  2. English
  3. ioBroker general
  4. Node.js update
    6.0k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.jsupdate
6 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
    ap2017
    What is proper procedure to update Node.JS on Raspberry? I am running 6.14.3 and was advised to try 8 or 10 to troubleshoot Blockly astro command execution.
    • BBTownB Offline
      BBTownB Offline
      BBTown
      schrieb am zuletzt editiert von BBTown
      try this:
      1.) deinstall existing node & node.js versions
      sudo apt-get --purge remove node
      sudo apt-get --purge remove nodejs
      sudo apt-get autoremove
      sudo reboot
      2.) node.js new installation for für Linux und Raspberry 2/3
      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      sudo reboot
      german documentation for this, you`ll find here
        ap2017
        @BBTown I followed your instructions to update node, now have 8.15.1, restarted ioBroker, after update Z-Wave and mySensors adapter don't work. One of the error messages in log is that Z-Wave was compiled against different node. What do I need to do to make system operational?
        Log.txt
        • eric2905E Offline
          eric2905E Offline
          eric2905
          You should start
          npm rebuild
          in /opt/iobroker (or the correct installation folder).
          See these part of the (German) installation instructions: Link
          Greetings,
          Eric
            ap2017
            I've noticed that all download images at http://www.iobroker.net/docu/?page_id=5139&lang=en are based on Node version 6 or lower. At what point it is recommended to update to newer version of Node?
            • A ap2017
              ap2017
              @ap2017 Got it. English site is just outdated. German site has latest images with Node 8 http://www.iobroker.net/docu/?page_id=2563&lang=de
