  5. *gelöst* wrong type of "number"
    6.1k
    1.5k
blocklyclimate
3 Beiträge 2 Kommentatoren 424 Aufrufe 1 Beobachtet
    SoerenKaiser99
    schrieb am zuletzt editiert von SoerenKaiser99
    Hallo Zs,
    ich habe ein problem mit einem Script für ein Wetterupload.
    Es produziert bei jedem Durchlauf folgenden Fehler:
    javascript.0	2019-03-08 15:08:50.681	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-03-08 15:08:50.681	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-03-08 15:08:50.681	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-03-08 15:08:50.681	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-03-08 15:08:50.681	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-03-08 15:08:50.681	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-08 15:08:50.681	warn	at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
    javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
    javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
    javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
    javascript.0	2019-03-08 15:08:50.681	warn	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
    javascript.0	2019-03-08 15:08:50.681	warn	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
    javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.emit (events.js:211:7)
    javascript.0	2019-03-08 15:08:50.680	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
    javascript.0	2019-03-08 15:08:50.680	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
    javascript.0	2019-03-08 15:08:50.680	warn	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-03-08 15:08:50.680	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-03-08 15:08:50.680	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-08 15:08:50.680	warn	at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-08 15:08:50.680	warn	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
    javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-08 15:08:50.680	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-08 15:08:50.680	warn	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    javascript.0	2019-03-08 15:08:50.680	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-08 15:08:50.680	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-03-08 15:08:50.680	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-03-08 15:08:50.680	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-03-08 15:08:50.680	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
    javascript.0	2019-03-08 15:08:50.680	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:756:38)
    javascript.0	2019-03-08 15:08:50.680	warn	at Object.<anonymous> (script.js.Schalter.wetterupload:9:3)
    javascript.0	2019-03-08 15:08:50.679	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
    javascript.0	2019-03-08 15:08:50.679	warn	Wrong type of mqtt.0.Wetterstation.Wetter.Fahrenheit: "number". Please fix, while deprecated and will not work in next versions.
    Das script schaut so aus:
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id=";|^#zEAG3eOW*X~.5RQ." x="38" y="-263">
      <mutation items="1"></mutation>
      <value name="OID0">
        <shadow type="field_oid" id="_@px^Xq@{e^JtFJBE1x9">
          <field name="oid">mqtt.0.Wetterstation.Wetter.Temperatur</field>
        </shadow>
      </value>
      <statement name="STATEMENT">
        <block type="controls_if" id="EZVIxR{GacCGF89[vp%?">
          <value name="IF0">
            <block type="get_value" id="m*`#(rIK;e2n:LuE}O7H">
              <field name="OID">mqtt.0.Wetterstation.Wetter.Temperatur</field>
            </block>
          </value>
          <statement name="DO0">
            <block type="variables_set" id="bP|8b60*bXdqM}hJSk*v">
              <field name="VAR">TempC</field>
              <value name="VALUE">
                <block type="get_value" id="}vFMoYXzWKiWs}Dlbe-w">
                </block>
              </value>
              <next>
                <block type="update" id="R0ROgqA^P[Y-HV^?su!J">
                  <mutation delay_input="false"></mutation>
                  <field name="OID">mqtt.0.Wetterstation.Wetter.Fahrenheit</field>
                    <block type="math_arithmetic" id="gD9[c}G/~8,L?8|IBdBA">
                      <field name="OP">ADD</field>
                      <value name="A">
                        <shadow type="math_number" id="o0RBo.MAL,O4onRazsgt">
                          <field name="NUM">1</field>
                        </shadow>
                        <block type="math_arithmetic" id="hF0OQP9?@p#-U+%Ro-!L">
                          <field name="OP">MULTIPLY</field>
                          <value name="A">
                            </shadow>
                            <block type="variables_get" id="seB8D689)e+P;@eyy:L_">
                            </block>
                          </value>
                          <value name="B">
                            <shadow type="math_number" id="{zlvMLIeWAL%xBgRiS,@">
                              <field name="NUM">1.8</field>
                            </shadow>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <shadow type="math_number" id="dKtE?RYei+4iSI+uL;yz">
                          <field name="NUM">32</field>
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </statement>
    </block>
      <value name="OID0">
        </shadow>
      </value>
          <value name="IF0">
            </block>
          </value>
                </block>
              </value>
              <next>
                      <value name="A">
                        </shadow>
                          <value name="A">
                            </shadow>
                            </block>
                          </value>
                          <value name="B">
                            </shadow>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </statement>
    </block>
    Es rechnet einen Wert in Celsius in Fahrenheit um den ich für einen upload zu einem Wetterservice benötige.
    Ich habe schon versucht den Matheblock hinter einen "erstelle Text aus " zu hängen, klappt aber auch nicht. Hat jemand einen Tipp für mich?
    Dank Euch!
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • S SoerenKaiser99
      Hallo Zs,
        <value name="OID0">
          </shadow>
        </value>
            <value name="IF0">
              </block>
            </value>
                  </block>
                </value>
                <next>
                        <value name="A">
                          </shadow>
                            <value name="A">
                              </shadow>
                              </block>
                            </value>
                            <value name="B">
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
        <value name="OID0">
          </shadow>
        </value>
            <value name="IF0">
              </block>
            </value>
                  </block>
                </value>
                <next>
                        <value name="A">
                          </shadow>
                            <value name="A">
                              </shadow>
                              </block>
                            </value>
                            <value name="B">
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
      Dank Euch!
      Dr. BakteriusD Offline
      Dr. Bakterius
      @SoerenKaiser99 Wie ist denn der Datenpunkt formatiert (Zeichenkette, Zahl, Feld,...)? Entweder diesen richtig stellen, oder den Wert vor dem Schreiben konvertieren.
        SoerenKaiser99
        dank dir! Hab den Datenpunkt auf "gemischt" umgestellt und der Fehler ist weg!
        82.7k
