTimezoneOffset() == -120  ){t=t+3600000};
                    if (virttime.getTimezoneOffset() == -120 && virttime.getTimezoneOffset() == -60  ){t=t-3600000};
                    var seconds = Math.floor( (t/1000) % 60 );
                    var minutes = Math.floor( (t/1000/60) % 60 );
                    var hours = Math.floor( (t/(1000*60*60)) % 24 );
                    var days = Math.floor( t/(1000*60*60*24) );
                    var weeks = Math.floor( t/(1000*60*60*24*7) );
                    return { 'total': t, 'days': days, 'hours': hours, 'minutes': minutes, 'seconds': seconds, 'weeks' : weeks };
                    function restzeit() {
                    setState(idTerminDatumString, formatDate(deadline));
                    setState(idTage, getTimeRemaining(deadline).days);
                    setState(idWochen, getTimeRemaining(deadline).weeks);
                    setState(idTotal, getTimeRemaining(deadline).total);
                    setState(idMinuten, getTimeRemaining(deadline).minutes);
                    setState(idStunden, getTimeRemaining(deadline).hours);
                    //log(deadline.getTimezoneOffset());
                    setState(idTotalText,  getTimeRemaining(deadline).days.toString() + " Tag(e) " +getTimeRemaining(deadline).hours.toString() + " Stunde(n) " + getTimeRemaining(deadline).minutes.toString() + " Minute(n) ");
                      setTimeout(function () { //The timer
                    if ( getState(idTage).val == 0  && getState(idStunden).val <= 4  ){setState(idAlarm, true) ;} else {setState(idAlarm, false); } //
                     }, 2000);
                     if ( getState(idTage).val == 0  && getState(idStunden).val == 0 && getState(idMinuten).val <= 0 ){setState(idFertig, true) ;setState(idTerminName, "FERTIG");setState(idTerminDatum, "FERTIG");} else {setState(idFertig, false); } //
                     }, 3000);
                    if (logging) log(getTimeRemaining(deadline).days + ' Resttage (' + getTimeRemaining(deadline).weeks + ' Wochen) bis zum ' + formatDate(deadline) + ' (' + getState(idTerminName).val + ')'); }
                    // Mitternacht
                    schedule('*/1 * * * *', function() { restzeit(); });
                    //bei Restart
                    var datecounter = getState("javascript.0.Countdown.Termin.Datum").val;
                    if (getState("javascript.0.Countdown.Termin.Datum").val != "") {
                    setStateDelayed("javascript.0.Countdown.Termin.Datum", datecounter, 2000, false);}
                    // Bei Terminänderung
                    on({id: 'javascript.0.Countdown.Termin.Datum', change: 'any'}, function (obj) {
                        deadline = new Date("4.5.2019");
                         restzeit();
                    // Scriptstart
                    das blockly script steuert das javascript - alle datenpunkte werden unter javascript.0.countdown angelegt - du musst nur die anzahl tage (javascript.0.Countdown.Termin.inTagen) ändern und schon wird "gecountdownt"
                    • P Offline
                      PatrickFro
                      super, vielen Dank. Eingebaut ist es, morgen werde ich sehen, ob ich es korrekt gemacht habe 😉
                      • jackblacksonJ Offline
                        jackblackson
                        @PatrickFro @liv-in-sky So - Version 0.6 ist fertig. Ihr könnt nun das Datumsformat aussuchen - Standard ist DD.MM.YYYY HH.mm. Weiters kann man mit SendTo nur des Namens den Countdown löschen. Es ist auch möglich, mit adddays, addmonths und addyears einen Countdown ab Heute zu erstellen - sollte alles im Readme erklärt sein. Freu mich auf euer Feedback und etwaige Verbesserungsvorschläge - und danke für eure Geduld!
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @jackblackson
                          • konnte ohne probleme drüber installieren
                          • konnte alle alten tests löschen
                          • konnte neue anlegen
                          • falsches datum wurde erkannt
                          • konnte existierenden einfach mit neuen datum überschreiben
                          eine frage - habe es in der vis versucht, einzugeben - also direkt in das datumsfeld zu schreiben - das funktioniert nicht- kann man das noch "enabeln" ? (man kann es über ein script ja auch lösen - falls nicht) (gelber pfeil)
                          adddays:
                          ich habe einfach mal einen neuen namen und adddays benutzt - datenpunkte werde angelegt bleiben aber leer - bug oder feature :-) - kann ihn nicht mehr löschen über blockly !
                          • ist adddays mit exisiterenden countdown oder einem neuen countdown zu nutzen?
                          jackblacksonJ 2 Antworten Letzte Antwort
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @jackblackson
                            so wie es aussieht geht adddays nur mit neuem namen - ist das richtig ? das funktioniert jetzt, nachdem ich mal alle alten tests gelöscht habe
                            einen neuen countdown mit adddays kann ich anlegen und löschen
                              @jackblackson
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @liv-in-sky
                              zeige mir doch mal bitte wie ich den Adapter aktuell nutzen kann. (Screeshot Blockly reicht)
                              Beispiel:
                              Der Rasenmäher schaltet auf Regenpause (state ist vorhanden-true/false), dann soll ein Countdown gestartet werden der mir die Restlaufzeit der Regenpause anzeigt.(bei mir 90 Minuten, auch der state ist vorhanden)
                              Wenn die Zeit abgelaufen ist, oder der Mäher wieder fährt, kann der Countdown automatisch wieder gelöscht werden oder auf Null gesetzt werden.
                              Ich würde mir das dann gern in iQontrol anzeigen lassen. (wie lange dauert die Regenpause noch ?)
                                @jackblackson
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @liv-in-sky
                                PS: ich habe bisher nicht verstanden wie man einen neuen Countdown setzt und dann startet.
                                Bisher schmiert mir der Adapter mit meinen Versuchen über sendto immer ab und startet ständig neu...
                                • dslraserD dslraser
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #66
                                  @dslraser bei dem problem adapter ertmal stoppen - dann
                                  terminal: pgrep countdown.0 -- falls wert zurückommt --> kill "wert" -- dann würde ich alle eintrage in den objecten löschen und die instanz dann wieder starten - wichtig - version 0.6 von github nehmen
                                  ich glaube du kannst keine minuten oder stunden angeben @jackblackson - vielleicht kann man das noch einbauen - addminutes, addhours
                                  beispiel mit adddays:
                                  in der momentanene version müßtest du ein blockly erstellen - zeitjetz +90minuten - und das dann einsetzen - statt 540000 eine variable !
                                  ich nehme mal an, nach dem countdown (datenpinkt "reached" ist true muss der countdown wieder gelöscht werden
                                  ich nehme mal an, nach dem countdown (datenpunkt "reached" ist true muss der countdown wieder gelöscht werden: (nur name als parameter löscht countdown)
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #67
                                    @liv-in-sky
                                    ah, okay, danke. Also doch noch zu Fuß rechnen. Ich dachte das könnte der Adapter selbst.
                                    Würde jedenfalls Sinn machen.
                                    Obwohl, in Deinem Datenpunkt steht ja 1 Stunde 28 Minuten (das ist doch die Restlaufzeit, oder ?)
                                    Das würde ja reichen.
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #68
                                      @dslraser ja genau - und der datenpunkt "reached" ist true - kann dir beim triggern für das nächst-anfallende helfen
                                      vielleicht kommt das noch dazu - momentan addyears, addmonths, adddays
                                      gut wäre auch addminutes, addhours
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #69
                                        @dslraser es gibt ja noch diese möglichkeit
                                        aber da denke ich ist das ausrechnen für 90 minuten noch mehr
                                          @jackblackson
                                          adddays:
                                          jackblackson
                                          schrieb am zuletzt editiert von jackblackson
                                          #70
                                          @liv-in-sky Ich schau mir das an, das man auch mit adddays überschreiben kann. Es sollte auch mit neuen Countdowns funktionieren - eigentlich nur mit diesen ;)
                                          @dslraser Ich werde noch einen Screenshot für die Add-Sachen im Readme hinzufügen. Ich schau, das ich noch addminutes und addhours einbaue.
                                          Die Datenpunkte bleiben bestehen, wenn im Setup das Autodelete nicht aktiv ist. Dann wechselt Reached auf true .
