  4. [gelöst]Fehlermeldung bei Installation des TR-064- und Radar-Adapters
    1.0k
    6.1k
19 Beiträge 5 Kommentatoren 1.9k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    Welche Versionen von Node, NPM, JS.Controller ?
    Hast du zufällig das komplette installations log?
      senger1985
      iobroker	2018-07-25 12:45:32.481	info	exit 25
      iobroker	2018-07-25 12:45:32.453	error	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      iobroker	2018-07-25 12:45:32.453	error	You need to make sure to repeat this step after installing an update to NodeJS and/or npm
      iobroker	2018-07-25 12:45:32.453	error	Use "npm install -g npm@4" or "npm install -g npm@>=5.7.1" to install a supported version.
      iobroker	2018-07-25 12:45:32.453	error	Please check that npm is installed correctly.
      iobroker	2018-07-25 12:45:32.453	error	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!
      iobroker	2018-07-25 12:45:32.448	error	at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)
      iobroker	2018-07-25 12:45:32.448	error	at require (internal/module.js:20:19)
      iobroker	2018-07-25 12:45:32.448	error	at Module.require (module.js:504:17)
      iobroker	2018-07-25 12:45:32.448	error	at Function.Module._load (module.js:445:3)
      iobroker	2018-07-25 12:45:32.448	error	at tryModuleLoad (module.js:453:12)
      iobroker	2018-07-25 12:45:32.448	error	at Module.load (module.js:494:32)
      iobroker	2018-07-25 12:45:32.448	error	at Object.Module._extensions..js (module.js:586:10)
      iobroker	2018-07-25 12:45:32.448	error	at Module._compile (module.js:549:28)
      iobroker	2018-07-25 12:45:32.448	error	at Object.runInThisContext (vm.js:97:10)
      iobroker	2018-07-25 12:45:32.448	error	at createScript (vm.js:56:10)
      iobroker	2018-07-25 12:45:32.448	error	SyntaxError: Invalid or unexpected token
      iobroker	2018-07-25 12:45:32.448	error	(function (exports, require, module, __filename, __dirname) { o
      iobroker	2018-07-25 12:45:32.448	error	Error trying to check npm version: Error: Command failed: npm -v/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1
      iobroker	2018-07-25 12:45:32.428	error	at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)
      iobroker	2018-07-25 12:45:32.428	error	at require (internal/module.js:20:19)
      iobroker	2018-07-25 12:45:32.428	error	at Module.require (module.js:504:17)
      iobroker	2018-07-25 12:45:32.428	error	at Function.Module._load (module.js:445:3)
      iobroker	2018-07-25 12:45:32.428	error	at tryModuleLoad (module.js:453:12)
      iobroker	2018-07-25 12:45:32.428	error	at Module.load (module.js:494:32)
      iobroker	2018-07-25 12:45:32.428	error	at Object.Module._extensions..js (module.js:586:10)
      iobroker	2018-07-25 12:45:32.428	error	at Module._compile (module.js:549:28)
      iobroker	2018-07-25 12:45:32.428	error	at Object.runInThisContext (vm.js:97:10)
      iobroker	2018-07-25 12:45:32.428	error	at createScript (vm.js:56:10)
      iobroker	2018-07-25 12:45:32.428	error	SyntaxError: Invalid or unexpected token
      iobroker	2018-07-25 12:45:32.428	error	/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1(function (exports, require, module, __filename, __dirname) { o</anonymous></anonymous>
      js-controler 1.4.2
      Node 6.13.1
      • wendy2702W Online
        wendy2702W Online
        Also im Prinzip steht es im log…
        Falsche bzw. Zu alte NPM Version oder fehlerhaft installiert.
        Was kommt denn bei````
        npm -v
          senger1985
          root@raspberrypi:~# /usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1
          -bash: /usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/tracker-group.js:1: Datei oder Verzeichnis nicht gefunden
          root@raspberrypi:~# (function (exports, require, module, __filename, __dirname) { o
          -bash: Syntaxfehler beim unerwarteten Wort `('
          root@raspberrypi:~#
          root@raspberrypi:~#
          root@raspberrypi:~# SyntaxError: Invalid or unexpected token
          -bash: SyntaxError:: Kommando nicht gefunden.
          root@raspberrypi:~#     at createScript (vm.js:56:10)
          root@raspberrypi:~#     at Object.runInThisContext (vm.js:97:10)
          root@raspberrypi:~#     at Module._compile (module.js:549:28)
          root@raspberrypi:~#     at Object.Module._extensions..js (module.js:586:10)
          root@raspberrypi:~#     at Module.load (module.js:494:32)
          root@raspberrypi:~#     at tryModuleLoad (module.js:453:12)
          root@raspberrypi:~#     at Function.Module._load (module.js:445:3)
          root@raspberrypi:~#     at Module.require (module.js:504:17)
          root@raspberrypi:~#     at require (internal/module.js:20:19)
          root@raspberrypi:~#     at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)
          root@raspberrypi:~# ^C
          root@raspberrypi:~# npm -v
              at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/npmlog/node_modules/are-we-there-yet/index.js:2:24)</anonymous></anonymous></anonymous>
          • wendy2702W Online
            wendy2702W Online
            Und was ist das jetzt für eine Ausgabe?
              senger1985
              Die kommt aus Putty, wenn ich "npm -v" eingebe.
              Kann sein, dass aus Versehen, noch irrelevant Informationen drin stehen.
              • StabilostickS Offline
                Stabilostick
                EIn Einfügen aus der Zwischenablage in die Kommandozeile und evtl. ein kaputtes npm.
                Bitte probiere noch, bevor wie node neu installieren dürfen, folgenden Befehl in der Kommandozeile:
                Kommt da auch der Fehler?
                  senger1985
                  Jep, da kommt der selbe Fehler.
                    Stabilostick
                    Ok. Geht
                    npm uninstall npm -g
                    Da löscht sich npm selbst. Oder es kommt wieder der Fehler.
                      Stabilostick
                      Wenn es nicht klappt, zum Entfernen von Nodejs und von npm sowie zur Neuinstallation der beiden Komponenten die folgende Befehlssequenz (immer schön einen Befehl nach den nächsten) verwenden:
                      apt-get remove --purge node* npm*
                      curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                      apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                      Dann eine reboot und wieder Check mit
                      cd /opt/iobroker
                      node -v
                      npm -v
                        senger1985
                        Ich habe node jetzt mal runter geschmissen und neu installiert.
                        Jetzt bekomme ich folgende Meldung, wenn ich die npm-Version abfrage:
                        root@raspberrypi:/opt/iobroker# node -v
                        v8.11.1
                        root@raspberrypi:/opt/iobroker# npm -v
                        -bash: npm: Kommando nicht gefunden.
                          Dann bist du in das aktuelle Problem gelaufen.
                          Hattest du curl … 6.x aufgerufen?
                          anschließen versucht upzudaten und hast jetzt node 8.x drauf, dafür kein npm mehr?
                            senger1985
                            Jip, so habe ich es gemacht! :-(
                            • paul53P Offline
                              @senger1985:
                              Jetzt bekomme ich folgende Meldung, wenn ich die npm-Version abfrage: `
                              Das ist der bereits bekannte Fehler in der Distribution von Node 6.x. Verwende die Node 8.x und update anschließend npm.
                              curl -sL https://deb.nodesource.com/setup_8.x | bash -
                              apt-get install -y nodejs
                              EDIT: npm@latest-5 geändert in npm@4.
                                dann bitte nochmal zurück;
                                den curl mit 8.x ausführen und dann
                                Viel Glück
                                  senger1985
                                  Ich habe zwar keinen Blassen, was ich jetzt genau gemacht habe, außer das, was du mir geschrieben hast.
                                  Aber jetzt funktioniert es.
                                    @senger1985:
                                    Aber jetzt funktioniert es. `
                                    Das war Sinn der Sache ;-)
                                    Nur für die Akten:
                                    Hast du jetzt Pauls version mit npm5 oder meine mit npm4 gemacht?
                                      senger1985
                                      Deine Rainer
