  4. [sensationell schnell gelöst] Nach Installation kein Zugriff
    6.0k
3 Beiträge 2 Kommentatoren 667 Aufrufe
    Markuse
    Hallo
    Habe nach einer Neuinstallation keinen Zugriff mit IP:Port
    Neu installiert habe ich nach dieser Anleitung:
    http://www.iobroker.net/docu/?page_id=5106&lang=de
    Nach einigem lesen hier habe ich es dann auf verschiedene Arten probiert.
    sudo npm install iobroker.js-Controller
    liefert mir jede Menge Fehler, ich hoffe hier kann man den Fehler erkennen, wo auch immer der liegt?
    ! login as: pi
    ! pi@192.168.178.30's password:
    ! Linux raspberrypi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l
    ! The programs included with the Debian GNU/Linux system are free software;
    ! the exact distribution terms for each program are described in the
    ! individual files in /usr/share/doc/*/copyright.
    ! Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    ! permitted by applicable law.
    ! Last login: Tue Apr 24 18:31:14 2018 from 192.168.178.21
    ! pi@raspberrypi:~ $ sudo npm install iobroker.js-controller
    ! npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    ! npm WARN lifecycle iobroker.js-controller@1.4.2~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.4.2 node lib/preinstall_check.js /home/pi/node_modules/.staging/iobroker.js-controller-5fe96bc0
    ! > unix-dgram@0.2.3 install /home/pi/node_modules/unix-dgram
    ! > node-gyp rebuild
    ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.1"
    ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/pi/node_modules/unix-dgram/.node-gyp"
    ! make: Entering directory '/home/pi/node_modules/unix-dgram/build'
    ! CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    ! SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
    ! COPY Release/unix_dgram.node
    ! make: Leaving directory '/home/pi/node_modules/unix-dgram/build'
    ! > ursa@0.9.4 install /home/pi/node_modules/ursa
    ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/pi/node_modules/ursa/.node-gyp"
    ! make: Entering directory '/home/pi/node_modules/ursa/build'
    ! CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
    ! SOLINK_MODULE(target) Release/obj.target/ursaNative.node
    ! COPY Release/ursaNative.node
    ! make: Leaving directory '/home/pi/node_modules/ursa/build'
    ! > iobroker.js-controller@1.4.2 install /home/pi/node_modules/iobroker.js-controller
    ! > node iobroker.js setup first
    ! /home/pi
    ! └─┬ iobroker.js-controller@1.4.2
    ! ├── bluebird@3.5.1
    ! ├── daemonize2@0.4.2
    ! ├─┬ greenlock@2.2.5
    ! │ ├── acme-v2@1.0.5
    ! │ ├── asn1js@1.2.12
    ! │ ├─┬ certpem@1.0.1
    ! │ │ ├── buffer-v6-polyfill@1.0.5
    ! │ │ └── node.extend@1.1.6
    ! │ ├── homedir@0.6.0
    ! │ ├── le-acme-core@2.1.2
    ! │ ├─┬ le-challenge-sni@2.0.1
    ! │ │ └── le-tls-sni@0.1.4
    ! │ ├── le-store-certbot@2.0.5
    ! │ ├── localhost.daplie.me-certificates@1.3.5
    ! │ ├── node.extend@1.1.6
    ! │ ├── pkijs@1.3.33
    ! │ └─┬ rsa-compat@1.3.2
    ! │ ├── node-forge@0.6.49
    ! │ └─┬ ursa@0.9.4
    ! │ ├── bindings@1.3.0
    ! │ └── nan@2.10.0
    ! ├─┬ iobroker.admin@3.4.0
    ! │ ├─┬ body-parser@1.18.2
    ! │ │ ├── bytes@3.0.0
    ! │ │ ├── content-type@1.0.4
    ! │ │ ├── debug@2.6.9
    ! │ │ ├── depd@1.1.2
    ! │ │ ├─┬ http-errors@1.6.3
    ! │ │ │ └── statuses@1.5.0
    ! │ │ ├── iconv-lite@0.4.19
    ! │ │ ├─┬ on-finished@2.3.0
    ! │ │ │ └── ee-first@1.1.1
    ! │ │ ├─┬ raw-body@2.3.2
    ! │ │ │ ├─┬ http-errors@1.6.2
    ! │ │ │ │ ├── depd@1.1.1
    ! │ │ │ │ └── setprototypeof@1.0.3
    ! │ │ │ └── unpipe@1.0.0
    ! │ │ └─┬ type-is@1.6.16
    ! │ │ └── media-typer@0.3.0
    ! │ ├── connect-flash@0.1.1
    ! │ ├─┬ cookie-parser@1.4.3
    ! │ │ ├── cookie@0.3.1
    ! │ │ └── cookie-signature@1.0.6
    ! │ ├─┬ express@4.16.3
    ! │ │ ├─┬ accepts@1.3.5
    ! │ │ │ └── negotiator@0.6.1
    ! │ │ ├── array-flatten@1.1.1
    ! │ │ ├── content-disposition@0.5.2
    ! │ │ ├── encodeurl@1.0.2
    ! │ │ ├── escape-html@1.0.3
    ! │ │ ├── etag@1.8.1
    ! │ │ ├─┬ finalhandler@1.1.1
    ! │ │ │ └── statuses@1.4.0
    ! │ │ ├── fresh@0.5.2
    ! │ │ ├── merge-descriptors@1.0.1
    ! │ │ ├── methods@1.1.2
    ! │ │ ├── parseurl@1.3.2
    ! │ │ ├── path-to-regexp@0.1.7
    ! │ │ ├─┬ proxy-addr@2.0.3
    ! │ │ │ ├── forwarded@0.1.2
    ! │ │ │ └── ipaddr.js@1.6.0
    ! │ │ ├── range-parser@1.2.0
    ! │ │ ├─┬ send@0.16.2
    ! │ │ │ ├── destroy@1.0.4
    ! │ │ │ ├── mime@1.4.1
    ! │ │ ├── serve-static@1.13.2
    ! │ │ ├── setprototypeof@1.1.0
    ! │ │ ├── statuses@1.4.0
    ! │ │ ├── utils-merge@1.0.1
    ! │ │ └── vary@1.1.2
    ! │ ├─┬ express-fileupload@0.4.0
    ! │ │ ├─┬ busboy@0.2.14
    ! │ │ │ ├─┬ dicer@0.2.5
    ! │ │ │ │ └── streamsearch@0.1.2
    ! │ │ │ └─┬ readable-stream@1.1.14
    ! │ │ │ └── isarray@0.0.1
    ! │ │ ├─┬ fs-extra@4.0.3
    ! │ │ │ ├── graceful-fs@4.1.11
    ! │ │ │ ├── jsonfile@4.0.0
    ! │ │ │ └── universalify@0.1.1
    ! │ │ ├─┬ md5@2.2.1
    ! │ │ │ ├── charenc@0.0.2
    ! │ │ │ ├── crypt@0.0.2
    ! │ │ │ └── is-buffer@1.1.6
    ! │ │ └── streamifier@0.1.1
    ! │ ├─┬ express-session@1.15.6
    ! │ │ ├── crc@3.4.4
    ! │ │ ├── on-headers@1.0.1
    ! │ │ └─┬ uid-safe@2.1.5
    ! │ │ └── random-bytes@1.0.0
    ! │ ├─┬ passport@0.4.0
    ! │ │ ├── passport-strategy@1.0.0
    ! │ │ └── pause@0.0.1
    ! │ ├── passport-local@1.0.0
    ! │ ├── passport.socketio@3.7.0
    ! │ └── xtend@4.0.1
    ! ├─┬ jsonwebtoken@8.2.1
    ! │ ├─┬ jws@3.1.4
    ! │ │ ├── base64url@2.0.0
    ! │ │ └─┬ jwa@1.1.5
    ! │ │ ├── buffer-equal-constant-time@1.0.1
    ! │ │ └── ecdsa-sig-formatter@1.0.9
    ! │ ├── lodash.includes@4.3.0
    ! │ ├── lodash.isboolean@3.0.3
    ! │ ├── lodash.isinteger@4.0.4
    ! │ ├── lodash.isnumber@3.0.3
    ! │ ├── lodash.isplainobject@4.0.6
    ! │ ├── lodash.isstring@4.0.1
    ! │ ├── lodash.once@4.1.1
    ! │ └── ms@2.1.1
    ! ├─┬ jszip@3.1.5
    ! │ ├── core-js@2.3.0
    ! │ ├── es6-promise@3.0.2
    ! │ ├─┬ lie@3.1.1
    ! │ │ └── immediate@3.0.6
    ! │ ├── pako@1.0.6
    ! │ └─┬ readable-stream@2.0.6
    ! │ ├── core-util-is@1.0.2
    ! │ ├── inherits@2.0.3
    ! │ ├── isarray@1.0.0
    ! │ ├── process-nextick-args@1.0.7
    ! │ ├── string_decoder@0.10.31
    ! │ └── util-deprecate@1.0.2
    ! ├── le-challenge-fs@2.0.8
    ! ├── le-sni-auto@2.1.4
    ! ├── mime@1.6.0
    ! ├─┬ mkdirp@0.5.1
    ! │ └── minimist@0.0.8
    ! ├── ncp@2.0.0
    ! ├─┬ node-schedule@1.3.0
    ! │ ├─┬ cron-parser@2.5.0
    ! │ │ ├─┬ is-nan@1.2.1
    ! │ │ │ └─┬ define-properties@1.1.2
    ! │ │ │ ├── foreach@2.0.5
    ! │ │ │ └── object-keys@1.0.11
    ! │ │ └─┬ moment-timezone@0.5.16
    ! │ │ └── moment@2.22.1
    ! │ ├── long-timeout@0.1.1
    ! │ └── sorted-array-functions@1.1.0
    ! ├─┬ node.extend@2.0.0
    ! │ └── is@3.2.1
    ! ├─┬ prompt@1.0.0
    ! │ ├── colors@1.2.1
    ! │ ├── pkginfo@0.4.1
    ! │ ├─┬ read@1.0.7
    ! │ │ └── mute-stream@0.0.7
    ! │ ├── revalidator@0.1.8
    ! │ ├─┬ utile@0.3.0
    ! │ │ ├── async@0.9.2
    ! │ │ ├── deep-equal@0.2.2
    ! │ │ ├── i@0.3.6
    ! │ │ ├── ncp@1.0.1
    ! │ │ └─┬ rimraf@2.6.2
    ! │ │ └─┬ glob@7.1.2
    ! │ │ ├── fs.realpath@1.0.0
    ! │ │ ├─┬ inflight@1.0.6
    ! │ │ │ └── wrappy@1.0.2
    ! │ │ ├─┬ minimatch@3.0.4
    ! │ │ │ └─┬ brace-expansion@1.1.11
    ! │ │ │ ├── balanced-match@1.0.0
    ! │ │ │ └── concat-map@0.0.1
    ! │ │ ├── once@1.4.0
    ! │ │ └── path-is-absolute@1.0.1
    ! │ └─┬ winston@2.1.1
    ! │ ├── async@1.0.0
    ! │ ├── colors@1.0.3
    ! │ └── pkginfo@0.3.1
    ! ├── pyconf@1.1.2
    ! ├─┬ redis@2.8.0
    ! │ ├── double-ended-queue@2.1.0-0
    ! │ ├── redis-commands@1.3.5
    ! │ └── redis-parser@2.6.0
    ! ├─┬ request@2.85.0
    ! │ ├── aws-sign2@0.7.0
    ! │ ├── aws4@1.7.0
    ! │ ├── caseless@0.12.0
    ! │ ├─┬ combined-stream@1.0.6
    ! │ │ └── delayed-stream@1.0.0
    ! │ ├── extend@3.0.1
    ! │ ├── forever-agent@0.6.1
    ! │ ├─┬ form-data@2.3.2
    ! │ │ └── asynckit@0.4.0
    ! │ ├─┬ har-validator@5.0.3
    ! │ │ ├─┬ ajv@5.5.2
    ! │ │ │ ├── co@4.6.0
    ! │ │ │ ├── fast-deep-equal@1.1.0
    ! │ │ │ ├── fast-json-stable-stringify@2.0.0
    ! │ │ │ └── json-schema-traverse@0.3.1
    ! │ │ └── har-schema@2.0.0
    ! │ ├─┬ hawk@6.0.2
    ! │ │ ├── boom@4.3.1
    ! │ │ ├─┬ cryptiles@3.1.2
    ! │ │ │ └── boom@5.2.0
    ! │ │ ├── hoek@4.2.1
    ! │ │ └── sntp@2.1.0
    ! │ ├─┬ http-signature@1.2.0
    ! │ │ ├── assert-plus@1.0.0
    ! │ │ ├─┬ jsprim@1.4.1
    ! │ │ │ ├── extsprintf@1.3.0
    ! │ │ │ ├── json-schema@0.2.3
    ! │ │ │ └── verror@1.10.0
    ! │ │ └─┬ sshpk@1.14.1
    ! │ │ ├── asn1@0.2.3
    ! │ │ ├── bcrypt-pbkdf@1.0.1
    ! │ │ ├── dashdash@1.14.1
    ! │ │ ├── ecc-jsbn@0.1.1
    ! │ │ ├── getpass@0.1.7
    ! │ │ ├── jsbn@0.1.1
    ! │ │ └── tweetnacl@0.14.5
    ! │ ├── is-typedarray@1.0.0
    ! │ ├── isstream@0.1.2
    ! │ ├── json-stringify-safe@5.0.1
    ! │ ├─┬ mime-types@2.1.18
    ! │ │ └── mime-db@1.33.0
    ! │ ├── oauth-sign@0.8.2
    ! │ ├── performance-now@2.1.0
    ! │ ├── qs@6.5.1
    ! │ ├── safe-buffer@5.1.1
    ! │ ├── stringstream@0.0.5
    ! │ ├─┬ tough-cookie@2.3.4
    ! │ │ └── punycode@1.4.1
    ! │ ├── tunnel-agent@0.6.0
    ! │ └── uuid@3.2.1
    ! ├── safe-replace@1.0.2
    ! ├── semver@5.5.0
    ! ├─┬ socket.io@2.1.0
    ! │ ├─┬ debug@3.1.0
    ! │ │ └── ms@2.0.0
    ! │ ├─┬ engine.io@3.2.0
    ! │ │ ├── base64id@1.0.0
    ! │ │ ├── debug@3.1.0
    ! │ │ ├─┬ engine.io-parser@2.1.2
    ! │ │ │ ├── after@0.8.2
    ! │ │ │ ├── arraybuffer.slice@0.0.7
    ! │ │ │ └── blob@0.0.4
    ! │ │ └─┬ ws@3.3.3
    ! │ │ ├── async-limiter@1.0.0
    ! │ │ └── ultron@1.1.1
    ! │ ├─┬ has-binary2@1.0.2
    ! │ │ └── isarray@2.0.1
    ! │ ├── socket.io-adapter@1.1.1
    ! │ └─┬ socket.io-parser@3.2.0
    ! │ ├── debug@3.1.0
    ! │ └── isarray@2.0.1
    ! ├─┬ socket.io-client@2.1.0
    ! │ ├── backo2@1.0.2
    ! │ ├── base64-arraybuffer@0.1.5
    ! │ ├── component-bind@1.0.0
    ! │ ├── component-emitter@1.2.1
    ! │ ├── debug@3.1.0
    ! │ ├─┬ engine.io-client@3.2.1
    ! │ │ ├── component-inherit@0.0.3
    ! │ │ ├── xmlhttprequest-ssl@1.5.5
    ! │ │ └── yeast@0.1.2
    ! │ ├── has-cors@1.1.0
    ! │ ├── indexof@0.0.1
    ! │ ├── object-component@0.0.3
    ! │ ├─┬ parseqs@0.0.5
    ! │ │ └─┬ better-assert@1.0.2
    ! │ │ └── callsite@1.0.0
    ! │ ├── parseuri@0.0.5
    ! │ └── to-array@0.1.4
    ! ├─┬ tar@4.4.1
    ! │ ├── chownr@1.0.1
    ! │ ├── fs-minipass@1.2.5
    ! │ ├── minipass@2.2.4
    ! │ ├── minizlib@1.1.0
    ! │ └── yallist@3.0.2
    ! ├─┬ winston@2.4.2
    ! │ ├── async@1.0.0
    ! │ ├── cycle@1.0.3
    ! │ ├── eyes@0.1.8
    ! │ └── stack-trace@0.0.10
    ! ├── winston-daily-rotate-file@1.7.2
    ! ├─┬ winston-syslog@1.2.6
    ! │ ├── glossy@0.1.7
    ! │ └─┬ unix-dgram@0.2.3
    ! │ ├── bindings@1.1.1
    ! │ └── nan@2.3.5
    ! └─┬ yargs@11.0.0
    ! ├─┬ cliui@4.1.0
    ! │ ├─┬ strip-ansi@4.0.0
    ! │ │ └── ansi-regex@3.0.0
    ! │ └─┬ wrap-ansi@2.1.0
    ! │ ├─┬ string-width@1.0.2
    ! │ │ ├── code-point-at@1.1.0
    ! │ │ └─┬ is-fullwidth-code-point@1.0.0
    ! │ │ └── number-is-nan@1.0.1
    ! │ └─┬ strip-ansi@3.0.1
    ! │ └── ansi-regex@2.1.1
    ! ├── decamelize@1.2.0
    ! ├─┬ find-up@2.1.0
    ! │ └─┬ locate-path@2.0.0
    ! │ ├─┬ p-locate@2.0.0
    ! │ │ └─┬ p-limit@1.2.0
    ! │ │ └── p-try@1.0.0
    ! │ └── path-exists@3.0.0
    ! ├── get-caller-file@1.0.2
    ! ├─┬ os-locale@2.1.0
    ! │ ├─┬ execa@0.7.0
    ! │ │ ├─┬ cross-spawn@5.1.0
    ! │ │ │ ├─┬ lru-cache@4.1.2
    ! │ │ │ │ ├── pseudomap@1.0.2
    ! │ │ │ │ └── yallist@2.1.2
    ! │ │ │ ├─┬ shebang-command@1.2.0
    ! │ │ │ │ └── shebang-regex@1.0.0
    ! │ │ │ └─┬ which@1.3.0
    ! │ │ │ └── isexe@2.0.0
    ! │ │ ├── get-stream@3.0.0
    ! │ │ ├── is-stream@1.1.0
    ! │ │ ├─┬ npm-run-path@2.0.2
    ! │ │ │ └── path-key@2.0.1
    ! │ │ ├── p-finally@1.0.0
    ! │ │ ├── signal-exit@3.0.2
    ! │ │ └── strip-eof@1.0.0
    ! │ ├─┬ lcid@1.0.0
    ! │ │ └── invert-kv@1.0.0
    ! │ └─┬ mem@1.1.0
    ! │ └── mimic-fn@1.2.0
    ! ├── require-directory@2.1.1
    ! ├── require-main-filename@1.0.1
    ! ├── set-blocking@2.0.0
    ! ├─┬ string-width@2.1.1
    ! │ └── is-fullwidth-code-point@2.0.0
    ! ├── which-module@2.0.0
    ! ├── y18n@3.2.1
    ! └─┬ yargs-parser@9.0.2
    ! └── camelcase@4.1.0
    ! npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    ! npm WARN pi No description
    ! npm WARN pi No repository field.
    ! npm WARN pi No README data
    ! npm WARN pi No license field.
    Wenn jemand evtl eine Lösung hat, so Schritt für Schritt, was ich am besten machen soll?
      alles gut!
      mach einfach mal````
      sudo iobroker start
        Markuse
        Boah, wie doof kann man sein?
        Danke!!!
