  3. Cloud Dienste
  4. Neuer Adapter: iobroker.alexa2
581 Beiträge 76 Kommentatoren 218.4k Aufrufe 3 Beobachtet
  • O Offline
    O Offline
    ooooli
    #437
    Hier das Script nochmal als Export. Sollte nun iimportierbar sein…
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="RUoTzvo?H17}CcoV|M]y" x="-262" y="-137"><field name="NAME">AnsageErfolgt</field>
        <next><block type="on" id="|[-@.==-%lkD3p#NA/|D"><field name="OID">hue.0.Philips_hue.Flur.on</field>
            <statement name="STATEMENT"><block type="controls_if" id="@218=IkE/qsKmRu{pA[)"><value name="IF0"><block type="logic_operation" id="h;:?sO;C*QR++sFvwlmj"><field name="OP">AND</field>
                    <value name="A"><block type="logic_compare" id="bEb2TgS_Vzfgrm4@YL,K"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="K.gTsCV12F:_5Ncs6-+#"><field name="ATTR">val</field>
                            <field name="OID">hue.0.Philips_hue.Flur.on</field></block></value>
                        <value name="B"><block type="logic_boolean" id="M2k`x?^@ELd;?/_Yx!O?"><field name="BOOL">TRUE</field></block></value></block></value>
                    <value name="B"><block type="logic_compare" id="G{)dWgjJ#+._~Hgk8mSQ"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="7=/x-BQ.v3Xa7@cb#N72"><field name="ATTR">val</field>
                            <field name="OID">javascript.0.AnsageErfolgt</field></block></value>
                        <value name="B"><block type="logic_boolean" id=".k]H{IFel`:;,S)b)d%z"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                <statement name="DO0"><block type="control" id="?WB3cxnc1VW;,;wpT7.m"><mutation delay_input="true"></mutation>
                    <field name="OID">alexa2.0.Echo-Devices.G090LV036445004S.Commands.speak</field>
                    <field name="DELAY_MS">5</field>
                    <value name="VALUE"><block type="text_join" id="(6p7BX#~~2P}xj7Wn1@;"><mutation items="5"></mutation>
                        <value name="ADD0"><block type="text" id="M76-)zYehBG]!LdyeY5q"><field name="TEXT">Hallo! willkommen zu Hause!</field></block></value>
                        <value name="ADD1"><block type="text" id="E|w.AEkyy_)gieFW[B1@"><field name="TEXT">Es sind</field></block></value>
                        <value name="ADD2"><block type="get_value" id="+23FeR%/`)Vy3Ni[(7za"><field name="ATTR">val</field>
                            <field name="OID">netatmo.0.zu-Hause.Wetterstation.Temperature.Temperature</field></block></value>
                        <value name="ADD3"><block type="text" id="7-:u)+Rn,a.REn{7XAl."><field name="TEXT">Grad in der Wohnung und der Zehohzweiwert beträgt</field></block></value>
                        <value name="ADD4"><block type="get_value" id="ss#R)QpEW`@hPOuqB`[%"><field name="ATTR">val</field>
                            <field name="OID">netatmo.0.zu-Hause.Wetterstation.CO2.CO2</field></block></value></block></value>
                    <next><block type="control" id=":+sw;3]O*:2=m;}oY-`%"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="logic_boolean" id="V:ezxxg{L.az[68LgO]E"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></statement>
            <next><block type="on" id="5%2sw2vN~IUt?:~nLn56"><field name="OID">geofency.0.Handy_[priv_].entry</field>
                <statement name="STATEMENT"><block type="controls_if" id="2.o(9=pF;72dQLlZd{Z}"><mutation elseif="1"></mutation>
                    <value name="IF0"><block type="logic_compare" id="n-3QfDqel51,DR:78:lE"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="[@ZAwx3Q~-5cnVrQn2e}"><field name="ATTR">val</field>
                            <field name="OID">geofency.0.Handy_[priv_].entry</field></block></value>
                        <value name="B"><block type="logic_boolean" id="/LqU`_{.-!+4G?=ARrER"><field name="BOOL">FALSE</field></block></value></block></value>
                    <statement name="DO0"><block type="control" id="+Kxc%`:x3XPxhj30^E:e"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="logic_boolean" id="Klxp/+JSwFl*I#}Muk^Q"><field name="BOOL">FALSE</field></block></value></block></statement>
                    <value name="IF1"><block type="logic_compare" id="C!EKDYHnHg)X@@cAeOT{"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="pd4|+~n%5WOdi_QxvPsU"><field name="ATTR">val</field>
                        <value name="B"><block type="logic_boolean" id="ZZkwi~iV+!bc0KV]7A)i"><field name="BOOL">TRUE</field></block></value></block></value>
                    <statement name="DO1"><block type="control" id="EoUSPk1}^Oly6`[a[k^%"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="logic_boolean" id="]PIxRNdgc/#6E`|nuw^B"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></next></block></next></block></xml>
    ioBroker Neuling mit 4 Alexas, Sonoff, Netatmo, Lametric Time, Hue, Harmony Hub und einigen anderen Spielereien die es zu verknüpfen gilt
    • H Offline
      hhilde
      #438
      @apollon77:
      Alte Version ist keine sinnvolle Option.
      Es hat sich glaube zwischen 0.2 und 0.3 der Name von history.#trigger nach History.#trigger geändert.
      Weiterhin wird jetzt strenger geprüft was in die datenpunkte reingeschrieben wird. Der Datentype muss stimmen. Da gibts debug im log.
      Bitte alexa2 Instanz loglevel auf debug. Dann bitte aus node red heraus ändern und log senden an der Änderung ein bissl.
      Bitte log nicht aus admin kopieren sondern von der Platte.
      Gesendet vom Handy … `
      Danke für die schnelle Antwort, und die Hinweise.
      Name war klar.
      Ich hab mir die Log-Datei mal angeschaut, und es lag tatsächlich an einem falschen Datentyp.
      Jetzt funktioniert es wieder.
      Danke!!!
      • L Offline
        ltsalvatore
        #439
        @ooooli:
        Hier das Script nochmal als Export. Sollte nun iimportierbar sein… `
        super, danke fürs hochladen.
        ich überlege gerade, ob ich anstatt mit dem geofencing das ganze mit dem tr-064 adapter umsetze.
        dort gibt es zu jedem device die beiden werte lastactive und lastinactive.
        so spare ich mir die installation eines weiteren adapters.
        müsste jetzt nur noch überlegen, wie die abfrage auszusehen hat. :roll: :?
        edit:
        ok,.. vielleicht habe ich mich doch zu früh gefreut?
        dachte die beiden werte würden anzeigen, wann das geräte das letzte mal erreichbar (lastactive) und das letzte mal bevor das gerät nicht mehr erreichbar war (lastinactive) anzeigen wüürde….
        • L Offline
          Lucky
          #440
          Sehr schöne Arbeit, vielen dank dafür !
          ich würde mir wünschen, (falls möglich) einen Datenpunkt der mit true oder false den jeweiligen Aktivzustand eines Device anzeigt.
          Also wenn ich "Alexa" sage und der Statusring am Gerät leuchtet, das der Datenpunkt auf true wechselt und wider zurück
          Ein nutzen wäre z.b. das kurzfristige Stumm schalten z.b. des Fernsehers oder Verstärkers zum besseren Verständnis des gesprochenen
          • apollon77A Offline
            #441
            GitHub issue bitte … vielleicht geht sowas in der Art ... verspreche aber nichts.
            Und ich weiß auch nicht ob man das unbedingt will. So oft wie alexa bei uns beim Fernsehen oder auch mal nebenher an geht ... hm ...
            Gesendet vom Handy ...
            • L Offline
              Lucky
              #442
              @apollon77:
              Gesendet vom Handy ... `
              ok mach ich !
              wofür man es nutzt ist ja jedem selbst überlassen, man könnte damit auch z.b. das optische Feedback des Echo auf eine Hue Leute auslagern usw..
              • L Offline
                ltsalvatore
                #443
                @ltsalvatore:
                @ooooli:
                edit:
                dachte die beiden werte würden anzeigen, wann das geräte das letzte mal erreichbar (lastactive) und das letzte mal bevor das gerät nicht mehr erreichbar war (lastinactive) anzeigen wüürde…. `
                so.. es scheint doch zu funktionieren bzw. aktualisieren sich die werte der objekte in dem tr-064 adapters wie gewünscht.
                meine idee nun, wenn das gerät 6 stunden inaktiv war, dann erst alexa befehlen, dass sie guten abend sagen soll.
                um das jetzt umzusetzen, würde es mich freuen, etwas hilfe von den blockly experten zu bekommen, auch wenn es eine einzige und evtl. recht simple abfrage ist.
                umsetzen wollte ich das ganze so:
                Wenn wert von "lastInactive-ts" - "lastActive-ts" >= 21600, dann "guten abend"
                danke schon mal
                • C Offline
                  csamaggi
                  #444
                  @Lucky:
                  Ein nutzen wäre z.b. das kurzfristige Stumm schalten z.b. des Fernsehers oder Verstärkers zum besseren Verständnis des gesprochenen ` Hallo lucky, gute Idee wenn du sonos Geräte besitzt geht dies automatisch sobald du alexa ansprichst dann wird der Ton gesenkt. Nur beim TV geht dies leider nicht beim hören von Musik schon. Warum auch immer.
                  Wie gesagt gebe dir recht wäre eine feine Sache.
                  Mfg Maggi
                  Gesendet von meinem SM-G955F mit Tapatalk
                  • L Offline
                    ltsalvatore
                    #445
                    @ltsalvatore:
                    @ltsalvatore:
                    @ooooli:
                    edit:
                    danke schon mal `
                    ich hoffe es funktioniert :-D
                    • G Offline
                      Granten
                      #446
                      wie ist es möglich über Alexa und die Routinen Werte eines Objekts abzurufen?
                      • haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #447
                        @apollon77
                        Ich habe über den Adapter Bluetooth Datenpunkte meiner gespeichterten Geräte mit Alexa.
                        Nun verbinde ich eines, trotzdem bleibt der Datenpunkt connected auf false.
                        Er ändert sich auch nicht automatisch wenn ich den "Button" drücke oder als Wert selber true eingebe.
                        Habe ich da was übersehen?
                          #448
                          @Granten:
                          wie ist es möglich über Alexa und die Routinen Werte eines Objekts abzurufen? `
                          Routinen Gar nicht meines Wissens nach.
                            #449
                            @haselchen:
                            @apollon77
                            Habe ich da was übersehen? `
                            Bluetooth Status wird aktuell noch nur beim Adapter Start aktualisiert. Im GitHub abstimmen bitte. Issue gib’s schon.
                              haselchenH Offline
                              haselchen
                              #450
                              Alles klar, danke für die schnelle Antwort .
                              • sissiwupS Offline
                                sissiwupS Offline
                                sissiwup
                                #451
                                habe leider das Update auf Alexa 2 gemacht.
                                Wie komme ich denn auf den Alexa 1 Adapter zurück?
                                Vlt. stehe ich auch auf dem Schlauch: Habe jetzt Alexa zugemüllt mit technischen Geräten, die nie zu steuern sind Z.B. HM RCV 50 BidCoS RF 21.LEVEL
                                und div. andere.
                                Ich hatte bisher im Alexa nur eine Hand voll Geräte aufgenommen und auch alle mit neuen Namen.
                                Diese sind teilweise übernommen worden (nicht alle korrekt geschrieben aber immerhin).
                                Wie füge ich denn einzelne Geräte zu Alexa 2 hinzu, wie ändere ich den Namen (oder geht das nur über die Objekt-Sicht?)
                                Der Alexa 1 Adapter war erheblich einfacher zu bedienen.
                                Noch eine Frage: Warum sind so ca. 30% der Geräte offline. Muster für mich nicht erkennbar ein paar Schalter, eine Rollo, ein paar Szenen…
                                Hat sich etwas beim cloud-Adapter geändert? Wie ist das Zusammenspiel?
                                MfG
                                Sissi
                                1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                                  #452
                                  Bei den smart devices unterscheiden sich Version 1 und 2 nicht. Die Liste ist die gleiche die auch in der alexa app angezeigt wird. Wenn du da schon „Müll“ drin hast dann wird der auch da angezeigt. Also schau mal in die App. Und wenn musst du da aufräumen.
                                  • dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #453
                                    Hat mal Jemand ein kurzes Blockly Beispiel wie ich den History trigger sinnvoll nutze ?
                                    Ich möchte eine Abfrage an einem Echo starten und dann von genau dem gleichen Echo eine Antwort bekommen.
                                    PS: also Konkret frage ich einen Echo z.B. im Wohnzimmer ob alle Fenster geschlossen sind und bekomme dann aus einem bestehenden Datenpunkt (Fensterscript) die offenen Fenster angesagt. Nur wie steuere ich jetzt Speak, das die Rückmeldung auch vom gleichen Echo kommt, ohne das ich einen angeben muß ? Ich denke ich müsste den History trigger auf wahr triggern, aber wann bzw. an welcher Stelle ? Der angefragte Echo hat ja nicht zwangsläufig als letzter gesabbelt…
                                    PS: ich habe es nun hinbekommen. Falls es Jemand nachbauen möchte, hier einmal eine Temperaturabfrage und die Abfrage nach offenen Fenstern/ Türen (mit dem Fensterscript aus dem Forum)
                                    Bei mir reichen die 500 ms und Alexa antwortet brav an dem Echo wo sie gefragt wurde.
                                    https://youtu.be/Zv1blw2ASF4
                                    https://youtu.be/8g6xmpQW8ew
                                    • Matten MattenM Offline
                                      Matten Matten
                                      #454
                                      @csamaggi:
                                      Danke sigi das war wieder mal so nah und doch so fern die Funktion hatte ich nicht in betracht gezogen.
                                      Danke für den Antsoss.
                                      Was natürlich noch etwas geiler wäre wenn der IO prüft in einem Script und sie dann eben nur das jeweilige ausspricht mal sehen ob man dass hin bekommt.
                                      MFG Maggi `
                                      Hab ich wie folgt programmiert
                                      Matten Matten
                                      ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
                                      • sigi234S Online
                                        sigi234S Online
                                        #455
                                        COOL :)
                                        Kannst du mir das exportieren?
                                        Wobei mir das Objekt noch nicht klar ist….
                                        • dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #456
                                          na ja, da das Fensterscript hier aus dem Forum (ich glaube von Pix) über die Gewerke bei mir eh läuft, sind ja bei jeder Veränderung die geöffneten Fenster schon als Ausgabe vorhanden. Aufbereit als Texxt für Sayit und Telegram.
                                          Nur diese Punkte greife ich bei mir ab.
