  4. Node-red Adapter macht Probleme
13 Beiträge 5 Kommentatoren 1.5k Aufrufe 1 Beobachtet
    Mitch
    ich habe folgende Versionen von Node.js und NPM im Einsatz
    Node.js: v8.14.0
    NPM: 6.5.0
    Leider passiert es immer wieder, das der node-red adapter aussteigt. Aktuell bekomme ich ihn nicht mehr in Betrieb:
    node-red.0	2018-12-16 07:59:05.583	info	node-red exited with 1
    node-red.0	2018-12-16 07:59:05.561	error	16 Dec 07:59:05 - [error] Error: port in use
    node-red.0	2018-12-16 07:59:05.560	error	16 Dec 07:59:05 - [error] Unable to listen on http://127.0.0.1:1880/
    node-red.0	2018-12-16 07:59:05.359	warn	16 Dec 07:59:05 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0	2018-12-16 07:59:03.051	warn	16 Dec 07:59:03 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
    node-red.0	2018-12-16 07:59:03.048	warn	16 Dec 07:59:03 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0	2018-12-16 07:58:59.967	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2018-12-16 07:58:54.966	info	node-red exited with 1
    node-red.0	2018-12-16 07:58:54.943	error	16 Dec 07:58:54 - [error] Error: port in use
    node-red.0	2018-12-16 07:58:54.942	error	16 Dec 07:58:54 - [error] Unable to listen on http://127.0.0.1:1880/
    node-red.0	2018-12-16 07:58:54.737	warn	16 Dec 07:58:54 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0	2018-12-16 07:58:52.271	warn	16 Dec 07:58:52 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
    node-red.0	2018-12-16 07:58:52.268	warn	16 Dec 07:58:52 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    Verlegen auf Port 1885 hat geklappt. Allerdings immer noch folgender Fehler:
    node-red.0	2018-12-16 08:19:29.351	error	at Fulfilled.when (/opt/iobroker/node_modules/when/lib/makePromise.js:592:4)
    node-red.0	2018-12-16 08:19:29.351	error	at runContinuation1 (/opt/iobroker/node_modules/when/lib/makePromise.js:804:4)
    node-red.0	2018-12-16 08:19:29.351	error	at tryCatchReject (/opt/iobroker/node_modules/when/lib/makePromise.js:845:30)
    node-red.0	2018-12-16 08:19:29.351	error	at start (/opt/iobroker/node_modules/node-red/red/runtime/nodes/flows/index.js:328:29)
    node-red.0	2018-12-16 08:19:29.351	error	at Flow.start (/opt/iobroker/node_modules/node-red/red/runtime/nodes/flows/Flow.js:89:35)
    node-red.0	2018-12-16 08:19:29.351	error	at createNode (/opt/iobroker/node_modules/node-red/red/runtime/nodes/flows/Flow.js:305:18)
    node-red.0	2018-12-16 08:19:29.351	error	at new AlexaLocalNode (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-alexa-local/index.js:56:20)
    node-red.0	2018-12-16 08:19:29.351	error	at Server.listen (net.js:1485:7)
    node-red.0	2018-12-16 08:19:29.351	error	at listenInCluster (net.js:1401:12)
    node-red.0	2018-12-16 08:19:29.351	error	at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    node-red.0	2018-12-16 08:19:29.351	error	16 Dec 08:19:29 - [error] [alexa-local:f22ac417.8ed948] Error: listen EADDRINUSE :::41413
    node-red.0	2018-12-16 08:19:29.206	warn	16 Dec 08:19:29 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
    node-red.0	2018-12-16 08:19:27.035	warn	16 Dec 08:19:27 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
    node-red.0	2018-12-16 08:19:27.029	warn	16 Dec 08:19:27 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
    node-red.0	2018-12-16 08:19:24.066	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2018-12-16 08:19:23.355	info	starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.14.0
    Hat jemand eine Idee, wie ich das Problem beseitigen kann? Eine Neuinstalation des Adapters hat den Fehler nicht beseitigt:
    $ ./iobroker add node-red  --host iobroker
    NPM version: 6.5.0
    npm install iobroker.node-red --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
    npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
    npm
     WARN deprecated mimelib@0.3.1: This project is unmaintained
    npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
    npm
     WARN deprecated buildmail@2.0.0: This project is unmaintained
    host.iobroker install adapter node-red
    got /opt/iobroker/node_modules/iobroker.node-red/admin
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    host.iobroker object system.adapter.node-red created
    host.iobroker create instance node-red
    host.iobroker object node-red.0 created
    host.iobroker object system.adapter.node-red.0.outputCount created
    host.iobroker object system.adapter.node-red.0.inputCount created
    host.iobroker object system.adapter.node-red.0.uptime created
    host.iobroker object system.adapter.node-red.0.memRss created
    host.iobroker object system.adapter.node-red.0.memHeapTotal created
    host.iobroker object system.adapter.node-red.0.memHeapUsed created
    host.iobroker object system.adapter.node-red.0.connected created
    host.iobroker object system.adapter.node-red.0.alive created
    host.iobroker object system.adapter.node-red.0 created
    process exited with code 0
    • apollon77A Offline
      Schau dir an welche Prozesse welche Ports belegen. Der 41413 ist auch schon belegt.
      Gesendet vom Handy …
        Mitch
        schrieb am zuletzt editiert von Jey Cee
        erstmal hätte dieser Thread auch schon weitergeholfen, wenn ich vorher danach gesucht hätte:
        viewtopic
        Ich bin dem Verhalten schon etwas auf der Spur. Wenn ich den ioBroker Host aus dem Menü neu starte über Hosts in ioBroker habe ich das verhalten.
        Wenn ich den kompletten Buanet Docker starte, dann verschwindet das Problem. Dann ist es vermutlich der nod-red nicht sauber über Hosts beendet worden.
        Was läuft normalerweise auf dem Port: 41413?
        • Master67M Offline
          Master67M Offline
          Master67
          Sorry.... aber der Link obendrüber geht nicht mehr, ich habe wohl einen "Identischen" Fehler im ioBroker Node-Red Adapter.
          node-red.0	2019-03-07 17:31:34.033	warn	7 Mar 17:31:34 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
          node-red.0	2019-03-07 17:31:34.033	warn	7 Mar 17:31:34 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
          Folge, die Seite bleibt Leer / Weiß die Scripte laufen aber, nur ich komme nicht mehr ran, ggf. Half ja der Link oben weiter :-)
          Gruß Master67
          Master67M SegwayS 2 Antworten Letzte Antwort
          • Master67M Master67
            Master67M Offline
            Master67M Offline
            Master67
            schrieb am zuletzt editiert von Master67
            @Master67 Ähmm....... schieb nach oben !
            Mir ist klar das mal immer ein Thema Untergeht, deshalb schiebe ich das mal nach mehr als 24 Std. nach oben!
            Mein Problem besteht immer noch und ich müsste ein paar Anpassungen dann den Scripts vornehmen :-)
            Edit: per direkten Aufruf in der Adresszeile mit Port öffnet sich Node Red, aber so war das sicher nicht geplant.. oder ? ;-)
            Gruß Master67
              @Master67 sagte in Node-red Adapter macht Probleme:
              Nach einer Woche wäre so etwas angebracht.
              Einige Helfende müssen in der Woche arbeiten.
              Am Wochenende -nach Familie- besteht da eine größere Chance.
              • Master67M Offline
                Master67M Offline
                Master67
                ... da hast du mich falsch verstanden... siehe "Mir ist klar das mal immer ein Thema Untergeht,,,", ich meinte das in Bezug zum Forum... ich finde auch oft Themen nicht mehr wieder !
                Und ja ich kenne das habe selbst über ein Jahrzehnt Foren geführt :-)
                Aber ist auch völlig Wurst, jetzt kommen ich ja an die Scripte ran, mache mir halt dafür nen Link ;-)
                Gruß Master67
                  SegwayS Offline
                  SegwayS Offline
                  Segway
                  Wieso geht der nicht ? Der funktioniert ganz normal --> einfach draufklicken ☺
                  Gruß Dirk
                  • Master67M Offline
                    Master67M Offline
                    Master67
                    Puh..... Leute ich weiß schon wie man die Maus benutzt... @Segway schön das der bei dir geht, bei mir nicht !Link.jpg
                    Gruß Master67
                    SegwayS 1 Antwort Letzte Antwort
                      SegwayS Offline
                      SegwayS Offline
                      Segway
                      Dann öffne es in einem neuen Tab per Rechtsklick. Dann geht es bestimmt
                      Gruß Dirk
                      • Master67M Offline
                        Master67M Offline
                        Master67
                        Japp das geht :-)
                        Ist aber ein bisschen "Gewöhnungsbedürftig" Weiterleitungen innerhalb des Forums per Rechtsklick auszuführen!
                        Ich habe mir das mal angeschaut, hat nichts mit meinem Problem zutun, aber wie oben geschrieben per direkt Aufruf im Browser kam ich an die Scripte ran und konnte diese ändern.
                        Gruß Master67
                          Japp das geht :-)
                          SegwayS Offline
                          SegwayS Offline
                          Segway
                          @Master67
                          Ich meine in den "alten" Links ist irgendwas was falsch drin (beim Umzug oder per Klick - keine Ahnung)... was irgendwie nicht auftritt wenn man es im extra Tab öffnet .... weiss ich aber nicht genau.
                          Gruß Dirk
                          • Master67M Offline
                            Master67M Offline
                            Master67
                            Ich habe das Problem gefunden, aber noch keine dauerhafte Lösung gefunden.
                            Google Chrome stuft das Script als nicht Sicher ein und Blockiert die Ausführung, per Klick auf das Schild in der Adresszeile lässt sich das Script dann starten, aber nur bis zum nächsten Aufruf.
                            Gruß Master67
