  4. [Gelöst] YAHKA funktioniert nicht mehr
    6.5k
23 Beiträge 4 Kommentatoren 2.8k Aufrufe
    msiemers
    Das hier:
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Module._compile (module.js:653:30)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/index.js:1:99)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.yahka/node_modules/bindings/bindings.js:84:48)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at require (internal/module.js:11:18)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Module.require (module.js:597:17)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Function.Module._load (module.js:498:3)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at tryModuleLoad (module.js:506:12)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Module.load (module.js:566:32)
    ! Caught 2018-12-28 20:04:01.006 error by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: the module (for instance, using npm rebuild or npm install).
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: was compiled against a different Node.js version using
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.yahka/node_modules/ed25519-hap/build/Release/ed25519.node'
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: ^
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: throw e
    ! Caught 2018-12-28 20:04:01.005 error by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/bindings/bindings.js:91</anonymous>
    • wendy2702W Online
      wendy2702W Online
      Steht im log: Please try re-compiling or re-installing
      Entweder reinstall.sh oder Adapter löschen und Neuinstallation könnte helfen
        msiemers
        Den Adapter habe ich schon einmal gelöscht und neu installiert. Leider ohne Erfolg.
        • StabilostickS Offline
          Stabilostick
          Hast du ggf. nur die Instanz gelöscht? Lösche auch den Adapter in der Adapterübersicht und füge ihn dann dort wieder hinzu. Sag Bescheid, wenn ich falsch liege.
          • wendy2702W Online
            wendy2702W Online
            Noch etwas, von wo hast du das log kopiert?
            Sieht so aus als wenn die Zeilen angeschnitten sind oder meine ich das nur?
            Sonst bitte ins Logfile unter /opt/iobroker/log/ gucken
              msiemers
              Ich habe in der Tat den Adapter gelöscht. Nachdem dieser neu installiert wurde, habe ich das gleiche Fehlerbild.
                Stabilostick
                Dann die betreffenden Logzeilen in voller Schönheit, bitte. ;-)
                  msiemers
                  So?
                  • wendy2702W Online
                    wendy2702W Online
                    Ne, so nicht.
                    Wie geschrieben bitte in das Logfile schauen. Im admin wird gerne etwas angeschnitten.
                      msiemers
                      • wendy2702W Online
                        wendy2702W Online
                        Sorry…
                        So auch nicht ;-)
                        Bitte als Text in Code Tags.
                        Und bitte mal die Ausgabe von````
                        node -v
                        npm -v
                          msiemers
                          Wie bitte?
                          Node- v ergibt v8.15.0
                          NodeJs -v ergibt das gleiche
                          NPM- v ergibt 6.4.1
                            msiemers
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:83
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: throw e
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: ^
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node'
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: was compiled against a different Node.js version using
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            2018-12-28 20:23:41.095 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module.load (module.js:566:32)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module.require (module.js:597:17)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at require (internal/module.js:11:18)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/ed25519-hap/index.js:1:99)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
                            2018-12-28 20:23:41.096 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                            2018-12-28 20:23:41.096 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 1 ()
                            • wendy2702W Online
                              wendy2702W Online
                              Also entweder ist der Adapter nicht mit deiner Node.JS Version kompatibel oder du solltest mal das „reinstall.sh“ laufen lassen und im log schauen ob er etwas mit dem Yahka Adapter neu kompiliert.
                                msiemers
                                Was genau soll ich denn durchführen? einfach reinstall.sh würde ich jetzt nicht machen.
                                  Stabilostick
                                  Wechsle in den Ordner /opt/iobroker/node_modules/ed25519-hap
                                  und dort
                                  npm rebuild
                                  ausführen. Klappt das oder macht das Fehler?
                                  PS: Was heißt, Du hast ioBroker verschoben? Den ganzen ioBroker-Ordner 1:1 kopiert?
                                    msiemers
                                    Ich habe jetz mal den Adapter gelöscht und wieder installiert. Dabei kam diese Fehlermeldung:
                                    $ ./iobroker add yahka  --host iobroker
                                    NPM version: 6.4.1
                                    npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
                                    npm WARN
                                     hoist-non-react-statics@3.1.0 requires a peer of react@>=14.x but none is installed. You must install peer dependencies yourself.npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
                                    npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN react-redux@5.1.0 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
                                    npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
                                    Was soll man da machen?
                                      msiemers
                                      Diese Meldung scheint ihn aber nicht zu stören. Ich habe gerade voller Verwunderung festgestellt, das der Adapter nun funktioniert.
                                      Und das obwohl ich nichts geändert habe außer das ich ihn zum zum zweiten mal deinstalliert und wieder installiert habe.
                                      Komisch
                                        Stabilostick
                                        Ist ja auch eine Warnung und kein Fehler.
                                        Kannst ja im ioBroker-Ordner den folgenden Befehl eingeben und dann nochmal den YAHKA-Adapter neu installieren:
                                        npm i react
                                        Sind die Warnungen dann weg?
                                        Schreibe bitte ein [Gelöst] in den Betreff des ersten Postings, wenn alles geht.
                                          msiemers
                                          Jo, sieht gut aus !
