  4. [gelöst]Fehlermeldung bei Installation des TR-064- und Radar-Adapters
    1.0k
    6.1k
19 Beiträge 5 Kommentatoren 1.9k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    Also im Prinzip steht es im log…
    Falsche bzw. Zu alte NPM Version oder fehlerhaft installiert.
    Was kommt denn bei````
    npm -v
      senger1985
      /usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1
      (function (exports, require, module, __filename, __dirname) { o
      SyntaxError: Invalid or unexpected token
          at createScript (vm.js:56:10)
          at Object.runInThisContext (vm.js:97:10)
          at Module._compile (module.js:549:28)
          at Object.Module._extensions..js (module.js:586:10)
          at Module.load (module.js:494:32)
          at tryModuleLoad (module.js:453:12)
          at Function.Module._load (module.js:445:3)
          at Module.require (module.js:504:17)
          at require (internal/module.js:20:19)
          at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)
      root@raspberrypi:~# /usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1
      -bash: /usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1: Datei oder Verzeichnis nicht gefunden
      root@raspberrypi:~# (function (exports, require, module, __filename, __dirname) { o
      -bash: Syntaxfehler beim unerwarteten Wort `('
      root@raspberrypi:~#
      root@raspberrypi:~#
      root@raspberrypi:~# SyntaxError: Invalid or unexpected token
      -bash: SyntaxError:: Kommando nicht gefunden.
      root@raspberrypi:~#     at createScript (vm.js:56:10)
      root@raspberrypi:~#     at Object.runInThisContext (vm.js:97:10)
      root@raspberrypi:~#     at Module._compile (module.js:549:28)
      root@raspberrypi:~#     at Object.Module._extensions..js (module.js:586:10)
      root@raspberrypi:~#     at Module.load (module.js:494:32)
      root@raspberrypi:~#     at tryModuleLoad (module.js:453:12)
      root@raspberrypi:~#     at Function.Module._load (module.js:445:3)
      root@raspberrypi:~#     at Module.require (module.js:504:17)
      root@raspberrypi:~#     at require (internal/module.js:20:19)
      root@raspberrypi:~#     at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)
      root@raspberrypi:~# ^C
      root@raspberrypi:~# npm -v
          at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)</anonymous></anonymous></anonymous>
      • wendy2702W Online
        wendy2702W Online
        Und was ist das jetzt für eine Ausgabe?
          senger1985
          Die kommt aus Putty, wenn ich "npm -v" eingebe.
          Kann sein, dass aus Versehen, noch irrelevant Informationen drin stehen.
          • StabilostickS Offline
            Stabilostick
            EIn Einfügen aus der Zwischenablage in die Kommandozeile und evtl. ein kaputtes npm.
            Bitte probiere noch, bevor wie node neu installieren dürfen, folgenden Befehl in der Kommandozeile:
            npm install -g npm@4
            Kommt da auch der Fehler?
              senger1985
              Jep, da kommt der selbe Fehler.
                Stabilostick
                Ok. Geht
                npm uninstall npm -g
                Da löscht sich npm selbst. Oder es kommt wieder der Fehler.
                  Stabilostick
                  Wenn es nicht klappt, zum Entfernen von Nodejs und von npm sowie zur Neuinstallation der beiden Komponenten die folgende Befehlssequenz (immer schön einen Befehl nach den nächsten) verwenden:
                  apt-get remove --purge node* npm*
                  curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                  apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                  Dann eine reboot und wieder Check mit
                  cd /opt/iobroker
                  node -v
                  npm -v
                    senger1985
                    Ich habe node jetzt mal runter geschmissen und neu installiert.
                    Jetzt bekomme ich folgende Meldung, wenn ich die npm-Version abfrage:
                    root@raspberrypi:/opt/iobroker# node -v
                    v8.11.1
                    root@raspberrypi:/opt/iobroker# npm -v
                    -bash: npm: Kommando nicht gefunden.
                      Dann bist du in das aktuelle Problem gelaufen.
                      Hattest du curl … 6.x aufgerufen?
                      anschließen versucht upzudaten und hast jetzt node 8.x drauf, dafür kein npm mehr?
                        senger1985
                        Jip, so habe ich es gemacht! :-(
                        • paul53P Offline
                          @senger1985:
                          Jetzt bekomme ich folgende Meldung, wenn ich die npm-Version abfrage: `
                          Das ist der bereits bekannte Fehler in der Distribution von Node 6.x. Verwende die Node 8.x und update anschließend npm.
                          curl -sL https://deb.nodesource.com/setup_8.x | bash -
                          apt-get install -y nodejs
                          EDIT: npm@latest-5 geändert in npm@4.
                            dann bitte nochmal zurück;
                            den curl mit 8.x ausführen und dann
                            Viel Glück
                              senger1985
                              Ich habe zwar keinen Blassen, was ich jetzt genau gemacht habe, außer das, was du mir geschrieben hast.
                              Aber jetzt funktioniert es.
                                @senger1985:
                                Aber jetzt funktioniert es. `
                                Das war Sinn der Sache ;-)
                                Nur für die Akten:
                                Hast du jetzt Pauls version mit npm5 oder meine mit npm4 gemacht?
                                  senger1985
                                  Deine Rainer
