Js-controller 0.7.3
Ich habe den 0.7.3 gar nicht angeboten bekommen.
Bin dann über putty rein und habe ./iobroker update aufgerufen.
Da bekam ich sehr viele ETIMEOUT Error.
Mag sein, dass du deswegen auch Probleme beim npm hast.
Wo hast du ioBroker installiert?
@Pman:npm
ERR! Linux 4.0.7-v7+npm `
895_20171018_191107.jpg -
jetzt geht es hier mit web nicht weiter:
$ ./iobroker add web npm install iobroker.web --production --prefix "/opt/iobroker" (System call) npm ERR! Linux 4.0.7-v7+ npm ERR! argv "node" "/usr/local/bin/npm" "install" "iobroker.web" "--production" "--prefix" "/opt/iobroker" npm ERR! node v0.10.22 npm ERR! npm v2.13.0npm ERR! path /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.jsonnpm ERR! code ENOENTnpm ERR! errno 34 npm ERR! enoent ENOENT, open '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.json' npm ERR! enoent This is most likely not a problem with npm itselfnpm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent npm ERR! Please include the following file with any support request: npm ERR! /opt/iobroker/node_modules/npm-debug.log Cannot install iobroker.web: 34 ERROR: process exited with code 25bzw. bei socketio
$ ./iobroker add socketio npm install iobroker.socketio --production --prefix "/opt/iobroker" (System call) npm ERR! Linux 4.0.7-v7+npm ERR! argv "node" "/usr/local/bin/npm" "install" "iobroker.socketio" "--production" "--prefix" "/opt/iobroker" npm ERR! node v0.10.22 npm ERR! npm v2.13.0npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.json npm ERR! code ENOENTnpm ERR! errno 34 npm ERR! enoent ENOENT, open '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.json' npm ERR! enoent This is most likely not a problem with npm itselfnpm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent npm ERR! Please include the following file with any support request:npm ERR! /opt/iobroker/node_modules/npm-debug.log Cannot install iobroker.socketio: 34 ERROR: process exited with code 25 -
ich bin ein absoluter linux noob.
ich habe bei dir die Meldung gesehen:
@Pman:npm ERR! node v0.10.22
npm ERR! npm v2.13.0npm `
node 0.10.22 ist ok,
wollte dann meine npm version rausfinden mit
npm versionund erhalte:
root@quad-pi:/opt/iobroker# npm version { http_parser: '1.0', node: '0.10.22', v8: '3.14.5.9', ares: '1.9.0-DEV', uv: '0.10.19', zlib: '1.2.3', modules: '11', openssl: '1.0.1e', npm: '1.3.14' }wieso hast du 2.13.0?
und passt das zu node 0.10.22?
Habe keine Ahnung :(
Stimmt, gute Frage.
Nochmal neu angefangen mit
sudo dpkg -i nodejs_0.10.22-1_armhf.deb ````und bin wieder bei 1.3.14 npm install iobroker läuft durch, danach direkt ****socketio**** adapter:$ ./iobroker add socketio
npm
http GET https://registry.npmjs.org/iobroker.socketio
npm
http
304 https://registry.npmjs.org/iobroker.socketio
npm
http GET https://registry.npmjs.org/socket.io
npmhttp GET
https://registry.npmjs.org/request
npm
http GET https://registry.npmjs.org/cookie-parser
npm
http 304 https://registry.npmjs.org/request
npm
http 304 https://registry.npmjs.org/cookie-parser
npm
http 304 https://registry.npmjs.org/socket.io
npmhttp GET
https://registry.npmjs.org/cookie-signature/1.0.6
npm
http
GET https://registry.npmjs.org/cookie/0.1.3
npm
http 304 https://registry.npmjs.org/cookie-signature/1.0.6
npm
http 304 https://registry.npmjs.org/cookie/0.1.3
npm
http GET https://registry.npmjs.org/engine.io/1.4.0
npm
http GET https://registry.npmjs.org/socket.io-parser/2.2.1
npm
http GET https://registry.npmjs.org/has-binary-data/0.1.3
npm
http GET https://registry.npmjs.org/socket.io-client/1.1.0
npm
http GET https://registry.npmjs.org/debug/0.7.4
npm
http GET https://registry.npmjs.org/socket.io-adapter/0.2.0
npm
http 304 https://registry.npmjs.org/debug/0.7.4
npm
http 304 https://registry.npmjs.org/socket.io-adapter/0.2.0
npm
http 304 https://registry.npmjs.org/has-binary-data/0.1.3
npm
http 304 https://registry.npmjs.org/socket.io-parser/2.2.1
npm
http 304 https://registry.npmjs.org/engine.io/1.4.0
npm
http 304 https://registry.npmjs.org/socket.io-client/1.1.0
npm
http GET https://registry.npmjs.org/forever-agent
npm
http GET https://registry.npmjs.org/mime-types
npm
http GET https://registry.npmjs.org/form-data
npm
http GET https://registry.npmjs.org/node-uuid
npm
http GET https://registry.npmjs.org/json-stringify-safe
npm
http GET https://registry.npmjs.org/qs
npm
http GET https://registry.npmjs.org/tunnel-agent
npm http GET https://registry.npmjs.org/http-signature
npm
http GET https://registry.npmjs.org/tough-cookie
npm http GET https://registry.npmjs.org/hawk/1.1.1
npm http GET https://registry.npmjs.org/oauth-sign
npm
http GET https://registry.npmjs.org/aws-sign2
npm http GET https://registry.npmjs.org/stringstream
npm
http GET https://registry.npmjs.org/combined-stream
npm
http GET https://registry.npmjs.org/bl
npm
http GET https://registry.npmjs.org/caseless
npm
http
304 https://registry.npmjs.org/forever-agent
npm http 304 https://registry.npmjs.org/form-data
npm
http 304 https://registry.npmjs.org/node-uuid
npm http 304 https://registry.npmjs.org/mime-types
npm
http 304 https://registry.npmjs.org/json-stringify-safe
npm http 304 https://registry.npmjs.org/qs
npm
http 304 https://registry.npmjs.org/tunnel-agent
npm
http 304 https://registry.npmjs.org/http-signature
npm
http 304 https://registry.npmjs.org/tough-cookie
npm
http 304 https://registry.npmjs.org/hawk/1.1.1
npm
http 304 https://registry.npmjs.org/oauth-sign
npm
http 304 https://registry.npmjs.org/aws-sign2
npm
http
304 https://registry.npmjs.org/stringstream
npm
http 304 https://registry.npmjs.org/combined-stream
npm
http 304 https://registry.npmjs.org/bl
npm
http 304 https://registry.npmjs.org/caseless
npm
http GET https://registry.npmjs.org/socket.io-parser/2.1.2
npm
http 304 https://registry.npmjs.org/socket.io-parser/2.1.2
npm
http GET https://registry.npmjs.org/delayed-stream/0.0.5
npm
http GET https://registry.npmjs.org/async
npm
http 304 https://registry.npmjs.org/delayed-stream/0.0.5
npm
http 304 https://registry.npmjs.org/async
npm
http GET https://registry.npmjs.org/json3/3.2.6
npm
http GET https://registry.npmjs.org/component-emitter/1.1.2
npm
http GET https://registry.npmjs.org/isarray/0.0.1
npm http GET https://registry.npmjs.org/benchmark/1.0.0
npm
http 304 https://registry.npmjs.org/component-emitter/1.1.2
npm
http 304 https://registry.npmjs.org/isarray/0.0.1
npm
http 304 https://registry.npmjs.org/benchmark/1.0.0
npm
http GET https://registry.npmjs.org/readable-stream
npm
http GET https://registry.npmjs.org/assert-plus
npm
http GET https://registry.npmjs.org/asn1/0.1.11
npm
http GET https://registry.npmjs.org/ctype/0.5.3
npm
http 304 https://registry.npmjs.org/readable-stream
npm
http 304 https://registry.npmjs.org/json3/3.2.6
npm http 304 https://registry.npmjs.org/assert-plus
npm
http 304 https://registry.npmjs.org/asn1/0.1.11
npm
http 304 https://registry.npmjs.org/ctype/0.5.3
npm
http GET http://github.com/component/emitter/archive/1.0.1.tar.gz
npm
http GET https://registry.npmjs.org/mime-db
npm
http GET https://registry.npmjs.org/engine.io-parser/1.1.0
npm
http GET https://registry.npmjs.org/debug/1.0.3
npm http GET https://registry.npmjs.org/base64id/0.1.0
npm
http GET https://registry.npmjs.org/ws/0.4.31
npm
http 304 https://registry.npmjs.org/mime-db
npm
http 304 https://registry.npmjs.org/base64id/0.1.0
npm
http 304 https://registry.npmjs.org/ws/0.4.31
npm
http 304 https://registry.npmjs.org/debug/1.0.3
npm
http 304 https://registry.npmjs.org/engine.io-parser/1.1.0
npm
http 200 http://github.com/component/emitter/archive/1.0.1.tar.gz
npm
http GET https://registry.npmjs.org/ms/0.6.2
npm
http GET https://registry.npmjs.org/string_decoder
npm http GET https://registry.npmjs.org/inherits
npm
http GET https://registry.npmjs.org/core-util-is
npm
http GET https://registry.npmjs.org/has-binary/0.1.5
npm
http GET https://registry.npmjs.org/indexof/0.0.1
npm http GET https://registry.npmjs.org/parseuri/0.0.2
npm
http GET https://registry.npmjs.org/to-array/0.1.3
npm http GET https://registry.npmjs.org/engine.io-client/1.4.0
npm
http GET https://registry.npmjs.org/socket.io-parser/2.2.2
npm
http GET https://registry.npmjs.org/component-bind/1.0.0
npm
http GET https://registry.npmjs.org/object-component/0.0.3
npm
http 304 https://registry.npmjs.org/ms/0.6.2
npm
http 304 https://registry.npmjs.org/string_decoder
npm
http 304 https://registry.npmjs.org/inherits
npm
http 304 https://registry.npmjs.org/core-util-is
npm
http 304 https://registry.npmjs.org/indexof/0.0.1
npm
http GET https://registry.npmjs.org/blob/0.0.2
npm http GET https://registry.npmjs.org/utf8/2.0.0
npm
http GET https://registry.npmjs.org/after/0.8.1
npm
http GET https://registry.npmjs.org/base64-arraybuffer/0.1.2
npm
http GET https://registry.npmjs.org/arraybuffer.slice/0.0.6
npm
http 304 https://registry.npmjs.org/has-binary/0.1.5
npm
http 304 https://registry.npmjs.org/engine.io-client/1.4.0
npm
http 304 https://registry.npmjs.org/object-component/0.0.3
npm
http 304 https://registry.npmjs.org/component-bind/1.0.0
npm
http 304 https://registry.npmjs.org/socket.io-parser/2.2.2
npm
http 304 https://registry.npmjs.org/parseuri/0.0.2
npm
http 304 https://registry.npmjs.org/to-array/0.1.3
npm
http 304 https://registry.npmjs.org/after/0.8.1
npm
http 304 https://registry.npmjs.org/blob/0.0.2
npm
http 304 https://registry.npmjs.org/arraybuffer.slice/0.0.6
npm
http 304 https://registry.npmjs.org/utf8/2.0.0
npm http 304 https://registry.npmjs.org/base64-arraybuffer/0.1.2
npm ERR! Error: ENOENT, utime '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof/index.js'npm ERR! If you need help, you may report this log at:
npm ERR!
<http: github.com/isaacs/npm/issues="">npm ERR! or email it to:
npm ERR! npm-@googlegroups.comnpm ERR! System Linux 4.0.7-v7+
npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.socketio" "--production" "--prefix" "/opt/iobroker"
npm ERR! cwd /opt/iobroker/node_modulesnpm ERR! node -v
v0.10.22npm ERR! npm -v 1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof/index.jsnpm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof/index.js
npm ERR! fstream_type File
npm ERR! fstream_class FileWriter
npm ERR! fstream_finish_call utimes
npm ERR! errno 34
npm ERR!
fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:305:19npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm
ERR! Error: ENOENT, utime '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/has-binary/README.md'npm ERR!
If you need help, you may report this log at:npm
ERR!
ERR! System Linux 4.0.7-v7+npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.socketio" "--production" "--prefix" "/opt/iobroker"
npm ERR! cwd /opt/iobroker/node_modulesnpm ERR! node -v v0.10.22npm ERR! npm -v 1.3.14
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/has-binary/README.mdnpm ERR!
fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/has-binary/README.md
npm ERR! fstream_type Filenpm ERR! fstream_class FileWriternpm ERR! fstream_finish_call utimesnpm ERR! code ENOENT
npm
ERR! errno 34npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:305:19
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! Error: ENOENT, utime '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind/index.js'npm ERR! If you need help, you may report this log at:
npm ERR! <http: github.com/isaacs/npm/issues="">
npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.socketio" "--production" "--prefix" "/opt/iobroker"npm ERR! cwd /opt/iobroker/node_modules
npm ERR!
npm -v 1.3.14
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind/index.jsnpm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind/index.js
npm ERR! errno 34
npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array/README.md'
npm
npm ERR!
npm ERR! path
/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array/README.mdnpm
ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array/README.mdnpm ERR! fstream_type File
npm ERR! errno 34npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:284:26npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)
npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component/index.js'
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component/index.js
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component/index.js
npm ERR! errno 34
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/test.js'npm ERR! If you need help, you may report this log at:
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/test.js
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/test.js
FileWriternpm ERR! code ENOENT
npm ERR! errno 34
npm
ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:284:26npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter/index.js'npm ERR! If you need help, you may report this log at:
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter/index.js
npm
ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter/index.jsnpm ERR! fstream_type File
npm ERR! errno 34
npm
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/socket.io-parser/binary.js'
npm ERR! If you need help, you may report this log at:npm ERR! <http: github.com/isaacs/npm/issues="">
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/socket.io-parser/binary.js
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/socket.io-parser/binary.js
npm ERR! errno 34
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after/.npmignore'npm ERR! If you need help, you may report this log at:
npm ERR!
or email it to:npm ERR! npm-@googlegroups.comnpm ERR! System Linux 4.0.7-v7+
npm ERR!
path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after/.npmignorenpm
ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after/.npmignorenpm ERR! fstream_type File
npm ERR!
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob/.npmignore'npm
npm ERR! npm -v
1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob/.npmignore
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob/.npmignore
npm ERR! code ENOENTnpm ERR! errno 34npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:284:26
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice/.npmignore'
npm ERR! or email it to:npm ERR! npm-@googlegroups.com
npm ERR! cwd
npm ERR! npm -v 1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice/.npmignorenpm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice/.npmignore
npm
ERR! fstream_class FileWriternpm ERR! code ENOENT
npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer'npm ERR! error rolling back socket.io@1.1.0 { [Error: ENOTEMPTY, rmdir '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer']
npm ERR! error rolling back errno: 53,
npm ERR! error rolling back code: 'ENOTEMPTY',
npm ERR! error rolling back path: '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer' }npm ERR! EEXIST, mkdir '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/utf8'File exists: /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/utf8
Move it away, and try again.npm ERR! System Linux 4.0.7-v7+
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/utf8
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/utf8/.npmignore
npm ERR! code EEXIST
npm ERR! errno 47npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/fstream/lib/writer.js:171:23npm ERR! fstream_stack /usr/local/lib/node_modules/npm/node_modules/mkdirp/index.js:37:53
npm ERR! fstream_stack Object.oncomplete (fs.js:107:15)npm
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3/coverage/lcov-report/prettify.js'npm ERR! If you need help, you may report this log at:
npm
ERR! or email it to:npm ERR! npm-@googlegroups.comnpm ERR! System
Linux 4.0.7-v7+
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3/coverage/lcov-report/prettify.js
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3/coverage/lcov-report/prettify.js
npm ERR! fstream_class FileWriternpm ERR! code ENOENTnpm ERR! errno 34
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/hawk/test'npm ERR! error rolling back iobroker.socketio@0.4.4 { [Error: ENOTEMPTY, rmdir '/opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/hawk/test']
npm ERR! error rolling back path: '/opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/hawk/test' }npm ERR! Error: ENOENT, open '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.json'npm ERR! If you need help, you may report this log at:
npm ERR! <http: github.com/isaacs/npm/issues="">npm ERR! or email it to:
npm ERR! npm -v 1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/package.jsonnpm ERR! code ENOENTnpm ERR! errno 34
npm
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/emitter/Readme.md'npm ERR! If you need help, you may report this log at:
npm
ERR! or email it to:npm ERR! npm-@googlegroups.comnpm ERR! System Linux 4.0.7-v7+
npm
ERR! npm -v 1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/emitter/Readme.md
npm ERR!
fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/emitter/Readme.mdnpm ERR! fstream_type File
npm ERR!
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)npm ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer/LICENSE-MIT'npm ERR! If you need help, you may report this log at:
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer/LICENSE-MIT
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer/LICENSE-MIT
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws/test/WebSocket.test.js'npm ERR! If you need help, you may report this log at:
npm
npm
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws/test/WebSocket.test.jsnpm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws/test/WebSocket.test.jsnpm ERR! fstream_type File
npm ERR!
npm
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/benchmark/test/test.js'npm ERR! If you need help, you may report this log at:
npm ERR!
npm ERR! npm-@googlegroups.comnpm ERR! System Linux 4.0.7-v7+npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.socketio" "--production" "--prefix" "/opt/iobroker"
npm ERR! node -v
npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/benchmark/test/test.js
npm ERR!
fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-parser/node_modules/benchmark/test/test.jsnpm ERR! fstream_type File
npm ERR!
ERR! Error: ENOENT, lstat '/opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/tough-cookie/public-suffix.txt'npm ERR! If you need help, you may report this log at:
npm ERR!
npm ERR!
node -v v0.10.22
npm ERR! npm -v 1.3.14npm ERR! path /opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/tough-cookie/public-suffix.txt
npm ERR! fstream_path /opt/iobroker/node_modules/iobroker.socketio/node_modules/request/node_modules/tough-cookie/public-suffix.txt
npm ERR! errno 34
ERR! npm ERR! Additional logging details can be found in:
npm ERR! /opt/iobroker/node_modules/npm-debug.lognpm ERR! not ok code 0
ERROR: process exited with code 25</anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:></anonymous>/npm-@googlegroups.com</http:>Bin also leider noch immer nicht weiter. Vielleicht hab ich mir irgendwie das ganze npm kaputt gemacht? -
- iobroker 2015-07-13 07:19:19 info exit 0
iobroker 2015-07-13 07:19:19 info Starting node restart.js iobroker 2015-07-13 07:19:19 info Chmod finished. Restart controller iobroker 2015-07-13 07:19:19 info Execute: chmod 777 -R /opt/iobroker/node_modules/iobroker.js-controller iobroker 2015-07-13 07:19:19 info Host "Pi2-3" (linux) updated iobroker 2015-07-13 07:17:33 info npm install iobroker.js-controller –production --prefix "/opt/iobroker" (System call) iobroker 2015-07-13 07:17:32 info upgrade selfDas mit dem Restat scheind nicht zu funktionieren.
- iobroker 2015-07-13 07:20:20 info exit 0
iobroker 2015-07-13 07:20:20 info Starting node restart.js iobroker 2015-07-13 07:20:19 info _restartSieht im LOG soweit gut aus.
Wenn ich mit der Console (Putty ssh) schaue bleicht die PID gleiche.
auch ein "ionroker restart" hilft nicht
auch ein "iobroker stop" ist nicht in der lage die Prozesse zu beenden
also hilft nur ein "init 6" (Neustart)
Jürgen
Habe gerade unter Windows und Ubunta ausprobiert. Es geht. Es ist irgendwas mit Rechten.
Vielleicht:
"sudo npm install iobroker.web"
Ich habe gerade auf der anderen Installation versucht upzudaten.
unter "hosts" unten links auf das update icon geklickt - nichts
unter adapter oben links auf das update-icon geklickt - auch nichts
mit putty ./iobroker update eingegeben:
root@RPi-Basement:/opt/iobroker# ./iobroker update Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rpc/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.pushover/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/package.json. Error: Error: ETIMEDOUT Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/package.json. Error: Error: ETIMEDOUT ...Werden die Fehler beim Aufruf über die WebUI abgefangen? sie erscheinen nicht im log.
der Rest ok, auch der controller wird als updateable gekennzeichnet.
Nach F5 im Reiter "Hosts" ist dann auch das update verfügbar
Anscheinend bleibt hier das update aber hängen. :(
Ich habe jetzt nochmal alles unter /root/.npm/ gelöscht, da waren anscheinend Fehler in den Archiven und die wurden nicht neu runtergeladen. Danach ließ sich web installieren, jedoch nicht starten, da simple-api und socketio nicht unter /opt/iobroker/node_modules/iobroker.web/node_modules/ gefunden wurden. Ich habe dann kurzerhand ein npm install iobroker.socketio im iobroker.web Verzeichnis gestartet und jetzt geht es. In den iobroker.web Einstellungen beides auf "intern".
Nächstes Problem: die Metro widgets werden im Editor nicht angezeigt, sind links in der Widgetauswahl nicht vorhanden.
Nächstes Problem: die Metro widgets werden im Editor nicht angezeigt, sind links in der Widgetauswahl nicht vorhanden. `
Hast du die metro-widgets separat installiert?Sie sind nicht mehr Bestandteil von vis!
da waren anscheinend Fehler in den Archiven und die wurden nicht neu runtergeladen. `
da sollte helfen:cd /opt/iobroker npm cache cleanGruß
` > Hast du die metro-widgets separat installiert?
Sie sind nicht mehr Bestandteil von vis! `
Ja sicher, sind installiert!
http://192.168.0.10:8082/vis/widgets/metro/css/iconFont.min.css Failed to load resource: the server responded with a status of 404 (Not Found) http://192.168.0.10:8082/vis/widgets/metro/css/metro-bootstrap.css Failed to load resource: the server responded with a status of 404 (Not Found) http://192.168.0.10:8082/vis/widgets/metro/js/metro.js Failed to load resource: the server responded with a status of 404 (Not Found)Die Dateien sind aber unter node_modules/iobroker.vis/www/widgets/metro/ vorhanden.
EDIT:
Bei der Installation von vis habe ich noch eine Warnung gefunden:
$ ./iobroker add vis npm install iobroker.vis --production --prefix "/opt/iobroker" (System call) npm http GET https://registry.npmjs.org/iobroker.vis npm http 200 https://registry.npmjs.org/iobroker.vis npm http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.2.tgz npm http 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.2.tgz install adapter vis npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call) npm WARN cannot run in wd iobroker.vis@0.6.2 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis) got /opt/iobroker/node_modules/iobroker.vis/admin upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png ...EDIT 2:
Wenn ich vis-metro installiere und dieses dann vis mitinstalliert sind die widgets übrigens da! Bin vorher mehrfach vergeblich den umgekehrten Weg gegangen.
721_keinstate.jpg -
Noch ein Fehler in 0.7.3
/opt/iobroker/iobroker-data/node_modules/ioBroker.js-controller/conf/sources-dist.json
Statt (Zeile 27)
"flot": { "meta": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/io-package.json", "icon": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/admin/flot.png" },muss sein
"flot": { "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/io-package.json", "icon": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/admin/flot.png" },Mann kann manuell ändern oder die nächste Version abwarten (nicht bald :( )
übrigens werden die vorhanden Widgets jetzt angezeigt, ich kann aber keiner neuen Metro Widgets hinzufügen (Metro fehlt links in der Liste).
EDIT:
Okay… iobroker.web hat mir immer eine alte config.js ausgeliefert, da war kein metro drin. Ein neustart von iobroker.web hat es dann behoben.
EDIT:
Okay… iobroker.web hat mir immer eine alte config.js ausgeliefert, da war kein metro drin. Ein neustart von iobroker.web hat es dann behoben. `
Habe gerade einen Fehler gefunden (mit config.js). In der nächste Version wird es besser. ;)
