  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 319.6k Aufrufe 54 Beobachtet
    smarti2015
    schrieb am zuletzt editiert von smarti2015
    #348
    Hab das Problem, das irgendwann der Radar meint, alles G-Tags sind abwesend. Was aber nicht stimmt. Im Log meldet er:
    radar2.0	2019-03-24 22:57:06.025	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:56:46.023	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:56:26.022	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:56:06.022	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:55:46.022	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:55:26.018	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:55:06.016	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:54:46.015	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:54:26.015	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:54:06.017	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:53:46.015	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:53:26.008	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:53:06.011	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:52:46.009	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:52:26.010	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:52:06.005	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:51:46.006	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:51:30.784	debug	system.adapter.admin.0: logging true
    radar2.0	2019-03-24 22:51:26.005	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:51:06.002	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:50:45.999	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:50:25.997	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:50:05.997	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:49:54.449	debug	system.adapter.admin.0: logging false
    radar2.0	2019-03-24 22:49:46.002	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:49:25.999	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:49:05.997	info	Noble scan Err 'not powered on'
    radar2.0	2019-03-24 22:48:45.996	info	Noble scan Err 'not powered on'
    Hat einer ne Idee? Hab einen externen BT Stick dran, der bis vor kurzem mit meiner alten pivccu2 perfekt lief.
    Jetzt mit neuer Einrichtung bekomme ich den Radar2 Adapter nicht mehr stabil zum laufe, also der Adapter läuft aber er zeigt mir ständig falsche Abwesenheit an.
    Im Adapter kann man ja einstellen, welchen BT man nutzen will, also entweder der BT on Board oder den USB Stick. Ich habe nen Asus Tinkerboard und da gibt es wohl mit dem internen ein Problem. Wie erkenne ich welchen der Adapter nutzt?
    GEEKOM AS 6
    frankjokeF 1 Antwort Letzte Antwort
    • S smarti2015
      frankjokeF Offline
      frankjokeF Offline
      frankjoke
      #349
      @smarti2015 hallo!
      Wann ist irgendwann? Nach 5sec 5min 5h oder 5 Tagen?
      Der Fehler deutet drauf hin dass Noble sich irgendwie nicht mehr mit dem BT-stick unterhalten kann das es sich nicht initialisieren kann.
      Manchmal ist das der Fall wenn mehere Programme gleichzeitig auf den Stick zugreifen.
      Einzige Läsung: Adapter neu starten!
      Ich starte meinen Adapter täglich neu (um 4h in der Früh).
      Frank,
      NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
      Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
        smarti2015
        #350
        also das ist sportadisch aber oft nach ein paar stunden passiert das. hab jetzt mal täglicher neustart auf 3 uhr eingestellt.
        was muss ich hier eintragen im Adapter: "bei Linux: nummer des Bluetooth-Adapters (0 = hci0):" da steht original "-1"
        Mit dem Befehl: sudo hciconfig sehe ich das:
        ^Croot@All-in-One-Tinker:~#  sudo hciconfig
        hci1:   Type: Primary  Bus: UART
                BD Address: 40:9F:38:DD:87:B6  ACL MTU: 1021:8  SCO MTU: 255:16
                UP RUNNING INQUIRY
                RX bytes:146062 acl:0 sco:0 events:9574 errors:0
                TX bytes:186631 acl:0 sco:0 commands:9149 errors:0
        hci0:   Type: Primary  Bus: USB
                BD Address: 00:15:83:E8:3E:0E  ACL MTU: 310:10  SCO MTU: 64:8
                DOWN
                RX bytes:10699386 acl:0 sco:0 events:279518 errors:0
                TX bytes:111992 acl:0 sco:0 commands:17543 errors:0
        mir lsusb das hier:
        root@All-in-One-Tinker:~# lsusb
        Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
        Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
        Bus 003 Device 002: ID 0bda:481a Realtek Semiconductor Corp.
        Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Dann muss ich doch da eine 0 eintragen oder?
        Das komische ist, in der Konsole mit sudo hcitool lescan findet er die G-Tags und im Adapter zeigt er sie auf false
        GEEKOM AS 6
        • S smarti2015
                  UP RUNNING INQUIRY
                  DOWN
          mir lsusb das hier:
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          schrieb am zuletzt editiert von frankjoke
          #351
          @smarti2015 sagte in [Adapter] Neuer radar2-Adapter:
          1. hci -1 heißt default, also was das noble oder das node scan halt findet und verwendet, normal ist es dann hci0. Mit 0-x kannst ein bestimmtes angeben, z.B. wenn du 2 BT sticks hast und einen für radar2 und einen anderen für den BLE-Adapter verwendets (oder kodi). Wenn du 2 BT-Geräte hast dann würd ich dir raten für Radar 1 (= das 2.te) zu verwenden da die meisten anderen Programme das 0 (als erstes) verwenden werden.
          2. im Adapter (unter nodejs) wird noble (ein nodejs-modul welches die BT-interface auf javascript abbildet) verwendet um BT-LE zu scannen. Es findet normal die selben das es das gleiche macht. Allerdings haben beide das selbe Problem: Es kann immer nur ein Programm auf den BT-LE-Teil zugreifen, also wenn du an der Konsole mit hcitools zugreifst wird der Adapter den Fehler melden!
          p.s.: Hab vergessen, noble läuft 80% von der Zeit, das bedeutet dass es kaum Chancen für ein anderes Programm gibt gleichzeitig zu laufen!
          Frank,
          MathiasJM 1 Antwort Letzte Antwort
          • frankjokeF frankjoke
            MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            #352
            Aber den Stick 1 kann er doch nicht nehmen, weil das das interne BT-Modul ist. gehe ich da richtig in der Annahme?
            Beim internen Modul gibt es Treiber-Probleme.
            IObroker auf dem NUC als VM.
            • Master67M Offline
              Master67M Offline
              Master67
              #353
              Sorry Leute,
              aber für ein "Nob", der Radar1 nur für 2 Handys zur Anwesenheitsabfrage nutzt ist der Radar2 sehr schwer zu verstehen.
              Warum ? weil ich nur 2 Geräte Abfragen will, und mit den Default Einstellungen bekommen ich es nicht hin, und ein "übertragen" der Einstellungen von R1 auf R2 bringt ja nix.
              Deshalb meine Frage, kann ich auch weiterhin den Radar1 nutzen ohne "Probleme" zubekommen ?
              Gruß Master67
              • Master67M Master67
                Sorry Leute,
                frankjokeF Offline
                frankjokeF Offline
                frankjoke
                #354
                @Master67 sagte in [Adapter] Neuer radar2-Adapter:
                Sorry Leute,
                1. Natürlich kannst die Daten der 2 Geräte übertragen, die Einstellungen können nur jetzt mehr individualisierungen vornehmen die für viele Nutzer notwendig sind. In der Geräteliste sollst halt alles eintragen was du von deinem Gerät kennst: IP, Hostname, ip-Mac, BT-Mac, ... je mehr du da hast desto sicherer ist die Erkennung.
                2. Natürlich kannst auch den alten 'radar'-Adapter weiterverwenden. Er ist weiterhin vorhanden, aber nur für Installation von git, was allerdings wenn du ihn schon installiert hast ja auch nicht brauchst.
                Wenn d noch Informationen brauchst kannst mich ja per Chat anpingen.
                Frank,
                Master67M 1 Antwort Letzte Antwort
                • MathiasJM MathiasJ
                  frankjokeF Offline
                  frankjokeF Offline
                  frankjoke
                  #355
                  @MathiasJ sagte in [Adapter] Neuer radar2-Adapter:
                  Ich kenne leider das Tinker-board nicht das du anscheinen hast, aber wenn der interne hci1 ist dann solltest du 0 für den externen verwenden! Bei meinen boards hat der interne immer 0, aber ich schalte sie wenn möglich in der boad-config aus und somit scheinen sie nicht mehr auf und ich sehe nur per USB angesteckte.
                  Frank,
                    smarti2015
                    #356
                    Wo kann ich das am Asus ausschalten? In dem armbianconfig?
                    GEEKOM AS 6
                    • S smarti2015
                      frankjokeF Offline
                      frankjokeF Offline
                      frankjoke
                      #357
                      Das kann ich dir nicht sagen, Google ist dein Freund! Bei meinen boards (raspis, orangepis) und MSI-NUc's hab ich immer gegoogled um das herauszufinden wie man das macht.
                      Beim Raspi kann man mit sudo nano /etc/modprobe.d/raspi-blacklist.conf
                      was eintragen wie
                      #wifi
                      #blacklist brcmfmac
                      #blacklist brcmutil
                      #bt
                      blacklist btbcm
                      blacklist hci_uart
                      womit die BT treiber nicht geladen werden die, W-lan aber schon... Wenn ich die # vor den beiden wlan-Zeilen auch wegnehm dan ist es auch ausgeschaltet.
                      Frank,
                        Sorry Leute,
                        Master67M Offline
                        Master67M Offline
                        Master67
                        #358
                        @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
                        Sorry Leute,
                        Ich habe mich da ein bisschen Unglücklich ausgedrückt, natürlich kann ich die 2 Handys Eintragen IP usw. sind ja bekannt.
                        Mit den Default Einstellungen wird der R2 nicht "Grün"....
                        Da es ja keine Probleme gibt bleibe ich bei R1 :-)
                        Gruß Master67
                          MiB
                          #359
                          warum müssen die States jetzt alle ein vorangestelltes "_" haben? Sieht irgendwie komisch gegenüber den anderen aus. Hat das einen bestimmten Zweck? Kann ich das ändern?
                          • M MiB
                            frankjokeF Offline
                            frankjokeF Offline
                            frankjoke
                            #360
                            @MiB
                            Die States haben nicht alle ein '_', nur jene die vom Adapter erzeugt werden und sozusagen künstlich (intern oder kalkuliert) sind.
                            Die namen die du für die Geräte vergibst bekommen kein '_' davor, somit ist sichergestellt dass nicht der selbe Name verwendet wird.
                            Ausschalten kann man das nicht.
                            Frank,
                              MiB
                              #361
                              @frankjoke
                              Moin, du hast bestimmt mit den Augen gerollt als du das gelesen hast 👀 ,ich weiß ich bin da ein wenig eigenartig. Aber eine andere Sache:
                              2019-03-25 00:00:28.542  - warn: radar2.0 BT already scanning!
                              2019-03-25 00:00:28.562  - warn: radar2.0 bl scan error: 'BT already scanning!'
                              2019-03-25 00:00:30.673  - info: radar2.0 Noble scan Err 'not powered on'
                              2019-03-25 00:00:48.562  - warn: radar2.0 BT already scanning!
                              2019-03-25 00:00:48.580  - warn: radar2.0 bl scan error: 'BT already scanning!'
                              2019-03-25 00:00:50.694  - info: radar2.0 Noble scan Err 'not powered on'
                              2019-03-25 00:01:08.581  - warn: radar2.0 BT already scanning!
                              2019-03-25 00:01:08.599  - warn: radar2.0 bl scan error: 'BT already scanning!'
                              2019-03-25 00:01:10.712  - info: radar2.0 Noble scan Err 'not powered on'
                              2019-03-25 00:01:28.600  - warn: radar2.0 BT already scanning!
                              2019-03-25 00:01:28.619  - warn: radar2.0 bl scan error: 'BT already scanning!'
                              2019-03-25 00:01:30.731  - info: radar2.0 Noble scan Err 'not powered on'
                              2019-03-25 00:01:48.620  - warn: radar2.0 BT already scanning!
                              2019-03-25 00:01:48.641  - warn: radar2.0 bl scan error: 'BT already scanning!'
                              2019-03-25 00:01:50.750  - info: radar2.0 Noble scan Err 'not powered on'
                              Ich hatte massig diesen Fehler. Hab Radar2 erstmal wieder entfernt und mir einen anderen BT Dongle bestellt. Muss ich noch etwas einstellen, oder was bedeutet der Fehler.
                              • M MiB
                                @frankjoke
                                frankjokeF Offline
                                frankjokeF Offline
                                frankjoke
                                #362
                                @MiB
                                Ja. Anscheinend verträgt sich da was nicht. Hast auch das scanintervall zu kurz da der BT scan noch nicht fertig ist und ein neuer wird schon gestartet. Auf manchen BT-geräten kann der scan schon 25-35 Sekunden dauern.
                                Frank,
                                • ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  #363
                                  20 - 35 Sekunden?
                                  Ich bin aktuell auf 45 Sekunden und habe 2-3 mal am Tag noch die Fehlermeldung das noch ein Scan aktiv ist.
                                  • lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    #364
                                    Moin,
                                    ich versuche radar2 auf einem Pi3 (slave) ans Laufen zu bringen.
                                    BLE funktioniert über die Konsosole. Geräte werden gescant und gefunden.
                                    Adapter steigt leider dauernd mit der Meldung aus.
                                    Habe auf 30sec gestellt und hci auf 0.
                                    Vielleicht ein Idee?
                                    radar2.1	2019-03-26 21:43:30.386	info	Adapter disconnected and stopped with dostop(1) and callback(false)
                                    radar2.1	2019-03-26 21:43:30.385	error	Error was catched by Adapter: should check installation or restart: { Error: bind EACCES 0.0.0.0:67 at _handle.lookup (dgram.js:266:18) at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                    radar2.1	2019-03-26 21:43:30.337	info	radar2 set to scan every 30 seconds and printers every 720 minutes.
                                    radar2.1	2019-03-26 21:43:30.336	info	arp-scan will use the following interfaces: [ 'eth0' ]
                                    radar2.1	2019-03-26 21:43:30.335	info	use known IP list: [ '1.1.1.1' ]
                                    radar2.1	2019-03-26 21:43:30.331	info	use known BT list: []
                                    radar2.1	2019-03-26 21:43:30.327	info	radar2 set to flag items away if they are not seen for 2 minutes
                                    radar2.1	2019-03-26 21:43:30.327	info	found 'node-bluetooth'
                                    radar2.1	2019-03-26 21:43:30.311	info	found '@abandonware/noble'
                                    radar2.1	2019-03-26 21:43:29.342	info	radar2 starting main...
                                    radar2.1	2019-03-26 21:43:29.341	info	radar2 initialization started...
                                    radar2.1	2019-03-26 21:43:22.339	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.15.1
                                    Host: NUC8i3 mit Proxmox:
                                    • Slave: Pi4
                                    • MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      #365
                                      Hast Du am Slave BLE und Radar laufen?
                                      Wenn ja, wie viele BT Dongles sind drin?
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #366
                                        @MathiasJ war etwas missverständlich von mir. Ich meinte mit BLE nicht den Adapter, sondern die Bluetooth Funktion.
                                        Habe nur den Radar Adapter alleine am laufen.
                                        Bluetooth funktioniert also grundsätzlich, nicht aber der Adapter. Wird grün, aber alle 30s rot und startet wieder neu.
                                        • Slave: Pi4
                                          steimi
                                          schrieb am zuletzt editiert von steimi
                                          #367
                                          Ich habe bisher den Radar-Adapter Version 1 im Einsatz und benutzte das Objekt Handy.here als Trigger für mein Blockly-Skript zum Ein-/Ausschalten der Überwachungskameras. Mit dem neuen Adapter gibt es dieses Objekt ja nicht mehr sondern nur das Objekt über .lastHere welches den Anwesenheitsstatus anzeigt. Allerdings wird bei Verwendung dieses mein Skript jetzt jede Minute angetriggert, weil sich ja das darunterliegende Objekt _lastHere ändert und somit das darüberliegende aktualisiert wird (wenn auch mit dem gleichen Wert). Wie kann ich das verhindern bzw wie muss ich meinen Blockly-Trigger jetzt anpassen? Ich bin Neueinsteiger in ioBroker und Blockly.
