  2. Русский
  3. ioBroker
  4. Визуализация
  5. ioBroker.vis Драйвер
  6. Драйвер ioBroker Visualisation (vis)
Geplant Angeheftet Gesperrt Verschoben ioBroker.vis Драйвер
157 Beiträge 7 Kommentatoren 33.3k Aufrufe
  • BluefoxB
    @electric69:
    Не стартует драйвер vis.
    Система 0.5.4, установлена с чистого листа через npm.
    В логе ошибки:
    ! bananapi 2015-01-29 23:51:47 info host.bananapi Restart adapter system.adapter.web.0 because enabled bananapi 2015-01-29 23:51:47 error host.bananapi instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 23:51:47 info web.0 http server listening on port 8082 web.0 2015-01-29 23:51:47 error Error: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' at Function.Module._resolveFilename (module.js:338:15) at Function.Modu web.0 2015-01-29 23:51:47 error uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 23:51:47 info web.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web bananapi 2015-01-29 23:51:44 info host.bananapi instance system.adapter.web.0 started with pid 2401 host.bananapi 2015-01-29 21:51:14 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:51:14 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:51:13 info http server listening on port 8082 Error: 2015-01-29 21:51:13 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:51:13 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:51:13 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:51:13 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:51:13 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:51:13 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:51:13 error at require (module.js:380:17) Error: 2015-01-29 21:51:13 error at Module.require (module.js:364:17) Error: 2015-01-29 21:51:13 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:51:13 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:51:13 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:51:13 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:51:13 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:51:11 info instance system.adapter.web.0 started with pid 2395 host.bananapi 2015-01-29 21:50:40 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:50:40 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:50:40 info http server listening on port 8082 Error: 2015-01-29 21:50:40 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:50:40 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:50:40 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:50:40 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:50:40 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:50:40 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:50:40 error at require (module.js:380:17) Error: 2015-01-29 21:50:40 error at Module.require (module.js:364:17) Error: 2015-01-29 21:50:40 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:50:40 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:50:40 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:50:40 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:50:40 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:50:37 info instance system.adapter.web.0 started with pid 2389 host.bananapi 2015-01-29 21:50:07 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:50:07 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:50:07 info http server listening on port 8082 Error: 2015-01-29 21:50:07 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:50:07 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:50:07 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:50:07 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:50:07 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:50:07 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:50:07 error at require (module.js:380:17) Error: 2015-01-29 21:50:07 error at Module.require (module.js:364:17) Error: 2015-01-29 21:50:07 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:50:07 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:50:07 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:50:07 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:50:07 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:50:04 info instance system.adapter.web.0 started with pid 2382 host.bananapi 2015-01-29 21:49:34 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:49:34 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:49:34 info http server listening on port 8082 Error: 2015-01-29 21:49:34 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:49:34 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:49:34 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:49:34 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:49:34 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:49:34 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:49:34 error at require (module.js:380:17) Error: 2015-01-29 21:49:34 error at Module.require (module.js:364:17) Error: 2015-01-29 21:49:34 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:49:34 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:49:34 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:49:34 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:49:34 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:49:31 info instance system.adapter.web.0 started with pid 2376 host.bananapi 2015-01-29 21:49:00 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:49:00 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:49:00 info http server listening on port 8082 Error: 2015-01-29 21:49:00 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:49:00 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:49:00 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:49:00 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:49:00 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:49:00 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:49:00 error at require (module.js:380:17) Error: 2015-01-29 21:49:00 error at Module.require (module.js:364:17) Error: 2015-01-29 21:49:00 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:49:00 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:49:00 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:49:00 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:49:00 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:48:57 info instance system.adapter.web.0 started with pid 2330 host.bananapi 2015-01-29 21:48:27 info Restart adapter system.adapter.web.0 because enabled host.bananapi 2015-01-29 21:48:27 error instance system.adapter.web.0 terminated with code 6 (uncaught exception) web.0 2015-01-29 21:48:27 info http server listening on port 8082 Error: 2015-01-29 21:48:27 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) Error: 2015-01-29 21:48:27 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12) Error: 2015-01-29 21:48:27 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6) Error: 2015-01-29 21:48:27 error at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:65:21) Error: 2015-01-29 21:48:27 error at main (/opt/iobroker/node_modules/iobroker.web/main.js:108:21) Error: 2015-01-29 21:48:27 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:321:30) Error: 2015-01-29 21:48:27 error at require (module.js:380:17) Error: 2015-01-29 21:48:27 error at Module.require (module.js:364:17) Error: 2015-01-29 21:48:27 error at Function.Module._load (module.js:280:25) Error: 2015-01-29 21:48:27 error at Function.Module._resolveFilename (module.js:338:15) Error: 2015-01-29 21:48:27 error Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' uncaught 2015-01-29 21:48:27 error exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' web.0 2015-01-29 21:48:27 info starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.web host.bananapi 2015-01-29 21:48:24 info instance system.adapter.web.0 started with pid 2324 host.bananapi 2015-01-29 21:47:54 info Restart adapter system.adapter.web.0 because enabled !
    В htop видно, что пытается запуститься и тут же рушится… `
    Зайди в /opt/iobroker/node_modules/iobroker.web/
    и выполни
    npm install
    Если не поможет то удали папку /opt/iobroker/node_modules/iobroker.web/node_modules/
    и выполни npm install
    Причина в том, что Socket.io в web не обновился.
    Вообще можно полностью удалить web и снова добавить. В /opt/iobroker/
    ./iobroker del web
    ./iobroker add web
    • I
      I
      instalator
      Имеется ли в драйвере кнопка для отправления гет запроса, чтобы раз нажал один запрос, повотрно другой?
      Высокий уровень Децибел вреден для здоровья!
      http://blog.instalator.ru/
      • BluefoxB
        Опиши, что ты хочешь делать.
        • I
          I
          instalator
          Сделать кнопку, при нажатии (включении) отправляется один гет запрос, при повторном нажатии (выключении) отправляется другой гет запрос.
          Так как драйвера под ардуину нет, пока потестить хотел
          • BluefoxB
            Это делается подругому. В javascript драйвере создаёшь скрипт:
            createState('arduinoButton', false);
            on('arduinoButton', function (obj) {
               if (!obj.newState.ack) {
                   if (obj.newState.val === 'true' || obj.newState.val === true) {
                        request('http://arduinoIP/setPort=ON', function () {
                           setState('arduinoButton', {val: true; ack: true});
                   } else {
                        request('http://arduinoIP/setPort=OFF', function () {
                           setState('arduinoButton', {val: false; ack: true});
            И вешаешь кнопку (например jqui-ctrl-icon-toggle) и вешаешь её на объект javascript.0.arduinoButton
            • I
              I
              instalator
              Сменил тип движка, перезашел теперь ругается на функцию:
              • BluefoxB
                Оставь тип движка, как был (javascript)
                В коде была ошибка:
                               setState('arduinoButton', {val: true, ack: true});
                       } else {
                               setState('arduinoButton', {val: false, ack: true});
                • I
                  I
                  instalator
                  У меня еще ниразу с первого раза ничего не получилось. В виз добавил кнопку, при нажатии значение объекта изменяется, но ардуина не реагирует, в логе вот что пишет:
                  javascript.1 2015-05-04 14:34:43 error ReferenceError: request is not defined at Object. (script.js.Test:9:13) at Object.subscriptions.push.callback (c:\ioBroker\node_modules\iobroker.javascript\javascript.js:772:48)
                  javascript.1 2015-05-04 14:34:43 error message javascript.1.arduinoButton [object Object] request is not defined
                  javascript.1 2015-05-04 14:34:40 error ReferenceError: request is not defined at Object. (script.js.Test:5:13) at Object.subscriptions.push.callback (c:\ioBroker\node_modules\iobroker.javascript\javascript.js:772:48)
                  javascript.1 2015-05-04 14:34:40 error message javascript.1.arduinoButton [object Object] request is not defined
                  • BluefoxB
                    Опять ошибка…
                    var request = require('request');
                           } else {
                    Всё заработает. Главное не сдавайся ;)
                    • I
                      I
                      instalator
                      @Bluefox:
                      Опять ошибка…
                             } else {
                      Всё заработает. Главное не сдавайся ;) `
                      Вот сейчас все заработало! Спасибо! Что там на счет драйвера Arduino? Хотелось бы хоть что то услышать;)
                      • I
                        I
                        instalator
                        Нюанс, с первого раза вроде срабатывает норм, если повторно нажать уже сразу не срабатывает. если ничего не жать то значение иногда перемелькивает False/true.
                        Такое чуство что значение меняется, а гет запрос уходит с задержкой.
                        Хм, а гет запрос уходит один раз? Когда скрипт активен, ардуина плохо отвечает даже на запросы браузера, как только скрипт останавливаю из браузера летает.
                        • BluefoxB
                          Попробуй:````
                          log('Switch ON');
                          } else {
                          log('Switch OFF');
                          Что пишет в логах?
                          • I
                            I
                            instalator
                            @Bluefox:
                            Что пишет в логах? `
                            javascript.1 2015-05-04 18:43:59 info javascript.1 script.js.Test: Switch OFF
                            javascript.1 2015-05-04 18:43:57 info javascript.1 script.js.Test: Switch ON
                            javascript.1 2015-05-04 18:43:55 info javascript.1 script.js.Test: Switch OFF
                            javascript.1 2015-05-04 18:43:51 info javascript.1 script.js.Test: Switch ON
                            javascript.1 2015-05-04 18:43:49 info javascript.1 script.js.Test: Switch OFF
                            javascript.1 2015-05-04 18:43:46 info javascript.1 script.js.Test: Switch ON
                            javascript.1 2015-05-04 18:43:44 info javascript.1 script.js.Test: Switch OFF
                            javascript.1 2015-05-04 18:43:42 info javascript.1 script.js.Test: Switch ON
                            javascript.1 2015-05-04 18:43:40 info javascript.1 script.js.Test: Switch OFF
                            javascript.1 2015-05-04 18:43:38 info javascript.1 script.js.Test: Switch ON
                            • BluefoxB
                                          log('Switch ON: ' + JSON.stringify(obj.newState));
                                     } else {
                                          log('Switch OFF: ' + JSON.stringify(obj.newState));
                              • I
                                I
                                instalator
                                javascript.1 2015-05-04 18:50:20 info javascript.1 script.js.Test: Switch OFF: {"val":false,"ts":1430743821,"ack":false,"lc":1430743821,"from":"system.adapter.web.0"}
                                javascript.1 2015-05-04 18:50:19 info javascript.1 script.js.Test: Switch ON: {"val":true,"ts":1430743820,"ack":false,"lc":1430743820,"from":"system.adapter.web.0"}
                                Вроде работает сейчас
                                Хоть освещением пока поуправлять можно)
                                • I
                                  I
                                  instalator
                                  Почему страничка созданная в vis не маштабируется и не скролится на телефоне?
                                  • BluefoxB
                                    Скроллится точно должна… У тебя актуальная версия?
                                    • I
                                      I
                                      instalator
                                      0.3.1
                                      В vis выставил разрешение 800 на 480, с телефона открывается только верхний левый угол, страница не скролится и не масштабируется. Смотрю через хром на андроиде.
                                      Только что проверил со стандартного браузера, там и скролится и масштабируется
                                      • I
                                        I
                                        instalator
                                        А как сделать чтобы в GET можно было переменную загонять?
                                        Есть запрос http://192.168.1.140/command?AO140=SERVO, где 140 это угол поворота сервопривода. Как завязать эту переменную на ползунок в vis? чтобы при перемещение ползунка угол в GET запросе изменялся?
                                        • BluefoxB
                                          createState('arduinoAngle', 0);
                                          on('arduinoAngle', function (obj) {
                                                 request(' http://192.168.1.140/command?AO' + obj.newState.val + '=SERVO', function () {
                                                         setState('arduinoAngle', obj.newState.val, true);
                                          И вешаешь "javascript.0.arduinoAngle" на ползунок.
                                          84.2k
