  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Windows
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
100 Beiträge 13 Kommentatoren 43.6k Aufrufe
  • X
    X
    X13
    @Bluefox:
    А какую папку? C:\Users\whense\AppData\Roaming\npm ? `
    Да. Сегодня попробую всё начисто поставить.
    • BluefoxB
      Есть новая версия инсталлятора:
      http://download.iobroker.org/ioBrokerIn … .0.1.1.exe
      • I
        I
        instalator
        Поставил новый дистр. набрал cd %ProgramFiles%\iobroker
        node controller.js
        ! C:\Program Files\ioBroker>node controller.js
        ! 2014-11-28 23:53:40.075 - info: ioBroker.js-controller version 0.1.1 js-controller starting
        ! 2014-11-28 23:53:40.077 - info: Copyright © 2014 hobbyquaker, bluefox
        ! 2014-11-28 23:53:40.078 - info: controller hostname: instalator
        ! 2014-11-28 23:53:40.078 - info: controller ip addresses: 192.168.1.35 2001:0:5ef5:79fb:2867:b
        ! a2:ac09:16a1 fe80::2867:ba2:ac09:16a1
        ! events.js:72
        ! throw er; // Unhandled 'error' event
        ! Error: EPERM, open 'C:\Program Files\ioBroker\log\iobroker.log'
        http://localhost:8081/ - Веб страница недоступна
        ! C:\Program Files\ioBroker>net start iobroker
        ! Системная ошибка 5.
        ! Отказано в доступе.
        После повторной переустановки
        ! 2014-11-29 00:09:48.894 - info: ioBroker.js-controller version 0.1.1 js-controller starting
        ! 2014-11-29 00:09:48.897 - info: Copyright © 2014 hobbyquaker, bluefox
        ! 2014-11-29 00:09:48.897 - info: controller hostname: instalator
        ! 2014-11-29 00:09:48.898 - info: controller ip addresses: 192.168.1.35 2001:0:5ef5:79fb:2867:b
        ! 2014-11-29 00:09:49.093 - info: controller couchdb connected
        ! 2014-11-29 00:09:49.118 - info: controller 1 instance found
        ! 2014-11-29 00:09:49.119 - info: controller starting 1 instance
        ! 2014-11-29 00:09:49.123 - warn: controller startInstance cannot find start file for adapter "
        ! admin". Try to install it...1 attempt
        ! 2014-11-29 00:09:49.124 - info: iobroker install admin
        ! events.js:72
        ! Error: Redis connection to 127.0.0.1:6379 failed - connect ECONNREFUSED
        ! at RedisClient.on_error (C:\Program Files\ioBroker\node_modules\redis\index.js:185:24)
        ! at Socket. <anonymous>(C:\Program Files\ioBroker\node_modules\redis\index.js:95:14)
        ! at Socket.emit (events.js:95:17)
        ! at net.js:440:14
        ! at process._tickCallback (node.js:419:13)</anonymous>
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
        • BluefoxB
          @instalator:
          node controller.js
          ! events.js:72
          При повторной установке выдает ошибку filename="Безымянный.png" index="0">~~
          ! events.js:72
          ! at net.js:440:14
          ! at process._tickCallback (node.js:419:13)</anonymous> `
          Взялся за установщик. Удалил node и couch, redis и поставил отсюда: http://download.iobroker.org/ioBrokerIn … .0.1.6.exe
          У меня заработало после исправления нескольких ошибок. Они уже в 0.1.6 исправлены.
          • I
            I
            instalator
            Удалил все, поставил ioBrokerInstaller.0.1.6.exe, http://localhost:8081/ - веб страница не доступна.
            ! 2014-11-30 11:38:15.128 - info: ioBroker.js-controller version 0.1.6 js-controller starting
            ! 2014-11-30 11:38:15.148 - info: Copyright © 2014 hobbyquaker, bluefox
            ! 2014-11-30 11:38:15.148 - info: controller hostname: instalator
            ! 2014-11-30 11:38:15.149 - info: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2
            ! 107:3f57:fef5 fe80::2094:2107:3f57:fef5
            ! events.js:72
            В логе вот что
            ! 2014-11-30 11:46:40.893 - [32minfo[39m: ioBroker.js-controller version 0.1.6 js-controller starting
            ! 2014-11-30 11:46:40.894 - [32minfo[39m: Copyright © 2014 hobbyquaker, bluefox
            ! 2014-11-30 11:46:40.894 - [32minfo[39m: controller hostname: instalator
            ! 2014-11-30 11:46:40.894 - [32minfo[39m: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2107:3f57:fef5 fe80::2094:2107:3f57:fef5
            ! 2014-11-30 11:46:41.087 - [32minfo[39m: controller couchdb connected
            ! 2014-11-30 11:46:41.111 - [32minfo[39m: controller 1 instance found
            ! 2014-11-30 11:46:41.111 - [32minfo[39m: controller starting 1 instance
            ! 2014-11-30 11:46:41.123 - [33mwarn[39m: controller startInstance cannot find start file for adapter "admin". Try to install it...1 attempt
            ! 2014-11-30 11:46:41.124 - [32minfo[39m: iobroker install admin[/spoiler]
            • aurodionovA
              aurodionovA
              aurodionov
              instalator, а если запустить с правами админа ?
              Пишу с пульта….
              • I
                I
                instalator
                @aurodionov:
                instalator, а если запустить с правами админа ? `
                Запустить что?
                Набрал iobroker install admin
                Поругался. Скачал с гитхаба по ссылке, пытаясь сохранить в c:\Program Files\ioBroker\tmp\ сказал что нету прав. Навесил прав - iobroker install admin прошло успешно. Сайт все равно не доступен
                ! 2014-11-30 12:12:28.221 - info: ioBroker.js-controller version 0.1.6 js-controller starting
                ! 2014-11-30 12:12:28.223 - info: Copyright © 2014 hobbyquaker, bluefox
                ! 2014-11-30 12:12:28.224 - info: controller hostname: instalator
                ! 2014-11-30 12:12:28.224 - info: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2
                ! 2014-11-30 12:12:28.416 - info: controller couchdb connected
                ! 2014-11-30 12:12:28.440 - info: controller 1 instance found
                ! 2014-11-30 12:12:28.441 - info: controller starting 1 instance
                ! 2014-11-30 12:12:28.454 - info: controller instance system.adapter.admin.0 started with pid 5
                ! 084
                ! module.js:340
                ! throw err;
                ! Error: Cannot find module 'express'
                ! at Function.Module._resolveFilename (module.js:338:15)
                ! at Function.Module._load (module.js:280:25)
                ! at Module.require (module.js:364:17)
                ! at require (module.js:380:17)
                ! at Object. <anonymous>(C:\Program Files\ioBroker\adapter\admin\admin.js:5:16)
                ! at Module._compile (module.js:456:26)
                ! at Object.Module._extensions..js (module.js:474:10)
                ! at Module.load (module.js:356:32)
                ! at Function.Module._load (module.js:312:12)
                ! at Function.Module.runMain (module.js:497:10)
                ! 2014-11-30 12:12:28.501 - error: controller instance system.adapter.admin.0 terminated with c
                ! ode 8
                ! 2014-11-30 12:12:28.502 - info: Restart adapter system.adapter.admin.0 because enabled
                ! events.js:72
                ! at net.js:440:14
                ! at process._tickCallback (node.js:419:13)</anonymous></anonymous>
                • aurodionovA
                  aurodionovA
                  aurodionov
                  по "форточкам не подскажу ,пользую на дебиане и шастаю с бука удалённо , после обновления постоянно слетают права на iobroker.
                  даю права на запуск всё стартует , попробуйте запускать файл с правами админа (вроде для запуска под форточками iobroker.bat)
                  Пишу с пульта….
                  • I
                    I
                    instalator
                    @aurodionov:
                    даю права на запуск всё стартует , попробуйте запускать файл с правами админа (вроде для запуска под форточками iobroker.bat) `
                    Уже пробовал.
                    Запускаю батник, окно промелькивает, сайт не доступен.
                    • BluefoxB
                      @instalator:
                      @aurodionov:
                      Уже пробовал.
                      Запускаю батник, окно промелькивает, сайт не доступен. `
                      Просто нет прав администратора на машине. Запустить можно всё и из консоли управления (не путать с коммандной строкой).
                      http://softlakecity.ru/os/windows/vklyu … uyu-stroku
                      Вот выдержка:
                      ` > Для того, чтобы выполнять описанные выше действия с любой службой Windows, необходимо знать её короткое имя. Получить это имя можно в свойствах службы:
                      Нажмите комбинацию клавиш Win+R.
                      В появившееся окно введите services.msc и нажмите Enter.
                      Когда перед Вами появится список служб Windows, выберите необходимую, кликните по ней правой кнопкой мыши и выберите пункт Свойства.
                      Вы увидите окно, в верхней части которого можно прочесть имя службы.
                      Свойства службы автоматических обновлений
                      Примечание. В операционных системах Windows 7 и Windows 8 командную строку необходимо запускать от имени администратора, иначе у Вас не будет полномочий для задание вышеуказанных настроек. `
                      Надо запустить Redis/CouchDB и ioBroker
                      А эта ошибка:
                      2014-11-30 11:38:15.148 - info: Copyright (c) 2014 hobbyquaker, bluefox
                      events.js:72
                      Вылезает только потому, что командная строка запущена не с администраторскими правами.
                      Запустите строку как здесь и всё заработает. И net stat и node controller.js
                      • I
                        I
                        instalator
                        @Bluefox:
                        Запустите строку как здесь и всё заработает. И net stat и node controller.js `
                        И так запускал.
                        ! c:\Program Files (x86)\ioBroker>node controller.js
                        ! 2014-12-01 20:09:07.420 - info: ioBroker.js-controller version 0.1.6 js-control
                        ! ler starting
                        ! 2014-12-01 20:09:07.422 - info: Copyright © 2014 hobbyquaker, bluefox
                        ! 2014-12-01 20:09:07.423 - info: controller hostname: instalator
                        ! 2014-12-01 20:09:07.423 - info: controller ip addresses: 192.168.1.10 2001:0:9d
                        ! 38:6abd:3447:2e3:3f57:fef5 fe80::3447:2e3:3f57:fef5
                        ! 2014-12-01 20:09:11.764 - info: controller couchdb connected
                        ! 2014-12-01 20:09:13.286 - info: controller 1 instance found
                        ! 2014-12-01 20:09:13.287 - info: controller starting 1 instance
                        ! 2014-12-01 20:09:13.299 - info: controller instance system.adapter.admin.0 star
                        ! ted with pid 3212
                        ! module.js:340
                        ! throw err;
                        ! at Object. <anonymous>(c:\Program Files (x86)\ioBroker\adapter\admin\admin.j
                        ! s:5:16)
                        ! 2014-12-01 20:09:13.350 - error: controller instance system.adapter.admin.0 ter
                        ! minated with code 8
                        ! 2014-12-01 20:09:13.350 - info: Restart adapter system.adapter.admin.0 because
                        ! enabled
                        ! 2014-12-01 20:09:43.359 - info: controller instance system.adapter.admin.0 star
                        ! ted with pid 5180</anonymous>
                        • BluefoxB
                          @instalator:
                          @Bluefox:
                          И так запускал.
                          ! ler starting
                          ! ted with pid 3212
                          ! module.js:340
                          ! throw err;
                          ! s:5:16)
                          ! enabled
                          ! ted with pid 5180</anonymous> `
                          Может быть такое, что интернет был не доступен во время установки?
                          Надо под админом в консоли зайти в c:\Program Files (x86)\ioBroker\ и выполнить
                          npm install "c:\Program Files (x86)\ioBroker\adapter\admin" --production --prefix "c:\Program Files (x86)\ioBroker\adapter\admin"
                          • I
                            I
                            instalator
                            @Bluefox:
                            Инет доступен.
                            Выполнил строку выше
                            теперь вот что выдает:
                            ! c:\Program Files\ioBroker>node controller.js
                            ! 2014-12-01 21:48:03.203 - info: ioBroker.js-controller version 0.1.6 js-control
                            ! ler starting
                            ! 2014-12-01 21:48:03.206 - info: Copyright © 2014 hobbyquaker, bluefox
                            ! 2014-12-01 21:48:03.207 - info: controller hostname: instalator
                            ! 2014-12-01 21:48:03.207 - info: controller ip addresses: 192.168.1.10 2001:0:5e
                            ! f5:79fb:2867:ba2:ac09:16a1 fe80::2867:ba2:ac09:16a1
                            ! 2014-12-01 21:48:06.081 - info: controller couchdb connected
                            ! 2014-12-01 21:48:06.186 - info: controller 1 instance found
                            ! 2014-12-01 21:48:06.187 - info: controller starting 1 instance
                            ! 2014-12-01 21:48:06.196 - info: controller instance system.adapter.admin.0 star
                            ! ted with pid 5636
                            ! module.js:340
                            ! throw err;
                            ! Error: Cannot find module 'socket.io'
                            ! at Object. <anonymous>(c:\Program Files\ioBroker\adapter\admin\admin.js:6:16
                            ! 2014-12-01 21:48:06.338 - error: controller instance system.adapter.admin.0 ter
                            ! 2014-12-01 21:48:06.338 - info: Restart adapter system.adapter.admin.0 because
                            ! enabled</anonymous>
                            Может через тимвьювер попробуешь сам?
                            • BluefoxB
                              @instalator:
                              @Bluefox:
                              Инет доступен.
                              ! ler starting
                              ! ted with pid 5636
                              ! module.js:340
                              ! throw err;
                              Может через тимвьювер попробуешь сам? `
                              Попробую, как только доберусь до дома. У меня витает сейчас идея: выбросить couchDb и redis вообще и всё делать через mqtt broker.
                              Сегодня посоветуюсь со вторым товарищем, а пока, я думаю, следует подождать следующей итерации.
                              • X
                                X
                                X13
                                @Bluefox:
                                У меня витает сейчас идея: выбросить couchDb и redis вообще и всё делать через mqtt broker. `
                                Одна из особенностей MQTT - на subscribe приходят только топики с установленным retain, остальное только по изменению. Из моего опыта - сильно не хватает возможности сказать сделай вот это. Я потому и смотрю на WAMP, что у него RPC есть в дополнение.
                                • BluefoxB
                                  @X13:
                                  Одна из особенностей MQTT - на subscribe приходят только топики с установленным retain, остальное только по изменению. `
                                  А что мешает мне установить все мои топики, как retain?
                                  @X13:
                                  Из моего опыта - сильно не хватает возможности сказать сделай вот это. `
                                  "Вот это". Что именно?
                                  @X13:
                                  Я потому и смотрю на WAMP, что у него RPC есть в дополнение. `
                                  Я не могу найти версии рутера для node.js.
                                  https://github.com/Orange-OpenSource/wamp.rt - это ещё сыроват,
                                  а вот этот - https://github.com/mcollina/mosca уже выглядит работающим.
                                  А если не применять node.js для брокера/рутера, то опять проблема установки. Через это мы уже проходили. 😢
                                  • K
                                    K
                                    KondorSoft
                                    @Bluefox:
                                    Сегодня посоветуюсь со вторым товарищем, а пока, я думаю, следует подождать следующей итерации. `
                                    База данных в любом случае нужна, для хранения истории, доведите систему до рабочего состояния, осталось уже совсем немножко ;)
                                    • X
                                      X
                                      X13
                                      @Bluefox:
                                      А что мешает мне установить все мои топики, как retain? `
                                      Только из личного опыта, за истину в последней инстанции прошу не считать.
                                      Лучше не сохранять: вычисляемые значения(меньше нагрузка на диск), состояние внешних устройств(корректное отображение подключен/значения после перезагрузки)
                                      @Bluefox:
                                      "Вот это". Что именно? `
                                      Основные проблемы у меня связаны с UI. Например undo/redo, правильно работающая реализация copy/paste, заменить устройство(перенять конфигурацию).
                                      При подписке неизвестно когда пришли все относящиеся к данному subsribe данные, приходится извращаться с задержками.
                                      Попытка эмулировать RPC при нескольких потоках тоже доставляет мало удовольствия.
                                      @Bluefox:
                                      А если не применять node.js для брокера/рутера, то опять проблема установки. Через это мы уже проходили. 😢 `
                                      Я начал разработку версии с MQTT почти 2 года назад, но для дальнейшего развития вынужден менять протокол. И тоже не нашёл подходящего проекта, поэтому беру существующий и напильником его. :roll:
                                      • I
                                        I
                                        instalator
                                        …надзор нагадил конечно. гитхаб заблочили
                                        • E
                                          E
                                          electric69
                                          @instalator:
                                          …надзор нагадил конечно. гитхаб заблочили `
                                          Я вот в серьез подумываю купить OpenVZ/KVM за границей…
                                          84.2k
