  4. Node-Red mit Alexa - Dimmer
    5.8k
39 Beiträge 5 Kommentatoren 9.8k Aufrufe 1 Beobachtet
  • V Offline
    V Offline
    vlink
    Muss doch nochmal fragen.
    So 100% klappt es noch nicht.
    Wenn ich sage 'Alexa Stehlampe 50' > setzt er es richtig.
    Alexa aus, geht auch.
    Bei Alexa 'Stehlampe ein' > Schaltet er sie zwar ein, jedoch immer auf eine undefinierte, teilweise die letzte Helligkeit, aber nicht auf 100% wie ich es eigentlich möchte. Was mache ich hier falsch?
    Danke!
    "id": "ff41b356.eda65",
    "type": "tab",
    "label": "Lichter",
    "disabled": false,
    "info": ""
    "id": "fa8c3d66.255e9",
    "type": "alexa-local",
    "z": "ff41b356.eda65",
    "devicename": "Stehlampe",
    "inputtrigger": false,
    "x": 110,
    "y": 57,
    "wires": [
    "26e02aef.786fe6",
    "1a6ff2c1.dc502d",
    "73caa55.6b0ed5c"
    "id": "26e02aef.786fe6",
    "type": "change",
    "name": "msg.bri -> msg.payload",
    "rules": [
    "t": "change",
    "p": "payload",
    "pt": "msg",
    "from": "off",
    "fromt": "str",
    "to": "0",
    "tot": "num"
    "t": "change",
    "p": "payload",
    "pt": "msg",
    "from": "on",
    "fromt": "str",
    "to": "100",
    "tot": "num"
    "t": "set",
    "p": "payload",
    "pt": "msg",
    "to": "bri",
    "tot": "msg"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 370,
    "y": 57,
    "wires": [
    "3cace69a.b1f98a",
    "40516257.b2fd4c"
    "id": "3cace69a.b1f98a",
    "type": "ioBroker out",
    "name": "Philips_hue.Wohnzimmer.Stehlampe.level",
    "topic": "hue.0.Philips_hue.Wohnzimmer.Stehlampe.level",
    "ack": "false",
    "autoCreate": "false",
    "x": 720,
    "y": 57,
    "wires": []
    "id": "1a6ff2c1.dc502d",
    "type": "debug",
    "name": "Stehlampe Input Payload",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "x": 370,
    "y": 153,
    "wires": []
    "id": "40516257.b2fd4c",
    "type": "debug",
    "name": "Stehlampe Output Bri",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "x": 660,
    "y": 140,
    "wires": []
    "id": "73caa55.6b0ed5c",
    "type": "debug",
    "name": "Stehlampe Input Bri",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "bri",
    "x": 350,
    "y": 193,
    "wires": []
    • V Offline
      V Offline
      vlink
      • R Offline
        rewenode
        Also interessant wäre mal, wie die Nachricht aussieht, wenn du "Alexa ein" sagst.
        Dazu solltest du aber nicht 2 debug nodes an Stehlampe klemmen, sondern Sur eines mit der Einstellung 'complete msg object'
        "Alexa ein" sollte ja nur EIN msg-object erzeugen und das hat eine payload-eigenschaft und ggf eine bri-eigenschaft.
        Interessant ist jetzt, gibt es da die bri-eigenschaft und falls ja, was hat die für Inhalt. Dazu die das Object im Debug Panel kopieren und hier posten.
        • V Offline
          V Offline
          vlink
          Wieder was gelernt. Danke!
          Wenn ich nur 'Alexa Stehlampe Ein' sage > Kommt Payload mit 'On' und Bri mit dem letzten Wert z.b. '50'
          Eigentlich kann ich damit leben. Bedeutet bei 'Alexa ein' schaltet er die Lampe ein mit der letzten Helligkeit.
          Hätte es nur gerne, dass ich bei 'Ein' die Lampe auf 100% bekomme.
          Das scheint sich nur zu beißen weil bei 'Ein' eben immer .payload = on und .bri = [letzter Wert] kommt.
          Wüsste nicht wie ich das hinbekomme dann auf 100% zu gehen.
          Wenn ich sage 'Alexa Stehlampe 75' kommt ja auch .paylod = on und .bri = 75
          Danke!
          • R Offline
            rewenode
            ` > Wenn ich nur 'Alexa Stehlampe Ein' sage > Kommt Payload mit 'On' und Bri mit dem letzten Wert z.b. '50'…
            Wenn ich sage 'Alexa Stehlampe 75' kommt ja auch .paylod = on und .bri = 75 `
            Da hat das change-node keine change, woher soll es dann wissen, ob Alexa "on" oder "bri" meint?
            Auszug aus der node Info
            payload string | on/off
            "on" or "off" trigger from Alexa.
            when dimming command is issued, this payload stays "on" as long as bri > 0. In other words, payload == "off" only when bri == 0. `
            Da hast du eigentlich keine change, das könnte nur der Entwickler des Alexa-node ändern. Da wirst du auch nicht tricksen können;-( Jedenfalls nicht in diese Konstellation NR/Alexa-local-node.
            Das node trennt praktisch nicht zwischen on und bri.
            • R Offline
              rewenode
              Da war ich wohl nicht gründlich. Wer lesen kann ist klar im Vorteil :lol:
              Sollte doch gehen.
              ` > on_off_command boolean | true/false
              indicate whether the command was an on/off command or a dimming/brightness command
              eg. Alexa turn on/off light -> true
              Alexa set light to 39% -> false
              Alexa set light to 0% -> false `
              Sollte so gehen (Pseudocode):
              Wenn msg.on_off_command dann
                  msg.payload -> 0/100 msg.payload
              Sonst
              Das Ganze ist leicht in einen JSONata-Ausdruck gepackt. Ersetze mal dein Change-node durch Dieses:
                      "id": "a07b6c76.f86d2",
                      "type": "change",
                      "z": "2262a318.45ba74",
                      "name": "on/off or bri to payload",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "(\t   on_off_command = true ? (\t       payload = \"on\" ? 100 : 0\t  \t   ) : (\t     bri\t  )\t\t)",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 680,
                      "y": 760,
                      "wires": [
                              "747a10d.f6d8ef"
              • V Offline
                V Offline
                vlink
                Ja cool
                das geht..super und vielen vielen dank!
                auch wenn ich es gerade noch nicht ganz verstehe wie es funktioniert :)
                  dondon4002
                  Können wir nicht gleich noch die Farbe hinzufügen :D Daran hapert es derzeit bei mir.
                  Leider brauch Phillips Hue einen "HUE" wert den weder der UI Colorpicker auswirft noch Alexa :D
                  • R Offline
                    rewenode
                    @vlink:
                    ..auch wenn ich es gerade noch nicht ganz verstehe wie es funktioniert :) `
                    Das kommt mit der Zeit :lol:
                    Im Grunde eine 1:1 Umsetzung des Pseudocodes.
                    Der Trick war, dass das Alexa-local-node noch eine Eigenschaft on_off_command kennt. Und diese wird auf true gesetzt, wenn es sich um einen ON oder OFF Befehl handelte und NUR dann.
                    Damit ist es dann möglich zu unterscheiden, ob die 100 (ON/OFF-Befehl=true UND payload="on") oder der Helligkeitswert (bri) (ON/OFF-Befehl=false) zu setzen ist.
                    Der JSONata-Ausdruck ist vlt. von der Syntax nicht gleich verständlich;-( JSONata ist KEIN Javascript! auch wenn es ähnlich aussieht.
                    Muss man sich halt einlesen: http://jsonata.org/
                    Und die paar node-red Besonderheiten dazu: https://github.com/node-red/cookbook.no … ta-Recipes
                    Natürlich kann das ähnlich einfach mit Javascript gemacht werden, aber das steht im Change-node nicht zur Verfügung. Müßte man einen functions-node nehmen.
                    @dondon4002
                    Ja, da weis ich auch erstmal nicht wie das gehen kann. Hab leider keine Hue :(
                    Mit welchem Adapter betreibst du denn das Teil? Kennt das Ding in den Objekten eine HUE-Eigenschaft ?
                    • V Offline
                      V Offline
                      vlink
                      Es gibt diese Datenpunkte vom HUE Adapter.
                      • R Offline
                        rewenode
                        Da gibt es doch einen hue-state. Was will der denn für Werte haben ?
                        Trag doch mal manuell welche ein und poste, wie die aussehen müssen.
                          dondon4002
                          Den Hue Adapter würde ich nicht nutzen wenn du eh Node-Red nutzt denn da gibt's ja das HueMagic
                          und dieses ist Flexibel, es nimmt RGB oder HEX entgegen.. aber leider gibt Alexa nur HSB/HSL Werte als HUE (Hue: 0, Saturation: 1, Brightness:1) für Rot zum Beispiel. Man müsste also einen Converter von HSB/HSL zu HEX oder RGB haben.
                          derzeit Steuer ich Rot / Blau / Weiss so.. was echt nicht toll ist.
                          if ((msg['command']) == 'SetColorRequest') {
                            if ((msg['payload']['hue']) == '0' && (msg['payload']['saturation']) == '1') {
                              msg['payload']['hex'] = '#ff0000';
                            } else if ((msg['payload']['hue']) == '240') {
                              msg['payload']['hex'] = '#3366ff';
                            } else if ((msg['payload']['hue']) == '0' && (msg['payload']['saturation']) == '0') {
                              msg['payload']['hex'] = '#ffffff';
                            msg['payload']['brightness'] = '100';
                            msg['payload']['saturation'] = '100';
                            return msg;
                          } else {
                          • R Offline
                            rewenode
                            Ich kenne mich da leider nicht gut aus.
                            Aber sollte sowas nicht hilfreich sein?
                            https://www.npmjs.com/package/node-red- … or-convert
                            ` > This node converts between different color representations, it can convert between the following systems.
                            RGB - Red, Green, Blue
                            HSL - Hue, Saturation, Level
                            HSV - Hue, Saturation, Value (brightnes)
                            CSS - CSS color names `
                              dondon4002
                              Ja den habe ich ausprobiert aber irgendwie klappt es damit nicht so richtig. vielleicht mache ich es auch falsch.. Am Ende wäre es aber der richtige Converter dafür. HSV Array-> RGB als Array
                              Man müsste dann aber schauen das man vorher Saturation und Brightness noch *100 nimmt..
                              • R Offline
                                rewenode
                                @dondon4002:
                                …Ja den habe ich ausprobiert aber irgendwie klappt es damit nicht so richtig.... `
                                Gut ist immer, wenn man ein Beispiel zeigen kann, wie es sein soll.
                                So nach dem Motto:
                                Für gelb müssen folgende states folgende Werte bekommen…
                                @dondon4002:
                                Man müsste dann aber schauen das man vorher Saturation und Brightness noch *100 nimmt.. `
                                Versuch doch mal die Werte per Hand bei den States zu setzen und schau, ob die Hue reagiert wie sie soll. Wenn das geht, sollte man das auch per flow hinbekommen;-)
                                  dondon4002
                                  Also irgendwas passt nicht :-(
                                    msg['payload']['hsv'] = [(msg['payload']['hue']), (msg['payload']['saturation']) * 100, (msg['payload']['brightness']) * 100];
                                    return msg;
                                  } else {
                                  Ausgabe Alexa und Blocky:
                                  {"hue":0,"saturation":1,"brightness":1,"hsv":[0,100,100]}
                                  Ausgabe Converter (HSV to RGB)
                                  [3,3,3]
                                  • R Offline
                                    rewenode
                                    Also wenn ich dich recht verstehe, soll zb. die Alexa Ausgabe so konvertiert werden. oder wie?
                                    sollte rot sein.
                                    so aussehen:
                                    ist immer noch rot, nur rgb
                                    {"hue":0,"saturation":1,"brightness":1,"rgb":[255,0,0]}
                                    oder verstehe ich das falsch?
                                      dondon4002
                                      Alexa wirft bei "Alexa Schalte Test auf ROT" dies aus:
                                      dies schiebe ich in den Blocky und mache ein Array daraus damit dies kommt:
                                      "hsv":[0,100,100]
                                      Der Converter macht aber nun ein RGB Array und zwar so:
                                      [3,3,3]
                                      Es müsste aber für den HUE Adapter so kommen:
                                      RGB [255,0,0]
                                      • R Offline
                                        rewenode
                                        Ich hoffe, ich habe richtig kapiert.
                                        Das sollte auch ohne Blockly problemlos gehen:
                                        hier der flow:
                                        "id": "26dc88fe.708c5",
                                        "type": "inject",
                                        "z": "ca47e1d4.9f532",
                                        "name": "Alexa Schalte Test auf ROT",
                                        "topic": "",
                                        "payload": "{"hue":0,"saturation":1,"brightness":1}",
                                        "payloadType": "json",
                                        "repeat": "",
                                        "crontab": "",
                                        "once": false,
                                        "onceDelay": 0.1,
                                        "x": 230,
                                        "y": 140,
                                        "wires": [
                                        "ad83b521.77c65",
                                        "7eb1492e.f3b3d8"
                                        "id": "86870acf.2656c",
                                        "type": "color-convert",
                                        "input": "hsv",
                                        "output": "rgb",
                                        "outputType": "array",
                                        "x": 190,
                                        "y": 300,
                                        "wires": [
                                        "a57a950f.248af8"
                                        "id": "ad83b521.77c65",
                                        "type": "change",
                                        "name": "{"hue":0,"saturation":1,"brightness":1} to [h,s,v]",
                                        "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "[\t payload.hue,\t payload.saturation * 100,\t payload.brightness * 100\t]",
                                        "tot": "jsonata"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 300,
                                        "y": 220,
                                        "wires": [
                                        "86870acf.2656c",
                                        "a4ad7796.ecdb8"
                                        "id": "ccb4443d.a17ce8",
                                        "type": "comment",
                                        "name": "msg.payload ={"hue":0,"saturation":1,"brightness":1}",
                                        "info": "",
                                        "x": 940,
                                        "y": 140,
                                        "wires": []
                                        "id": "3e66cbf2.9da13c",
                                        "type": "comment",
                                        "name": "direct convert to rgb[r,g,b]",
                                        "info": "",
                                        "x": 830,
                                        "y": 300,
                                        "wires": []
                                        "id": "bd23336d.d791e8",
                                        "type": "comment",
                                        "name": "object hsv[h,s,v]",
                                        "info": "",
                                        "x": 800,
                                        "y": 220,
                                        "wires": []
                                        "id": "a57a950f.248af8",
                                        "type": "debug",
                                        "name": "rgb[r,g,b]",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "x": 600,
                                        "y": 300,
                                        "wires": []
                                        "id": "7eb1492e.f3b3d8",
                                        "type": "debug",
                                        "name": "{"hue":0,"saturation":1,"brightness":1}",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "x": 550,
                                        "y": 140,
                                        "wires": []
                                        "id": "a4ad7796.ecdb8",
                                        "type": "debug",
                                        "name": "hsv[h,s,v]",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "x": 600,
                                        "y": 220,
                                        "wires": []
                                         ![3999_bild_1.png](/assets/uploads/files/3999_bild_1.png)
                                        Am Eingang bekommt das Teil ein Oblect````
                                        Am Ausgang hast du ein Array````
                                        [r,g,b]
                                        Wenn das lieber ein Object sein soll, der Form:````
                                        {"rgb": [r,g,b]}
                                        ````ist eine minimale Änderung nötig.
                                          dondon4002
                                          Perfekt :D dann hab ich nur den Converter falsch benutzt :D :D danach noch nen Change to msg.payload.rgb und Alexa schaltet das ganze :-) Danke dir
