  3. Cloud Dienste
  4. Neuer Adapter: iobroker.alexa2
581 Beiträge 76 Kommentatoren 218.4k Aufrufe 3 Beobachtet
  • L Offline
    LaBamba
    #151
    Ok habe ich gemacht!
    pi@raspberrypi:/opt/iobroker $ iobroker add alexa2
    host.raspberrypi install adapter alexa2
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.alexa2"
    got /opt/iobroker/node_modules/iobroker.alexa2/admin
    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    host.raspberrypi object system.adapter.alexa2 created
    host.raspberrypi create instance alexa2
    host.raspberrypi object alexa2.0.info.csrf created
    host.raspberrypi object alexa2.0.info.cookie created
    host.raspberrypi object alexa2.0.info.connection created
    host.raspberrypi object alexa2.0.info created
    host.raspberrypi object system.adapter.alexa2.0.outputCount created
    host.raspberrypi object system.adapter.alexa2.0.inputCount created
    host.raspberrypi object system.adapter.alexa2.0.uptime created
    host.raspberrypi object system.adapter.alexa2.0.memRss created
    host.raspberrypi object system.adapter.alexa2.0.memHeapTotal created
    host.raspberrypi object system.adapter.alexa2.0.memHeapUsed created
    host.raspberrypi object system.adapter.alexa2.0.connected created
    host.raspberrypi object system.adapter.alexa2.0.alive created
    host.raspberrypi object system.adapter.alexa2.0 created
    pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.alexa2
    - arr-diff@4.0.0 node_modules/iobroker.alexa2/node_modules/arr-diff
    - arr-flatten@1.1.0 node_modules/iobroker.alexa2/node_modules/arr-flatten
    - arr-union@3.1.0 node_modules/iobroker.alexa2/node_modules/arr-union
    - array-flatten@1.1.1 node_modules/iobroker.alexa2/node_modules/array-flatten
    - array-unique@0.3.2 node_modules/iobroker.alexa2/node_modules/array-unique
    - assign-symbols@1.0.0 node_modules/iobroker.alexa2/node_modules/assign-symbols
    - atob@2.1.1 node_modules/iobroker.alexa2/node_modules/atob
    - buffer-from@1.1.0 node_modules/iobroker.alexa2/node_modules/buffer-from
    - bufferhelper@0.2.1 node_modules/iobroker.alexa2/node_modules/bufferhelper
    - bytes@3.0.0 node_modules/iobroker.alexa2/node_modules/bytes
    - component-emitter@1.2.1 node_modules/iobroker.alexa2/node_modules/component-emitter
    - content-disposition@0.5.2 node_modules/iobroker.alexa2/node_modules/content-disposition
    - content-type@1.0.4 node_modules/iobroker.alexa2/node_modules/content-type
    - cookie@0.3.1 node_modules/iobroker.alexa2/node_modules/cookie
    - cookie-signature@1.0.6 node_modules/iobroker.alexa2/node_modules/cookie-signature
    - copy-descriptor@0.1.1 node_modules/iobroker.alexa2/node_modules/copy-descriptor
    - core-util-is@1.0.2 node_modules/iobroker.alexa2/node_modules/core-util-is
    - decode-uri-component@0.2.0 node_modules/iobroker.alexa2/node_modules/decode-uri-component
    - depd@1.1.2 node_modules/iobroker.alexa2/node_modules/depd
    - destroy@1.0.4 node_modules/iobroker.alexa2/node_modules/destroy
    - ee-first@1.1.1 node_modules/iobroker.alexa2/node_modules/ee-first
    - encodeurl@1.0.2 node_modules/iobroker.alexa2/node_modules/encodeurl
    - escape-html@1.0.3 node_modules/iobroker.alexa2/node_modules/escape-html
    - etag@1.8.1 node_modules/iobroker.alexa2/node_modules/etag
    - eventemitter3@3.1.0 node_modules/iobroker.alexa2/node_modules/eventemitter3
    - for-in@1.0.2 node_modules/iobroker.alexa2/node_modules/for-in
    - forwarded@0.1.2 node_modules/iobroker.alexa2/node_modules/forwarded
    - fresh@0.5.2 node_modules/iobroker.alexa2/node_modules/fresh
    - get-value@2.0.6 node_modules/iobroker.alexa2/node_modules/get-value
    - https@1.0.0 node_modules/iobroker.alexa2/node_modules/https
    - iconv-lite@0.4.19 node_modules/iobroker.alexa2/node_modules/iconv-lite
    - inherits@2.0.3 node_modules/iobroker.alexa2/node_modules/inherits
    - ipaddr.js@1.6.0 node_modules/iobroker.alexa2/node_modules/ipaddr.js
    - is-buffer@1.1.6 node_modules/iobroker.alexa2/node_modules/is-buffer
    - kind-of@4.0.0 node_modules/iobroker.alexa2/node_modules/has-values/node_modules/kind-of
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-accessor-descriptor/node_modules/kind-of
    - is-accessor-descriptor@0.1.6 node_modules/iobroker.alexa2/node_modules/is-accessor-descriptor
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-data-descriptor/node_modules/kind-of
    - is-data-descriptor@0.1.4 node_modules/iobroker.alexa2/node_modules/is-data-descriptor
    - kind-of@5.1.0 node_modules/iobroker.alexa2/node_modules/is-descriptor/node_modules/kind-of
    - is-descriptor@0.1.6 node_modules/iobroker.alexa2/node_modules/is-descriptor
    - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/class-utils/node_modules/define-property
    - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/expand-brackets/node_modules/define-property
    - is-extendable@0.1.1 node_modules/iobroker.alexa2/node_modules/is-extendable
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/braces/node_modules/extend-shallow
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/expand-brackets/node_modules/extend-shallow
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/extend-shallow
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/fill-range/node_modules/extend-shallow
    - is-extglob@2.1.1 node_modules/iobroker.alexa2/node_modules/is-extglob
    - is-glob@4.0.0 node_modules/iobroker.alexa2/node_modules/is-glob
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-number/node_modules/kind-of
    - is-number@3.0.0 node_modules/iobroker.alexa2/node_modules/is-number
    - has-values@1.0.0 node_modules/iobroker.alexa2/node_modules/has-values
    - is-windows@1.0.2 node_modules/iobroker.alexa2/node_modules/is-windows
    - isarray@1.0.0 node_modules/iobroker.alexa2/node_modules/isarray
    - isobject@3.0.1 node_modules/iobroker.alexa2/node_modules/isobject
    - has-value@1.0.0 node_modules/iobroker.alexa2/node_modules/has-value
    - is-plain-object@2.0.4 node_modules/iobroker.alexa2/node_modules/is-plain-object
    - is-extendable@1.0.1 node_modules/iobroker.alexa2/node_modules/extend-shallow/node_modules/is-extendable
    - extend-shallow@3.0.2 node_modules/iobroker.alexa2/node_modules/extend-shallow
    - kind-of@6.0.2 node_modules/iobroker.alexa2/node_modules/kind-of
    - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-accessor-descriptor
    - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-data-descriptor
    - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-descriptor
    - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/define-property
    - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-accessor-descriptor
    - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-data-descriptor
    - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-descriptor
    - define-property@2.0.2 node_modules/iobroker.alexa2/node_modules/define-property
    - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-accessor-descriptor
    - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-data-descriptor
    - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-descriptor
    - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/define-property
    - lodash@4.17.10 node_modules/iobroker.alexa2/node_modules/lodash
    - map-cache@0.2.2 node_modules/iobroker.alexa2/node_modules/map-cache
    - fragment-cache@0.2.1 node_modules/iobroker.alexa2/node_modules/fragment-cache
    - media-typer@0.3.0 node_modules/iobroker.alexa2/node_modules/media-typer
    - merge-descriptors@1.0.1 node_modules/iobroker.alexa2/node_modules/merge-descriptors
    - methods@1.1.2 node_modules/iobroker.alexa2/node_modules/methods
    - mime@1.4.1 node_modules/iobroker.alexa2/node_modules/mime
    - mime-db@1.35.0 node_modules/iobroker.alexa2/node_modules/mime-db
    - mime-types@2.1.19 node_modules/iobroker.alexa2/node_modules/mime-types
    - is-extendable@1.0.1 node_modules/iobroker.alexa2/node_modules/mixin-deep/node_modules/is-extendable
    - mixin-deep@1.3.1 node_modules/iobroker.alexa2/node_modules/mixin-deep
    - ms@2.0.0 node_modules/iobroker.alexa2/node_modules/ms
    - debug@2.6.9 node_modules/iobroker.alexa2/node_modules/debug
    - debug@3.1.0 node_modules/iobroker.alexa2/node_modules/follow-redirects/node_modules/debug
    - follow-redirects@1.5.1 node_modules/iobroker.alexa2/node_modules/follow-redirects
    - negotiator@0.6.1 node_modules/iobroker.alexa2/node_modules/negotiator
    - accepts@1.3.5 node_modules/iobroker.alexa2/node_modules/accepts
    - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/object-copy/node_modules/define-property
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/object-copy/node_modules/kind-of
    - object-copy@0.1.0 node_modules/iobroker.alexa2/node_modules/object-copy
    - object-visit@1.0.1 node_modules/iobroker.alexa2/node_modules/object-visit
    - map-visit@1.0.0 node_modules/iobroker.alexa2/node_modules/map-visit
    - collection-visit@1.0.0 node_modules/iobroker.alexa2/node_modules/collection-visit
    - object.pick@1.3.0 node_modules/iobroker.alexa2/node_modules/object.pick
    - on-finished@2.3.0 node_modules/iobroker.alexa2/node_modules/on-finished
    - parseurl@1.3.2 node_modules/iobroker.alexa2/node_modules/parseurl
    - pascalcase@0.1.1 node_modules/iobroker.alexa2/node_modules/pascalcase
    - path-to-regexp@0.1.7 node_modules/iobroker.alexa2/node_modules/path-to-regexp
    - posix-character-classes@0.1.1 node_modules/iobroker.alexa2/node_modules/posix-character-classes
    - process-nextick-args@2.0.0 node_modules/iobroker.alexa2/node_modules/process-nextick-args
    - proxy-addr@2.0.3 node_modules/iobroker.alexa2/node_modules/proxy-addr
    - qs@6.5.1 node_modules/iobroker.alexa2/node_modules/qs
    - querystring@0.2.0 node_modules/iobroker.alexa2/node_modules/querystring
    - range-parser@1.2.0 node_modules/iobroker.alexa2/node_modules/range-parser
    - depd@1.1.1 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/depd
    - setprototypeof@1.0.3 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/setprototypeof
    - repeat-element@1.1.2 node_modules/iobroker.alexa2/node_modules/repeat-element
    - repeat-string@1.6.1 node_modules/iobroker.alexa2/node_modules/repeat-string
    - requires-port@1.0.0 node_modules/iobroker.alexa2/node_modules/requires-port
    - http-proxy@1.17.0 node_modules/iobroker.alexa2/node_modules/http-proxy
    - resolve-url@0.2.1 node_modules/iobroker.alexa2/node_modules/resolve-url
    - ret@0.1.15 node_modules/iobroker.alexa2/node_modules/ret
    - safe-buffer@5.1.1 node_modules/iobroker.alexa2/node_modules/safe-buffer
    - safe-regex@1.1.0 node_modules/iobroker.alexa2/node_modules/safe-regex
    - regex-not@1.0.2 node_modules/iobroker.alexa2/node_modules/regex-not
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/set-value/node_modules/extend-shallow
    - setprototypeof@1.1.0 node_modules/iobroker.alexa2/node_modules/setprototypeof
    - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-accessor-descriptor
    - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-data-descriptor
    - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-descriptor
    - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/define-property
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/snapdragon-util/node_modules/kind-of
    - snapdragon-util@3.0.1 node_modules/iobroker.alexa2/node_modules/snapdragon-util
    - snapdragon-node@2.1.1 node_modules/iobroker.alexa2/node_modules/snapdragon-node
    - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/snapdragon/node_modules/define-property
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/snapdragon/node_modules/extend-shallow
    - source-map@0.5.7 node_modules/iobroker.alexa2/node_modules/source-map
    - source-map-url@0.4.0 node_modules/iobroker.alexa2/node_modules/source-map-url
    - split-string@3.1.0 node_modules/iobroker.alexa2/node_modules/split-string
    - set-value@2.0.0 node_modules/iobroker.alexa2/node_modules/set-value
    - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/static-extend/node_modules/define-property
    - static-extend@0.1.2 node_modules/iobroker.alexa2/node_modules/static-extend
    - class-utils@0.3.6 node_modules/iobroker.alexa2/node_modules/class-utils
    - statuses@1.4.0 node_modules/iobroker.alexa2/node_modules/statuses
    - http-errors@1.6.3 node_modules/iobroker.alexa2/node_modules/http-errors
    - http-errors@1.6.2 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/http-errors
    - send@0.16.2 node_modules/iobroker.alexa2/node_modules/send
    - serve-static@1.13.2 node_modules/iobroker.alexa2/node_modules/serve-static
    - string_decoder@1.1.1 node_modules/iobroker.alexa2/node_modules/string_decoder
    - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/to-object-path/node_modules/kind-of
    - to-object-path@0.3.0 node_modules/iobroker.alexa2/node_modules/to-object-path
    - to-regex@3.0.2 node_modules/iobroker.alexa2/node_modules/to-regex
    - to-regex-range@2.1.1 node_modules/iobroker.alexa2/node_modules/to-regex-range
    - fill-range@4.0.0 node_modules/iobroker.alexa2/node_modules/fill-range
    - type-is@1.6.16 node_modules/iobroker.alexa2/node_modules/type-is
    - typedarray@0.0.6 node_modules/iobroker.alexa2/node_modules/typedarray
    - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/union-value/node_modules/extend-shallow
    - set-value@0.4.3 node_modules/iobroker.alexa2/node_modules/union-value/node_modules/set-value
    - union-value@1.0.0 node_modules/iobroker.alexa2/node_modules/union-value
    - unpipe@1.0.0 node_modules/iobroker.alexa2/node_modules/unpipe
    - finalhandler@1.1.1 node_modules/iobroker.alexa2/node_modules/finalhandler
    - raw-body@2.3.2 node_modules/iobroker.alexa2/node_modules/raw-body
    - body-parser@1.18.2 node_modules/iobroker.alexa2/node_modules/body-parser
    - isobject@2.1.0 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-value/node_modules/isobject
    - has-values@0.1.4 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-values
    - has-value@0.3.1 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-value
    - unset-value@1.0.0 node_modules/iobroker.alexa2/node_modules/unset-value
    - cache-base@1.0.1 node_modules/iobroker.alexa2/node_modules/cache-base
    - base@0.11.2 node_modules/iobroker.alexa2/node_modules/base
    - urix@0.1.0 node_modules/iobroker.alexa2/node_modules/urix
    - source-map-resolve@0.5.2 node_modules/iobroker.alexa2/node_modules/source-map-resolve
    - use@3.1.1 node_modules/iobroker.alexa2/node_modules/use
    - snapdragon@0.8.2 node_modules/iobroker.alexa2/node_modules/snapdragon
    - braces@2.3.2 node_modules/iobroker.alexa2/node_modules/braces
    - expand-brackets@2.1.4 node_modules/iobroker.alexa2/node_modules/expand-brackets
    - extglob@2.0.4 node_modules/iobroker.alexa2/node_modules/extglob
    - nanomatch@1.2.13 node_modules/iobroker.alexa2/node_modules/nanomatch
    - micromatch@3.1.10 node_modules/iobroker.alexa2/node_modules/micromatch
    - http-proxy-middleware@0.18.0 node_modules/iobroker.alexa2/node_modules/http-proxy-middleware
    - util-deprecate@1.0.2 node_modules/iobroker.alexa2/node_modules/util-deprecate
    - readable-stream@2.3.6 node_modules/iobroker.alexa2/node_modules/readable-stream
    - concat-stream@1.6.2 node_modules/iobroker.alexa2/node_modules/concat-stream
    - http-proxy-response-rewrite@0.0.1 node_modules/iobroker.alexa2/node_modules/http-proxy-response-rewrite
    - utils-merge@1.0.1 node_modules/iobroker.alexa2/node_modules/utils-merge
    - vary@1.1.2 node_modules/iobroker.alexa2/node_modules/vary
    - express@4.16.3 node_modules/iobroker.alexa2/node_modules/express
    - alexa-cookie2@0.2.2 node_modules/iobroker.alexa2/node_modules/alexa-cookie2
    - alexa-remote2@0.2.4 node_modules/iobroker.alexa2/node_modules/alexa-remote2
    iobroker.inst@1.1.2 /opt/iobroker
    └── iobroker.alexa2@0.2.4
       │   Update available 4.6.1 → 6.2.0    │
       │     Run npm i -g npm to update      │
    Soll ich das update von 4.6.1 → 6.2.0 machen?
    • L Offline
      LaBamba
      #152
      @apollon77:
      Vor dem Upload muss mal mindestens mal eine Instanz angelegt sein.
      iobroker add alexa2
      danach das Upload `
      Jetzt taucht der Adapter schon einmal in den Instanzen auf!
      Aus meiner Sicht wäre es hilfreich, wenn ihr diesen Punkt noch in der Adapterbeschreibung hinzufügt.
        #153
        Wenn es läuft, bitte im Moment nicht.
        Da scheint ein Bug/Inkompatibilität in npm 6.x zu sein
          #154
          @LaBamba:
          Aus meiner Sicht wäre es hilfreich, wenn ihr diesen Punkt noch in der Adapterbeschreibung hinzufügt. `
          Wieso?
          Es ist doch normal, dass eine Installation eines Adapters noch keine Instanz erzeugt.
          Eine Instanz muss immer händisch angelegt werdn (Außer beim Admin)
          • chucky666C Online
            chucky666C Online
            chucky666
            #155
            Ja warte lieber die 6.2 hat bei mir auch Probleme gemacht
            Gesendet von iPad mit Tapatalk Pro
            • L Offline
              LaBamba
              #156
              @Homoran:
              @LaBamba:
              Wieso?
              Rainer `
              Ihr seit Profis! Als Anfänger kann man an solchen kleinen Problemen scheitern.
                #157
                ~~@[url=http://www.iobroker.net/docu/?page_id=5473⟨=de#Adapter:~~
                Doku"]http://www.iobroker.net/docu/?page_id=5379&lang=de
                Hier werden die verfügbaren und installierten Adapter angezeigt und verwaltet.
                http://www.iobroker.net/docu/?page_id=5474&lang=de
                Hier werden die bereits über den Reiter Adapter installierten Instanzen aufgelistet und können entsprechend konfiguriert werden. `
                  stephan
                  #158
                  @stephan:
                  Hallo, war lange nicht mehr an meinem Iobroker…
                  Doch durch den neuen Adapter bin ich wieder munter geworden.
                  Installiert bekomme ich ihn nur wirft er mir nur Fehler im Log.
                  Habe nur meinen Benutzer und Passwort im Adapter eingegeben, oder fehlen da noch mehr eingaben.
                  host.ioBroker-Pi 2018-07-23 17:17:17.129 info Restart adapter system.adapter.alexa2.0 because enabled
                  host.ioBroker-Pi 2018-07-23 17:17:17.129 error instance system.adapter.alexa2.0 terminated with code 1 ()
                  host.ioBroker-Pi 2018-07-23 17:17:16.791 info instance system.adapter.alexa2.0 started with pid 20703
                  host.ioBroker-Pi 2018-07-23 17:16:46.762 info Restart adapter system.adapter.alexa2.0 because enabled
                  host.ioBroker-Pi 2018-07-23 17:16:46.761 error instance system.adapter.alexa2.0 terminated with code 1 ()
                  host.ioBroker-Pi 2018-07-23 17:16:46.380 info instance system.adapter.alexa2.0 started with pid 20634
                  Was mache ich denn da verkehrt ?
                  Danke schon mal im vorrauss `
                  Hat keiner eine Antwort auf mein Problem…
                  • C Offline
                    chrizzel
                    #159
                    sudo apt-get install git
                    wird das beheben.
                    rainer `
                    Ich danke dir! Das hat geholfen!
                    Beste Grüße
                    Chris
                    • apollon77A Offline
                      #160
                      @stephan:
                      Interessant. Welche js.controller Version?
                      mach mal: Kommandozeile ins iobroker verzeichnis. Dort dann
                      node node_modules/iobroker.alexa2/main.js --force --logs
                      Was ist die Ausgabe?
                        stephan
                        #161
                        sorry bin absoluter Anfänger…wie mache ich das
                          stephan
                          #162
                          @apollon77:
                          @stephan:
                          Was ist die Ausgabe? `
                            #163
                            SSH auf deinen Raspi oder was such immer du nutzt
                            cd /opt/iobroker
                            Dann das was oben steht.
                            Gesendet vom Handy …
                            • ? Offline
                              #164
                              Changelog
                              0.3.0 (2018-07-23)
                                  (Bluefox) Admin3 fixes and slight changes to roles and code
                                  (Apollon77) Combine Player-Control and Player-Info into channel Player to support better detection and material support
                              :shock: Das heisst, wir bauen nun unsere Views und Skripte wieder um.
                                #165
                                Die 0.3.0 ist noch nicht fertig also bitte Finger weg vom GitHub heute ;-)
                                Aber ja leider. Es wurde nötig weil Bluefox gerade für Material einige dinge standardisiert und wie sind jetzt immer noch eher früh unterwegs.
                                Sollte aber die letzte Anpassung sein. Sorry.
                                • Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  #166
                                  @apollon77:
                                  @Merlin123:
                                  Danke, hab es gerade kurz vorher gefunden und den Post geändert.
                                  Dauert jetzt nur noch recht lange, bis die Konfig aufgerufen wird. Nur bei der konfig von diesem Adapter? Oder auch andere? Sollte an sich nicht am Adapter liegen.
                                  Nur bei dem. Das hat mich ja so gewundert….
                                  Beta-Tester
                                    stephan
                                    #167
                                    @apollon77:
                                    cd /opt/iobroker
                                    Gesendet vom Handy … `
                                    Das kommt bei mir…
                                      Kochenmitmusik
                                      #168
                                      habe eine Verständnisfrage: kommt das was von Alexa gesprochen werden soll hier rein:
                                      oder hier
                                      • dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #169
                                        @Kochenmitmusik:
                                        Danke `
                                        kommt in das Script. Das Script schreibt es dann (wenn der Trigger ausgelöst wird) in den Datenpunkt.
                                          #170
                                          @stephan:
                                          @apollon77:
                                          cd /opt/iobroker
                                          Gesendet vom Handy … Das kommt bei mir…
                                          Dann installier mal neu bzw checke mal deine SD Karte falls Du eine hast … nicht das die gerade anfängt Ihren Geist aufzugeben
