  4. Einbindung (IP) Kamera über "Motion"
142 Beiträge 29 Kommentatoren 138.4k Aufrufe 7 Beobachtet
    Terrax
    Hallo Ralf,
    installiere gerade ffmpeg und h264, bekomme bei Eingabe make -j 4 am Ende folgendes angezeigt:
    ! filters/video/resize.c:215:30: error: ‘AVComponentDescriptor {aka const struct AVComponentDescriptor}’ has no member named ‘depth’
    ! if( pix_desc->comp__.depth > 8 )
    ! Makefile:277: die Regel für Ziel „filters/video/resize.o“ scheiterte
    ! make: *** [filters/video/resize.o] Fehler 1
    ! make: *** Es wird auf noch nicht beendete Prozesse gewartet…
    ! input/lavf.c: In function ‘codec_from_stream’:
    ! input/lavf.c:63:50: error: ‘AVStream {aka struct AVStream}’ has no member named ‘codecpar’; did you mean ‘codec’?
    ! AVCodec *codec = avcodec_find_decoder( stream->codecpar->codec_id );
    ! input/lavf.c:71:9: warning: implicit declaration of function ‘avcodec_parameters_to_contex’ [-Wimplicit-function-declaration]
    ! if( avcodec_parameters_to_context( c, stream->codecpar ) < 0 )
    ! input/lavf.c:71:49: error: ‘AVStream {aka struct AVStream}’ has no member named ‘codecpar’; did you mean ‘codec’?
    ! input/lavf.c: In function ‘read_frame_internal’:
    ! input/lavf.c:107:23: warning: implicit declaration of function ‘avcodec_receive_frame’ [-Wimplicit-function-declaration]
    ! while( (ret = avcodec_receive_frame( h->lavc, h->frame )) )
    ! input/lavf.c:115:27: warning: implicit declaration of function ‘avcodec_send_packet’ [-Wimplicit-function-declaration]
    ! ret = avcodec_send_packet( h->lavc, NULL );
    ! input/lavf.c: In function ‘open_file’:
    ! input/lavf.c:199:58: error: ‘AVStream {aka struct AVStream}’ has no member named ‘codecpar’; did you mean ‘codec’?
    ! while( i < h->lavf->nb_streams && h->lavf->streams__->codecpar->codec_type != AVMEDIA_TYPE_VIDEO )
    ! Makefile:277: die Regel für Ziel „input/lavf.o“ scheiterte
    ! make: *** [input/lavf.o] Fehler 1____ ____Kann ich das ignorieren?
    Rainer____
    • Ralla66R Offline
      Ralla66R Offline
      Ralla66
      Hallo Rainer,
      das mit sudo motion start sieht gut aus, kein Fehler.
      Die -dist wird auch erkannt. Scheint Fehlerfrei zu sein.
      Bei den Fehlern kann ich leider nicht helfen.
      Die Größe wurde mir beim Backup angezeigt, dieses hat 15,8 GB.
      Das ohne IO, also eine SD Karte mit min 32 GB verwenden.
      Mit Windows greife ich per Remotedesktop Verbindung auf den Raspberry zu.
      Bin dann auf dem raspi unter Linux.
      Dort verwende ich Nano als Texteditor.
      Installieren mußte ich dieses:
      Link:
      https://www.smarthomeassistent.de/raspb … erreichen/
      In dem Reiter „Interfaces“ unter Einstellungen aktivierst du noch SSH.
      Hier:
      https://www.smarthomeassistent.de/grund ... vornehmen/
      Am besten ist du liest eben den Hauptartikel ganz durch.
      Bei mir läuft Motion auf dem Rasp unter Stretch vom 11.2017.
      Jessie macht da wohl ärger.
      Du kannst ein Logfile mit motion erstellen.
      Dazu mußt du was in der motion.conf umstellen.
      Habe ich noch nicht gemacht, aber Anleitung wie steht hier:
      https://motion-project.github.io/motion_config.html
      der Log liegt dann unter: /var/log/motion/motion.log
      Lege dir mal meine motion.conf in den Spoiler als Vergleich.
      Die kannst du kopieren und genau so bei dir einfügen.
      Meine -dist liegt auch im Spoiler, dort füge nur deine Cam URL ( unter netcam_url ) ein.
      Dann kopiere diese auch.
      Dann sollte das laufen, wenn nicht liegt der Fehler nicht bei motion.
      Dann könnte es ein Codec fehler, oder falsches Betiebssystem oder ähnliches sein.
      ! # Rename this distribution example file to motion.conf
      ! # This config file was generated by motion 4.0
      ! # Daemon
      ! # Start in daemon (background) mode and release terminal (default: off)
      ! daemon on
      ! # File to store the process ID, also called pid file. (default: not defined)
      ! process_id_file /var/run/motion/motion.pid
      ! # Basic Setup Mode
      ! # Start in Setup-Mode, daemon disabled. (default: off)
      ! setup_mode off
      ! # Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
      ! logfile /var/log/motion/motion.log
      ! # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
      ! log_level 6
      ! # Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
      ! log_type all
      ! # Capture device options
      ! # Videodevice to be used for capturing (default /dev/video0)
      ! # for FreeBSD default is /dev/bktr0
      ! # videodevice /dev/video0
      ! # HooToo
      ! # netcam_url http://192.168.2.203:1111/cgi-bin/hi351 … -getstream
      ! # v4l2_palette allows one to choose preferable palette to be use by motion
      ! # to capture from those supported by your videodevice. (default: 17)
      ! # E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
      ! # V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
      ! # Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
      ! # instead.
      ! # Values :
      ! # V4L2_PIX_FMT_SN9C10X : 0 'S910'
      ! # V4L2_PIX_FMT_SBGGR16 : 1 'BYR2'
      ! # V4L2_PIX_FMT_SBGGR8 : 2 'BA81'
      ! # V4L2_PIX_FMT_SPCA561 : 3 'S561'
      ! # V4L2_PIX_FMT_SGBRG8 : 4 'GBRG'
      ! # V4L2_PIX_FMT_SGRBG8 : 5 'GRBG'
      ! # V4L2_PIX_FMT_PAC207 : 6 'P207'
      ! # V4L2_PIX_FMT_PJPG : 7 'PJPG'
      ! # V4L2_PIX_FMT_MJPEG : 8 'MJPEG'
      ! # V4L2_PIX_FMT_JPEG : 9 'JPEG'
      ! # V4L2_PIX_FMT_RGB24 : 10 'RGB3'
      ! # V4L2_PIX_FMT_SPCA501 : 11 'S501'
      ! # V4L2_PIX_FMT_SPCA505 : 12 'S505'
      ! # V4L2_PIX_FMT_SPCA508 : 13 'S508'
      ! # V4L2_PIX_FMT_UYVY : 14 'UYVY'
      ! # V4L2_PIX_FMT_YUYV : 15 'YUYV'
      ! # V4L2_PIX_FMT_YUV422P : 16 '422P'
      ! # V4L2_PIX_FMT_YUV420 : 17 'YU12'
      ! v4l2_palette 17
      ! # Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
      ! # This is ONLY used for FreeBSD. Leave it commented out for Linux
      ! ; tunerdevice /dev/tuner0
      ! # The video input to be used (default: -1)
      ! # Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
      ! # Set to 0 for uvideo(4) on OpenBSD
      ! input -1
      ! # The video norm to use (only for video capture and TV tuner cards)
      ! # Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
      ! norm 0
      ! # The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
      ! frequency 0
      ! # Override the power line frequency for the webcam. (normally not necessary)
      ! # Values:
      ! # -1 : Do not modify device setting
      ! # 0 : Power line frequency Disabled
      ! # 1 : 50hz
      ! # 2 : 60hz
      ! # 3 : Auto
      ! power_line_frequency -1
      ! # Rotate image this number of degrees. The rotation affects all saved images as
      ! # well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
      ! rotate 0
      ! # Image width (pixels). Valid range: Camera dependent, default: 640
      ! # width 640
      ! # Image height (pixels). Valid range: Camera dependent, default: 480
      ! # height 480
      ! # Maximum number of frames to be captured per second.
      ! # Valid range: 2-100. Default: 100 (almost no limit).
      ! # Ralla5
      ! framerate 5
      ! # Minimum time in seconds between capturing picture frames from the camera.
      ! # Default: 0 = disabled - the capture rate is given by the camera framerate.
      ! # This option is used when you want to capture images at a rate lower than 2 per second.
      ! minimum_frame_time 0
      ! # URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// mjpg:// rtsp:// mjpeg:// or file:///)
      ! # Must be a URL that returns single jpeg pictures or a raw mjpeg stream. A trailing slash may be required for some cameras.
      ! # Default: Not defined
      ! ; netcam_url value
      ! # Username and password for network camera (only if required). Default: not defined
      ! # Syntax is user:password
      ! ; netcam_userpass value
      ! # The setting for keep-alive of network socket, should improve performance on compatible net cameras.
      ! # off: The historical implementation using HTTP/1.0, closing the socket after each http request.
      ! # force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
      ! # on: Use HTTP/1.1 requests that support keep alive as default.
      ! # Default: off
      ! netcam_keepalive off
      ! # URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
      ! # If a port number other than 80 is needed, use "http://myproxy:1234".
      ! # Default: not defined
      ! ; netcam_proxy value
      ! # Set less strict jpeg checks for network cameras with a poor/buggy firmware.
      ! # Default: off
      ! netcam_tolerant_check off
      ! # RTSP connection uses TCP to communicate to the camera. Can prevent image corruption.
      ! # Default: on
      ! rtsp_uses_tcp on
      ! # Name of camera to use if you are using a camera accessed through OpenMax/MMAL
      ! ; mmalcam_name vc.ril.camera
      ! # Camera control parameters (see raspivid/raspistill tool documentation)
      ! ; mmalcam_control_params -hf
      ! # Let motion regulate the brightness of a video device (default: off).
      ! # The auto_brightness feature uses the brightness option as its target value.
      ! # If brightness is zero auto_brightness will adjust to average brightness value 128.
      ! # Only recommended for cameras without auto brightness
      ! auto_brightness off
      ! # Set the initial brightness of a video device.
      ! # If auto_brightness is enabled, this value defines the average brightness level
      ! # which Motion will try and adjust to.
      ! # Valid range 0-255, default 0 = disabled
      ! brightness 0
      ! # Set the contrast of a video device.
      ! contrast 0
      ! # Set the saturation of a video device.
      ! saturation 0
      ! # Set the hue of a video device (NTSC feature).
      ! hue 0
      ! # Round Robin (multiple inputs on same video device name)
      ! # Number of frames to capture in each roundrobin step (default: 1)
      ! roundrobin_frames 1
      ! # Number of frames to skip before each roundrobin step (default: 1)
      ! roundrobin_skip 1
      ! # Try to filter out noise generated by roundrobin (default: off)
      ! switchfilter off
      ! # Motion Detection Settings:
      ! # Threshold for number of changed pixels in an image that
      ! # triggers motion detection (default: 1500)
      ! threshold 1500
      ! # Automatically tune the threshold down if possible (default: off)
      ! threshold_tune off
      ! # Noise threshold for the motion detection (default: 32)
      ! noise_level 32
      ! # Automatically tune the noise threshold (default: on)
      ! noise_tune off
      ! # Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
      ! # Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
      ! # (l)abeling must only be used once and the 'l' must be the last letter.
      ! # Comment out to disable
      ! despeckle_filter EedDl
      ! # Detect motion in predefined areas (1 - 9). Areas are numbered like that: 1 2 3
      ! # A script (on_area_detected) is started immediately when motion is 4 5 6
      ! # detected in one of the given areas, but only once during an event. 7 8 9
      ! # One or more areas can be specified with this option. Take care: This option
      ! # does NOT restrict detection to these areas! (Default: not defined)
      ! ; area_detect value
      ! # PGM file to use as a sensitivity mask.
      ! # Full path name to. (Default: not defined)
      ! ; mask_file value
      ! # Dynamically create a mask file during operation (default: 0)
      ! # Adjust speed of mask changes from 0 (off) to 10 (fast)
      ! smart_mask_speed 0
      ! # Ignore sudden massive light intensity changes given as a percentage of the picture
      ! # area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
      ! lightswitch 0
      ! # Picture frames must contain motion at least the specified number of frames
      ! # in a row before they are detected as true motion. At the default of 1, all
      ! # motion is detected. Valid range: 1 to thousands, recommended 1-5
      ! # Ralla 2
      ! minimum_motion_frames 2
      ! # Specifies the number of pre-captured (buffered) pictures from before motion
      ! # was detected that will be output at motion detection.
      ! # Recommended range: 0 to 5 (default: 0)
      ! # Do not use large values! Large values will cause Motion to skip video frames and
      ! # cause unsmooth movies. To smooth movies use larger values of post_capture instead.
      ! pre_capture 0
      ! # Number of frames to capture after motion is no longer detected (default: 0)
      ! post_capture 3
      ! # Event Gap is the seconds of no motion detection that triggers the end of an event.
      ! # An event is defined as a series of motion images taken within a short timeframe.
      ! # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
      ! # events causing all Motion to be written to one single movie file and no pre_capture.
      ! # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
      ! # event ends right after no more motion is detected and post_capture is over.
      ! # Default 60
      ! # Ralla 1
      ! event_gap 1
      ! # Maximum length in seconds of a movie
      ! # When value is exceeded a new movie file is created. (Default: 0 = infinite)
      ! # Ralla 10 default 0
      ! max_movie_time 20
      ! # Always save images even if there was no motion (default: off)
      ! emulate_motion off
      ! # Image File Output
      ! # Output 'normal' pictures when motion is detected (default: on)
      ! # Valid values: on, off, first, best, center
      ! # When set to 'first', only the first picture of an event is saved.
      ! # Picture with most motion of an event is saved when set to 'best'.
      ! # Picture with motion nearest center of picture is saved when set to 'center'.
      ! # Can be used as preview shot for the corresponding movie.
      ! output_pictures on
      ! # Output pictures with only the pixels moving object (ghost images) (default: off)
      ! output_debug_pictures off
      ! # The quality (in percent) to be used by the jpeg compression (default: 75)
      ! quality 100
      ! # Type of output images
      ! # Valid values: jpeg, ppm (default: jpeg)
      ! picture_type jpeg
      ! # FFMPEG related options
      ! # Film (movies) file output, and deinterlacing of the video input
      ! # The options movie_filename and timelapse_filename are also used
      ! # by the ffmpeg feature
      ! # Use ffmpeg to encode movies in realtime (default: off)
      ! ffmpeg_output_movies on
      ! # Use ffmpeg to make movies with only the pixels moving
      ! # object (ghost images) (default: off)
      ! ffmpeg_output_debug_movies off
      ! # Use ffmpeg to encode a timelapse movie
      ! # Default value 0 = off - else save frame every Nth second
      ! ffmpeg_timelapse 0
      ! # The file rollover mode of the timelapse video
      ! # Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
      ! ffmpeg_timelapse_mode daily
      ! # Bitrate to be used by the ffmpeg encoder (default: 400000)
      ! # This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
      ! ffmpeg_bps 400000
      ! # Enables and defines variable bitrate for the ffmpeg encoder.
      ! # ffmpeg_bps is ignored if variable bitrate is enabled.
      ! # Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
      ! # or the range 1 - 100 where 1 means worst quality and 100 is best.
      ! ffmpeg_variable_bitrate 100
      ! # Codec to used by ffmpeg for the video compression.
      ! # Timelapse videos have two options.
      ! # mpg - Creates mpg file with mpeg-2 encoding.
      ! # If motion is shutdown and restarted, new pics will be appended
      ! # to any previously created file with name indicated for timelapse.
      ! # mpeg4 - Creates avi file with the default encoding.
      ! # If motion is shutdown and restarted, new pics will create a
      ! # new file with the name indicated for timelapse.
      ! # Supported formats are:
      ! # mpeg4 or msmpeg4 - gives you files with extension .avi
      ! # msmpeg4 is recommended for use with Windows Media Player because
      ! # it requires no installation of codec on the Windows client.
      ! # swf - gives you a flash film with extension .swf
      ! # flv - gives you a flash video with extension .flv
      ! # ffv1 - FF video codec 1 for Lossless Encoding
      ! # mov - QuickTime
      ! # mp4 - MPEG-4 Part 14 H264 encoding
      ! # mkv - Matroska H264 encoding
      ! # hevc - H.265 / HEVC (High Efficiency Video Coding)
      ! ffmpeg_video_codec mpeg4
      ! # When creating videos, should frames be duplicated in order
      ! # to keep up with the requested frames per second
      ! # (default: true)
      ! ffmpeg_duplicate_frames true
      ! # SDL Window
      ! # Number of motion thread to show in SDL Window (default: 0 = disabled)
      ! #sdl_threadnr 0
      ! # External pipe to video encoder
      ! # Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
      ! # Bool to enable or disable extpipe (default: off)
      ! use_extpipe off
      ! # External program (full path and opts) to pipe raw video to
      ! # Generally, use '-' for STDIN...
      ! ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of avi -o %f.avi - -fps %fps
      ! ;extpipe x264 - --input-res %wx%h --fps %fps --bitrate 2000 --preset ultrafast --quiet -o %f.mp4
      ! ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:fps=%fps -ovc x264 -x264encopts preset=ultrafast -of lavf -o %f.mp4 - -fps %fps
      ! ;extpipe ffmpeg -y -f rawvideo -pix_fmt yuv420p -video_size %wx%h -framerate %fps -i pipe:0 -vcodec libx264 -preset ultrafast -f mp4 %f.mp4
      ! # Snapshots (Traditional Periodic Webcam File Output)
      ! # Make automated snapshot every N seconds (default: 0 = disabled)
      ! snapshot_interval 0
      ! # Text Display
      ! # %Y = year, %m = month, %d = date,
      ! # %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
      ! # %v = event, %q = frame number, %t = camera id number,
      ! # %D = changed pixels, %N = noise level, \n = new line,
      ! # %i and %J = width and height of motion area,
      ! # %K and %L = X and Y coordinates of motion center
      ! # %C = value defined by text_event - do not use with text_event!
      ! # You can put quotation marks around the text to allow
      ! # leading spaces
      ! # Locate and draw a box around the moving object.
      ! # Valid values: on, off, preview (default: off)
      ! # Set to 'preview' will only draw a box in preview_shot pictures.
      ! locate_motion_mode off
      ! # Set the look and style of the locate box if enabled.
      ! # Valid values: box, redbox, cross, redcross (default: box)
      ! # Set to 'box' will draw the traditional box.
      ! # Set to 'redbox' will draw a red box.
      ! # Set to 'cross' will draw a little cross to mark center.
      ! # Set to 'redcross' will draw a little red cross to mark center.
      ! locate_motion_style box
      ! # Draws the timestamp using same options as C function strftime(3)
      ! # Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
      ! # Text is placed in lower right corner
      ! text_right %Y-%m-%d\n%T-%q
      ! # Draw a user defined text on the images using same options as C function strftime(3)
      ! # Default: Not defined = no text
      ! # Text is placed in lower left corner
      ! ; text_left CAMERA %t
      ! # Draw the number of changed pixed on the images (default: off)
      ! # Will normally be set to off except when you setup and adjust the motion settings
      ! # Text is placed in upper right corner
      ! text_changes off
      ! # This option defines the value of the special event conversion specifier %C
      ! # You can use any conversion specifier in this option except %C. Date and time
      ! # values are from the timestamp of the first image in the current event.
      ! # Default: %Y%m%d%H%M%S
      ! # The idea is that %C can be used filenames and text_left/right for creating
      ! # a unique identifier for each event.
      ! text_event %d%m%Y%H%M%S
      ! # Draw characters at twice normal size on images. (default: off)
      ! text_double off
      ! # Text to include in a JPEG EXIF comment
      ! # May be any text, including conversion specifiers.
      ! # The EXIF timestamp is included independent of this text.
      ! ;exif_text %i%J/%K%L
      ! # Target Directories and filenames For Images And Films
      ! # For the options snapshot_, picture_, movie_ and timelapse_filename
      ! # you can use conversion specifiers
      ! # Quotation marks round string are allowed.
      ! # Target base directory for pictures and films
      ! # Recommended to use absolute path. (Default: current working directory)
      ! target_dir /media/usbralla2
      ! # File path for snapshots (jpeg or ppm) relative to target_dir
      ! # Default: %v-%Y%m%d%H%M%S-snapshot
      ! # Default value is equivalent to legacy oldlayout option
      ! # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
      ! # File extension .jpg or .ppm is automatically added so do not include this.
      ! # Note: A symbolic link called lastsnap.jpg created in the target_dir will always
      ! # point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
      ! snapshot_filename %v-%d%m%Y%H%M%S-snapshot
      ! # File path for motion triggered images (jpeg or ppm) relative to target_dir
      ! # Default: %v-%Y%m%d%H%M%S-%q
      ! # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
      ! # Set to 'preview' together with best-preview feature enables special naming
      ! # convention for preview shots. See motion guide for details
      ! picture_filename %v-%d%m%Y%H%M%S-%q
      ! # File path for motion triggered ffmpeg films (movies) relative to target_dir
      ! # File extensions(.mpg .avi) are automatically added so do not include them
      ! movie_filename %v-%d%m%Y%H%M%S
      ! # File path for timelapse movies relative to target_dir
      ! # Default: %Y%m%d-timelapse
      ! timelapse_filename %d%m%Y-timelapse
      ! # Global Network Options
      ! # Enable IPv6 (default: off)
      ! ipv6_enabled off
      ! # Live Stream Server
      ! # The mini-http server listens to this port for requests (default: 0 = disabled)
      ! stream_port 8085
      ! # Quality of the jpeg (in percent) images produced (default: 50)
      ! stream_quality 100
      ! # Output frames at 1 fps when no motion is detected and increase to the
      ! # rate given by stream_maxrate when motion is detected (default: off)
      ! stream_motion off
      ! # Maximum framerate for stream streams (default: 1)
      ! stream_maxrate 25
      ! # Restrict stream connections to localhost only (default: on)
      ! stream_localhost off
      ! # Limits the number of images per connection (default: 0 = unlimited)
      ! # Number can be defined by multiplying actual stream rate by desired number of seconds
      ! # Actual stream rate is the smallest of the numbers framerate and stream_maxrate
      ! stream_limit 0
      ! # Set the authentication method (default: 0)
      ! # 0 = disabled
      ! # 1 = Basic authentication
      ! # 2 = MD5 digest (the safer authentication)
      ! stream_auth_method 0
      ! # Authentication for the stream. Syntax username:password
      ! # Default: not defined (Disabled)
      ! ; stream_authentication username:password
      ! # Percentage to scale the stream image for preview
      ! # Default: 25
      ! ; stream_preview_scale 25
      ! # Have stream preview image start on a new line
      ! # Default: no
      ! ; stream_preview_newline no
      ! # HTTP Based Control
      ! # TCP/IP port for the http server to listen on (default: 0 = disabled)
      ! webcontrol_port 8080
      ! # Restrict control connections to localhost only (default: on)
      ! webcontrol_localhost on
      ! # Output for http server, select off to choose raw text plain (default: on)
      ! webcontrol_html_output on
      ! # Authentication for the http based control. Syntax username:password
      ! ; webcontrol_authentication username:password
      ! # Tracking (Pan/Tilt)
      ! # Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
      ! # The generic type enables the definition of motion center and motion size to
      ! # be used with the conversion specifiers for options like on_motion_detected
      ! track_type 0
      ! # Enable auto tracking (default: off)
      ! track_auto off
      ! # Serial port of motor (default: none)
      ! ;track_port /dev/ttyS0
      ! # Motor number for x-axis (default: 0)
      ! ;track_motorx 0
      ! # Set motorx reverse (default: 0)
      ! ;track_motorx_reverse 0
      ! # Motor number for y-axis (default: 0)
      ! ;track_motory 1
      ! # Set motory reverse (default: 0)
      ! ;track_motory_reverse 0
      ! # Maximum value on x-axis (default: 0)
      ! ;track_maxx 200
      ! # Minimum value on x-axis (default: 0)
      ! ;track_minx 50
      ! # Maximum value on y-axis (default: 0)
      ! ;track_maxy 200
      ! # Minimum value on y-axis (default: 0)
      ! ;track_miny 50
      ! # Center value on x-axis (default: 0)
      ! ;track_homex 128
      ! # Center value on y-axis (default: 0)
      ! ;track_homey 128
      ! # ID of an iomojo camera if used (default: 0)
      ! track_iomojo_id 0
      ! # Angle in degrees the camera moves per step on the X-axis
      ! # with auto-track (default: 10)
      ! # Currently only used with pwc type cameras
      ! track_step_angle_x 10
      ! # Angle in degrees the camera moves per step on the Y-axis
      ! track_step_angle_y 10
      ! # Delay to wait for after tracking movement as number
      ! # of picture frames (default: 10)
      ! track_move_wait 10
      ! # Speed to set the motor to (stepper motor option) (default: 255)
      ! track_speed 255
      ! # Number of steps to make (stepper motor option) (default: 40)
      ! track_stepsize 40
      ! # External Commands, Warnings and Logging:
      ! # You can use conversion specifiers for the on_xxxx commands
      ! # %f = filename with full path
      ! # %n = number indicating filetype
      ! # Both %f and %n are only defined for on_picture_save,
      ! # on_movie_start and on_movie_end
      ! # Do not sound beeps when detecting motion (default: on)
      ! # Note: Motion never beeps when running in daemon mode.
      ! quiet on
      ! # Command to be executed when an event starts. (default: none)
      ! # An event starts at first motion detected after a period of no motion defined by event_gap
      ! ; on_event_start value
      ! # Command to be executed when an event ends after a period of no motion
      ! # (default: none). The period of no motion is defined by option event_gap.
      ! ; on_event_end value
      ! # Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
      ! # To give the filename as an argument to a command append it with %f
      ! ; on_picture_save value
      ! # Command to be executed when a motion frame is detected (default: none)
      ! ; on_motion_detected value
      ! # Command to be executed when motion in a predefined area is detected
      ! # Check option 'area_detect'. (default: none)
      ! ; on_area_detected value
      ! # Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
      ! ; on_movie_start value
      ! # Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
      ! ; on_movie_end value
      ! # Command to be executed when a camera can't be opened or if it is lost
      ! # NOTE: There is situations when motion don't detect a lost camera!
      ! # It depends on the driver, some drivers dosn't detect a lost camera at all
      ! # Some hangs the motion thread. Some even hangs the PC! (default: none)
      ! ; on_camera_lost value
      ! # Common Options for database features.
      ! # Options require database options to be active also.
      ! # Log to the database when creating motion triggered picture file (default: on)
      ! ; sql_log_picture on
      ! # Log to the database when creating a snapshot image file (default: on)
      ! ; sql_log_snapshot on
      ! # Log to the database when creating motion triggered movie file (default: off)
      ! ; sql_log_movie off
      ! # Log to the database when creating timelapse movies file (default: off)
      ! ; sql_log_timelapse off
      ! # SQL query string that is sent to the database
      ! # Use same conversion specifiers has for text features
      ! # Additional special conversion specifiers are
      ! # %n = the number representing the file_type
      ! # Default value:
      ! # Create tables :
      ! # Mysql
      ! # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
      ! # Postgresql
      ! # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
      ! # insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
      ! ; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
      ! # Database Options
      ! # database type : mysql, postgresql, sqlite3 (default : not defined)
      ! ; database_type value
      ! # database to log to (default: not defined)
      ! # for sqlite3, the full path and name for the database.
      ! ; database_dbname value
      ! # The host on which the database is located (default: localhost)
      ! ; database_host value
      ! # User account name for database (default: not defined)
      ! ; database_user value
      ! # User password for database (default: not defined)
      ! ; database_password value
      ! # Port on which the database is located
      ! # mysql 3306 , postgresql 5432 (default: not defined)
      ! ; database_port value
      ! # Database wait time in milliseconds for locked database to
      ! # be unlocked before returning database locked error (default 0)
      ! ; database_busy_timeout 0
      ! # Video Loopback Device (vloopback project)
      ! # Output images to a video4linux loopback device
      ! # The value '-' means next available (default: not defined)
      ! ; video_pipe value
      ! # Output motion images to a video4linux loopback device
      ! ; motion_video_pipe value
      ! # camera config files - One for each camera.
      ! # Except if only one camera - You only need this config file.
      ! # If you have more than one camera you MUST define one camera
      ! # config file for each camera in addition to this config file.
      ! # Remember: If you have more than one camera you must have one
      ! # camera file for each camera. E.g. 2 cameras requires 3 files:
      ! # This motion.conf file AND camera1.conf and camera2.conf.
      ! # Only put the options that are unique to each camera in the
      ! # camera config files.
      ! camera /etc/motion/camera1-dist.conf
      ! camera /etc/motion/camera2-dist.conf
      ! ; camera /etc/motion/camera3.conf
      ! ; camera /etc/motion/camera4.conf
      ! # Camera config directory - One for each camera.
      ! ; camera_dir /etc/motion/conf.d
      ! # /etc/motion/camera1.conf
      ! # Camera Id
      ! # Consistent identification number to assign to each camera across multiple
      ! # invocations of Motion.
      ! # Default: The order when the camera file was read
      ! # camera_id = 1
      ! # 0 = disabled
      ! stream_auth_method 1
      ! netcam_url rtsp://admin:pw@192.168.2.xx:xx
      ! width 1280
      ! height 720
      ! # Should normally be set to 1 for video/TV cards, and -1 for USB cameras
      ! input -1
      ! text_left CAMERA 1
      ! # For the options snapshot_, picture_, mpeg_ and timelapse_filename
      ! # Recommended to use absolute patch. (Default: current working directory)
      ! #target_dir /tmp/motion/cam1
      ! picture_filename CAM1_%v-%d%m%Y%H%M%S-%q
      ! stream_port 8085
      ! # The filename of the picture is appended as an argument for the command.
      ! #on_picture_save /usr/local/motion-extras/camparse2.pl
      ! # Filename of movie is appended as an argument for the command.
      ! #on_movie_end /usr/local/motion-extras/mpegparse2.pl
      Gruß Ralf
        Terrax
        Hallo Ralf,
        nochmals Danke für deine Unterstützung.
        Habe meine motion.conf und camera1-dist.conf 1:1 mit deinen abgelichen, habe noch einiges angepasst, läuft aber immer noch nicht,
        auch nicht unter Mozilla mit dem stream http://192.168.2.XXX:8085. Zum verrückt werden.
        Habe die Version RASPBIAN STRETCH LITE vom 13.08.2018, möglicherwiese liegt hier das Problem ?
        Die Lite Version hat zudem keine remote Unterstützung, bekomme daher kein remotedesktop angezeigt.
        Schade. Möchte ungern alles wieder neu unter anderer Version (11.2017) aufsetzen, wenns daran dann
        nicht gelegen hat war das ne Menge Arbeit umsonst.
        Heute scheint nicht mein Tag zu sein.
        • Ralla66R Offline
          Ralla66R Offline
          Ralla66
          Schade,
          wenn du mal wieder Lust ,Zeit und Geld hast dann ein zweiten Rasp mit SD 32 GB kaufen zum spielen.
          So habe ich das gemacht weil IO / VIS ja immer laufen soll.
          Motion läuft bei mir auf Raspi 2.
          Habe die Version RASPBIAN STRETCH LITE vom <u>13.08.2018</u>. Echt ? :lol: :mrgreen:
          Heute scheint nicht mein Tag zu sein. Stimmt !
          Gut möglich das die Lite wie auch Jessie mit motion nicht geht.
          Versuche das direkt mit http Syntax der Cam in VIS, ist wirklich einfacher.
          Positiv daran ist ja, das jetzt eine Anleitung für IP Cams mit motion im Netz steht.
          So gebündelt mit Infos gibt es die nicht.
          Dank uns :mrgreen:
          Man hört sich,
          Ralla
            Terrax
            Hi Ralf,
            das mit motion reizt, ich bleib dran und setze mal ein System mit der Raspbian 11.2017 auf. Das läßt mich jetzt nicht los.
            Vielen Dank für deine tolle Unterstützung hier und bis bald.
              Terrax
              Hi Ralf,
              also zweiter Raspi ist bestellt, habe mich für den RPi2 entschieden, soll dann wie bei Dir mit dem Images von 11.2017 laufen. Es gibt anscheinend
              ja für den Pi3 model B+ ein neues Images weil es dort mit dem von 11.2017 nicht so recht läuft. Hatte ich hier zumindest gelesen. Der Unterschied zw. 2 und 3 ist nun aber auch nicht besonders groß, zumindest was RAM angeht. WLAN brauche ich nicht. Image vom 22.11.2017 ist auf 32GB SD geladen und fertig.
              Frage: Du hast ja auch einen zweiten RPi zum Testen laufen, muss ich da noch was beachten wenn ich den zweiten RPi bei iobroker anmelde ? Ich meine wegen der VIS Lizenz u.s.w. ? Werde natürlich nur einen von beiden gleichzeitig dran haben. Brauche ich noch eine bestimmte Kombi was die SW angeht z.B.
              Admin 3.3.5
              node 6.3.1
              npm 3.10.10
              motion 4.0
              bzw. wie hoch sollte/kann ich updaten ohne Probleme zu kriegen ? Mal wieder Fragen über Fragen.
                Thosch
                einer meiner Vorredner hatte glaube ich das selbe Problem wie ich gerade.
                Der Motion Daemon ist installiert und ich bekomme über 192.168.X.X:8081 einen Stream angezeigt.
                Bewegungen werden auch erkannt und entsprechende snapshots gespeichert.
                Einzig der Motion Adapter will nicht.
                Ich habe die motion.conf und events.sh gemäß Anleitungen hier im Board erstellt/bearbeitet, den motion adapter installiert und konfiguriert. Er leuchtet auch grün. Allerdings werden auch bei mir keine Objekte von motion angezeigt. Auch nach Bewegungserkennung nicht.
                Hat jemand eine Idee?
                • Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  Hast du mal ein link wo ich den Adapter finde.
                    Thosch
                    https://github.com/ruhigundrelaxed/ioBroker.motion
                    Gibts alles in diesem Thread: viewtopic.php?f=20&t=6642
                      Terrax
                      Hi Ralf,
                      habe meine Foscam FI9901EP mit rtsp-stream jetzt über motion in der VIS am laufen. motion und motion adapter installiert. Nun möchte ich Bilder
                      bzw. Videos bei Bewegungserkennung auf meinen FTP server speichern. Mein FTP-server ist ein USB Stick an meinem speedport. Den FTP Server
                      habe ich probeweise in der SW für die Foscam eingetragen, Bewegungserkennung dort aktiviert, funktioniert. Nun möchte ich das aber nicht über die SW der Foscam sondern über motion machen. Möchte hier bei TRUE weitere Aktionen in iobroker starten. Wie lege ich den Pfad in der motion.conf am besten dafür an ? Der Pfad zum FTP server auf meinem MAC sieht für Bild und video so aus:
                      smb://speedport/Rainer/FI9901EP_00626E8547FF/record (für videos)
                      smb://speedport/Rainer/FI9901EP_00626E8547FF/snap (für Bilder)
                      Ich meine hier in der motion.conf
                      target_dir /usbstick/IPCam (an das System anpassen)
                      Komme hier nicht klar. Zudem habe ich den Teil mit den "events" noch nicht geblickt. Siehe hier:
                      ! on_event_start /usbstick/motion/events.sh on_event_start %t %s %N
                      ! on_event_end /usbstick/motion/events.sh on_event_end %t %s %N
                      ! # Command to be executed when a picture (.ppm|.jpg|.webp) is saved (default: none)
                      ! on_picture_save /usbstick/motion/events.sh on_picture_save %t %s %N %f
                      ! on_motion_detected value /usbstick/motion/events.sh on_motion_detected %t %s %N
                      ! on_area_detected /usbstick/motion/events.sh on_area_detected %t %s %N
                      ! on_movie_start /usbstick/motion/events.sh on_movie_start %t %s %N %f
                      ! on_movie_end /usbstick/motion/events.sh on_movie_end %t %s %N %f
                      ! on_camera_lost /usbstick/motion/events.sh on_camera_lost %t %s %N
                      Kannst Du mir dazu etwas Erklärung geben ?
                      Danke für deine Hilfe.
                      • Ralla66R Offline
                        Ralla66R Offline
                        Ralla66
                        Hallo Rainer,
                        bei mir ist ja der USB Stick direkt am Raspi dran.
                        wenn das überhaupt geht dann hier
                        target_dir /media/usbralla2 entfernen und das einfügen.
                        smb://speedport/Rainer/FI9901EP_00626E8547FF/record oder so
                        target_dir smb://speedport/Rainer/FI9901EP_00626E8547FF/record
                        Target_dir sind ja eigentlich Verzeichnisse des RPI.
                        Per FTP kann ich nicht helfen.
                        Zu aus IO heraus.
                        Dann mußt du ja die Kamera triggern.
                        Entweder per Kabel mit den GPIO oder per CGI Befehl.
                        Mußt du mal schaun was deine Kamera kann.
                        Bei meiner Kamera steuere ich aus IO heraus Rechts / Links usw per CGI.
                        Geht also.
                        Foscam CGI hier:
                        https://www.foscam.es/descarga/Foscam-I … .11.06.pdf
                        Picture wäre dann : http s://deineIP:443/cgi-bin/CGIProxy.fcgi?cmd=snapPicture
                        Links wäre dann : http s://deine IP:443/cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft
                        Mit diesen Events habe ich auch noch nicht gearbeitet.
                        Denke eher das sind .sh Aufrufe.
                        Die eigentliche Einstellung Bewegungserkennung ist ja unter:
                        Motion Detection Settings in der motion.conf
                        Denke das ist so: Wenn ein Ereignis Eintritt ( on_event_start ) wird diese .sh aufgerufen ( /usbstick/motion/events.sh)
                        mit der ? on_event_start %t %s %N.
                        Schaue heute Abend mal wo diese .sh liegt und was dort drin steht.
                        Gruß Ralf
                          Terrax
                          Hi Ralf,
                          Danke, probiere ich heute Abend aus. Würde ansonsten auch den USB Stick am PI einsetzen aber da ich am PI nur mit dem Terminal arbeite ist das wohl nicht so schön mit dem Aufruf der gespeicherten Bilder/Videos wegen der fehlenden Oberfläche.
                          Vielleicht sehe ich das aus Unwissenheit aber auch falsch dann wäre ich für Tipps dankbar wie ich den Stick am besten am PI mounten kann. Hatte das schon Mal probiert und da hats mir den Pi zerschossen bzw. kam nicht mehr drauf.
                          Sicher ein blöder Fehler von mir. Vielleicht hast du eine gute Anleitung für mich?
                          Gruss
                          • Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            Hallo Rainer,
                            mache erst ein Voll Backup deiner SD Card.
                            Verbindung habe ich mit Windows Lappy per Remote Desktop zum RPI.
                            Hier:
                            Schau mal ob dein MAC das hat ist einfacher.
                            Hier:
                            http://www.welzels.de/blog/2013/03/per- ... pberry-pi/
                            Mounten schaue ich heute Abend wegen einer Anleitung.
                            oder hier:
                            https://jankarres.de/2013/01/raspberry- ... einbinden/
                            Wenn du den USB Stick formatierst nimm nicht NTFS, das ging bei mir nicht.
                            Hatte glaube ich Fat32 formatiert.
                            Wenn der Stick gemountet ist fährt der RPI nur hoch wenn der Stick erkannt wird !
                            Wenn gemountet ist wieder ein Voll Backup ausführen.
                            Bis nachher.
                            Gruß Ralf
                              abuzze
                              Schaut euch mal motioneyeos / motioneye an. Find ich persönlich super. Muss nicht auf dem selben System wie iobroker laufen. Gibt es auch als fertiges Image.Nur mal so als Tip.
                              • Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                Funktioniert motioneye auch per Wifi ?
                                  abuzze
                                  @Ralla66:
                                  Funktioniert motioneye auch per Wifi ? `
                                  Ja das ist möglich. ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... 17c04b.jpg">https://uploads.tapatalk-cdn.com/20180424/d3b20a95c5a2089c6f2eb6636317c04b.jpg</link_text>" />
                                  • Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    Scheint ja eine eigenständige Kamera Soft zu sein.
                                    Es ging ja bei mir darum die Kameras in VIS einzubinden
                                    und das per http oder rtsp Stream.
                                    Wobei rtsp nur über motion einzubinden geht.
                                    Aber wer das nicht braucht scheint das gute Soft zu sein.
                                      abuzze
                                      @Ralla66:
                                      Aber wer das nicht braucht scheint das gute Soft zu sein. `
                                      Ist ja auch möglich. Nachdem die Cameras eingebunden sind stellt der Camera Server (motioneye) eine Bild oder Video url der Camera zur Verfügung die dann in VIS eingebunden werden kann. Einfach mal probieren. Bewegungsmeldung oder Alarmweiterleitung zu iobroker inclusive.
                                        abuzze
                                        @abuzze:
                                        @Ralla66:
                                        Aber wer das nicht braucht scheint das gute Soft zu sein. Ist ja auch möglich. Nachdem die Cameras eingebunden sind stellt der Camera Server (motioneye) eine Bild oder Video url der Camera zur Verfügung die dann in VIS eingebunden werden kann. Einfach mal probieren. Bewegungsmeldung oder Alarmweiterleitung zu iobroker inclusive.
                                        ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... 98268d.jpg">https://uploads.tapatalk-cdn.com/20180424/b11158d699dbf4b05c3d8c7cbf98268d.jpg</link_text>" />
                                        • Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          Danke, werde ich mal testen.
