  4. [Gelöst] YAHKA funktioniert nicht mehr
    6.5k
23 Beiträge 4 Kommentatoren 2.8k Aufrufe
    msiemers
    So?
    • wendy2702W Offline
      wendy2702W Offline
      Ne, so nicht.
      Wie geschrieben bitte in das Logfile schauen. Im admin wird gerne etwas angeschnitten.
        msiemers
          wendy2702W Offline
          Sorry…
          So auch nicht ;-)
          Bitte als Text in Code Tags.
          Und bitte mal die Ausgabe von````
          node -v
          npm -v
            msiemers
            Wie bitte?
            Node- v ergibt v8.15.0
            NodeJs -v ergibt das gleiche
            NPM- v ergibt 6.4.1
              msiemers
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:83
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: throw e
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: ^
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node'
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: was compiled against a different Node.js version using
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
              2018-12-28 20:23:41.095 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module.load (module.js:566:32)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module.require (module.js:597:17)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at require (internal/module.js:11:18)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/ed25519-hap/index.js:1:99)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
              2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
              2018-12-28 20:23:41.096 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 1 ()
                wendy2702W Offline
                Also entweder ist der Adapter nicht mit deiner Node.JS Version kompatibel oder du solltest mal das „reinstall.sh“ laufen lassen und im log schauen ob er etwas mit dem Yahka Adapter neu kompiliert.
                  msiemers
                  Was genau soll ich denn durchführen? einfach reinstall.sh würde ich jetzt nicht machen.
                  • StabilostickS Offline
                    Stabilostick
                    Wechsle in den Ordner /opt/iobroker/node_modules/ed25519-hap
                    und dort
                    npm rebuild
                    ausführen. Klappt das oder macht das Fehler?
                    PS: Was heißt, Du hast ioBroker verschoben? Den ganzen ioBroker-Ordner 1:1 kopiert?
                      msiemers
                      Ich habe jetz mal den Adapter gelöscht und wieder installiert. Dabei kam diese Fehlermeldung:
                      $ ./iobroker add yahka  --host iobroker
                      NPM version: 6.4.1
                      npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
                      npm WARN
                       hoist-non-react-statics@3.1.0 requires a peer of react@>=14.x but none is installed. You must install peer dependencies yourself.npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-redux@5.1.0 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
                      Was soll man da machen?
                        msiemers
                        Diese Meldung scheint ihn aber nicht zu stören. Ich habe gerade voller Verwunderung festgestellt, das der Adapter nun funktioniert.
                        Und das obwohl ich nichts geändert habe außer das ich ihn zum zum zweiten mal deinstalliert und wieder installiert habe.
                        Komisch
                          Stabilostick
                          Ist ja auch eine Warnung und kein Fehler.
                          Kannst ja im ioBroker-Ordner den folgenden Befehl eingeben und dann nochmal den YAHKA-Adapter neu installieren:
                          npm i react
                          Sind die Warnungen dann weg?
                          Schreibe bitte ein [Gelöst] in den Betreff des ersten Postings, wenn alles geht.
                            msiemers
                            Jo, sieht gut aus !
