  4. Iobroker web admin nicht mehr erreichbar HILFE
    6.8k
25 Beiträge 5 Kommentatoren 4.4k Aufrufe
    Wenn du das als Text eingestellt hättest, lönnte ich es dir auch markieren :(
    ENOSPC
    Kein Platz mehr
      apfelschorle
       node node_modules/iobroker.js-controller/controller.js --logs
      2019-02-02 18:31:09.593  - info: host.ioBroker-RasPi iobroker.js-controller version 1.4.0 js-controller starting
      2019-02-02 18:31:09.611  - info: host.ioBroker-RasPi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-02-02 18:31:09.614  - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v8.11.1
      2019-02-02 18:31:09.628  - info: host.ioBroker-RasPi ip addresses: xxx.xxx.x.xxx 2003:ea:a700xxxx:exxxfe
      2019-02-02 18:31:10.599  - info: host.ioBroker-RasPi  inMem-objects listening on port 9001
      2019-02-02 18:31:10.690  - info: host.ioBroker-RasPi States connected to redis: 127.0.0.1:6379
      2019-02-02 18:31:10.697  - info: host.ioBroker-RasPi InMemoryDB connected
      2019-02-02 18:31:10.752  - info: host.ioBroker-RasPi 23 instances found
      host.ioBroker-RasPi check instance "system.adapter.admin.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.discovery.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.hm-rpc.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.hm-rega.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.web.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.rpi2.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.socketio.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.cloud.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.vis.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.history.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.javascript.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.mobile.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.deconz.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.hue.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.vis-weather.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.vis-timeandweather.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.vis-hqwidgets.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.cloud.1" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.text2command.0" for host "ioBroker-RasPi"
      host.ioBroker-RasPi check instance "system.adapter.telegram.0" for host "ioBroker-RasPi"
      2019-02-02 18:31:10.818  - info: host.ioBroker-RasPi starting 15 instances
      2019-02-02 18:31:10.954  - info: host.ioBroker-RasPi instance system.adapter.admin.0 started with pid 6663
      2019-02-02 18:31:11.964  - error: uncaught exception: ENOSPC: no space left on device, write
      2019-02-02 18:31:11.974  - error: Error: ENOSPC: no space left on device, write
          at Object.fs.writeSync (fs.js:735:20)
          at Object.fs.writeFileSync (fs.js:1309:24)
          at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1779:16)
          at ontimeout (timers.js:482:11)
          at tryOnTimeout (timers.js:317:5)
          at Timer.listOnTimeout (timers.js:277:5)
      2019-02-02 18:31:11.996  - info: iobroker _restart
      2019-02-02 18:31:13.779  - info: iobroker Starting node restart.js
      2019-02-02 18:31:13.857  - info: iobroker exit 0
          at Timeout.saveConfig [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemSer                                                ver.js:1897:16)
          at listOnTimeoutNT (timers.js:353:26)
          at _combinedTickCallback (internal/process/next_tick.js:135:11)
          at process._tickCallback (internal/process/next_tick.js:180:9)
      Hab nochmal als Text. Kannst du mir bitte die stelle markieren?
      • paul53P Offline
        Die SD Card ist voll.
          apfelschorle
          Hi vielen Dank für den Hinweis! Ich hab mit df -h nachgeehen es sind tatsächlich 100% der SD Karte voll… Hab eine 16GB SD Karte drin, aber genutzt werden 1,8GB
          Habe mir die iobroker image runtergeladen und nach der Installation anscheinend vergessen über raspi-config "expand filesystem auszuführen"
          Kann ich dies noch nachträglich machen? Oder sind alle EInstellung die ich über die iobroker weboberfläche gemacht habe dann weg?
            @apfelschorle:
            2019-02-02 18:31:11.974 - error: Error: ENOSPC: no space left on device, write `
            im screenshot stand das mehrmals ;-)
              @apfelschorle:
              Habe mir die iobroker image runtergeladen `
              Welches?
              @apfelschorle:
              Kann ich dies noch nachträglich machen? Oder sind alle EInstellung die ich über die iobroker weboberfläche gemacht habe dann weg? `
              Für die Erweiterung braucht das Betriebssystem ein wenig reserveplatz.
              Wenn jetzt wirklich nichts mehr frei ist wird es eng.
              solltest du History-Daten haben. wären die mein erster Kandidat diese zu löschen, damit der Rest gerettet werden kann.
                apfelschorle
                Hi habs über raspi-config probiert, leider klappt der expand Befehl nicht mehr da 0% Speicher verfügbar, was kann ich eventuell löschen um den expand filesystem Befehl auszuführen? Hat wer eine Idee wie ich das lösen kann um die vollen 16Gb zu nutzen ohne alles löschen zu müssen oder iobroker neu aufzussetzen?
                 sudo raspi-config
                Welcome to fdisk (util-linux 2.29.2).
                Changes will remain in memory only, until you decide to write them.
                Be careful before using the write command.
                Command (m for help): Disk /dev/mmcblk0: 14,9 GiB, 15931539456 bytes, 31116288 sectors
                Units: sectors of 1 * 512 = 512 bytes
                Sector size (logical/physical): 512 bytes / 512 bytes
                I/O size (minimum/optimal): 512 bytes / 512 bytes
                Disklabel type: dos
                Disk identifier: 0x9c63c4e6
                Device         Boot Start     End Sectors  Size Id Type
                /dev/mmcblk0p1       8192   93802   85611 41,8M  c W95 FAT32 (LBA)
                /dev/mmcblk0p2      98304 3987455 3889152  1,9G 83 Linux
                Command (m for help): Partition number (1,2, default 2):
                Partition 2 has been deleted.
                Command (m for help): Partition type
                   p   primary (1 primary, 0 extended, 3 free)
                   e   extended (container for logical partitions)
                Select (default p): Partition number (2-4, default 2): First sector (2048-31116287, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (98304-31116287, default 31116287):
                Created a new partition 2 of type 'Linux' and of size 14,8 GiB.
                Partition #2 contains a ext4 signature.
                Disklabel type: dos
                /dev/mmcblk0p2      98304 31116287 31017984 14,8G 83 Linux
                Command (m for help): The partition table has been altered.
                Calling ioctl() to re-read partition table.
                Re-reading the partition table failed.: Das Gerät oder die Ressource ist belegt
                The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
                cat: Schreibfehler: Auf dem Gerät ist kein Speicherplatz mehr verfügbar
                pi@ioBroker-RasPi:~ $ sudo raspi-config
                Disklabel type: dos
                Disklabel type: dos
                  apfelschorle
                  Hab folgende image:
                  Kannst du mir sagen wie ich vorgehen muss um die Historie Daten falls vorhanden, zu löschen?
                  Unter /opt/iobroker/iobroker-data/ sind folgende Dateien, welche davon darf ich löschen?
                    rechts steht "ReadMe"
                    Hast du da schon mal draufgeklickt?
                    Da steht alles wichtige drin, was beachtet werden muss.
                      > die Historie Daten ****__falls vorhanden__****
                      Das kannst nur du mir sagen, ob du einen History-Adapter installiert hast
                        apfelschorle
                        Hi ja habs installiert >> system.adapter.history.0
                        Hab bereits versucht bestimmte adapter über die Konsole zu löschen, leider klappt das nicht da nicht genug Speicher vorhanden ist…ärgerlich.
                        Die Readme habe ich mir durchgelesen, da ich in meinen Anfängen iwo ein Fehler hatte, hatte ich auf die schnelle beim zweiten mal erstellen der Image das expand vergessen
                        insgesamt 1996
                        drwxr-xr-x  2 root root    4096 Feb  2 15:39 backup-objects
                        drwxrwxrwx 29 root root    4096 Feb  2 19:58 files
                        drwxrwxrwx  2 root root    4096 Mär 30  2018 history
                        -rwxrwxrwx  1 root root    2274 Mär 30  2018 iobroker.json
                        -rwxrwxrwx  1 root root 2004107 Feb  2 15:39 objects.json
                        -rwxrwxrwx  1 root root       0 Feb  2 19:59 objects.json.bak
                        -rwxrwxrwx  1 root root    4586 Mär 30  2018 states.json
                        -rwxrwxrwx  1 root root    4588 Mär 30  2018 states.json.bak
                        drwxrwxrwx  3 root root    4096 Jan 31 19:01 tmp
                        Leider ist der history ordner leer…was kann ich nun versuchen zu löschen?
                          @apfelschorle:
                          Hab bereits versucht bestimmte adapter über die Konsole zu löschen, `
                          Keine gute Idee.
                          Hast du filezilla oder winscp?
                          Die history-Daten sind im Ordner History
                          Darin befindet sich pro Tag ein weiteres Verzeichnis.
                          Ich würde das (die) älteste(n) Verzeichnis(se) löschen.
                          Danach über sudo raspi-config das expand filesystem versuchen
                          Wenn du da nichts drin hast,
                          • hast du den Adapter aktiv?
                          • hast du Datenpunkte zum loggen aktiviert
                          • oder nutzst du einen anderen Adapter (influx, sql)??
                            apfelschorle
                            Hi Rainer,
                            habs über filezilla gemacht. History Ordner ists leer…leider:
                            Ich meine ich habe in dem History Adapter auch nichts eingetellt oder aktiviert.
                            Ich habe nebem dem iobroker verzeichnis noch ein v verzeichnis gefunden (siehe Bild), brauche ich das?
                            Noch ne Idee was ich löschen könnte?
                            Was ist mit den logfiles? Können die getrost gelöscht werden?
                            • haselchenH Offline
                              haselchenH Offline
                              haselchen
                              Muss das mal raussuchen mit dem Filesystem anpassen. Hatte das auch. 32GB Karte aber nur 1.8 GB wurden belegt.
                              Gab eine Anleitung im Netz wie man die 32GB ausreizt.
                              Poste den Link sobald ich den habe .
                              Gefunden. Bisschen tricky, aber wenn du dich genau an die Anleitung hälst , klappt das.
                              https://dracoy.com/2016/06/26/expanding … installed/
                                @haselchen:
                                Bisschen tricky, `
                                Nicht notwendig!
                                Einfach
                                sudo raspi-config
                                aufrufen, den Menüpunkt "expand filesystem" raussuchen (ist nicht mehr auf der obersten Ebene-suchen!)
                                Anklicken und fertig.
                                  haselchenH Offline
                                  haselchen
                                  Leider nicht Rainer. Wenn es so einfach wäre,hätte ich den Trick nicht gepostet.
                                  Der Befehl gibt eine Fehlermeldung aus , wenn man über NOOBS installiert hat.
                                  raspi-config -> expand Filesytem -> "your partition layout is not supported ….. you're probably using noobs........."
                                    Habe noch nie mit noobs gearbeitet, daher kenne ich das nicht.
                                    Und das image wurde auch nicht über Noobs erstellt ;)
                                      haselchenH Offline
                                      haselchen
                                      Er hat ja den expand Filesytem Befehl probiert , ohne Erfolg. Deshalb mein Vorschlag ;)
                                        apfelschorle
                                        Hallo ich habs zum Glück mit Löschen der logfiles geschafft.
                                          ` > Beitrag von haselchen » 03.02.2019, 09:47
                                          Er hat ja den expand Filesytem Befehl probiert , ohne Erfolg `
                                          Wirklich?
                                          Das muss ich dann überlesen haben.
                                          Allerdings braucht diese Routine etwas Platz auf der Karte.
                                          Deswegen muss ggf. Irgendetwas gelösvht werden.
                                          Historydaten hat er keine, blieben noch backups, von denen ich aber auch nicht zu hoffen wage, dass er die hat.
                                          Was dann och weg kann muss ich mir mal in Ruhe ansehen.
