  4. Homematic Taster gedrückt halten
    5.8k
19 Beiträge 7 Kommentatoren 5.0k Aufrufe
  • R Offline
    RappiRN
    So ich habe jetzt mal auf die Schnelle ein log eingebaut:
    2017-11-15 17:52:29.336 - [32minfo[39m: javascript.0 Start javascript script.js.Eltako_Dimmer 2017-11-15 17:52:29.358 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: registered 5 subscriptions and 0 schedules 2017-11-15 17:52:55.673 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:52:55.672Press_Short_2 2017-11-15 17:52:55.695 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:52:55.695Dimmer0 2017-11-15 17:53:05.067 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:05.067Press_Short_1 2017-11-15 17:53:05.087 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:05.086Dimmer100 2017-11-15 17:53:20.062 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:20.062Press_Short_2 2017-11-15 17:53:20.079 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:20.079Dimmer0 2017-11-15 17:53:24.709 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:24.709Press_Long 2017-11-15 17:53:24.725 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:24.723Dimmer30 2017-11-15 17:53:25.728 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:25.728Dimmer50 2017-11-15 17:53:26.722 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:26.722Dimmer70 2017-11-15 17:53:26.874 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:26.874Press_Long_Release 2017-11-15 17:53:35.058 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:35.057Press_Long 2017-11-15 17:53:35.089 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:35.088Dimmer90 2017-11-15 17:53:36.068 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:36.067Dimmer100 2017-11-15 17:53:39.360 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:39.360Press_Long_Release 2017-11-15 17:53:46.483 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:46.483Press_Short_2 2017-11-15 17:53:46.496 - [32minfo[39m: javascript.0 script.js.Eltako_Dimmer: 17:53:46.495Dimmer0[/code]
    ! Is leider nur der Auszug aus der log-Datei direkt vom log-Ordner, das Erstellen eines Auszuges direkt aus dem log funktioniert irgendwie nicht, das ging aber schonmal!? :?:
    ! Enrico
      dwm
      Ja. Definitiv anderes Verhalten der Taster.
      Das obige Script loggt übrigens nur die Tastenevents, halt mit dem kompletten Zustand der Datenpunkte als JSON.
      Egal, ich hab das JSON wieder rausgeschmissen, machts nur unübersichtlich.
      Nach 5s Drücken des Tasters:
      06:57:08.067	[info]	javascript.0 script.js.Steuerung.testzeugs: PRESS_LONG
      06:57:08.068	[info]	javascript.0 script.js.Steuerung.testzeugs: PRESS_LONG_RELEASE
      Zeitunterschied nach IOBroker 1ms! Und zwar gesendet beim Loslassen des Tasters.
      Heißt also (für mich):
      Wenn man von HM-Taster einen Nicht-HM Dimmer steuern will, muss man einen 230V Taster (HM-RC-2-PBU-FM) nehmen, nur so kann man über ein IOBroker Programm das gleiche Verhalten erreichen wie bei der Homematic Direktverknüpfung.
      Mit dem Batterie-Wandtaster (HM-PB-2-WM55-2) klappts NICHT.
      HM-Taster auf HM-Dimmer ist sowieso die Direktverknüpfung schlauer, weil man dann den Dutycycle der CCU nicht zumüllt.
      Ja, wieder was gelernt :)
      Werner
      • L Offline
        lukics
        @dwm:
        Werner `
        hast du mal probiert beim WM55 bei den Kanälen die AES Verschlüsselung zu deaktivieren?
          dwm
          Hm, nein. Weiss ehrlich gesagt gar nicht, ob die Verschlüsselung aktiviert ist,
          aber das ist ein guter Punkt.
          Muss heut Abend mal schaun.
          • L Offline
            lukics
            @dwm:
            Zusätzlich hilft vielleicht in der CCU leere Programme mit all den Kanälen zu erzeugen.
            Ich kann leider das nicht ausprobieren weil ich 900km entfernt von meiner Installtion bin. Verwende openhab.
            • simatecS Offline
              simatecS Offline
              simatec
              Hatte auch bei mir das Problem.
              Die Verschlüsselung muss deaktiviert sein.
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • L Offline
                lukics
                Stimmt, hab das auch mittlerweile entdeckt, hab den thread vergessen. Danke
                • O Offline
                  O Offline
                  oliver2017
                  @lukics:
                  @dwm:
                  Werner hast du mal probiert beim WM55 bei den Kanälen die AES Verschlüsselung zu deaktivieren?
                  Moin
                  danke für den Hinweis. Hatte genau das gleiche Problem, die Gesicherte Übertragung war schuld.
                  Ein paar details über meinen iobroker:
                  Proxmox VM iobroker
                  Alarmanlage mit Alexa Sprachausgabe
                  Solvis Heizung anbindung
                    TonyDom
                    Ich habe diesen Vorschlag zum abdimmen.
                    Dieses Script funktioniert bei mit jedoch nur mit einem Trigger (ohne release), weil ich bei mir das Schlafzimmer automatisch abdimmen lasse. Deshalb wirds auch bei mir so langsam dunkel, aber man kann ja die Zeiten und Schritte ändern.
                    • L Offline
                      lukics
                      Hast du die "CONT" option probiert.
                      Das CONT kommt periodisch. Ich habe (openhab) damit das dimmen realisiert, indem ich bei jedem CONT einen 5% Schritt die Helligkeit erhöhe.
                      Die Funktion des Tasters ist:
                      Kurz -> EIN/AUS (100%/0%)
                      Lang -> Hochdimmen in 5% basierend auf CONT events.
                      Gruss
