  4. Iobroker und cloud???
    6.3k
52 Beiträge 7 Kommentatoren 7.0k Aufrufe
    denjo
    jetzt geht gar nix mehr
    ! pi@raspberrypi:~ $ sudo su
    ! root@raspberrypi:/home/pi#
    ! root@raspberrypi:/home/pi# cd /opt/iobroker
    ! root@raspberrypi:/opt/iobroker#
    ! root@raspberrypi:/opt/iobroker# iobroker stop
    ! module.js:550
    ! throw err;
    ! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    ! at Function.Module._resolveFilename (module.js:548:15)
    ! at Function.Module._load (module.js:475:25)
    ! at Function.Module.runMain (module.js:694:10)
    ! at startup (bootstrap_node.js:204:16)
    ! at bootstrap_node.js:625:3
    ! root@raspberrypi:/opt/iobroker# npm i iobroker.js-controller@1.4.2
    ! > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    ! > node lib/preinstall_check.js
    ! NPM version: 6.4.1
    ! npm version >= 5: disabling package-lock
    ! > bcrypt@2.0.1 install /opt/iobroker/node_modules/bcrypt
    ! > node-pre-gyp install –fallback-to-build
    ! node-pre-gyp ERR! Pre-built binaries not installable for bcrypt@2.0.1 and node@8.12.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    ! node-pre-gyp ERR! Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/bcrypt/lib'
    ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.12.0"
    ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/bcrypt/.node-gyp"
    ! gyp WARN install got an error, rolling back install
    ! gyp ERR! configure error
    ! gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/bcrypt/.node-gyp'
    ! gyp ERR! System Linux 4.14.70-v7+
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/bcrypt/lib/binding/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/bcrypt/lib/binding" "--napi_version=3" "--node_abi_napi=napi"
    ! gyp ERR! cwd /opt/iobroker/node_modules/bcrypt
    ! gyp ERR! node -v v8.12.0
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! build error
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding --napi_version=3 --node_abi_napi=napi' (1)
    ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/bcrypt/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
    ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
    ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    ! node-pre-gyp ERR! System Linux 4.14.70-v7+
    ! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/bcrypt/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/bcrypt
    ! node-pre-gyp ERR! node -v v8.12.0
    ! node-pre-gyp ERR! node-pre-gyp -v v0.9.1
    ! node-pre-gyp ERR! not ok
    ! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding --napi_version=3 --node_abi_napi=napi' (1)
    ! > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
    ! > node iobroker.js setup first
    ! Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    ! Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    ! fs.js:885
    ! return binding.mkdir(pathModule._makeLong(path),
    ! Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
    ! at Object.fs.mkdirSync (fs.js:885:18)
    ! at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:143:58)
    ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:629:27
    ! at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:661:15)
    ! at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3166:5)
    ! at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
    ! at Module._compile (module.js:653:30)
    ! at Object.Module._extensions..js (module.js:664:10)
    ! at Module.load (module.js:566:32)
    ! at tryModuleLoad (module.js:506:12)
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    ! npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 (node_modules/bcrypt):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bcrypt@2.0.1 install: node-pre-gyp install --fallback-to-build
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! errno 1
    ! npm ERR! iobroker.js-controller@1.4.2 install: node iobroker.js setup first
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the iobroker.js-controller@1.4.2 install script.
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:
    ! npm ERR! /root/.npm/_logs/2018-11-03T08_46_44_302Z-debug.log
    ! root@raspberrypi:/opt/iobroker# iobroker start
    ! module.js:550
    ! throw err;
    ! root@raspberrypi:/opt/iobroker#</anonymous></anonymous>
      denjo
      ich kann nur den 1.5.3 installieren wenn ich den 1.4.2 drauf mache kommt wie oben gezeigt der error
      • J Offline
        Jan1
        Hast den Admin schon auf 3?
          denjo
          ja
          • J Offline
            Jan1
            Deine Installation war, oder ist recht durcheinander. Kann gut sein, dass man das nicht so einfach wieder hingebogen bekommt.
            Mach mal :
                node -v
                nodejs -v
                npm -v
              denjo
              ` > root@raspberrypi:~# node -v
              v8.12.0
              root@raspberrypi:~#
              root@raspberrypi:~# nodejs -v
              v8.12.0
              root@raspberrypi:~#
              root@raspberrypi:~# npm -v
              6.4.1
              root@raspberrypi:~# `
              • J Offline
                Jan1
                Entweder Du liest jetzt mal die Anleitung, oder Du brauchst hier nicht länger mit Hilfe rechnen.
                Was steht denn dort zu den Versionen und was empfohlen wird?
                  denjo
                  das hatte ich gemacht aber ich mach es jetzt nochmal
                  • J Offline
                    Jan1
                    Da steht was zur NPM Version und da ich vermute, dass dieser Hinweis:
                    Bei einer bestehenden ioBroker-Installation müssen beim Wechsel der Masterversion von nodejs (4.x, 6.x, 8.x, 10.x) anschließend unbedingt die bereits installierten Adapter für diese geänderte node-Version neu kompiliert werden.
                    Deine Installation ebenfalls betrifft, sollte das auch mal, in Betracht gezogen werden.
                    Wenn die Ausgaben dann mit der Anleitung überein stimmen, läuft das. Wenn nicht hat man zumindest mal ne Basis
                      denjo
                      so hat alles fast geklappt außer das reinstall wie zu sehen und ich kann immer noch keine neuen gerät hinzufügen
                      ! root@raspberrypi:~# node -v
                      ! v8.12.0
                      ! root@raspberrypi:~# nodejs -v
                      ! v8.12.0
                      ! root@raspberrypi:~# npm -v
                      ! 4.6.1
                      ! root@raspberrypi:~# sudo ./reinstall.sh
                      ! sudo: ./reinstall.sh: Befehl nicht gefunden
                      ! root@raspberrypi:~# cd iobroker
                      ! bash: cd: iobroker: Datei oder Verzeichnis nicht gefunden
                      ! root@raspberrypi:~# cd /opt/iobroker
                      ! root@raspberrypi:/opt/iobroker# ls -l reinstall.sh
                      ! ls: Zugriff auf 'reinstall.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                        denjo
                        bei mir fehlt die das verzeichniss reinstall.sh
                        ! root@raspberrypi:/opt/iobroker# ls -la
                        ! insgesamt 516
                        ! drwxr-xr-x 7 root root 4096 Nov 3 10:40 .
                        ! drwxr-xr-x 9 root root 4096 Mär 4 2018 ..
                        ! drwxrwxrwx 2 root root 4096 Nov 3 07:06 backups
                        ! drwxrwxrwx 2 root root 4096 Jan 29 2018 etc
                        ! -rwxrwxrwx 1 root root 297 Jan 29 2018 install.sh
                        ! -rwxrwxrwx 1 root root 57 Nov 3 09:56 iob
                        ! -rwxrwxrwx 1 root root 67 Jan 29 2018 iobroker
                        ! drwxrwxrwx 6 root root 4096 Nov 3 00:19 iobroker-data
                        ! -rwxrwxrwx 1 root root 92 Nov 3 10:36 killall.sh
                        ! drwxrwxrwx 2 root root 4096 Nov 3 02:28 log
                        ! drwxrwxrwx 813 root root 32768 Nov 3 10:40 node_modules
                        ! -rw-rw-rw- 1 root root 19 Nov 3 09:56 .npmrc
                        ! -rwxrwxrwx 1 root root 2059 Nov 3 10:40 package.json
                        ! -rwxrwxrwx 1 root root 426988 Nov 2 22:50 package-lock.json
                        ! -rwxrwxrwx 1 root root 709 Nov 3 09:53 reinstall.dos
                        ! -rwxrwxrwx 1 root root 5868 Nov 3 09:56 reinstall.js
                        • J Offline
                          Jan1
                          wie man das löst, steht auch in der Anleitung :lol:
                            denjo
                            soo habe jetzt alles gemacht und alle genannten Adapter auf die Versionen die ihr gesagt habt alle Adapter laufen auch wieder nur leider kann ich kein neues gerät hinzufügen.
                            • J Offline
                              Jan1
                              hat das neu compilieren jetzt geklappt?
                                denjo
                                ja hat alles
                                • J Offline
                                  Jan1
                                  in welchem Adapter möchtest Du jetzt ein Gerät hinzufügen?
                                    denjo
                                    Cloud adapter
                                    • J Offline
                                      Jan1
                                      Wie willst das hinzufügen, über einzelne DPs oder enmu?
                                        denjo
                                        ich will ein gerät hinzufügen, gehe also auf die Cloud Instanz dann auf smart geräte, dann auf + und füge das objekt hinzu wie ich es sonst auch immer gemacht habe aber dann passiert nix wenn ich es ausgewählt habe. das fenster schließt sich nur und es kommt kein neues wo ich es benennen kann.
                                        • J Offline
                                          Jan1
                                          Heißt also Du willst ein DP hinzufügen und das klappt nur wenn der beschreibbar ist (auch wenn das nicht nötig sein sollte). Also einfach unter Objekte den DP suchen und den Haken bei "Schreinen erlauben" setzten", dann wieder in den Cloud Adapter und das ganze wiederholen ;)
