  4. Frage zu Modbus
    6.5k
Frage zu Modbus
22 Beiträge 5 Kommentatoren 4.2k Aufrufe
  • R Offline
    Rapsi
    Hier ist mein Log:
    modbus.0	2018-12-30 22:47:01.304	debug	system.adapter.admin.0: logging true
    modbus.0	2018-12-30 22:46:44.456	debug	Cleaning up request fifo.
    modbus.0	2018-12-30 22:46:44.455	debug	Clearing timeout of the current request.
    modbus.0	2018-12-30 22:46:44.450	info	Disconnected from slave
    modbus.0	2018-12-30 22:46:43.450	warn	Poll error count: 1 code: {"err":"timeout"}
    modbus.0	2018-12-30 22:46:43.448	error	Request timed out.
    modbus.0	2018-12-30 22:46:43.448	warn	Error: undefined
    modbus.0	2018-12-30 22:46:38.436	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
    modbus.0	2018-12-30 22:46:38.434	debug	Poll device 1
    modbus.0	2018-12-30 22:46:38.432	info	Connected to slave
    modbus.0	2018-12-30 22:46:38.414	debug	connect to serial /dev/ttyUSB0 with 9600
    modbus.0	2018-12-30 22:46:38.051	info	starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.4
    modbus.0	2018-12-30 22:46:37.929	debug	statesDB connected
    modbus.0	2018-12-30 22:46:37.858	debug	objectDB connected
    modbus.0	2018-12-30 22:46:37.030	info	terminating
    modbus.0	2018-12-30 22:46:36.046	warn	Poll error count: 10 code: {"err":"timeout"}
    modbus.0	2018-12-30 22:46:36.045	error	Request timed out.
    modbus.0	2018-12-30 22:46:36.045	warn	Error: undefined
    modbus.0	2018-12-30 22:46:31.039	info	Connected to slave
    modbus.0	2018-12-30 22:45:31.024	info	Disconnected from slave
    modbus.0	2018-12-30 22:45:30.023	warn	Poll error count: 9 code: {"err":"timeout"}
    modbus.0	2018-12-30 22:45:30.023	error	Request timed out.
    modbus.0	2018-12-30 22:45:30.022	warn	Error: undefined
    modbus.0	2018-12-30 22:45:25.014	info	Connected to slave
    modbus.0	2018-12-30 22:44:25.001	info	Disconnected from slave
    modbus.0	2018-12-30 22:44:24.001	warn	Poll error count: 8 code: {"err":"timeout"}
    • R Offline
      Rapsi
      modbus.0	2018-12-30 22:50:02.516	debug	Cleaning up request fifo.
      modbus.0	2018-12-30 22:50:02.516	debug	Clearing timeout of the current request.
      modbus.0	2018-12-30 22:50:02.513	info	Disconnected from slave
      modbus.0	2018-12-30 22:50:01.520	warn	Poll error count: 4 code: {"err":"timeout"}
      modbus.0	2018-12-30 22:50:01.520	error	Request timed out.
      modbus.0	2018-12-30 22:50:01.520	warn	Error: undefined
      modbus.0	2018-12-30 22:49:56.511	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
      modbus.0	2018-12-30 22:49:56.511	debug	Poll device 1
      modbus.0	2018-12-30 22:49:56.510	info	Connected to slave
      modbus.0	2018-12-30 22:49:56.497	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-12-30 22:48:56.503	debug	Cleaning up request fifo.
      modbus.0	2018-12-30 22:48:56.502	debug	Clearing timeout of the current request.
      modbus.0	2018-12-30 22:48:56.493	info	Disconnected from slave
      modbus.0	2018-12-30 22:48:55.493	warn	Poll error count: 3 code: {"err":"timeout"}
      modbus.0	2018-12-30 22:48:55.493	error	Request timed out.
      modbus.0	2018-12-30 22:48:55.493	warn	Error: undefined
      modbus.0	2018-12-30 22:48:50.496	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
      modbus.0	2018-12-30 22:48:50.496	debug	Poll device 1
      modbus.0	2018-12-30 22:48:50.492	info	Connected to slave
      modbus.0	2018-12-30 22:48:50.486	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-12-30 22:47:50.487	debug	Cleaning up request fifo.
      modbus.0	2018-12-30 22:47:50.486	debug	Clearing timeout of the current request.
      modbus.0	2018-12-30 22:47:50.483	info	Disconnected from slave
      modbus.0	2018-12-30 22:47:49.482	warn	Poll error count: 2 code: {"err":"timeout"}
      modbus.0	2018-12-30 22:47:49.482	error	Request timed out.
      modbus.0	2018-12-30 22:47:49.481	warn	Error: undefined
      modbus.0	2018-12-30 22:47:44.484	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
      • R Offline
        RappiRN
        Da steht was von Pollerror, ich denke mal, dass da noch eine Einstellung falsch ist.
        Hast du denn mal die oberste Einstellung, RTU usw verändert?
        Enrico
        • R Offline
          Rapsi
          Das ist ein USB-Serial-Adapter. Also Einstellung "Serial" ist richtig.
          Vierschiedene Boudrate habe ich probiert - gleiches Ergebnis.
          Was ist bei diskreten Eingängen, Ausgängen, Eingangsregister und Holding Registers einzutragen?
          Bei mir sind die Felder leer.
          • V Offline
            V Offline
            vupls1
            ich habe sehr ähnliches, wie das hier beschriebene Problem.
            Mein Adapter hängt ebenfalls am USB Anschluss und wird auch entsprechend (/dev/ttyUSB) erkannt. Das Adernpaar geht dann zu meiner Lüftungsanlage, welche für Modbus RS485 RTU konfiguriert ist. Beide Enden habe ich mit dem Abschluss-Widerstand versehen. Wenn ich mit anderen Tools (eg. Modbus Poll oder Modbus Master) mich mit dem gleichen USB-Stick und der gleichen Hardwarekonstellation verbinden, funktioniert es sehr gut und ich kann die Coils und Register auslesen.
            Mache ich das gleiche via IOBroker und dem Modbus Adapter geht es schief.
            Der Adapter geht nach der Konfiguaration von Rot auf Gelb, flackert dann für eine kurze Zeit in Richtung grün, fällt dann aber wieder auf gelb zurück und bleibt dann dan.
            Im Log (debug) steht dann folgendes:
            modbus.0 2019-01-01 13:09:32.908 info Disconnected from slave
            modbus.0 2019-01-01 13:09:32.907 info Connected to slave
            modbus.0 2019-01-01 13:09:32.892 debug connect to serial /dev/ttyUSB0 with 9600
            modbus.0 2019-01-01 13:08:32.906 debug redis pmessage io.modbus.0.* io.modbus.0.info.connection {"val":false,"ack":true,"ts":1546344512893,"q":0,"from":"system.adapter.modbus.0","lc":1546344032780}
            modbus.0 2019-01-01 13:08:32.904 debug redis pmessage io.modbus.0.* io.modbus.0.info.connection {"val":true,"ack":true,"ts":1546344512890,"q":0,"from":"system.adapter.modbus.0","lc":1546344512890}
            modbus.0 2019-01-01 13:08:32.903 debug Cleaning up request fifo.
            und das wiederholt sich dann.
            Leider stehe ich jetzt im Wald und würde mich freuen, von euch einen Tipp zu bekommen.
            Besten Dank schon im Voraus.
            • R Offline
              RappiRN
              Ich habe nicht viel Ahnung vom Modbus, bin aber auch bei dir der Meinung, wie auch bei Rapsi, dass die Einstellung im ioBoker-Modbus-Adapter auf RTU stehen muss! Da muss, meinem Verständnis nach, nicht die Einstellung des USB-Adapters eingegeben werden, sondern, der Modbus-Typ, so habe ich bisher die Infos dazu verstanden. Ich gerade auf der Suche nach einem Modbus-Zähler und wie ich das anstellen kann.
              Enrico
              • V Offline
                V Offline
                vupls1
                Hallo Enrico,
                vielen Dank für deine Antwort, mit meinem Halbwissen würde ich aber vermuten, dass Serial ja RS485 RTU bedeutet. Eine RTU Abfrage kann aber auch über TCP erfolgen. Das geht natürlich gar nicht, weil ich keinen ETH zu Serial Adapter habe.
                Beste Grüße
                Thomas
                • wendy2702W Online
                  wendy2702W Online
                  @Rapsi:
                  Habe ich eingetragen. Der Adapter wird für ca. 10 sek. grün und dann wieder gelb.
                  Muss ich was bei diskreten Eingängen, Ausgängen, Eingangsregister und Holding eintragen? `
                  ja es muss etwas eingetragen werden. Je nachdem was du machen willst, auslesen, schreiben etc.
                  Wichtig ist auch zu beachten das der Adapter immer das gleiche Device bleibt. Da ändert sich z.B. schon mal nach einem PI reboot.
                  • V Offline
                    V Offline
                    vupls1
                    Chapeau! Wendy
                    Das war genau der richtige Tip. In den Registern muss etwas stehen, sonst verbindet sich der Adapter nicht.
                    Herzlichen Dank. jetzt kann es bei mir los gehen.
                    • wendy2702W Online
                      wendy2702W Online
                      Sehr schön.
                      Kannst du dann bitte noch den Titel deines ersten Posts um ein "Gelöst" ergänzen.
                      • R Offline
                        Rapsi
                        Hallo Wendy,
                        was muss ich denn bei Eingängen, Ausgängen usw eintragen?
                        Ich nutze diese Komponente:
                        https://www.ebay.de/itm/RS485-Konverter … 2749.l2649
                        https://www.ebay.de/itm/16-Kanal-RS485- ... 2749.l2649
                        Wo bekomme ich die Adressen her?
                        Hast du oder jemand Anderer eine Idee/Vorschlag?
                        • wendy2702W Online
                          wendy2702W Online
                          Da wirst du wohl Kontakt zum Hersteller/Verkäufer aufnehmen müssen wenn es keine Dokumentation gibt.
                          Aus der Ebay Auktion gehen auch keine Modbus Register hervor.
