  3. Entwicklung
  4. Adapter: jeelink
Adapter: jeelink
jeelink
185 Beiträge 28 Kommentatoren 69.0k Aufrufe 4 Beobachtet
    TStolzmann
    #115
    Hallo
    Ich bin neu hier und wollte heute das Jeelink Modul installieren und bekomme solch eine Fehlermeldung:
    npm ERR! /home/npm-debug.log
    iobroker 2018-01-25 11:59:26.833 info npm ERR! Please include the following file with any support request:
    iobroker 2018-01-25 11:59:25.856 info npm ERR! There is likely additional logging output above.
    iobroker 2018-01-25 11:59:25.856 info npm ERR! npm owner ls serialport
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Or if that isn't available, you can get their info via:
    iobroker 2018-01-25 11:59:25.856 info npm ERR! npm bugs serialport
    iobroker 2018-01-25 11:59:25.856 info npm ERR! You can get information on how to open an issue for this project with:
    iobroker 2018-01-25 11:59:25.856 info npm ERR! node-pre-gyp install –fallback-to-build
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Tell the author that this fails on your system:
    iobroker 2018-01-25 11:59:25.856 info npm ERR! not with npm itself.
    iobroker 2018-01-25 11:59:25.856 info npm ERR! If you do, this is most likely a problem with the serialport package,
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Failed at the serialport@3.1.2 install script 'node-pre-gyp install --fallback-to-build'.
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Exit status 1
    iobroker 2018-01-25 11:59:25.856 info npm ERR! serialport@3.1.2 install: node-pre-gyp install --fallback-to-build
    iobroker 2018-01-25 11:59:25.856 info npm ERR! code ELIFECYCLE
    iobroker 2018-01-25 11:59:25.856 info npm ERR! npm v3.10.10
    iobroker 2018-01-25 11:59:25.856 info npm ERR! node v6.12.3
    iobroker 2018-01-25 11:59:25.856 info npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/foxthefox/ioBroker.j ... all/master" "--production" "--prefix" "/opt/iobroker"
    iobroker 2018-01-25 11:59:25.856 info npm ERR! Linux 4.13.16-sunxi
    iobroker 2018-01-25 11:59:25.856 info SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuildnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    iobroker 2018-01-25 11:59:25.789 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional
    Was kann ich machen um das Modul zu installieren?
    ioBroker läuft auf einem BananaPi Version 1.23
    Gruß Thomas
    • F Abwesend
      F Abwesend
      foxthefox
      #116
      Das Modul serialport ist nicht so einfach zu installieren, bzw s gibt keine vorkompilierten versionen für arm-CPU deswegen bitte
      sudo npm install –unsafe-perm https://github.com/foxthefox/ioBroker.j ... all/master --production
      Benutzen.
      Das Verzeichnis sollte /opt/iobroker sein, wo der Befehl abgesetzt werden sollte.
      Klaus
      Adapterüberblick: Profil Github;
      Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
      Ein Aufruf: video
        TStolzmann
        #117
        Hallo
        Danke für deine schnelle Antwort.
        Das Modul konnte ich jetzt Fehler frei installieren, aber wenn ich jetzt konfigurieren möchte, ist die Seite nicht vollständig sichtbar.
        So sieht die Seite bei mir aus. Habe ioBroker nochmal auf einen Raspi3 installiert, das gleiche Bild.
        Laut Log empfängt das Modul Daten.
        Thomas
        • F Abwesend
          F Abwesend
          foxthefox
          #118
          @TStolzmann:
          Hallo
          Thomas `
          Hallo Thomas,
          Leider hab ich die Anpassung für das Admin v3 noch nicht fertig. Hab am Wochenende schon damit angefangen, aber es sind halt nicht nur kleine Anpassungen. Ich hab auch am we festgestellt, dass bei Neuinstallation nur Admin v3 installiert wird.
          Wenn es dringend ist, dann gibt es aus meiner Sicht nur 2 Möglichkeiten.
          • downgrade des admin adapters zum Zwecke der Konfiguration
          • im jeelink Adapter die Datei index_m.html löschen, damit sollte die alte Version zur Anzeige kommen.
          Klaus
          Ein Aufruf: video
          • F Abwesend
            F Abwesend
            foxthefox
            #119
            die neue Version 0.0.4 ist veröffentlicht und enthält nun das adminv3.
            Leider gibt es noch unschöne Verhaltensweisen:
            • wird eine neue Zeile hinzugefügt so werden die Auswahlfelder leider leer dargestellt
            • löschen und einfügen einer Zeile macht die Löschtasten unwirksam
            Wenn die Einstellungen gespeichert werden und die Seite neu aufgerufen wird, sind die gemachten Änderungen enthalten und die Löschtasten sind auch wieder rot (aktiv).
            Klaus
            Ein Aufruf: video
              der_Auge
              #120
              die Installation läuft zur Zeit nicht
              Was ist das Problem?
              Jürgen
              Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
              Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
              SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
              Test : DS916+ VM Debian
              Test : Tinker mit piVCCU
              • F Abwesend
                F Abwesend
                foxthefox
                #121
                Hallo Jürgen,
                Bin grad in Japan und kann es hier leider nicht ausprobieren, ich würde es mit einer Installation von der kommandozeile probieren.
                npm install –unsafe-perm iobroker.jeelink
                Ansonsten kann ich es erst zu hause versuchen nachzustellen.
                Klaus
                Ein Aufruf: video
                • F Abwesend
                  F Abwesend
                  foxthefox
                  #122
                  Die Installationsproblematik konnte ich nicht nachvollziehen, habe aber mal 2 neue Versionen erstellt.
                  auf npm liegt 0.0.5 in der die Probleme mit dem admin Adapter gelöst sind, jetzt geht wieder der alte Aufruf values2table und Add/Delete verhält sich wie erwartet wird.
                  auf github liegt 0.0.6 mit der neuesten Version von "serialport", somit sollte die Zukunft für node 10 auch gegeben sein.
                  Bitte die 0.0.6 testen und berichten!!!
                  Klaus
                  Ein Aufruf: video
                    Travin
                    #123
                    vielleicht kann mir jemand weiterhelfen…
                    ich wollte gerade den jeelink Adapter im iobroker installieren. Hat aber leider nicht funktioniert. Ich bekomme folgende Fehlermeldung:
                    ERROR: (node:14333) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Can't find end of central directory : is this a zip file ? If it is, see https://stuk.github.io/jszip/documentat … d_zip.html
                    Scheint die gleiche zu sein wie bei der_Auge.
                    Ich habe die admin Vers 3.4.6 am laufen.
                    Schönen Dank für die Hilfe schon mal;-)
                    • F Abwesend
                      F Abwesend
                      foxthefox
                      #124
                      @Travin:
                      Schönen Dank für die Hilfe schon mal;-) `
                      Wie schon oben von mir beschrieben, ich kann es leider nicht nachstellen, habe beide Versionen (npm und die neue auf github auf raspi und auf qnap installiert).
                      Evtl hilft es von der Kommandozeile und ggf. mit dem –unsafe Parameter, die möglichen installationskommandos stehen in der readme auf github.
                      Klaus
                      Ein Aufruf: video
                      • H Offline
                        honda11
                        #125
                        ich habe da eine Frage (ich trau mich mal diese zu stellen… ):
                        Bisher lief bei mir jeelink "unter fhem" mit separater Stromversorgung und wlan.
                        Ich habe nun den Adapter unter iobroker installiert.
                        Wie konfiguriere ich den Adapter?
                        Vielen Dank.
                        Gruß, Jens
                        • F Abwesend
                          F Abwesend
                          foxthefox
                          #126
                          Hallo Jens,
                          Du brauchst die Id mit der der Sensor sendet. Die müsste auch unter FHEM benötigt sein.
                          Diese Id ändert sich wohl wenn man die Batterie tauscht, deswegen gibt es zum Ablegen in der objektstruktur eine eindeutige Id, die du selbst festlegst.
                          Beides und den Typ mit Beschreibung trägst du im Admin Bereich des Adapters ein.
                          Die beispielzeile kannst du rauslöschen.
                          Klaus
                          Ein Aufruf: video
                          • H Offline
                            honda11
                            #127
                            meine Frage war evtl. zu unpräzise:
                            Da mein jeelink über wlan eingerichtet ist, wie trage ich das in den Settings ein?
                            "/dev/ttyUSB0" geht ja so nicht.
                            Gruß, Jens
                            • F Abwesend
                              F Abwesend
                              foxthefox
                              #128
                              Hallo Jens,
                              Ich befürchte, das du einen anderen Adapter brauchst. Ich habe den Adapter so geschrieben, dass der jeelink-Stick am USB des iobroker-Servers hängt.
                              Wie du hier über WLAN routest ist mir schleierhaft.
                              Klaus
                              Ein Aufruf: video
                              • H Offline
                                honda11
                                #129
                                Das geht mit einem "WLAN-Jeelink".
                                model: LaCrosseITPlusReader.Gateway.1.22
                                flashCommand: avrdude -p atmega328P -c arduino -P [PORT] -D -U flash:w:[HEXFILE] 2>[LOGFILE]
                                Wenn es so nicht geht ist es ebend so.
                                Hätte ja sein können, dass ich die Adapter-Einstellungen nicht verstanden habe.
                                Gruß, Jens
                                • StabilostickS Offline
                                  Stabilostick
                                  #130
                                  Hast du das WiFi-LaCrosse-Gateway, das wie hier https://wiki.fhem.de/wiki/LaCrosseGateway_V1.x beschrieben ist?
                                    Stabilostick
                                    #131
                                    Und was ist da mit dem Punkt USB? Kann das ein Ansatz sein?
                                    • H Offline
                                      honda11
                                      #132
                                      hm…. vermutlich.
                                      Ich möchte das aber aktuell nicht verändern.
                                      • C Offline
                                        C1500
                                        #133
                                        Servus
                                        wie hoch seht ihr die Chance, das die Technoline MA 10050 Wetterstation mit diesem Adapter verwendet werden kann?
                                        Also per CUL ohne den Gateway?
                                        Gruß Peer
                                        Hier noch ein kleines EDIT
                                        Irgenwie findet er meine Sensoren nicht
                                        Im Log werden folgende Sensore gefunden:
                                        jeelink.0	2018-08-09 18:17:46.531	info	data received: H005400750255
                                        jeelink.0	2018-08-09 18:17:44.084	info	data received: H000700320268
                                        jeelink.0	2018-08-09 18:17:42.965	info	data received: H000100290270
                                        jeelink.0	2018-08-09 18:17:41.015	info	data received: H000001100700
                                        jeelink.0	2018-08-09 18:17:38.509	info	data received: H002700680253
                                        jeelink.0	2018-08-09 18:17:38.314	info	data received: H002500390426
                                        Es sind alles TX29DTH-IT
                                        Wenn ich dies dann wie folgt anlege, werde aber keine Daten angezeigt.
                                        Die Objekte werden angelegt, bleiben aber leer.
                                        Mit dem CuxD auf der CCU2 hat es funktoiniert.
                                        Die CCU2 wollte ich aber etwas entlasten und auf ioBroker verschieben.
                                        Was mach ich denn falsch?
                                        Und noch ein EDIT:
                                        Hab im Debug-Log folgende Meldung gefunden:
                                        jeelink.0	2018-08-09 19:02:26.693	debug	system.adapter.admin.0: logging false
                                        jeelink.0	2018-08-09 19:02:26.686	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1533834146683,"q":0,"from":"system.adapter.admin.0","lc":1533834146683}
                                        Vielleicht hilft das der Fehlersuche weiter..
                                        Installiert ist Ver. 0.0.5 da ich beim Update auf die 0.0.6 imer die ZIP-File Fehlermeldung bekomme.
                                        Gruß Peer
                                        • F Abwesend
                                          F Abwesend
                                          foxthefox
                                          #134
                                          Hallo Peer,
                                          von den Datentelegrammen sieht es erstmal nicht so schlecht aus, ich werde sie mal dekodieren und schauen was da schief läuft.
                                          Was genau ist bei der 0.0.6 das Problem, da hatte ich mir die Arbeit gemacht auf neue serielle Bibliothek upzudaten.
                                          Klaus
                                          Ein Aufruf: video
