  4. IoBroker undefinierter Neustart
    1.0k
    6.1k
45 Beiträge 6 Kommentatoren 5.5k Aufrufe
  • L Offline
    LJSven
    Ich habe jetzt als Wetter Adapter den „yr.no“ installiert. Da besteht aber keine Verbindung, oder?
    • L Offline
      LJSven
      Ich habe gerade mal die vis-weather Adapter deinstalliert und stoße auf folgende Fehlermeldung. Hat die was zu sagen?
       2018-07-01 10:14:29.946 - info: iobroker Delete adapter "vis-weather.0"
      2018-07-01 10:14:30.116 - info: iobroker host.raspberrypi Counted 1 instances of vis-weather
      2018-07-01 10:14:36.550 - info: iobroker host.raspberrypi Deleting 1 object(s).
      2018-07-01 10:14:36.574 - info: host.raspberrypi object change system.adapter.vis-weather.0
      2018-07-01 10:14:36.575 - info: host.raspberrypi object deleted system.adapter.vis-weather.0
      2018-07-01 10:14:36.639 - info: iobroker exit 0
      2018-07-01 10:14:53.365 - info: iobroker del vis-timeandweather.0
      2018-07-01 10:14:56.056 - info: iobroker Delete adapter "vis-timeandweather.0"
      2018-07-01 10:14:56.188 - info: iobroker host.raspberrypi Counted 1 instances of vis-timeandweather
      2018-07-01 10:15:02.553 - info: iobroker host.raspberrypi Deleting 1 object(s).
      2018-07-01 10:15:02.566 - info: host.raspberrypi object change system.adapter.vis-timeandweather.0
      2018-07-01 10:15:02.567 - info: host.raspberrypi object deleted system.adapter.vis-timeandweather.0
      2018-07-01 10:15:02.615 - info: iobroker exit 0
      2018-07-01 10:15:42.087 - info: iobroker del vis-timeandweather
      2018-07-01 10:15:44.838 - info: iobroker Delete adapter "vis-timeandweather"
      2018-07-01 10:15:44.977 - info: iobroker host.raspberrypi no instances of adapter vis-timeandweather found
      2018-07-01 10:15:45.056 - info: iobroker host.raspberrypi Counted 1 adapters for vis-timeandweather
      2018-07-01 10:15:45.620 - info: iobroker host.raspberrypi Counted 1 states of vis-timeandweather
      2018-07-01 10:15:45.689 - info: iobroker host.raspberrypi Counted 1 states (system.adapter.vis-timeandweather.*) from states
      2018-07-01 10:15:45.757 - info: iobroker host.raspberrypi Deleting 2 object(s).
      2018-07-01 10:15:45.784 - info: iobroker host.raspberrypi Deleting 1 state(s).
      2018-07-01 10:15:46.723 - error: host.raspberrypi Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/vis-timeandweather.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/vis-timeandweather.admin/_data.json'
      2018-07-01 10:15:48.035 - info: iobroker npm uninstall iobroker.vis-timeandweather --silent --save --prefix "/opt/iobroker" (System call)
      2018-07-01 10:17:23.763 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
      compilation terminated.
      2018-07-01 10:17:23.806 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      2018-07-01 10:17:30.089 - info: iobroker In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
      #include
      2018-07-01 10:17:30.096 - info: iobroker compilation terminated.
      2018-07-01 10:17:30.572 - info: iobroker make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
      2018-07-01 10:17:46.564 - info: iobroker exit 0
      2018-07-01 10:18:07
      • apollon77A Offline
        Die Meldung bedeutet erstmal nichts.
        Gesendet vom Handy …
        • L Offline
          LJSven
          Ist der Adapter (DasWetter) vielleicht nicht richtig deinstalliert? Kann ich das prüfen?
            Marcel85
            Ich denke das hat erstmal nichts zu sagen. Bei mir hat es gereicht ihn zu deaktivieren. Installiert habe ich ihn noch.
            yr.no habe ich aktuell noch deaktiviert. Ich aktiviere ihn mal wieder und berichte dann.
            • L Offline
              LJSven
              Mein Gedanke war, dass der Adapter zwar deinstalliert ist, aber dennoch was im Hintergrund läuft (was ich nicht sehen kann).
                Marcel85
                Ich habe es bei mir so gemacht, dass ich alle Adapter deaktiviert habe.
                Als erstes habe ich die notwendigsten Adapter wie VIS usw. wieder aktiviert und jetzt aktiviere ich einen nach dem anderen, um zu sehen an welchem es hapert.
                  Super Idee. Bin gespannt
                  • L Offline
                    LJSven
                    @Marcel85:
                    Als erstes habe ich die notwendigsten Adapter wie VIS usw. wieder aktiviert und jetzt aktiviere ich einen nach dem anderen, um zu sehen an welchem es hapert. `
                    Was sind denn die „notwendigsten“? Sorry, bin Newbie ;-)
                      Marcel85
                      @LJSven:
                      @Marcel85:
                      Gesendet von iPhone mit Tapatalk `
                      Naja, die die du für dich am wichtigsten erachtest.
                      In meinem Fall VIS, HM, JS, HUE. So das wenigstens die Grundfunktionen erhalten bleiben.
