  4. Nach Update des RPC Adapter auf V 1.82 Dauercrashes
    5.2k
13 Beiträge 7 Kommentatoren 1.1k Aufrufe
    Marty56
    Leider hat mir das Update des Homematic Adapter von 1.8 auf 1.82 einen sich ständig wiederholenden Dauercrash eingefangen.
    Wie kann ich wieder downgraden?
    host.ioBroker-OPi2E	2019-01-04 05:47:43.686	info	Do not restart adapter system.adapter.hm-rpc.0 because disabled or deleted
    host.ioBroker-OPi2E	2019-01-04 05:47:43.684	error	instance system.adapter.hm-rpc.0 terminated with code 3 (Adapter disabled or invalid config)
    hm-rpc.0	2019-01-04 05:47:43.537	error	adapter disabled
    host.ioBroker-OPi2E	2019-01-04 05:47:26.944	info	object change system.adapter.hm-rpc.0
    host.ioBroker-OPi2E	2019-01-04 05:47:11.102	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host.ioBroker-OPi2E	2019-01-04 05:47:11.101	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    Caught	2019-01-04 05:47:11.100	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/client.js:6:14)
    Caught	2019-01-04 05:47:11.099	error	by controller[0]: at require (internal/module.js:20:19)
    Caught	2019-01-04 05:47:11.098	error	by controller[0]: at Module.require (module.js:504:17)
    Caught	2019-01-04 05:47:11.097	error	by controller[0]: at Function.Module._load (module.js:445:3)
    Caught	2019-01-04 05:47:11.096	error	by controller[0]: at tryModuleLoad (module.js:453:12)
    Caught	2019-01-04 05:47:11.096	error	by controller[0]: at Module.load (module.js:494:32)
    Caught	2019-01-04 05:47:11.095	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    Caught	2019-01-04 05:47:11.094	error	by controller[0]: at Module._compile (module.js:549:28)
    Caught	2019-01-04 05:47:11.093	error	by controller[0]: at Object.runInThisContext (vm.js:97:10)
    Caught	2019-01-04 05:47:11.093	error	by controller[0]: at createScript (vm.js:56:10)
    Caught	2019-01-04 05:47:11.092	error	by controller[0]: SyntaxError: Unexpected token *
    Caught	2019-01-04 05:47:11.091	error	by controller[0]: ^
    Caught	2019-01-04 05:47:11.090	error	by controller[0]: var man = Math.floor((d * (2 ** -exp)) * (1 << 30));
    Caught	2019-01-04 05:47:11.089	error	by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:213
    hm-rpc.0	2019-01-04 05:47:11.033	info	terminating
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/client.js:6:14)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at require (internal/module.js:20:19)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Module.require (module.js:504:17)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Function.Module._load (module.js:445:3)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at tryModuleLoad (module.js:453:12)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Module.load (module.js:494:32)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Object.Module._extensions..js (module.js:586:10)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Module._compile (module.js:549:28)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at Object.runInThisContext (vm.js:97:10)
    hm-rpc.0	2019-01-04 05:47:10.870	error	at createScript (vm.js:56:10)
    hm-rpc.0	2019-01-04 05:47:10.870	error	SyntaxError: Unexpected token *
    hm-rpc.0	2019-01-04 05:47:10.870	error	^
    hm-rpc.0	2019-01-04 05:47:10.870	error	var man = Math.floor((d * (2 ** -exp)) * (1 << 30));
    hm-rpc.0	2019-01-04 05:47:10.870	error	/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:213
    hm-rpc.0	2019-01-04 05:47:10.868	error	uncaught exception: Unexpected token *
    hm-rpc.0	2019-01-04 05:47:10.757	info	starting. Version 1.8.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.4</anonymous></anonymous>
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
      Marty56
      Ich habe in der protocol.js den Syntax Fehler an zwei Stellen manuell korrigiert.
      Jetzt scheint es wieder zu gehen.
      HW:NUC (16 GB Ram)
      • N Offline
        N Offline
        Nanouk
        ich habe das gleiche Problem.
        Könntest Du mir sagen was Du genau geändert hast?
        Der Fehler bleibt bei einem Downgrade erhalten.
        Nanouk
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Moin,
          @Marty56:
          hast Du mal nachgeschaut, ob der Adapter bzw. die Instanz ggf. tatsächlich disabled ist?
          Gruß,
          Eric
          • N Offline
            N Offline
            Nanouk
            Ich habe folgendes im Log
            hm-rpc.2	2019-01-04 07:12:41.326	info	terminating
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/client.js:6:14)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at require (internal/module.js:20:19)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Module.require (module.js:504:17)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Function.Module._load (module.js:445:3)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at tryModuleLoad (module.js:453:12)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Module.load (module.js:494:32)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Object.Module._extensions..js (module.js:586:10)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Module._compile (module.js:549:28)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at Object.runInThisContext (vm.js:97:10)
            hm-rpc.2	2019-01-04 07:12:41.282	error	at createScript (vm.js:56:10)
            hm-rpc.2	2019-01-04 07:12:41.282	error	SyntaxError: Unexpected token *
            hm-rpc.2	2019-01-04 07:12:41.282	error	^
            hm-rpc.2	2019-01-04 07:12:41.282	error	var man = Math.floor((d * (2 ** -exp)) * (1 << 30));
            hm-rpc.2	2019-01-04 07:12:41.282	error	/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:213
            hm-rpc.2	2019-01-04 07:12:41.281	error	uncaught exception: Unexpected token *
            hm-rpc.2	2019-01-04 07:12:41.255	info	starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.4</anonymous>
            Nach dem Downgrade auf 1.8.0, weil es nach dem Update nicht ging.
            Nach Update auf 1.8.2 den selben Fehler.
            hm-rpc.2	2019-01-04 07:17:48.156	info	terminating
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/client.js:6:14)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at require (internal/module.js:20:19)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Module.require (module.js:504:17)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Function.Module._load (module.js:445:3)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at tryModuleLoad (module.js:453:12)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Module.load (module.js:494:32)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Object.Module._extensions..js (module.js:586:10)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Module._compile (module.js:549:28)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at Object.runInThisContext (vm.js:97:10)
            hm-rpc.2	2019-01-04 07:17:48.096	error	at createScript (vm.js:56:10)
            hm-rpc.2	2019-01-04 07:17:48.096	error	SyntaxError: Unexpected token *
            hm-rpc.2	2019-01-04 07:17:48.096	error	^
            hm-rpc.2	2019-01-04 07:17:48.096	error	var man = Math.floor((d * (2 ** -exp)) * (1 << 30));
            hm-rpc.2	2019-01-04 07:17:48.096	error	/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:213
            hm-rpc.2	2019-01-04 07:17:48.096	error	uncaught exception: Unexpected token *
            hm-rpc.2	2019-01-04 07:17:48.075	info	starting. Version 1.8.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.4</anonymous>
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              Dann bin ich ja froh daß ich das Update NICHT mitgemacht habe
              Gesendet von meinem MI 8 mit Tapatalk
              IObroker auf dem NUC als VM.
              • SegwayS Offline
                SegwayS Offline
                Segway
                Oh, wollte gerade updaten … dann lass ich das mal lieber sein und warte noch etwas.
                v1.8.0 läuft bei mir sauber
                Gruß Dirk
                • foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  Problem liegt daran, dass eine externe Dependency in einer nicht funktionalen Version veröffentlicht wurde, jedoch heute Vormittag nun eine gefixte Version veröffentlicht wurde. 'Eigentlich' sollte bei einem Update nun nichts mehr schief laufen, allerdings sobald 1.8.3 veröffentlicht ist, ist dies auch unsererseits wirklich sicher gestellt.
                  Videotutorials & mehr
                  • SegwayS Offline
                    SegwayS Offline
                    Segway
                    TOP wie schnell ihr immer daran arbeitet ! 5 STERNE *****
                    Gruß Dirk
                    • N Offline
                      N Offline
                      Nanouk
                      Super, vielen Dank dass so schnell nachgebessert wurde.
                      Funktioniert alles wieder prima.
                      Viele Grüße
                      • N Offline
                        N Offline
                        nevermind
                        ich habe das gleiche Problem, kapiere nur nicht ganz, was ich jetzt machen muss um das Problem zu beheben?
                        Jens
                        • N Offline
                          N Offline
                          Nanouk
                          Hallo Jens,
                          einfach das update nochmal machen.
                          Gruß Nanouk
                          • N Offline
                            N Offline
                            nevermind
                            ok. danke. hab jetzt 1.83 installiert.
                            32.7k
                            82.5k
