  4. JavaScript
  5. Frage Javascript "on-id-change"
javascript
45 Beiträge 3 Kommentatoren 7.1k Aufrufe 5 Beobachtet
    sveni_lee
    okay, also das ganze sieht nun so aus...
    var anwesenheit_devices = ["hm-rega.0.1857", "hm-rega.0.1858", "hm-rega.0.1864"];
    var online_devices = ["hm-rega.0.1867", "hm-rega.0.1868", "hm-rega.0.1869", "hm-rega.0.1871", "hm-rega.0.1872", "hm-rega.0.1873", "hm-rega.0.1874", "hm-rega.0.1875", "hm-rega.0.1876", "hm-rega.0.1877", "hm-rega.0.1879", "hm-rega.0.1880", "hm-rega.0.1881", "hm-rega.0.1882", "hm-rega.0.1883", "hm-rega.0.1884"];
    var str;
    var humans = {"hm-rega.0.1857" : "XXX", "hm-rega.0.1858" : "YYY", "hm-rega.0.1864" : "ZZZ"};
    on(anwesenheit_devices, function(dp) {
       if(dp.state.val) {
          var str1 = dp.id;
          // Reaktionen auf true
          sendTo("telegram.0", "send", {
            text: humans[dp.id] + " ist anwesend"
       else {
          // Reaktionen auf false
            text: humans[dp.id] + " ist abwesend"
    on(online_devices, function(dp) {
        str = dp.common.name;
       if(dp.state.val) {
            text: str.substr(12) + " ist online"
       else {
            text: str.substr(12) + " ist offline"
    Ich warte dann mal bis heute nachmittag jemand nach Hause kommt. ann weiß ich ob es geht.
      sveni_lee
      jetzt versuche ich grad in dem zusammenhang eien json-datei auszulesen.
      [{"id":290,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:48","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":289,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:47","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":288,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:46","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":287,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:45","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":286,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:43","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":285,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:42","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":284,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:40","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":283,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:38","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":282,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:33","duration":"0:00","count":"","path":"","sym":"x","external":""},
       {"id":281,"type":"2","caller":"","called":"SIP: 700000","callednumber":"700000","name":"Unbekannt","numbertype":"sip","device":"","port":"-1","date":"24.06.19 14:29","duration":"0:00","count":"","path":"","sym":"x","external":""}]
      jetzt hatte ich folgendes probiert um zu sehen ob etwas augegeben wird:
          var objects = JSON.parse(jsonstring);
          log(objects.id);
      aber wird es natürlich nicht. Ich denke ich müsste mit einer Schleife arbeiten aber irgendwie hab ich da grad keine idee...
      thewhoboxT 1 Antwort Letzte Antwort
      • S sveni_lee
            log(objects.id);
        thewhoboxT Offline
        thewhoboxT Offline
        thewhobox
        @sveni_lee
        Bei dir ist objects ein Array/Liste.
        Du musst, wie du gesagt hast, mit einer Schleife alle Einträge durchgehen.
        for(var i = 0; i<objects.length; i++) {
            var tempObj = objects[i];
            log(tempObj.id);
        Meine Adapter: emby | discovery
          sveni_lee
          ja, das hat funktioniert.
          ich hab das ganze jetzt mal versuht in ein scrpt zu packen: am ende möchte ich per telegram einen button drücken und dann bekomme ich die entsprechende Liste.
          var jsonstring = getState("tr-064-community.0.calllists.missed.json"/*json*/).val;
          function list_Calls(jsonstring, call_list){
              call_list = call_list.split('\r\n');
                  call_list.unshift(tempObj.date + " " + tempObj.name + " " + tempObj.caller + '\r\n');
              log(call_list);
               text: call_list
          list_Calls(jsonstring, "missed calls:");
          wenn ich das so mache bekomme ich eine Fehlermeldung von Telegram:
          telegram.0	2019-06-25 12:06:59.838	error	Cannot send message [chatId - xxxxxxx]: Error: ETELEGRAM: 400 Bad Request: message text is empty
          javascript.0	2019-06-25 12:06:59.812	info	script.js.common.Telegram.Abfrage_Calls: registered 0 subscriptions and 0 schedules
          javascript.0	2019-06-25 12:06:59.812	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.javascript.0
          javascript.0	2019-06-25 12:06:59.811	info	,missed calls:
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:48 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:47 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:46 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:45 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:43 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:42 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:40 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:38 Unbekannt
          javascript.0	2019-06-25 12:06:59.811	info	,24.06.19 14:33 Unbekannt
          lt. Log wird die Variable "call_list" ja erzeugt.
          • S sveni_lee
                log(call_list);
                 text: call_list
            thewhoboxT Offline
            thewhoboxT Offline
            thewhobox
            @sveni_lee Das problem ist, dass call_list ein Array ist und kein String.
            Das erstellt ein Array und trennt den String nach jeder neuen Zeile.
            Lass das weg, dann bleibt es ein String.
            Und ersetze dann folglich:
            durch
            call_list = tempObj.date + " " + tempObj.name + " " + tempObj.caller + '\r\n' + call_list;
            Oder... was ach geht:
                 text: call_list.join("\r\n");
            (Dann musst du aber das \r\n in "unshift" weglassen, da sonst zwei Zeilenumbrüche entstehen.)
              sveni_lee
              ja, das klappt...
              aber kann ich irgendwie das "missed calls:" an den Anfang?
              • S sveni_lee
                ja, das klappt...
                thewhoboxT Offline
                thewhoboxT Offline
                thewhobox
                @sveni_lee Ich würde es so machen:
                function list_Calls(){
                    var call_list = [];
                        call_list.push(tempObj.date + " " + tempObj.name + " " + tempObj.caller);
                    call_list = call_list.reverse();
                    log(call_list);
                        text: "missed calls:\r\n\r\n" + call_list.join("\r\n");
                list_Calls();
                Was es tut:
                Es schreibt alle Anrufer in ein Array.
                Array umdrehen, damit neue ganz oben stehen.
                Array zusammenführen mit einem Zeilenumbruch, davor noch "missed calls" anfügen.
                Minimaler aufwand, Liste wird bei jedem Funktionsaufruf aktualisiert, keine unnötigen Parameter.
                  sveni_lee
                  jepp...
                  perfect: so klappt es.
                    sveni_lee
                    gibt es auch einen "schnellen weg" an den vorherigen Wert eines DP zu gelangen?
                    als ich möchte den aktuellen Wert gern mit dem Wert davor vergleichen...
                    • S sveni_lee
                      thewhoboxT Offline
                      thewhoboxT Offline
                      thewhobox
                      @sveni_lee Den alten Wert bekommst du mit
                      dp.oldState.val
                        sveni_lee
                        ich habe mal einen kleinen Test gemacht...
                        function test() {
                           var dp = "hm-rpc.0.xxxxxxxx.1.DIRECTION";
                           log("State: " + dp.oldState.val);
                        test();
                        klappt aber nicht
                        Log:
                        javascript.0	2019-06-26 08:59:45.835	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                        javascript.0	2019-06-26 08:59:45.835	error	at script.js.common.Telegram.Test:5:1
                        javascript.0	2019-06-26 08:59:45.835	error	at test (script.js.common.Telegram.Test:3:32)
                        javascript.0	2019-06-26 08:59:45.835	error	TypeError: Cannot read property 'val' of undefined
                        javascript.0	2019-06-26 08:59:45.835	error	^
                        javascript.0	2019-06-26 08:59:45.835	error	log("State: " + dp.oldState.val);
                        javascript.0	2019-06-26 08:59:45.835	error	script.js.common.Telegram.Test: script.js.common.Telegram.Test:3
                        • S sveni_lee
                          function test() {
                          test();
                          klappt aber nicht
                          Log:
                          thewhoboxT Offline
                          thewhoboxT Offline
                          thewhobox
                          @sveni_lee Ja, weil deine Variable dp nur ein String ist.....
                          Ebenso ist "oldState" nur innerhalb des Triggers vorhanden.
                            sveni_lee
                            okay... ich probiere es mal inner halb eines Triggers.
                              sveni_lee
                              das hat jetzt schon mal richtig gut geklappt...
                              danke für die Hilfe!
                              Wie das immer so ist, kommt ein zum anderen.
                              kann ich irgendwie eine Zeitschleife einbauen, das der neue wert erst übertragen wird, wenn ein DP, wie in diesem Fall "Festverglasung rechts.WORKING" wieder auf false steht.
                              ich hatte da an eine "while" Schleife gedacht oder soetwas in der Art.
                              • S sveni_lee
                                thewhoboxT Offline
                                thewhoboxT Offline
                                thewhobox
                                @sveni_lee Ich verstehe nicht ganz was du erreichen willst?
                                Was meinst du mit Zeitschleife? oder neuer Wert?
                                Wenn der Adapter den neuen Wert setzt hast du in Javascript keinen Einfluss darauf.
                                Da musst du dann mit einem eigenen Datenpunkt arbeiten, den du nur setzt, wenn der DP false ist.
                                Da ist eine schleife unnötig, da du einfach auf den DP triggerst und mit nem if prüfst ob es false ist.
                                Mal ein Beispiel:
                                var stateToHold;
                                //Speichere den letzen Helligkeitswert in einer Variable
                                on({id: "hue.0.Light_0.bri", change: "ne", ack: true}, (dp) => {
                                    stateToHold = dp.state.val;
                                //Triggere wenn Lampe geschaltet wird
                                on({id: "hue.0.Light_0.on", change: "ne", ack: true}, (dp) => {
                                    //wenn Lampe ausgeschaltet wird, schreibe letzt Helligkeit in einen eigenen Datenpunkt
                                    if(dp.state.val == false) {
                                        setState("mein.eigener.datenpunkt.lastbri", stateToHold, true);
                                  sveni_lee
                                  okay, da hatte ich mich undeutlich ausgedrückt.
                                  ich trigger zur den Level eines Rollladen. wenn der Wert sich ändert wird mir das gemeldet.
                                  Das Problem ist aber, das der Wert sich solange ändert bis der Rolladen die Endposition erreicht hat.
                                  Ich möchte die Nachricht erst haben, wenn die endposition erreicht ist.
                                  Es gibt den DP "Festverglasung rechts.WORKING" der geht auf true solange der Rollladen in Bewegung ist.
                                  Ich wollte nun den DP als auslöser verwenden um die nachricht abzusetzen...
                                  • S sveni_lee
                                    @sveni_lee sagte:
                                    const idFestRechtsWork = getIdByName('Festverglasung rechts.WORKING');
                                    const idFestRechtsLevel = getIdByName('Festverglasung rechts.LEVEL');
                                    var rechtslevel = getState(idFestRechtsLevel).val; // Initialisierung bei Skriptstart
                                    on(idFestRechtsLevel, function(dp) { // Triggern bei Wertänderung
                                        rechtslevel = dp.state.val;
                                    on(idFestRechtsWork, function(dp) {
                                       if(!dp.state.val) { // Änderung auf false
                                          // Nachricht mit Auswertung von rechtslevel
                                      sveni_lee
                                      wie könnte ich mir anzeigen lassen, welcher state getriggert hat?
                                      var Rolllaeden = ["hm-rpc.0.xxxx.1.LEVEL"/*Terrassentür links.LEVEL*/, "hm-rpc.0.yyyy.1.LEVEL"/*Terrassentür rechts.LEVEL*/, "hm-rpc.0.zzzz.1.LEVEL"/*Festverglasung links.LEVEL*/, "hm-rpc.0.rrrr.1.LEVEL"/*Festverglasung rechts.LEVEL*/];
                                      on(Rolllaeden, function(dp) {...
                                      • S sveni_lee
                                        @sveni_lee sagte:
                                           log('Trigger: ' + dp.common.name);
                                          sveni_lee
                                          ich kann das grad nicht testen. gibt das den State "hm-rpc.0.xxxx.1.LEVEL" oder den Namen "Terrassentür links.LEVEL" aus?
