  4. [Vorlage] Spotify Skript
    6.6k
javascript
745 Beiträge 95 Kommentatoren 341.9k Aufrufe 41 Beobachtet
    schubi82
    #337
    bei mir ist es irgendwie ein Glücksspiel, ob der Adapter irgendwelche Eingaben annimmt oder nicht… Nach einem Neustart des Adapters geht es dann für unbestimmte Zeit wieder. Wenn es nicht geht, bekomme ich folgende Einträge:
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage.emit (events.js:185:7)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitNone (events.js:91:20)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage.g (events.js:292:16)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1085:12)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.emit (events.js:188:7)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitOne (events.js:96:13)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request. (/opt/iobroker/node_modules/request/request.js:1163:10)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.emit (events.js:191:7)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitTwo (events.js:106:13)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
    ! spotify-premium.0 2018-05-05 18:10:25.416 warn Error
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1162:21)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
    ! spotify-premium.0 2018-05-05 18:10:25.414 warn Error
    ! spotify-premium.0 2018-05-05 18:10:25.413 warn HTTP Request Error not handled, please debug
    Jemand eine Idee?
      schubi82
      #338
      Nochmal zum Verständnis… wenn ich den Adapter von Twonky habe, benötige ich das Skript von Lucky nicht, oder? Ich habe anscheinend das Problem, was Lucky auf Seite zwei gelöst hat: ich kann kein Device auswählen, wenn die Wiedergabe nicht läuft. Ist natürlich doof, denn im Vis kann ich die Wiedergabe nicht starten, wenn kein Gerät ausgewählt ist - ein Teufelskreis :)
      Oder muss ich im JavaScript-Adapter doch ein Skript erstellen?
      • wendy2702W Online
        wendy2702W Online
        #339
        Richtig!
        Entweder Script oder Adapter. Beides zusammen ist nicht notwendig.
          schubi82
          #340
          Ok, danke. Dann ist das wohl in Twonkys Adapter nicht implementiert…
          @twonky: Kannst Du da was machen?
          Mich würde auch noch interessieren, welches Widget ich für die Darstellung von Playlisten oder Sendern nehmen kann, was mir auch das Cover aus den Objekten zieht.
          • wendy2702W Online
            wendy2702W Online
            #341
            Ich habe ein kleines Blockly gemacht und mit einem Widget verknüpft.
            Mit dem Widget schalte ich das Device an und mit dem Blockly „drücke“ ich dann paar Sekunden später den „Use this for playback“ button.
            • J Offline
              jankir
              #342
              @wendy2702:
              Mit dem Widget schalte ich das Device an und mit dem Blockly „drücke“ ich dann paar Sekunden später den „Use this for playback“ button. `
              So mache ich es auch, aber nach ein paar Minuten geht der State "musiccast.0.WX-030_0E417983.netusb.playback" auf Pause und lässt sich dann auch nicht in der Musiccast oder Spotify app wieder starten. Wenn man auf Play drückt fängt es eine Sekunde zu laufen an und geht dann wieder auf Pause.
              Per Knopfdruck auf "spotify-premium.0.Player.Play" geht es wieder.
              Hat jemand eine Idee woran das liegen kann?
                seppel786
                #343
                ich bin neu hier bzw. auch relativ neu im Bereich ioBroker.
                Ich habe eine kleine Frage an Euch: Den Spotifyadapter konnte ich inioBroker ohne Probleme installieren und authorisieren.
                Wenn ich nun in den Objekten im Playerordner nun bei Play oder Pause den simulierten Button drücke wird auch eine Aktion ausgeführt.
                Füge ich nun in meine View einen einfach Statebutton hinzu und weise diesem bspweise den Wert "spotify-premium.0.Player.Pause" zu
                und führe die View und drücke den Button passiert irgendwie nichts.
                Das Log wirft folgende Meldung:
                spotify-premium.0	2018-05-12 18:27:52.972	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v6.14.2
                host.raspberrypi	2018-05-12 18:27:50.522	info	instance system.adapter.spotify-premium.0 started with pid 5619
                host.raspberrypi	2018-05-12 18:27:20.479	info	Restart adapter system.adapter.spotify-premium.0 because enabled
                host.raspberrypi	2018-05-12 18:27:20.479	error	instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
                Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request.emit (events.js:188:7)
                Caught	2018-05-12 18:27:20.478	error	by controller[0]: at emitOne (events.js:96:13)
                Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request.emit (events.js:191:7)
                Caught	2018-05-12 18:27:20.475	error	by controller[0]: at emitTwo (events.js:106:13)
                Caught	2018-05-12 18:27:20.475	error	by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                Caught	2018-05-12 18:27:20.475	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                Caught	2018-05-12 18:27:20.475	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                Caught	2018-05-12 18:27:20.474	error	by controller[0]: at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                Caught	2018-05-12 18:27:20.474	error	by controller[0]: at Array.forEach (native)
                Caught	2018-05-12 18:27:20.473	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:32
                Caught	2018-05-12 18:27:20.464	error	by controller[0]: TypeError: Cannot read property 'url' of undefined
                spotify-premium.0	2018-05-12 18:27:20.413	info	terminating
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.emit (events.js:188:7)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at emitOne (events.js:96:13)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                spotify-premium.0	2018-05-12 18:27:20.225	error	at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at Array.forEach (native)
                spotify-premium.0	2018-05-12 18:27:20.225	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:32
                spotify-premium.0	2018-05-12 18:27:20.225	error	TypeError: Cannot read property 'url' of undefined
                spotify-premium.0	2018-05-12 18:27:20.215	error	uncaught exception: Cannot read property 'url' of undefined
                Edit:
                Nun habe ich über die VIS-Player Widget die ganze Sache zum Laufen zu bekommen. Hier nun diese Meldungen.
                Reaktion gab es leider keine :-(
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage.emit (events.js:185:7)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitNone (events.js:91:20)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage.g (events.js:292:16)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.emit (events.js:188:7)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitOne (events.js:96:13)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                spotify-premium.0	2018-05-12 18:48:59.947	warn	Error
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at tryOnImmediate (timers.js:645:5)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at runCallback (timers.js:672:20)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at Adapter.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at Array.forEach (native)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                spotify-premium.0	2018-05-12 18:48:59.945	warn	Error
                spotify-premium.0	2018-05-12 18:48:59.945	warn	HTTP Request Error not handled, please debug
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage.emit (events.js:185:7)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitNone (events.js:91:20)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage.g (events.js:292:16)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.emit (events.js:188:7)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitOne (events.js:96:13)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                spotify-premium.0	2018-05-12 18:48:58.940	warn	Error
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at tryOnImmediate (timers.js:645:5)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at runCallback (timers.js:672:20)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at Adapter.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at Array.forEach (native)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                spotify-premium.0	2018-05-12 18:48:58.938	warn	Error
                spotify-premium.0	2018-05-12 18:48:58.938	warn	HTTP Request Error not handled, please debug
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage.emit (events.js:185:7)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitNone (events.js:91:20)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage.g (events.js:292:16)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.emit (events.js:188:7)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitOne (events.js:96:13)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                spotify-premium.0	2018-05-12 18:48:57.810	warn	Error
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at tryOnImmediate (timers.js:645:5)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at runCallback (timers.js:672:20)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at Adapter.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at Array.forEach (native)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                spotify-premium.0	2018-05-12 18:48:57.808	warn	Error
                spotify-premium.0	2018-05-12 18:48:57.807	warn	HTTP Request Error not handled, please debug
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage.emit (events.js:185:7)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitNone (events.js:91:20)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage.g (events.js:292:16)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.emit (events.js:188:7)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitOne (events.js:96:13)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                spotify-premium.0	2018-05-12 18:48:40.360	warn	Error
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at tryOnImmediate (timers.js:645:5)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at runCallback (timers.js:672:20)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at Adapter.emit (events.js:191:7)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at emitTwo (events.js:106:13)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at Array.forEach (native)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                spotify-premium.0	2018-05-12 18:48:40.357	warn	Error
                spotify-premium.0	2018-05-12 18:48:40.347	warn	HTTP Request Error not handled, please debug
                Kann mir da bitte jemand unter die Arme greifen?
                Danke für Eure Hilfe,
                Daniel aka Seppel
                Geändert: Code in Code-Tags; Homoran (Admin)
                • twonkyT Offline
                  twonkyT Offline
                  twonky
                  #344
                  Ich habe jetzt eine ganze Weile an Version https://github.com/twonky4/ioBroker.spotify-premium gearbeitet.
                  Der große Versionssprung, weil ich die States umbenannt habe. Sie folgen nun einem einheitlichem Namensschema das mit den Standard ioBroker States übereinstimmt. Alles States haben nun eine Beschreibung und es sind auch einige neue hinzugekommen. Es müssen also die alten Instanzen gelöscht und neu angelegt werden.
                  Was mir für eine Veröffentlichung nur noch fehlt sind ein paar VIS Beispiele.
                  Nun happy State umbennen ;) (Ja, ich weiß das ist nervig, aber ich wollte das machen bevor der Adapter in das ioBroker repo aufgenommen wird)
                  • MicM Offline
                    MicM Offline
                    Mic
                    #345
                    Vielen Dank twonky, funktioniert sehr gut
                      mikiline
                      #346
                      ich hab da wieder probleme die app zu autorisieren….
                      Browser bleibt beim Login stehen und wird nicht weitergeleitet......Es wird aber trotzdem bei spotify eingeloggt.
                      Beim 2. Aufruf kommt dann die redirect uri....
                      Weiss jemand weiter?
                      • twonkyT Offline
                        twonkyT Offline
                        twonky
                        #347
                        Wie sieht denn die URL aus? Kannst du mal den Browser Cache leeren und nochmal probieren.
                          schubi82
                          #348
                          Funktioniert fast gut, bis auf zwei Sachen:
                          • der isAvailable-Status ist bei mir fast nie richtig, in der Spotify-App werden die Geräte aber angezeigt (z.B. der Onkyo-Receiver im Network-Standby)
                          • der Fortschritt wird nicht mehr angezeigt, keine Ahnung was da vorher eingetragen war:
                          [{"tpl":"tplValueListHtml8","data":{"oid":"","visibility-cond":"==","visibility-val":1,"count":"1","value1":"","style0":"","style1":"","value0":"","test_list":"","name":"","comment":"","visibility-groups-action":"hide","class":"","views":null,"g_css_background":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_css_shadow_padding":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"Fortschritt: {spotify-premium.0.PlaybackInfo.progress}
                          ","html_append":"Länge: {spotify-premium.0.PlaybackInfo.duration}"},"style":{"left":"664px","top":"119px","text-align":"left","width":"114px","height":"27px","font-family":"","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"x-small","z-index":"10","color":"white","line-height":""},"widgetSet":"basic"}]
                          • twonkyT Offline
                            twonkyT Offline
                            twonky
                            #349
                            @schubi82:
                            • isAvailable: Spotify kennt nicht immer alle Geräte. Ich glaube irgendwann verlieren die Geräte bei Nichtbenutzung die Verbindung zu Spotify. Die Spotify-App scannt das Netzwerk selbst nach Geräten (auch nicht nicht mit deinem Spotify Account verbunden sind). Das tut der Adapter aktuell nicht. Wenn also ein Gerät als isAvailable = false hat, musst du erst mit einer App (Handy/Desktop egal) das Gerät mit deinem Account verbinden. Ich plane da aber was, das der Adapter auch Geräte registrieren kann, das ist nur von Spotify nicht dokumentiert und leider nicht so einfach.
                            • Fortschritt: Wie geschrieben habe die States umbenannt. Bitte auch Groß/Kleinschreibung beachten.
                              mikiline
                              #350
                              @twonky:
                              Wie sieht denn die URL aus? Kannst du mal den Browser Cache leeren und nochmal probieren. `
                              Die URL sieht so aus (ID natürlich mal ausge"X"xt ;)
                              https://accounts.spotify.com/de/authori … ad-private
                              • twonkyT Offline
                                twonkyT Offline
                                twonky
                                #351
                                @mikiline:
                                In der URL gibt es einen unterschied. Kann natürlich das es hier am Forum liegt, aber diese "&" müsssen einfache "&" sein.
                                  mikiline
                                  #352
                                  @twonky:
                                  @mikiline:
                                  In der URL gibt es einen unterschied. Kann natürlich das es hier am Forum liegt, aber diese "&" müsssen einfache "&" sein. `
                                  Das kopier ich genau so aus dem Objekt raus…..liegt nicht am Forum.
                                  Hab mal mit suchen und ersetzen alle ersetzt. Genau das gleiche.....es bringt mich zum Login um die App zuzulassen. Nach klick auf Login bleibt die Seite gleich, es wird nirgends weitergeleitet.
                                  • twonkyT Offline
                                    twonkyT Offline
                                    twonky
                                    #353
                                    Hast du mal versucht die selbe URL nach dem Login nochmal aufzurufen?
                                      mikiline
                                      #354
                                      @twonky:
                                      Hast du mal versucht die selbe URL nach dem Login nochmal aufzurufen? `
                                      ja, dann kommt gleich die missing required uri Meldung.
                                      Auch auf einem anderen PC keine Chance. Nach Klick auf "Anmelden" wird keine andere Seite geladen. Fenster bzw Webseite bleibt beim Logion stehen
                                      • twonkyT Offline
                                        twonkyT Offline
                                        twonky
                                        #355
                                        Bei mir funktioniert das ohne Probleme, in Chrome/Firefox/IE. Ich habe auch an der Autorisierung nichts geändert.
                                        Hattest du versucht mal den Browser Cache zu leeren? Kopierst du auch die ganze URL? Versuch doch mal im Spotify Portal eine neue App anzulegen. Und wie geschrieben "&" dürfen in der URL nicht vorkommen, das sollte einfach nur ein "&" sein.
                                        Haben damit auch andere Probleme?
                                          schubi82
                                          #356
                                          Danke twonky für die Erklärung, dann kann ich wohl erstmal nicht aus VIS die Wiedergabe an den Onkyo starten.
                                          Ich hatte keine Probleme mit der Authorisierungs-URL (Chrome), außer das authorized erst sehr viel später auf TRUE stand. Ging aber trotzdem.
