  4. Rock64 Nach neustart kein Admin start
    6.0k
20 Beiträge 3 Kommentatoren 1.1k Aufrufe
  • wendy2702W Offline
    wendy2702W Offline
    Hast du mal die Ausgaben von dem was du auf der Troubleshooting Seite alles abgebarbeitet hast?
      shaowkahn
      Einmal der iobroker log von heute
      2018-04-16 11:11:24.544  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
      2018-04-16 11:11:24.559  - [32minfo[39m: host.ioBroker-Rock64 terminated
      2018-04-16 11:12:10.896  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
      2018-04-16 11:12:10.921  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-04-16 11:12:10.923  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
      2018-04-16 11:12:10.926  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
      2018-04-16 11:12:11.029  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
      2018-04-16 11:12:11.102  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
      2018-04-16 11:12:11.147  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
      2018-04-16 11:12:11.203  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
      2018-04-16 11:14:02.673  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
      2018-04-16 11:14:02.686  - [32minfo[39m: host.ioBroker-Rock64 terminated
      2018-04-16 11:15:03.107  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
      2018-04-16 11:15:03.129  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-04-16 11:15:03.131  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
      2018-04-16 11:15:03.134  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
      2018-04-16 11:15:03.197  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
      2018-04-16 11:15:03.249  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
      2018-04-16 11:15:03.280  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
      2018-04-16 11:15:03.330  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
      2018-04-16 12:15:03.096  - [32minfo[39m: host.ioBroker-Rock64 Delete log file iobroker.2018-04-09.log
      2018-04-16 13:17:23.242  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
      2018-04-16 13:17:23.253  - [32minfo[39m: host.ioBroker-Rock64 terminated
      2018-04-16 13:17:24.252  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
      2018-04-16 13:17:28.013  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
      2018-04-16 13:17:28.035  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2018-04-16 13:17:28.038  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
      2018-04-16 13:17:28.041  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
      2018-04-16 13:17:28.104  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
      2018-04-16 13:17:28.159  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
      2018-04-16 13:17:28.191  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
      2018-04-16 13:17:28.241  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
      oder welchen brauch man da?
        wendy2702W Offline
        Wenn du die Befehle deiner verlinkten Seite abgearbeitet hast, dann wären die Ausgaben dazu interressant.
          shaowkahn
            wendy2702W Offline
            Bitte mal:
            cd /opt/iobroker
            sudo iobroker update
            Bitte die Ausgabe als Text in Code Tags Posten.
            Was hast du denn als letztes vor dem neustart gemacht?
              shaowkahn
              @wendy2702:
              Bitte mal:
              cd /opt/iobroker
              Was hast du denn als letztes vor dem neustart gemacht? ` Cloud Adapter wollte nicht. Hatte ihn einmal stromlos gemacht. Danach ist er nicht mehr hochgefahren
              Gesendet von meinem SM-G960F mit Tapatalk
                shaowkahn
                root@ioBroker-Rock64:~# cd /opt/iobroker
                root@ioBroker-Rock64:/opt/iobroker# sudo iobroker update
                Error: Object "system.config" not found
                ^C
                sagt er nur
                  wendy2702W Offline
                  Stromlos machen war ganz schlecht :(
                  Ich hoffe du hast ein Backup !?
                    shaowkahn
                    ok habe mal das hier gemacht.
                    cd /opt/iobroker
                    iobroker stop
                    npm install iobroker.js-controller
                    iobroker setup
                    iobroker add admin
                    iobroker start
                    jetzt muss ich natürlich alle backups einspielen
                    aber es läuft erst mal
                      shaowkahn
                      @wendy2702:
                      Ich hoffe du hast ein Backup !? ` Ok wie kann ich am besten den Rock neu starten?
                      Und warum ist das schlecht?
                      Was mache ich nach einem Stromausfall?
                        wendy2702W Offline
                        ein wegnehmen der Stromversorgung ist für jeden Rechner / Betriebssystem schlecht.
                        Es sind Dateien offen die eventuell gerade bearbeitet werden vom System, Prozesse laufen die ineinander greifen oder aufeinander aufbauen. Deshalb sollte man eigentlich nie den Stecker einfach ziehen.
                        Ein sauber restart ist z.B.:
                        reboot
                        oder wenn du den Stecker ziehen willst zum runterfahren
                        shutdown -h now
                        Dann immer noch ein wenig warten bevor man den Strom kappt.
                        Der Fall eines Stromausfalles existiert natürlich immer, deshalb sollte man sich für "wichtige" Dinge überlegen ob eine Notstromversorgung (USV) Sinn macht. Die überbrückt den Ausfall für einen kurzen moment und kann dann, wenn unterstützt, das System sauber runterfahren.
                        Hast du denn jetzt ein Backup bzw. wieviel hattest du schon eingerichtet?
                          shaowkahn
                          @wendy2702:
                          reboot
                          shutdown -h now
                          Hast du denn jetzt ein Backup bzw. wieviel hattest du schon eingerichtet? ` Ja Backup habe ich.
                          Das Problem ist das ich so was nur mit dem rock64 habe beim raspberry hatte ich nie diese Problem. Auch wenn ich ihn mal vom Strom getrennt hatte
                            wendy2702W Offline
                            Ich habe keinen Rock, aber denke die Probleme kann es bei jedem Rechner System geben.
                            Vielleicht hat auch nur deine SD Karte (nutzt doch eine, oder?) einen Schaden.
                            Ich hatte das übrigens auch schon beim PI.
                              shaowkahn
                              @wendy2702:
                              Ich hatte das übrigens auch schon beim PI. ` Beim Pi hatte ich nie Probleme. Beim Rock jedes mal. Aber erst mal danke für deine hilfe
                                wendy2702W Offline
                                Habe selber keinen Rock aber wenn du das jedesmal hast ist schon merkwürdig.
                                Läuft denn nur iobroker auf dem Teil oder macht der auch nich andere Dinge?
                                  shaowkahn
                                  Nein nur der iobroker. Mit dem Image von der Web seite
                                    Ich nutze u.a. auch einen Rock64. Bei meinen Versuchen über "einfach stromlos machen" reagierte diese nicht schlimmer als ein anderer SBC.
                                    Je mehr Daten geschrieben werden, desto größer ist die Wahrscheinlichkeit genau einen Schreibzugriff zu erwischen.
                                    Hatte dein Pi und dein Rock EXAKT die gleiche Installation?
                                    • auch gleiche Anzahl history Daten
                                    • auch gleiche Anzahl flot Charts
                                      @shaowkahn:
                                      Mit dem Image von der Web seite `
                                      welches?
                                        shaowkahn
                                        @Homoran:
                                        @shaowkahn:
                                        welches?
                                        filename="Rocks.png" index="0">~~
                                        Rainer ` Das 1.
                                        Hatte damalig nen Backup vom Raps gemacht und das bei rock64 aufgespielt.
                                        Flot und history nutze ich nicht
