  4. Test Adapter MercedesMe v0.0.x
    6.8k
mercedes
1.0k Beiträge 122 Kommentatoren 362.5k Aufrufe 107 Beobachtet
    mrx
    ein Adapter auf den ich schon laenger gewartet habe :)
    Er laeuft soweit auch gut bis auf ein Problem
    host.raspberrypi 2019-05-09 20:37:12.418 error instance system.adapter.mercedesme.0 terminated with code 0 (OK)
    host.raspberrypi 2019-05-09 20:37:12.418 error Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
    host.raspberrypi 2019-05-09 20:37:12.418 error Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/request/request.js:1083:12)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at Request.emit (events.js:211:7)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at emitOne (events.js:116:13)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/request/request.js:1161:10)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at Request.emit (events.js:214:7)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at emitTwo (events.js:126:13)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/request/request.js:185:22)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at Request.request.get [as _callback] (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:127:24)
    host.raspberrypi 2019-05-09 20:37:12.417 error Caught by controller[0]: at JSON.parse (<anonymous>)
    host.raspberrypi 2019-05-09 20:37:12.416 error Caught by controller[0]: SyntaxError: Unexpected token < in JSON at position 0
    mercedesme.0 2019-05-09 20:37:12.278 error SyntaxError: Unexpected token < in JSON at position 0 at JSON.parse (<anonymous>) at Request.request.get [as _callback] (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:127:24) at R
    mercedesme.0 2019-05-09 20:37:12.276 error uncaught exception: Unexpected token < in JSON at position 0
    das wiederholt sich etwa jede stunde.
    Gruss
    Stefan
      SpS
      schrieb am zuletzt editiert von SpS
      Adapter ohne Fehler installiert, Instanz angelegt und erfolgreich angemeldet. Daten sehen auf den ersten Blick sehr plausibel aus. Mehr werde ich die nächsten Tage testen.
      Gibt es eine Variable, die mir den Status der Standheizung verrät?
      Auf jeden Fall schon mal GREAT JOB !
      Gruß Stefan
      • BBTownB Offline
        BBTownB Offline
        BBTown
        Auch von mir eine kurze Rückmeldung, installation verlief problemlos, Daten kommen sauber rein. Nun muss ich nur noch schauen, was ich mit denen anfange 😎
        • J Offline
          jrudolph
          Danke für die gute Arbeit.
          Habe den Adapter installiert und die Instanz gestartet. Läuft bisher fehlerfrei. Die Daten sind aus meiner Sicht korrekt. Ich sammle mal einiges in der SQL DB und werde weiter beobachten.
          Jürgen
            tombox
            Ich habe die Version 0.0.3 hochgeladen. Einfach den Adapter neuinstallieren.
            Es wurde ein Bug behoben, dass nach 1h keine Daten mehr reingekommen sind.
            Ich habe nun Echzeitdaten hinzugefügt unabhängig vom update interval wie zb. Vorklimatisierung.
            BBTownB 1 Antwort Letzte Antwort
              tombox
              Kann jemand den Adapter mit mehreren Fahrzeugen testen? Wenn keine Featurewünsche mehr gibt würde ich den Adapter morgen in latest veröffentlichen.
              • cashC Offline
                cashC Offline
                cash
                Schade kriege es nicht installiert. Meine js-Controller Version ist noch 1.23
                Muss ich wohl doch mal updaten... Welche Daten von Mercedes kommen denn rein? Kann ich damit meine Standheizung steuern?
                  SpS
                  Hallo Tombox,
                  die Daten sind soweit plausibel, ich kenn aber weder die Türen öffnen/schließen, noch die Vorklimatisierung starten. Fahrzeug ist aktuelle V-Klasse.
                  Feature Wunsch: Standheizung mit Startzeit aktivieren
                  Gruß Stefan
                  PS: seit Update auf Version 0.3 hab ich folgenden Fehler im Log:
                  host.RASPioBroker 2019-05-10 17:19:44.761 info instance system.adapter.mercedesme.0 started with pid 2979
                  host.RASPioBroker 2019-05-10 17:19:14.738 info Restart adapter system.adapter.mercedesme.0 because enabled
                  host.RASPioBroker 2019-05-10 17:19:14.738 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                  host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                  host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  host.RASPioBroker 2019-05-10 17:19:14.738 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                  host.RASPioBroker 2019-05-10 17:19:14.737 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
                  host.RASPioBroker 2019-05-10 17:19:14.736 error Caught by controller[0]: TypeError: Cannot read property 'val' of undefined
                  mercedesme.0 2019-05-10 17:19:13.696 error TypeError: Cannot read property 'val' of undefined at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter
                  mercedesme.0 2019-05-10 17:19:13.695 error uncaught exception: Cannot read property 'val' of undefined
                  mercedesme.0 2019-05-10 17:19:06.765 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                  host.RASPioBroker 2019-05-10 17:19:02.359 info instance system.adapter.mercedesme.0 started with pid 2932
                  BBTownB T 2 Antworten Letzte Antwort
                  • S SpS
                    Hallo Tombox,
                    Gruß Stefan
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @SpS ist denn das Fahrzeug bereits "aktiviert"?
                    Dies erfolgt üblicherweise gegen Vorlage des Fahrzeugscheins bei einem Vertragshändler.
                    Bis dahin sind nur unkritische Informationen wie Verbrauch, Tankinhalt usw. verfügbar, aber keine Aktionen.
                      SpS
                      Fahrzeug ist aktiviert - in der App kann ich die Funktionen nutzen.
                      • T tombox
                        BBTownB Offline
                        BBTownB Offline
                        BBTown
                        @tombox seltsam, ich bekomme nur die 0.0.2er installiert
                        • S SpS
                          Hallo Tombox,
                          Gruß Stefan
                          tombox
                          @SpS kannst du mal ein screenshot von den DOORLOCK_STATUS und PRECONDITIONING_DATA Objekten machen?
                          • BBTownB BBTown
                            tombox
                            @BBTown Browser Cache oder iobroker neustarten
                            • T tombox
                              BBTownB Offline
                              BBTownB Offline
                              BBTown
                              @tombox sagte in [Aufruf] Mecedes me Adapter:
                              das hat ihn beides nicht sonderlich beeindruckt
                              • BBTownB BBTown
                                tombox
                                @BBTown Was passiert auf der Konsole bei ./iobroker url "https://github.com/TA2k/iobroker.mercedesme"
                                BBTownB 2 Antworten Letzte Antwort
                                • T tombox
                                  BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  Auf welcher Konsole?
                                  • T tombox
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    @tombox Bitte nicht steinigen ... einmal kurz den PiHole deaktiviert und schon funktionierte das Update ... da werde ich wohl mal meine WhiteList ergänzen müssen 😕
                                      mrx
                                      Hallo
                                      also bei mir kommt nach dem starten
                                      host.raspberrypi 2019-05-10 18:28:55.492 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      Caught 2019-05-10 18:28:55.492 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                      Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                      Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                      Caught 2019-05-10 18:28:55.491 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
                                      Caught 2019-05-10 18:28:55.490 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
                                      Caught 2019-05-10 18:28:55.489 error by controller[0]: TypeError: Cannot read property 'val' of undefined
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
                                      mercedesme.0 2019-05-10 18:28:54.368 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
                                      mercedesme.0 2019-05-10 18:28:54.368 error TypeError: Cannot read property 'val' of undefined
                                      mercedesme.0 2019-05-10 18:28:54.367 error uncaught exception: Cannot read property 'val' of undefined
                                      und der adapter wird rot er hat sich aber einige daten gezogen.
                                      nodejs ist aktuell 1.5.8
                                      gruss
                                      stefan
                                      • M mrx
                                        Hallo
                                        gruss
                                        stefan
                                        BBTownB Offline
                                        BBTownB Offline
                                        BBTown
                                        schrieb am zuletzt editiert von BBTown
                                        @mrx ja, diese Fehler kommen bei mir ebenfalls
                                        [Nachtrag]
                                        und dann startet der Adapter auch neu durch
                                          tombox
