  4. Telegram funktioniert nicht mehr
    6.8k
telegrameconnrefused
18 Beiträge 4 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • radicalreelR Offline
    radicalreel
    schrieb am zuletzt editiert von radicalreel
    Danke für die Antwort.
    Telegram 1.3.0
    Node.js: v8.15.1
    NPM: 6.4.1
    JS Controller 4.1.12
    Außer:
    2019-04-02 05:04:06.729  - error: telegram.0 polling_error:EFATAL, EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
    Steht im Log:
    2019-04-02 00:30:17.593  - debug: telegram.0 bot polling OK
    2019-04-02 05:04:03.683  - debug: telegram.0 objectDB connected
    2019-04-02 05:04:03.722  - debug: telegram.0 statesDB connected
    2019-04-02 05:04:03.728  - info: telegram.0 States connected to redis: xxx.x.x.xxxx
    2019-04-02 05:04:03.911  - info: telegram.0 starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.1
    2019-04-02 05:04:04.033  - debug: telegram.0 Schedule restart: 4 5 * * *
    2019-04-02 05:04:04.081  - debug: telegram.0 Start polling with: 300(number) ms interval
    2019-04-02 05:04:04.134  - debug: telegram.0 redis pmessage  io.telegram.0.communicate.request io.telegram.0.communicate.request {"val":"","ack":true,"ts":1554xxxxx28,"q":0,"from":"system.adapter.telegram.0","lc":15xxxxx3678}
    2019-04-02 05:04:04.137  - debug: telegram.0 redis pmessage  io.telegram.0.communicate.response io.telegram.0.communicate.response {"val":"","ack":true,"ts":155417xxxxx9,"q":0,"from":"system.adapter.telegram.0","lc":154xxxxx43679}
    2019-04-02 09:44:25.108  - debug: telegram.0 redis pmessage  messagebox.system.adapter.telegram.0 messagebox.system.adapter.telegram.0 {"command":"send","message":{"text":"Fenster Bad unten offen"},"from":"system.adapter.javascript.0","_id":xxxxxxxxx}
    2019-04-02 09:44:25.121  - debug: telegram.0 Send message to "P": Fenster Bad unten offen
    2019-04-02 09:44:25.126  - debug: telegram.0 Send message to "L": Fenster Bad unten offen
    2019-04-02 09:44:25.157  - error: telegram.0 Cannot send message [chatId - xxxxxxxxx]: Error: EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
    2019-04-02 09:44:25.165  - error: telegram.0 Cannot send message [chatId - xxxxxxxxx]: Error: EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
    2019-04-02 05:04:04.217  - error: telegram.0 polling_error:EFATAL, EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
    2019-04-02 17:36:55.115  - debug: telegram.0 redis pmessage  io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":155xxxxxxx4,"q":0,"from":"system.adapter.admin.0","lc":155xxxxxxx14}
    Hoffe das reicht. Wollte nicht alles posten, da mir der Adapter jede Sekunde 2 Zeilen reinknallt...
    • wendy2702W Online
      wendy2702W Online
      Wir sind aktuell ein paar Versionen weiter. Mal ein Update versucht?
      Und mit JS-Controller meinte ich nicht die JavaScript Adapter Version sondern die unter Hosts angezeigte.
        radicalreel
        Was genau meinst du? Was würdest du updaten?
        Unter Hosts: 1.4.2
        • wendy2702W Online
          wendy2702W Online
          Na den Telegram Adapter meine ich.
            radicalreel
            Mir wird kein Update angeboten. Sorry wenn ich mich blöd anstelle und Danke für die Geduld.
            • wendy2702W Online
              wendy2702W Online
              Oha...
              Da haben es offensichtlich einige Versionen noch nicht ins Stable geschafft.
              Stell mal deinen Verwahrungsort auf „latest“ und schaue was du dann angeboten bekommst.
              Aber bitte nicht alles was neuer angeboten wird dann updaten!
              radicalreelR 1 Antwort Letzte Antwort
                Arnulf
                @wendy2702 sagte in Telegram funktioniert nicht mehr:
                Oha...
                Bei mir scheint der Telegram-Adapter auch Probleme zu bereiten.
                Kann es sein, dass er ein Memory-Leak hat und sogar ioBroker zum erliegen bringen kann?
                Zumindest passiert das bei mir manchmal.
                Und er startet ab und zu von selbst neu:
                Gerade eben wieder:
                telegram.0	2019-04-04 22:32:40.845	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.14.0
                host.ioBroker2	2019-04-04 22:32:37.282	info	instance system.adapter.telegram.0 started with pid 1781
                host.ioBroker2	2019-04-04 22:32:36.268	info	Restart adapter system.adapter.telegram.0 because enabled
                host.ioBroker2	2019-04-04 22:32:36.267	error	instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
                telegram.0	2019-04-04 22:32:36.248	error	already running
                telegram.0	2019-04-04 22:32:36.148	warn	Reconnection to DB.
                telegram.0	2019-04-04 22:32:36.144	warn	Reconnection to DB.
                • wendy2702W Online
                  wendy2702W Online
                  Ich weiß nichts von einem Memory Leak oder so.
                  Auch die Probleme mit dem Telegramm Adapter sind aktuell ziemlich gering was ich hier im Forum so mit bekomme.
                  • wendy2702W wendy2702
                    Oha...
                    radicalreel
                    @wendy2702
                    Verwahrungsort habe ich auf latest gestellt. Zumindest, wenn das bedeutet den Default Pfad mal wegzunehmen. Ich habe da auch keine andere Version angeboten bekommen.
                    • radicalreelR radicalreel
                      @wendy2702
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      @radicalreel
                      den Verwahrungsort kannst Du hier einstellen.
                      • dslraserD dslraser
                        @radicalreel
                        radicalreel
                        @dslraser
                        Achso den Eintrag hatte ich übersehen. Allerdings war es schon auf lastet eingestellt. Frage mich nur warum ich dann nicht die neuste Version angeboten bekomme. Die Pfade sind doch so OK oder?
                          @dslraser
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          @radicalreel
                          ja, die sind genau wie meine...
                          • A Arnulf
                            Oha...
                            Gerade eben wieder:
                            radicalreel
                            @Arnulf
                            Funktioniert der Adapter bei dir mittlerweile wieder?
                            Habe ein neues token generiert, den Adapter gelöscht, neu installiert, bisschen hin und her gestellt.... da tut sich gar nichts
                            • wendy2702W Online
                              wendy2702W Online
                              Was heisst:
                              @radicalreel sagte in Telegram funktioniert nicht mehr:
                              Adapter Instanz mal auf "Debug" für das loggen gestellt?
                              Da steht bestimmt "irgendwas" drin.
                                Was heisst:
                                radicalreel
                                @wendy2702
                                Ja habe ich, siehe Post vom 02.04.
                                  @Arnulf
                                  Arnulf
                                  @radicalreel
                                  Sorry. Habe nicht weiter getestet, da ich den Telegram Adapter kurz danach deaktiviert und nicht wieder aktiviert habe.
                                  Es hatte mich zu sehr genervt, dass plötzlich bei meinem (Slave-ioBroker) alle Prozese blockiert wurden und dann einige wichtige Funktionen nicht mehr gingen.
                                  Erst Recht, wenn man morgens aufwacht und das Licht nicht mehr ging.
                                  Wie ich sehe, haben andere Nutzer auch/immer noch Probleme, so dass ich den Adapter wohl weiterhin deaktiviert lasse.
                                  Ich informiere mich seit dem per Mail statt Telegramm.
                                  Ist zwar nicht so schick, funktioniert aber
