  4. Homematic Thermostat Auto/Manu Mode Widged
    6.0k
43 Beiträge 16 Kommentatoren 15.9k Aufrufe 4 Beobachtet
  • kmxakK Offline
    kmxakK Offline
    kmxak
    das Problem könnte sein das du die css klassen die der Farbverlauf nutzt nicht angelegt hast dazu finde ich auch in dem Beitrag keinen Hinweis.
    Das Widget ist hier verlinkt
    ! @AxelF1977:
    ! > Sorry das es länger gedauert hat, ich habe aber ioBroker gerade auf ein Tinker Board umgezogen, das musste ich erstmal fertig machen.
    filename="Heizungsollist.jpg" index="0">~~
    Anbei das Widget, einfach als Widget importieren
    [{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.2.OEQ0854223.4.ACTUAL_TEMPERATURE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"5","max":"30","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"135px","top":"64px","width":"200px","height":"25px","z-index":3,"background":"linear-gradient(to right, #005aff 0px, #4CAF50 120px, #F44336 150px )"},"widgetSet":"basic"}]
    Aber das alleine bringt leider ohne die CSS Klasse nix.
    Er scheint das MD Style von Uhula zu nutzen.
    Anbei mal ein Auszug der CSS Klassen mit der Hoffnung das es reicht um bei dir den Effekt zu aktivieren.
    .mdui-h-bargraph, .mdui-v-bargraph {
    background-position : -1000px !important ;
    background-repeat : no-repeat !important ;
    box-shadow : 0 0 0 1000px rgba(255, 255, 255, 0.1) inset;
    border : none !important ;
    .mdui-h-bargraph > *, .mdui-v-bargraph > * {
    background-image : inherit !important ;
    .mdui-h-bargraph:after, .mdui-v-bargraph:after {
    content : "";
    position : absolute;
    left : 0;
    top : 0;
    width : 100%;
    height : 100%;
    opacity : 0.100000001490116119384765625;
    .mdui-h-bargraph.mdui-segment-10 {
    clip-path : polygon(0% 100%,0% 0%,9% 0%,9% 100%,10% 100%,10% 0%,19% 0%,19% 100%,20% 100%,20% 0%,29% 0%,29% 100%,30% 100%,30% 0%,39% 0%,39% 100%,40% 100%,40% 0%,49% 0%,49% 100%,50% 100%,50% 0%,59% 0%,59% 100%,60% 100%,60% 0%,69% 0%,69% 100%,70% 100%,70% 0%,79% 0%,79% 100%,80% 100%,80% 0%,89% 0%,89% 100%,90% 100%,90% 0%,100% 0%,100% 100%);
    .mdui-h-bargraph.mdui-triangle {
    clip-path : polygon(0% 40%,100% 0%,100% 100%,0% 60%);
    .mdui-h-bargraph.mdui-ramp {
    clip-path : polygon(0% 80%,100% 0%,100% 100%,0% 100%);
    .mdui-h-bargraph.mdui-segment-10.mdui-ramp {
    clip-path : polygon(9% 100%,9% 71%,0% 80%,0% 100%,19% 100%,19% 63%,10% 72%,10% 100%,29% 100%,29% 55%,20% 64%,20% 100%,39% 100%,39% 47%,30% 56%,30% 100%,49% 100%,49% 39%,40% 48%,40% 100%,59% 100%,59% 31%,50% 40%,50% 100%,69% 100%,69% 23%,60% 32%,60% 100%,79% 100%,79% 15%,70% 24%,70% 100%,89% 100%,89% 7%,80% 16%,80% 100%,100% 100%,100% 0%,90% 8%,90% 100%);
    .mdui-h-bargraph.mdui-segment-10.mdui-triangle {
    clip-path : polygon(9% 37%,9% 63%,0% 60%,0% 40%,19% 33%,19% 67%,10% 64%,10% 36%,29% 29%,29% 71%,20% 68%,20% 32%,39% 25%,39% 75%,30% 72%,30% 28%,49% 21%,49% 79%,40% 76%,40% 24%,59% 17%,59% 83%,50% 80%,50% 20%,69% 13%,69% 87%,60% 84%,60% 16%,79% 9%,79% 91%,70% 88%,70% 12%,89% 5%,89% 95%,80% 92%,80% 8%,100% 0%,100% 100%,90% 96%,90% 4%);
    Diesen Code bitte unter CSS im Vis Projekt einfügen
    Gruß Alex
    • Z Offline
      Z Offline
      Zeebo
      @AxelF1977:
      Die oberen Button sind nun durchsichtig und die Schrift genau über die der unteren Button gelegt. `
      Hallo AxelF1977,
      wie hast du denn die oberen Buttons durchsichtig bekommen? Unter background -color "transparent" einzutragen bringt leider nicht, der Button interessiert sich nicht für die Werte, welche ich hier eintrage :(
      ioBroker auf Ubuntu 16.04.5 LTS (VM auf ESXi 6.5 Hypervisor) • CCU2 • HomeMatic • Alexa • Harmony Hub
      • L Offline
        ltsalvatore
        hey leute, ich hab auch mal ne frage bez. vis und homematic geräte…
        gibt es die möglichkeit, sich den status von bspw. wandthermostaten anzeigen zu lassen?
        ich würde gern in meinem vis darstellen lassen, ob ein thermostat an oder aus ist...find dafür aber keinen datenpunkt.
        edit: bin leider immer noch nicht fündig geworden. keiner ne idee..
        weiterhin frag ich mich...
        müsste der wert unreach nicht auf true stehen, sobald man die batterien von dem gerät raus nimmt / das gerät nicht mehr erreichbar ist?
        bei mir ist das nämlich nicht der fall, und den wert, wenn dieser dafür vorgesehen ist, hätte ich gerne für mein anliegen s.o. gerne genutzt.
        • L Offline
          ltsalvatore
          @AxelF1977:
          Eine sehr kreative Lösung @Camuri :mrgreen:
          Und sie funtioniert! Vielen Dank. Ich habe es an mein Layout angepasst. Die oberen Button sind nun durchsichtig und die Schrift genau über die der unteren Button gelegt. `
          Hi AxelF1977,
          erstmal Kompliment zu deinem Widget.
          Gäbe es die Möglichkeit, das Gesamte Widget zu teilen? ;)
          • AxelF1977A Offline
            AxelF1977A Offline
            AxelF1977
            @ltsalvatore:
            Hi AxelF1977,
            Gäbe es die Möglichkeit, das Gesamte Widget zu teilen? ;) `
            Hallo ltsalvatore,
            danke. Wenn ich nachher daran denke, dann stelle ich es hier rein.
            ASROCK Deskmini Intel I3 8100 16GB mit Proxmox VM ioBroker VM DIYHue| CCU piVCCU + FHEM auf Raspberry | Maria DB mit Grafana und Prometheus auf Tinker Board
            • L Offline
              ltsalvatore
              @AxelF1977:
              @ltsalvatore:
              Hi AxelF1977,
              Hallo ltsalvatore,
              danke. Wenn ich nachher daran denke, dann stelle ich es hier rein. `
              super, danke.
              das wäre sehr lieb von dir
                AxelF1977A Offline
                AxelF1977
                @ltsalvatore:
                super, danke.
                das wäre sehr lieb von dir `
                Kein Problem.
                Dazu sei gesagt, das Widget ist für für Homematic Thermostate (HM-CC-RT-DN) und die entsprechenden Wandthermostate (HM-TC-IT-WM-W-EU) ausgelegt. Ich habe im Widget die Bezeichnung der Datenpunkte drin gelassen. Die richtigen Thermostate musste Du natürlich für Dich selber auswählen.
                Mehr als die Objekt_id mit dem richtigen Datenpunkt musst Du nicht auswählen, das Widget läuft dann.
                Noch ein Hinweis, die unteren Button "AUTO | MANU | BOOST" bestehen aus 2 Ebenen. Je nach Gerät, kann es zu Verschiebungen kommen. Wenn Du das Widget einfügst, sieht die Schrift schief aus, je nach Gerät, ist es dann aber perfekt. Ansonsten verschiebe die Schriften in 1 px Schritten bis es passt.
                Ansonsten, ich bin ja hier
                [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"Badezimmer","class":"mdui-title","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"8px","top":"8px","width":"280px","height":"23px","z-index":1},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Ventil:"},"style":{"left":"5px","top":"121px","width":"224px","height":"19px","font-weight":"normal","z-index":1},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"BOOST_STATE","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":" min","html_prepend":"Boost: "},"style":{"left":"220px","top":"10px","width":"115px","height":"19px","z-index":1,"text-align":"right"},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.0.KEQ0509273.4.BATTERY_STATE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"2","max":"3","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"8px","top":"211px","width":"320px","height":"5px","z-index":2,"background":"linear-gradient(to right, #005aff 0px, #4CAF50 120px, #F44336 350px )"},"widgetSet":"basic"},{"tpl":"tplJquiSlider","data":{"oid":"hm-rpc.2.OEQ0578951.2.SET_TEMPERATURE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-slider mdui-transparent-acc","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-working":"","min":"4.5","max":"30.5","step":"1","oid-2":"","oid-2-working":""},"style":{"left":"4px","top":"199px","width":"330px","height":"28px","z-index":5},"widgetSet":"jqui"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Batterie Wand:"},"style":{"left":"5px","top":"144px","width":"213px","height":"19px","font-weight":"normal","z-index":1},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"BATTERY_STATE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"2","max":"3","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"246px","top":"144px","width":"80px","height":"15px","z-index":3,"background":"linear-gradient(to right, #F44336 0px, #FFEB3B 40px, #4CAF50 80px )"},"widgetSet":"basic"},{"tpl":"tplJustgageValueColored","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_tdp":false,"factor":"1","balance1":"25","balance2":"60","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"ACTUAL_HUMIDITY","min_oid":"1","max_oid":"100","unit":"%","mid_oid":"50","color1":"#0077ff","color2":"#34cc00","color3":"#d10000"},"style":{"left":"246px","top":"98px","font-weight":"bold","width":"","height":"19px","z-index":1},"widgetSet":"justgage"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Luftfeuchtigkeit:"},"style":{"left":"5px","top":"98px","width":"224px","height":"23px","font-weight":"normal","z-index":1},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Batterie Heizung:"},"style":{"left":"5px","top":"168px","width":"209px","height":"23px","font-weight":"normal","z-index":1},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.2.OEQ0854223.4.BATTERY_STATE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"2","max":"3","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"246px","top":"168px","width":"80px","height":"15px","z-index":3,"background":"linear-gradient(to right, #F44336 0px, #FFEB3B 40px, #4CAF50 80px )"},"widgetSet":"basic"},{"tpl":"tplJustgageValueColored","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_tdp":false,"factor":"1","balance1":"25","balance2":"60","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"VALVE_STATE","min_oid":"1","max_oid":"100","unit":"%","mid_oid":"50","color1":"#34cc00","color2":"#ffe12e","color3":"#d10000"},"style":{"left":"246px","top":"119px","font-weight":"bold","width":"","height":"19px","z-index":1},"widgetSet":"justgage"},{"tpl":"tplValueStringRaw","data":{"oid":"SET_TEMPERATURE","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":"°C"},"style":{"left":"139px","top":"40px","z-index":4,"color":"#ffffff","font-weight":"bold","width":"69px","height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueStringRaw","data":{"oid":"ACTUAL_TEMPERATURE","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_append":"°C"},"style":{"left":"140px","top":"68px","z-index":6,"color":"#FFFFFF","font-weight":"bold","width":"73px","height":"20px"},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"ACTUAL_TEMPERATURE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"5","max":"30","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"135px","top":"64px","width":"200px","height":"25px","z-index":3,"background":"linear-gradient(to right, #005aff 0px, #4CAF50 120px, #F44336 150px )"},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"SET_TEMPERATURE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"5","max":"30","orientation":"horizontal","color":"#2196F3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-h-bargraph","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"135px","top":"35px","width":"200px","height":"25px","z-index":3,"background":"linear-gradient(to right, #005aff 0px, #4CAF50 120px, #F44336 150px )","border-width":"100%","border-style":"solid","border-color":"#FFFFFF"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Soll:"},"style":{"left":"5px","top":"41px","width":"55px","height":"18px","font-weight":"normal","z-index":2},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Ist:"},"style":{"left":"5px","top":"67px","width":"62px","height":"19px","font-weight":"normal","z-index":2},"widgetSet":"basic"},{"tpl":"tplValueListHtml8","data":{"oid":"CONTROL_MODE","count":"3","value0":"AUTO","value1":"MANU","style0":"color: #34cc00;","style1":"color: orange;","test_list":"0","name":"Geräte Modus","value2":"PARTY","style2":"color: lightblue;","value3":"BOOST","style3":"color: red;","html_prepend":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_css_shadow_padding":false,"g_css_background":false,"g_css_border":false,"g_gestures":false},"style":{"left":"137px","top":"11px","z-index":"30","color":"#ffffff","text-align":"left","width":"70px","height":"16px","line-height":"","font-size":"small"},"widgetSet":"basic"},{"tpl":"tplJquiRadioList","data":{"oid":"CONTROL_MODE","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"0;1;3","texts":"AUTO;MANU;BOOST","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"name":"Wohnzimmer HK2","lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-is-moment":false,"lc-zindex":0,"class":""},"style":{"left":"8px","top":"241px","height":"2px","width":"2px","font-size":"medium","z-index":"4","font-weight":"normal","background-color":"#00bd08","background":"","background-repeat":"","color":""},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"BOOST_STATE","visibility-cond":"==","visibility-val":1,"buttontext":"BOOST","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true","visibility-groups-action":"hide","name":"Wohnzimmer HK2","lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"no_style":false,"lc-is-moment":false,"lc-zindex":0,"class":"mdui-flatbutton mdui-none-bg mdui-white"},"style":{"left":"154px","top":"240px","font-size":"small","width":"90px","text-align":"right","z-index":"10","height":"34px","padding-left":""},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"MANU_MODE","visibility-cond":"==","visibility-val":1,"buttontext":"MANU","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"20","visibility-groups-action":"hide","name":"Wohnzimmer HK2","no_style":false,"lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-is-moment":false,"lc-zindex":0,"class":"mdui-flatbutton mdui-none-bg mdui-white"},"style":{"left":"80px","top":"241px","font-size":"small","width":"78px","text-align":"center","z-index":"10","height":"34px"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"AUTO_MODE","visibility-cond":"==","visibility-val":1,"buttontext":"AUTO","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true","visibility-groups-action":"hide","no_style":false,"name":"Wohnzimmer HK2","gestures-offsetX":"5","lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-is-moment":false,"lc-zindex":0,"class":"mdui-flatbutton mdui-none-bg mdui-white"},"style":{"left":"9px","top":"241px","font-size":"","width":"72px","text-align":"center","z-index":"7","height":"34px","font-family":"","color":"","font-weight":"","letter-spacing":"","font-variant":""},"widgetSet":"jqui"}]
                • L Offline
                  ltsalvatore
                  @AxelF1977:
                  @ltsalvatore:
                  super, danke.
                  Kein Problem.
                  cool, danke.. ich werde es die tage testen und mich melden, sollte ich noch fragen haben.
                  schöne grüße
                  • L Offline
                    ltsalvatore
                    ok.. ich habe dann doch ein paar dinge, die ich nicht so ganz verstehe.
                    bei dir sieht das ganze so aus:
                    wenn ich es bei mir importiere, dann sieht es so aus:
                    da frage ich mich:
                    der Schieberegler auf dem bild, ist dieser für die temperatur reglung zuständig?
                    denn beim importieren der widgets versteckt sich der bunte streifen, welchen ich eigentlich gerne zum regulieren der temperatur nur nutzen wollen würde, hinter einem anderen widget (den schwarzen schieberegler).
                    dann verstehe ich auch nicht, wieso sich hinter den auto/manu/boost widget nochmal das gleiche widget befindet, das auch noch total versetzt.
                      AxelF1977A Offline
                      AxelF1977
                      @ltsalvatore:
                      ok.. ich habe dann doch ein paar dinge, die ich nicht so ganz verstehe. `
                      Das Widget ist von mir angepasst. Die Optik hängt von Deinen Einstellungen ab. Ich nutze den Material-Design-Style als Grundlage. Nur wenn dieser Style genutzt wird, und für den Schieberegler die CCS Klasse````
                      Der farbige Balken ist eine Grafik
                      ~~@ltsalvatore:~~
                      > dann verstehe ich auch nicht, wieso sich hinter den auto/manu/boost widget nochmal das gleiche widget befindet, das auch noch total versetzt. `
                      Lies mal das Thema von Anfang an, dann erklärt es sich warum.
                      Auch hier muss der Material-Design-Style als Grundlage dienen, hier ist die Klasse der überlagernden Button die CSS Klasse````
                      • AxelF1977A AxelF1977
                        TG70T Offline
                        TG70T Offline
                        TG70
                        Forum Testing
                        @AxelF1977
                        Könntest du evtl. dein kpl. Widget zur Verfügung stellen ??? Wäre echt super
                        ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
                        AxelF1977A 1 Antwort Letzte Antwort
                        • TG70T TG70
                          @AxelF1977
                          AxelF1977A Offline
                          AxelF1977A Offline
                          AxelF1977
                          @TG70 sagte in Homematic Thermostat Auto/Manu Mode Widged:
                          @AxelF1977
                          im Beitrag vom 23.8.18 ist das Widget drinn, denke ich, ist ja schon etwas her. Hattest Du das schon probiert?
                            kg36304
                            schrieb am zuletzt editiert von kg36304
                            ist zwar schon etwas älter aber ich bekomme es nicht hin.
                            Ich habe einige HM Heizkörperthermostate und da klappt alles.
                            Leider bei dem einen HM IP Thermostat bekomme ich es nicht hin, dass die Homematic Zentrale den Modus umschaltet.
                            Im Widget schaltet es alles ganz normal aber es wird nicht an die Zentrale gesendet.
                            Versucht wird es über den Datenpunkt Set_Point_Mode.
                            Dieser schaltet von 0 auf 1 und umgekehrt. Aber eben nur im Iobroker und nicht in der Zentrale.
                            Wenn ich in der Zentrale über das Web Interface schalte, zeigt iobroker das auch an.
                            Ist der Set_Point_Mode nur zum lesen?
                            Was muss ich da tun?
                            Danke.
                            • DickenD Offline
                              DickenD Offline
                              Dicken
                              Hey, ich habe auch ein Problem mit meiner Heizung im VIS
                              habe das Wandthermostat (HmIP-WTH-2) und den Regler (HmIP-eTRV-B) in der CCU3 einer Gruppe hinzugefügt.
                              Schalte ich nun am Wandthermostat auf Manuell funktioniert das und wird auch vom Regler übernommen.
                              Der Datenpunkt CONTROL_MODE bleibt allerdings bei beiden Geräten auf 0. Der Datenpunkt SET_POINT_MODE ändert sich allerdings auf 1.
                              Wenn ich jetzt über die VIS den CONTROL_MODE des Wandthermostats ansteuern möchte, schaltet dieser auch auf MANU, gibt das allerdings nicht weiter an den Regler, der bleibt fröhlich im AUTO.
                              Habe dann auch mal versucht den SET_POINT_MODE Datenpunkt anzusteuern, der ist aber anscheind tatsächlich nur zum lesen?
                              Ich hoffe ihr könnt mir weiterhelfen
                              LG
                              Dicken
