  4. [Projekt] ioGo # Smarthome to go
    1.0k
    6.1k
iogoappandroid
1.1k Beiträge 61 Kommentatoren 472.9k Aufrufe 20 Beobachtet
  • E Offline
    eMd
    #433
    Also ich habe gestern den enigma2 adapter installiert und 2 states zugeordnet, diese hat er gesynct, den rest wieder nicht.
    2018-11-18 06:58:08.687 - info: host.raspberrypi instance system.adapter.iogo.0 terminated with code 156 ()
    2018-11-18 06:58:11.160 - info: host.raspberrypi instance system.adapter.iogo.0 started with pid 30656
    2018-11-18 06:58:13.101 - debug: iogo.0 objectDB connected
    2018-11-18 06:58:13.166 - debug: iogo.0 statesDB connected
    2018-11-18 06:58:13.282 - info: iogo.0 starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.12.0
    2018-11-18 06:58:13.331 - info: iogo.0 initialize app devices
    2018-11-18 06:58:14.091 - info: iogo.0 logged in as: OcpKCaPrCkQ9aQqrtzW1JgZ80Dz1
    2018-11-18 06:58:14.110 - info: iogo.0 removed states from remote database
    2018-11-18 06:58:14.116 - info: iogo.0 removed objects from remote database
    2018-11-18 06:58:14.119 - info: iogo.0 removed enums from remote database
    2018-11-18 06:58:14.780 - info: iogo.0 database initialized with 2 enums
    2018-11-18 06:58:14.865 - info: iogo.0 database initialized with 2 objects
    2018-11-18 06:58:15.147 - info: iogo.0 database initialized with 2 states
    Der Rest sind bei mir die 4 Sonoff-Basic und 3 HM-IP Fenstersensoren…
    Master: Intel NUC 16GB/500GB
    Slave: Raspberry Pi 3 + Homematicmodul
    Shelly, Google Home, Zigbee Aqara, Sonoff
    Meine VIS: https://youtu.be/JMYr2KYlpME
    • ? Offline
      #434
      @eMd:
      Der Rest sind bei mir die 4 Sonoff-Basic und 3 HM-IP Fenstersensoren… `
      Dann poste mal bitte den RAW eines der States die noch nicht gehen.
      • E Offline
        eMd
        #435
          "_id": "sonoff.0.S-Wohnzimmer-Lampe_67171E.POWER",
          "common": {
            "type": "boolean",
            "role": "button",
            "read": true,
            "write": true,
            "storeMap": true,
            "name": "S-Wohnzimmer-Lampe_67171E POWER",
            "smartName": {
              "smartType": "LIGHT"
          "native": {},
          "type": "state",
          "from": "system.adapter.sonoff.0",
          "ts": 1541704589691,
          "acl": {
            "object": 1636,
            "state": 1636
        ich hoffe das ist richtig so :)
        • ? Offline
          #436
          Das sieht ganz ok aus.
          Wie sieht denn der RAW von dem Raum aus wo der zugeordnet ist.
          Kannst du das auch nochmal posten bitte
          • E Offline
            eMd
            #437
              "ts": 1542433046712,
              "common": {
                "name": "Wohnzimmer",
                "color": false,
                "members": [
                	"sonoff.0.S-Wohnzimmer-Lampe_67171E",
                	"enigma2.0.main_command.STANDBY";
                	"enigma2.0.main_command.WAKE_UP_FROM_STANDBY"
                "native": {},
                "acl": {
                	"object": 1636,
                	"owner": "system.user.admin",
                "_id": "enum.rooms.wohnzimmer",
                "type": "enum"
            • ? Offline
              #438
              Der State ist: sonoff.0.S-Wohnzimmer-Lampe_67171E****.POWER****
              Zugeordnet wurde jedoch: sonoff.0.S-Wohnzimmer-Lampe_67171E
              Scheinbar hast du nicht den State, sondern den gesamten Channel zugewiesen.
              In der App werden nur States angezeigt, die direkt zugeordnet wurden
              • ? Offline
                #439
                Neue Beta Version
                App: 1.2.2 (beta)
                Adapter: 0.2.0 (latest)
                Es ist nun möglich den ioGo-Adapter als PRO Variante zu nutzen.
                Weiterhin bleibt auch eine kostanlose Variante bestehen.
                Und ebenfalls bleibt die Verbindung mit web-Adapter und cloud-Adapter bestehen.
                Neue iogoPro Features:
                • Versenden von Bilder als Benachrichtigung(push-notification)
                Anpassungen:
                • Icons der enums werden nur noch von der PRO Variante unterstützt
                Über Feedback, Wünsche und Kritik würde ich mich freuen.
                Gerne hier im Forum oder als issue in github.
                App: https://github.com/nisiode/ioGo/issues
                Adapter: https://github.com/nisiode/ioBroker.iogo/issues
                Sehr erfreulich sind die stetig steigenden Installationen der App.
                Aktuell ist die App auf 400 Geräten installiert.
                Diese ergeben über 40.000 screen-views jeden Monat.
                Allerdings ist der Traffic nicht endlos kostenfrei.
                Durch die PRO Variante soll ein Teil der Kosten ausgeglichen werden.
                • E Offline
                  eMd
                  #440
                  @nisio:
                  In der App werden nur States angezeigt, die direkt zugeordnet wurden `
                  Habe es entsprechend geändert, und siehe da es funktioniert! Auch in material ui und anderen <emoji seq="1f601">😁</emoji>
                  Vielen Dank für deine Hilfe, das war top!
                  • E Offline
                    eMd
                    #441
                    Bin jetzt beta tester, hab alles frisch installiert, sobald ich aber den iogo Adapter aktiviere kommt folgende fehlermeldung
                    java.lang.NullPointerException: Attempt to invoke virtual method 'boolean java.lang.Boolean.booleanValue()' on a null object reference
                    	at de.nisnagel.iogo.data.repository.StateRepository.lambda$checkPro$1(StateRepository.java:271)
                    	at de.nisnagel.iogo.data.repository.-$Lambda$StateRepository$NBOVyki1boaOIO8By189LTfHmSA.onSuccess(Unknown Source:4)
                    	at com.google.android.gms.tasks.zzn.run(Unknown Source:4)
                    	at android.os.Handler.handleCallback(Unknown Source:2)
                    	at android.os.Handler.dispatchMessage(Unknown Source:4)
                    	at android.os.Looper.loop(Unknown Source:152)
                    	at android.app.ActivityThread.main(Unknown Source:68)
                    	at java.lang.reflect.Method.invoke(Native Method)
                    	at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Unknown Source:11)
                    	at com.android.internal.os.ZygoteInit.main(Unknown Source:203)
                    App stürzt sofort ab…
                    • ? Offline
                      #442
                      @eMd:
                      App stürzt sofort ab… ` Vielen Dank fürs Testen.
                      Schicke heute Abend einen Bugfix raus.
                      • ? Offline
                        #443
                        Version 1.2.3 ist als Beta unterwegs.
                        Hoffe die App stürzt dann nicht mehr ab.
                        • E Offline
                          eMd
                          #444
                          Keine Ahnung ob was anders ist, aber wieder Absturz nach Aktivierung des iogo Adapter in den Einstellungen…
                          • ? Offline
                            #445
                            Ach Mist, hab den falschen Bug behoben.
                            Nun nochmal den richtigen behoben :-)
                            Bitte mit Version 1.2.4 nochmal versuchen…
                            • E Offline
                              eMd
                              #446
                              	at de.nisnagel.iogo.data.repository.StateRepository.lambda$checkPro$1(StateRepository.java:266)
                              Keine Änderungen bei mir, mach ich was falsch?
                              • ? Offline
                                #447
                                Du machst wahrscheinlich nix falsch.
                                Aber hast du wirklich schon v1.2.4? Ich sehe keine Fehlermeldunegn zu dieser Version bisher.
                                • U Offline
                                  U Offline
                                  UweS
                                  #448
                                  Hi
                                  Ich checkes es nicht wie ich die States zuordne. Die App findet meine Räume und Funktionen aber keinen einzigen State.
                                  Bitte einen kleiner Stupser in die richtige Richtung.
                                  • R Offline
                                    rudiraz
                                    #449
                                    Vielleicht hab ichs etwas verstanden:
                                    Nur dem State darf der Raum zugewiesen worden sein.
                                    Wenn dem Channel (dem Ordner, in dem der State ist) ebenfalls ein Raum zugewiesen wurde, wird nichts in der App angezeigt.
                                    Problem beim Loxone-Adapter (siehe Anhang):
                                    den Channels werden beim syncen ebenfalls die Räume zugewiesen, was dazu führt, dass die States nicht in der App angezeigt werden.
                                    Wenn ich bei dem "Ordner" den Raum "Zentral" entferne, wird der State "DisMv Bad" ohne Probleme angezeigt
                                    Ich kann aber nicht immer manuelle die Raumzurodnung aus den Channels löschen, wenn der Adapter neu synct (bsp bei Änderung im Loxone-Miniserver). Das mach mir etwas Probleme
                                    • ? Offline
                                      #450
                                      Was auf den oberen Ebenen (channel, device) zugeordnet wurde ist eigentlich egal.
                                      Hauptsache der einzelne State ist zugeordnet.
                                      Es müsste eigentlich auch gehen die Zuordnung auf dem Channel und zusätzlich auf dem State zu machen.
                                      Dann wird glaube ich beim State die Zuordnung doppelt angezeigt in der Objekt-Übersicht.
                                      • R Offline
                                        rudiraz
                                        #451
                                        Also bei mir funktioniert es nur so, wie oben beschrieben. Keine Ahnung warum
                                        • U Offline
                                          U Offline
                                          UweS
                                          #452
                                          So habe ich mal probiert, hilft aber auch nichts.
