  4. Material UI update
Material UI update
13 Beiträge 8 Kommentatoren 2.3k Aufrufe
  • sigi234S Online
    sigi234S Online
    update ausgeführt, bleibt aber auf der alten Version…..
    Verständnis - Frage, die Daten kommen ja von der CCU2?
      Kann ich (fast) bestätigen.
      Habe gerade von 0.9.3 auf 0.9.8 upgedatet und habe die 0.9.7
      Wahrscheinlich wurde nur die Versionsnummer nicht angepasst.
        blackplanet333
        Bei der Installation bleibe ich immer beim Punkt 9 hängen… jemand ne Lösung?
        root@raspberrypi:~# iobroker install material
        NPM version: 3.10.10
        npm install iobroker.material --production --save --prefix "/opt/iobroker" (System call)
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN material-ui@0.20.1 requires a peer of react@^15.4.0 || ^16.0.0 but none was installed.
        npm WARN material-ui@0.20.1 requires a peer of react-dom@^15.4.0 || ^16.0.0 but none was installed.
        npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none was installed.
        npm WARN react-event-listener@0.5.9 requires a peer of react@^15.3.0 || ^16.0.0 but none was installed.
        npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none was installed.
        npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.
        npm WARN react-transition-group@1.2.1 requires a peer of react@^15.0.0 || ^16.0.0 but none was installed.
        npm WARN react-transition-group@1.2.1 requires a peer of react-dom@^15.0.0 || ^16.0.0 but none was installed.
        npm WARN recompose@0.26.0 requires a peer of react@^0.14.0 || ^15.0.0 || ^16.0.0 but none was installed.
        host.Master object system.adapter.material created
        got /opt/iobroker/node_modules/iobroker.material/admin
        upload [1] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.svg material.svg image/svg+xml
        upload [0] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.png material.png image/png
        got /opt/iobroker/node_modules/iobroker.material/www
        upload [30] material /opt/iobroker/node_modules/iobroker.material/www/vendor.js vendor.js application/javascript
        upload [20] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-MediumItalic.ttf vendor/fonts/Roboto-MediumItalic.ttf application/x-font-ttf
        upload [19] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Medium.ttf vendor/fonts/Roboto-Medium.ttf application/x-font-ttf
        upload [18] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-LightItalic.ttf vendor/fonts/Roboto-LightItalic.ttf application/x-font-ttf
        upload [17] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Light.ttf vendor/fonts/Roboto-Light.ttf application/x-font-ttf
        upload [16] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Italic.ttf vendor/fonts/Roboto-Italic.ttf application/x-font-ttf
        upload [15] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-BoldItalic.ttf vendor/fonts/Roboto-BoldItalic.ttf application/x-font-ttf
        upload [14] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Bold.ttf vendor/fonts/Roboto-Bold.ttf application/x-font-ttf
        upload [13] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-BlackItalic.ttf vendor/fonts/Roboto-BlackItalic.ttf application/x-font-ttf
        upload [12] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Black.ttf vendor/fonts/Roboto-Black.ttf application/x-font-ttf
        upload [11] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/LICENSE.txt vendor/fonts/LICENSE.txt text/plain
        upload [10] material /opt/iobroker/node_modules/iobroker.material/www/static/media/apartment.28bae16c.jpg static/media/apartment.28bae16c.jpg image/jpeg
        upload [9] material /opt/iobroker/node_modules/iobroker.material/www/static/js/main.7d62d711.js.map static/js/main.7d62d711.js.map application/json
        • sigi234S Online
          sigi234S Online
          @Homoran:
          Rainer `
          Hallo, geht noch immer nicht.
          Vielleicht kannst du was mit dieser Meldung anfangen:
          iobroker	2018-08-05 10:37:54.896	info	npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
          iobroker	2018-08-05 10:37:54.896	info	WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.
          iobroker	2018-08-05 10:37:54.895	info	npm
          iobroker	2018-08-05 10:37:20.004	info	npm install iobroker.material@0.9.8 --production --save --prefix "C:/ioBroker" (System call)
          iobroker	2018-08-05 10:37:19.287	info	NPM version: 5.7.1
          iobroker	2018-08-05 10:37:18.461	info	Update material from @0.9.7 to @0.9.8
          • sigi234S Online
            sigi234S Online
            Version 0.9.9 ist da, die geht jetzt!
            • W Offline
              W Offline
              w2kscout
              nach der Installation bekomme ich die Meldung: File 0.9.10/index.html not found: Not exists!
              Was habe ich falsch gemacht?
              • LausiDL Offline
                LausiDL Offline
                LausiD
                nach Updae auf 0.9.10 kommt Ladebalken mit Verbinden, Objekte lesen und lese App-konfiguration.
                Danach leider nur leere,weisse Seite. Was mache ich falsch?
                Danke und Gruß
                LausiD
                Doku zum FHEM Adapter
                Aktuelles zum FHEM Adapter
                Test FHEM Adapter
                • sigi234S Online
                  sigi234S Online
                  ioBroker neu starten….
                    Stoni
                    Huhu,
                    wollte von 0.8.9 auf 0.9.10 updaten. Dazu musste ich erstmal den Web Adapter auf den aktuellsten Stand bringen.
                    Als ich den Material Adapter dann updaten wollte, hat sich der Raspi bzw. ioB aufgehangen.
                    SD gezogen, Raspi aus, SD rein, Raspi an. Läuft wieder.
                    Unter den Instanzen wird jetzt die Version 0.9.10 angezeigt, aaaaaaber im Adapter selber immer noch 0.8.9. Auch die Änderungen, bspw. Cams per URL einzubinden oder neue Widgets zu erstellen , sind nicht ersichtlich.
                    Was soll ich machen?
                    • Q Offline
                      Q Offline
                      Qlink
                      In der WebUI von Material auf das Zahnrad klicken und dann auf den roten Button mit 0.9.10 klicken. Dann wird die Version auch genutzt.
                        Stoni
                        @Qlink:
                        In der WebUI von Material auf das Zahnrad klicken und dann auf den roten Button mit 0.9.10 klicken. Dann wird die Version auch genutzt. ` Wo soll da ein roter Button sein?
                        EDIT: nach dem Update auf 0.9.11 werden die Änderungen im WebUI des Adapters übernommen.
