  3. Cloud Dienste
  4. IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!
    6.3k
643 Beiträge 91 Kommentatoren 194.9k Aufrufe 57 Beobachtet
  • NashraN Nashra
    Adapter auf 2.3.1 aktualisiert und im Log taucht dies auf:
    host.ioBroker-Slave	2019-06-21 10:10:00.039	info	instance system.adapter.dwd.0 started with pid 12642
    host.ioBroker-Slave	2019-06-21 10:10:00.038	info	instance system.adapter.openweathermap.0 started with pid 12636
    host.ioBroker-RasPi	2019-06-21 10:09:57.008	info	Restart adapter system.adapter.alexa2.0 because enabled
    host.ioBroker-RasPi	2019-06-21 10:09:57.008	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
    host.ioBroker-RasPi	2019-06-21 10:09:57.008	error	Caught by controller[0]: at Receiver.getData (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:352:17)
    host.ioBroker-RasPi	2019-06-21 10:09:57.008	error	Caught by controller[0]: at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:413:14)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at Receiver.emit (events.js:198:13)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/websocket.js:789:20)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at WebSocket.emit (events.js:198:13)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at WebSocket.websocket.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-wsmqtt.js:202:22)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at AlexaWsMqtt.emit (events.js:198:13)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at AlexaWsMqtt.alexaWsMqtt.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:348:26)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at AlexaRemote.emit (events.js:198:13)
    host.ioBroker-RasPi	2019-06-21 10:09:57.007	error	Caught by controller[0]: at AlexaRemote.alexa.on (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2112:46)
    host.ioBroker-RasPi	2019-06-21 10:09:57.006	error	Caught by controller[0]: TypeError: Cannot read property 'serialNumber' of undefined
    Was kann/muß ich tun
    #562
    @Nashra Bitte nochmal vom Github aktualisieren. Jetzt besser? Version bleibt 2.3.1
    • J Jan1
      @lexlev
      irgendwie klemmt da die Kommunikation in der Richtung bei Dir. Mir gehen die Ideen dazu leider aus. Musst auf @apollon77 warten, ob er was raus lesen kann, er sitzt ja eh dran und strickt ☺
      lexlev
      #563
      @Jan1
      Schon nur trotzdem komisch nach mehreren Neuinstallationen auf Docker und auch VM Debian.
      Trotzdem erstmal danke für deine Zeit, dann warte ich mal auf @apollon77 ☺
      • L lexlev
        @Jan1
        Das habe ich schon mehrfach gemacht:
        https://www.directupload.net/file/d/5490/f6r94xe4_png.htm
        Was mir auffällt, die Werte werden beim starten des Alex Adapters eingelesen, aber ab dann nicht mehr aktualisiert. 🤔
        Wenn ich NUR das Einschalten eines Gerätes über Echo (wohnzimmer media atmo einschalten) im Alexa Adapter debuge, bekomme ich folgendes im LOG und der Wert unter Objekte bleibt trotzdem auf false:
        Seriennummern und IDs wurden verfälscht:
        alexa2.0	2019-06-21 10:07:17.413	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2019-06-21 10:07:17.290	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2019-06-21 10:04:17.408	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2019-06-21 10:04:17.285	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2019-06-21 10:01:17.403	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2019-06-21 10:01:17.280	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2019-06-21 09:58:17.407	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2019-06-21 09:58:17.279	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2019-06-21 09:57:40.780	debug	sendTo "getStatusInfo" to system.adapter.admin.0 from system.adapter.alexa2.0
        alexa2.0	2019-06-21 09:57:40.780	debug	Message: {"command":"getStatusInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":171,"ack":false,"time":1561103860771},"_id":7564641}
        alexa2.0	2019-06-21 09:56:37.970	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.muted: {"val":false,"ack":true,"ts":1561103797968,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921778}
        alexa2.0	2019-06-21 09:56:37.968	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.volume: {"val":30,"ack":true,"ts":1561103797966,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921776}
        alexa2.0	2019-06-21 09:56:37.966	debug	Alexa-Push-Connection Device Volume change for G090U11111171B52 -> 30/false
        alexa2.0	2019-06-21 09:56:37.966	debug	Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "dopplerId": { "deviceSerialNumber": "G090U11111171B52", "deviceType": "A32DOYUDS1DTXA
        alexa2.0	2019-06-21 09:56:37.959	debug	Alexa-Remote WS-MQTT: Command PUSH_EQUALIZER_STATE_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "bass": 0, "treble": 0, "dopplerId": { "deviceSerialNumber": "G090U5022222B5
        alexa2.0	2019-06-21 09:56:35.496	debug	State changed alexa2.0.History.json: {"val":"{\"name\":\"Alexanders Echo Dot\",\"serialNumber\":\"G090U11111171B52\",\"summary\":\"wohnzimmer media atmo einschalten\",\"creationTime\":1561103795401,\"
        alexa2.0	2019-06-21 09:56:35.496	debug	State changed alexa2.0.History.cardJson: {"val":"","ack":true,"ts":1561103795489,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099185962}
        alexa2.0	2019-06-21 09:56:35.496	debug	State changed alexa2.0.History.cardContent: {"val":"","ack":true,"ts":1561103795489,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099185956}
        alexa2.0	2019-06-21 09:56:35.496	debug	State changed alexa2.0.History.domainApplicationname: {"val":"","ack":true,"ts":1561103795488,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561102693211}
        alexa2.0	2019-06-21 09:56:35.496	debug	State changed alexa2.0.History.domainApplicationId: {"val":"","ack":true,"ts":1561103795488,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099185946}
        alexa2.0	2019-06-21 09:56:35.495	debug	State changed alexa2.0.History.creationTime: {"val":1561103795401,"ack":true,"ts":1561103795488,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561103795488}
        alexa2.0	2019-06-21 09:56:35.495	debug	State changed alexa2.0.History.status: {"val":"SUCCESS","ack":true,"ts":1561103795488,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561102693211}
        alexa2.0	2019-06-21 09:56:35.495	debug	State changed alexa2.0.History.summary: {"val":"wohnzimmer media atmo einschalten","ack":true,"ts":1561103795487,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561103795487}
        alexa2.0	2019-06-21 09:56:35.495	debug	State changed alexa2.0.History.serialNumber: {"val":"G090U11111171B52","ack":true,"ts":1561103795486,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561103571238}
        alexa2.0	2019-06-21 09:56:35.495	debug	State changed alexa2.0.History.name: {"val":"Alexanders Echo Dot","ack":true,"ts":1561103795484,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561103571237}
        alexa2.0	2019-06-21 09:56:35.495	debug	device-activity: {"data":{"_disambiguationId":null,"activityStatus":"SUCCESS","creationTimestamp":1561103795401,"description":"{\"summary\":\"echo wohnzimmer media atmo einschalten\",\"firstUtteranceI
        alexa2.0	2019-06-21 09:56:35.495	debug	Alexa-Remote: Response: {"activities":[{"_disambiguationId":null,"activityStatus":"SUCCESS","creationTimestamp":1561103795401,"description":"{\"summary\":\"echo wohnzimmer media atmo einschalten\",\"f
        alexa2.0	2019-06-21 09:56:35.152	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/activities?startTime=&size=3&offset=1","method":"GET","timeout":10000,"headers":{}}
        alexa2.0	2019-06-21 09:56:35.152	debug	Alexa-Remote: No authentication check needed (time elapsed 442684)
        alexa2.0	2019-06-21 09:56:35.151	debug	Alexa-Remote WS-MQTT: Command PUSH_ACTIVITY: { "destinationUserId": "AD2SUUSMJQ11X", "key": { "entryId": "1566666666401#A32DOYNONONODTXA#G090U11111171B52", "registeredUserId": "A
        alexa2.0	2019-06-21 09:56:34.878	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.muted: {"val":false,"ack":true,"ts":1561103794876,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921778}
        alexa2.0	2019-06-21 09:56:34.877	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.volume: {"val":30,"ack":true,"ts":1561103794875,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921776}
        alexa2.0	2019-06-21 09:56:34.873	debug	Alexa-Remote WS-MQTT: Command PUSH_EQUALIZER_STATE_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "bass": 0, "treble": 0, "dopplerId": { "deviceSerialNumber": "G090U5022222B5
        alexa2.0	2019-06-21 09:56:34.873	debug	Alexa-Push-Connection Device Volume change for G090U11111171B52 -> 30/false
        alexa2.0	2019-06-21 09:56:34.873	debug	Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "dopplerId": { "deviceSerialNumber": "G090U11111171B52", "deviceType": "A32DOYUDS1DTXA
        alexa2.0	2019-06-21 09:56:31.914	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.muted: {"val":false,"ack":true,"ts":1561103791911,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921778}
        alexa2.0	2019-06-21 09:56:31.913	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.volume: {"val":30,"ack":true,"ts":1561103791910,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921776}
        alexa2.0	2019-06-21 09:56:31.911	debug	Alexa-Remote WS-MQTT: Command PUSH_EQUALIZER_STATE_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "bass": 0, "treble": 0, "dopplerId": { "deviceSerialNumber": "G090U5022222B5
        alexa2.0	2019-06-21 09:56:31.911	debug	Alexa-Push-Connection Device Volume change for G090U11111171B52 -> 30/false
        alexa2.0	2019-06-21 09:56:31.911	debug	Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "dopplerId": { "deviceSerialNumber": "G090U11111171B52", "deviceType": "A32DOYUDS1DTXA
        alexa2.0	2019-06-21 09:56:31.438	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.muted: {"val":false,"ack":true,"ts":1561103791436,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921778}
        alexa2.0	2019-06-21 09:56:31.436	debug	State changed alexa2.0.Echo-Devices.G090U11111171B52.Player.volume: {"val":30,"ack":true,"ts":1561103791435,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1561099921776}
        alexa2.0	2019-06-21 09:56:31.435	debug	Alexa-Push-Connection Device Volume change for G090U11111171B52 -> 30/false
        alexa2.0	2019-06-21 09:56:31.435	debug	Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "dopplerId": { "deviceSerialNumber": "G090U11111171B52", "deviceType": "A32DOYUDS1DTXA
        alexa2.0	2019-06-21 09:56:31.435	debug	Alexa-Remote WS-MQTT: Command PUSH_EQUALIZER_STATE_CHANGE: { "destinationUserId": "AD2SUUSMJQ11X", "bass": 0, "treble": 0, "dopplerId": { "deviceSerialNumber": "G090U5022222B5
        Was ich mich frage, was macht er da mit Command PUSH_VOLUME_CHANGE usw. ?
        Device Volume change for G090U11111171B52 -> 30/false?
        #564
        @lexlev Nochmal zur Klastellung: Die Werte der Smart Devices werden EINMALIG zum Adapterstart gelesen, danach aber nur wenn man "#query" triggert!! Amazon sendet keine Push-Infos zu den Devices also kann der Adapter das auch nicht.
        Also wenn das dein Problem ist dann ist alles ok und "as designed" (schon immer)
        L 1 Antwort Letzte Antwort
        • C Camuri
          Sieht bei mir auch so aus Adapter ist wieder grün aber stueren kann er nichts wenn ich im Bad das Licht anschalte sollte eigentlich Alexa Musik wiedergeben aber sie bleibt stumm.
          #565
          @Camuri Und wie ist diese regel gebaut?
          C 1 Antwort Letzte Antwort
          • apollon77A apollon77
            lexlev
            schrieb am zuletzt editiert von lexlev
            #566
            @apollon77 Hi Apollon, interessant und mit dem einmaligen auslesen kann ich leben, aber ich kann die Werte auch nicht im Alexa Apater setzen und bekomme immer folgendes im Log ausgeworfen:
            alexa2.0	2019-06-21 10:24:11.575	debug	Alexa-Remote: Response: {"message":"Forbidden","code":null}
            alexa2.0	2019-06-21 10:24:11.399	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/phoenix/state","method":"PUT","timeout":10000,"headers":{}}and data={"controlRequests":[{"entityId":"5bca1ed9-e35c-4af6-ae42-
            alexa2.0	2019-06-21 10:24:11.399	debug	Alexa-Remote: No authentication check needed (time elapsed 60070)
            alexa2.0	2019-06-21 10:24:11.397	debug	State changed alexa2.0.Smart-Home-Devices.5bca1ed9-e35c-4af6-ae42-0dc584c60eb8.powerState: {"val":true,"ack":false,"ts":1561105451393,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin",
            alexa2.0	2019-06-21 10:23:25.392	debug	Alexa.ColorPropertiesController.[object Object]: setValueFor=colorTemperatureName to null
            Schreibrechte sind mehr als ausreichend gesetzt:
            drwxrwxrwx 5 iobroker iobroker 4096 Jun 21 08:37 alexa-cookie2
            drwxrwxrwx 4 iobroker iobroker 4096 Jun 21 10:40 alexa-remote2
            drwxrwxrwx 5 iobroker iobroker 4096 Jun 21 10:40 iobroker.alexa2
            Version 2.3.1
              1.) Auf Github gibt es eine 2.3.1 die nochmal Dinge optimiert für "kein csrf sonderfälle" ... Bitte nochmal udaten, wenn aber wieder grün sollte sich nichts ändern. Interessant wäre noch tester die von der 1.1.3 kommen
              2.) ssml ... muss ich checken. an sich ist daran nichts relevantes geändert worden :-(
              3.) Bei "Forbidden" meldungen oder sowas am besten Instanz mal löschen. da hat sich was anderes wohl verklemmt
              sigi234S Online
              sigi234S Online
              #567
              @apollon77 sagte in IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!:
              Debug Ausschnitt:
              [],"applianceLambdaControlled":true,"ipaddress":"","applianceDriverIdentity":{"namespace":"AAA","identifier":"SonarCloudService"}} / undefined
              2019-06-21 10:17:24.901  - debug: alexa2.0 Smarthome-Device Capability Alexa.AcousticEventSensor unknown. Report to developer this and next log line from logfile on disk!
              Kommen einige Fehler, wenn du willst kann ich dir den Debug per Mail senden.
                NashraN Offline
                NashraN Offline
                Nashra
                Most Active Forum Testing
                schrieb am zuletzt editiert von Nashra
                #568
                @apollon77 keine Änderung
                host.ioBroker-RasPi	2019-06-21 10:53:56.163	info	Restart adapter system.adapter.alexa2.0 because enabled
                host.ioBroker-RasPi	2019-06-21 10:53:56.163	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at Receiver.getData (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:352:17)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:413:14)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at Receiver.emit (events.js:198:13)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/websocket.js:789:20)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at WebSocket.emit (events.js:198:13)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at WebSocket.websocket.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-wsmqtt.js:202:22)
                Caught	2019-06-21 10:53:56.163	error	by controller[0]: at AlexaWsMqtt.emit (events.js:198:13)
                Caught	2019-06-21 10:53:56.162	error	by controller[0]: at AlexaWsMqtt.alexaWsMqtt.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:353:26)
                Caught	2019-06-21 10:53:56.162	error	by controller[0]: at AlexaRemote.emit (events.js:198:13)
                Caught	2019-06-21 10:53:56.162	error	by controller[0]: at AlexaRemote.alexa.on (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2112:46)
                Caught	2019-06-21 10:53:56.162	error	by controller[0]: TypeError: Cannot read property 'serialNumber' of undefined
                alexa2.0	2019-06-21 10:53:56.115	info	terminating
                alexa2.0	2019-06-21 10:53:56.106	warn	Exception: TypeError: Cannot read property 'serialNumber' of undefined
                alexa2.0	2019-06-21 10:53:56.101	error	at Receiver.getData (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:352:17)
                alexa2.0	2019-06-21 10:53:56.101	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/receiver.js:413:14)
                alexa2.0	2019-06-21 10:53:56.101	error	at Receiver.emit (events.js:198:13)
                alexa2.0	2019-06-21 10:53:56.101	error	at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/ws/lib/websocket.js:789:20)
                alexa2.0	2019-06-21 10:53:56.101	error	at WebSocket.emit (events.js:198:13)
                alexa2.0	2019-06-21 10:53:56.101	error	at WebSocket.websocket.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-wsmqtt.js:202:22)
                alexa2.0	2019-06-21 10:53:56.101	error	at AlexaWsMqtt.emit (events.js:198:13)
                alexa2.0	2019-06-21 10:53:56.101	error	at AlexaWsMqtt.alexaWsMqtt.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:353:26)
                alexa2.0	2019-06-21 10:53:56.101	error	at AlexaRemote.emit (events.js:198:13)
                alexa2.0	2019-06-21 10:53:56.101	error	at AlexaRemote.alexa.on (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2112:46)
                alexa2.0	2019-06-21 10:53:56.101	error	TypeError: Cannot read property 'serialNumber' of undefined
                alexa2.0	2019-06-21 10:53:56.100	error	uncaught exception: Cannot read property 'serialNumber' of undefined
                alexa2.0	2019-06-21 10:53:34.290	info	Deleting the following states: ["Smart-Home-Devices.ed186c2f-f3a2-","Smart-Home-Devices.dc92995d-","Smart-Home-Devices.5a4cad81-2ad7-
                alexa2.0	2019-06-21 10:53:20.660	info	Alexa-Push-Connection established. Disable Polling
                alexa2.0	2019-06-21 10:53:15.322	info	starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.16.0
                host.ioBroker-RasPi	2019-06-21 10:53:13.212	info	instance system.adapter.alexa2.0 started with pid 15269
                host.ioBroker-RasPi	2019-06-21 10:52:43.146	info	Restart adapter system.adapter.alexa2.0 because enabled
                Gruß Ralf
                • Q Offline
                  Q Offline
                  quorle
                  schrieb am zuletzt editiert von quorle
                  #569
                  @apollon77 :
                  Habe mir die aktuellste Version von Github installiert ( wie du in der Issus geschrieben hast ). Leider bleibt der Adapter gelb.
                  Wenn man die im log aufgeführte URL aufruft, passiert nichts und es erscheint im Browser " Seite nicht erreichbar ".
                  Hier meine DEBUG-LOG:
                  alexa2.0	2019-06-21 10:57:28.297	error	Error: You can try to get the cookie manually by opening http://192.168.2.102:42477/ with your browser.
                  alexa2.0	2019-06-21 10:57:28.297	debug	Alexa-Remote: Error from retrieving cookies
                  alexa2.0	2019-06-21 10:57:28.297	debug	Alexa-Cookie: Proxy-Server listening on port 42477
                  alexa2.0	2019-06-21 10:57:28.297	debug	Proxy Init: reuse deviceId from former data
                  alexa2.0	2019-06-21 10:57:28.297	debug	Proxy Init: reuse map-md from former data
                  alexa2.0	2019-06-21 10:57:28.297	debug	Proxy Init: reuse frc from former data
                  alexa2.0	2019-06-21 10:57:28.297	debug	Alexa-Cookie: Proxy-Mode enabled if needed: 192.168.2.102:0 to listen on 192.168.2.102
                  alexa2.0	2019-06-21 10:57:28.297	debug	Alexa-Cookie: Use as Accept-Language: de-DE
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Cookie: Use as User-Agent: pi
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Cookie: Use as Login-Amazon-URL: amazon.de
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Remote: No cookie given, generate one
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Remote: Use as Base-URL: alexa.amazon.de
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Remote: Use as Login-Amazon-URL: amazon.de
                  alexa2.0	2019-06-21 10:57:28.296	debug	Alexa-Remote: Use as User-Agent: pi
                  alexa2.0	2019-06-21 10:57:27.940	info	starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.16.0
                  • Q Offline
                    Q Offline
                    quorle
                    #570
                    @quorle sagte in IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!:
                    @apollon77 :
                    Habe den Adapter mehrmals neu gestartet und dann mal eine Zeit lang ruhen lassen. Im Anschluss die in der Fehlerlog aufgelistete IP im Browser aufgerufen und siehe da, nun ist der Adapter wieder grün.
                    • L lexlev
                      Version 2.3.1
                      #571
                      @lexlev mal Instanz neu erstellt und so? Das hast du in keinem deiner Antworten gesagt.
                      Können andere ihre smart devices steuern?
                      ? sigi234S L 3 Antworten Letzte Antwort
                        #572
                        @apollon77 Hi, Version 2.3.0 - 2.3.1 funktionieren, musste aber unbedingt vorher die alte Instanz löschen, sonst hat er das mit dem Cookie nicht verstanden ( stand im Adapter, dass der Cookie aktuell wäre, war er aber nicht).
                        War auch kein Fehler im Log (debug) zu sehen.
                        Erst als ich die Instanz gelöscht hatte, ging es. ( Proxy aufgerufen, fertig.).
                        Smarthome Geräte laufen auch alle.
                          sigi234S Online
                          sigi234S Online
                          #573
                          Ja...........
                          Habe einfach drüber installiert, kein Problem bis auf sslm
                            lexlev
                            #574
                            @apollon77 Ich hab das ganze System schon mehrfach neu aufgesetzt, also auch die Instanzen neu installiert.
                            Trotzdem keine Besserung :(
                              Camuri
                              #575
                              Das ist jetzt von der Küche, im Bad sollte sie eigentlich noch einen Text sprechen und dann Musik abspielen beides geht aber nicht.
                              • L Offline
                                lexlev
                                #576
                                @apollon77 Läuft jetzt, aber merkwürdige Lösung.
                                Ich habe die Echos und Geräte jetzt auf einem neuen Amazon Konto aufgehangen und es funktionierte dann auch direkt.
                                Vielleicht hat meine letztens versehentlich eingebaute Endlosschleife das System dazu veranlasst meine Abfragen zu ignorieren bzw. mich auf eine Blackliste zu setzen 😁 , keine Ahnung.
                                Jedenfalls läuft es nun wie immer 😀 , danke.
                                • dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #577
                                  Wie kann ich über Konsole eine bestimmte Adapterversion installieren ? (finde gerade wieder den Befehl nicht)
                                  sigi234S apollon77A 2 Antworten Letzte Antwort
                                  • dslraserD dslraser
                                    sigi234S Online
                                    sigi234S Online
                                    #578
                                    @dslraser sagte in IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!:
                                    https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                                    • L lexlev
                                      #579
                                      @lexlev und es tat schonmal oder tat es noch nie? Ur das wir hier auch die richtige Richtung bei einer Lösung einschlagen.
                                      So oder so brauche ich bitte vollständiges debug log aus dem logfile und nicht Admin vom Start des Adapters und so einer Am besten Vis E-Mail an iobroker@fischer-ka.de
                                        #580
                                        @dslraser welche willst du?
                                        • L lexlev
                                          #581
                                          @lexlev wie war es denn vorher? Mir mehreren Amazon Accounts kann es zu solchen Themen kommen ... da wäre das komplette debug log interessant gewesen. Aber wenn’s jetzt tut
