  4. Rock64 Nach neustart kein Admin start
    6.0k
20 Beiträge 3 Kommentatoren 1.1k Aufrufe
    shaowkahn
    Einmal der iobroker log von heute
    2018-04-16 11:11:24.544  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-04-16 11:11:24.559  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-04-16 11:12:10.896  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
    2018-04-16 11:12:10.921  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-04-16 11:12:10.923  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
    2018-04-16 11:12:10.926  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
    2018-04-16 11:12:11.029  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-04-16 11:12:11.102  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-04-16 11:12:11.147  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-04-16 11:12:11.203  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    2018-04-16 11:14:02.673  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-04-16 11:14:02.686  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-04-16 11:15:03.107  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
    2018-04-16 11:15:03.129  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-04-16 11:15:03.131  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
    2018-04-16 11:15:03.134  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
    2018-04-16 11:15:03.197  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-04-16 11:15:03.249  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-04-16 11:15:03.280  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-04-16 11:15:03.330  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    2018-04-16 12:15:03.096  - [32minfo[39m: host.ioBroker-Rock64 Delete log file iobroker.2018-04-09.log
    2018-04-16 13:17:23.242  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-04-16 13:17:23.253  - [32minfo[39m: host.ioBroker-Rock64 terminated
    2018-04-16 13:17:24.252  - [32minfo[39m: host.ioBroker-Rock64 received SIGTERM
    2018-04-16 13:17:28.013  - [32minfo[39m: host.ioBroker-Rock64 iobroker.js-controller version 1.4.0 js-controller starting
    2018-04-16 13:17:28.035  - [32minfo[39m: host.ioBroker-Rock64 Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2018-04-16 13:17:28.038  - [32minfo[39m: host.ioBroker-Rock64 hostname: ioBroker-Rock64, node: v6.14.1
    2018-04-16 13:17:28.041  - [32minfo[39m: host.ioBroker-Rock64 ip addresses: 192.168.178.42 2a02:8108:8700:e44:94f6:5ff:fe01:6715 fe80::94f6:5ff:fe01:6715
    2018-04-16 13:17:28.104  - [32minfo[39m: host.ioBroker-Rock64  inMem-states listening on port 9000
    2018-04-16 13:17:28.159  - [32minfo[39m: host.ioBroker-Rock64  inMem-objects listening on port 9001
    2018-04-16 13:17:28.191  - [32minfo[39m: host.ioBroker-Rock64 InMemoryDB connected
    2018-04-16 13:17:28.241  - [31merror[39m: host.ioBroker-Rock64 _design/system missing - call node iobroker.js setup
    oder welchen brauch man da?
    • wendy2702W Offline
      wendy2702W Offline
      Wenn du die Befehle deiner verlinkten Seite abgearbeitet hast, dann wären die Ausgaben dazu interressant.
        shaowkahn
          wendy2702W Offline
          Bitte mal:
          cd /opt/iobroker
          sudo iobroker update
          Bitte die Ausgabe als Text in Code Tags Posten.
          Was hast du denn als letztes vor dem neustart gemacht?
            shaowkahn
            @wendy2702:
            Bitte mal:
            cd /opt/iobroker
            Was hast du denn als letztes vor dem neustart gemacht? ` Cloud Adapter wollte nicht. Hatte ihn einmal stromlos gemacht. Danach ist er nicht mehr hochgefahren
            Gesendet von meinem SM-G960F mit Tapatalk
              shaowkahn
              root@ioBroker-Rock64:~# cd /opt/iobroker
              root@ioBroker-Rock64:/opt/iobroker# sudo iobroker update
              Error: Object "system.config" not found
              ^C
              sagt er nur
                wendy2702W Offline
                Stromlos machen war ganz schlecht :(
                Ich hoffe du hast ein Backup !?
                  shaowkahn
                  ok habe mal das hier gemacht.
                  cd /opt/iobroker
                  iobroker stop
                  npm install iobroker.js-controller
                  iobroker setup
                  iobroker add admin
                  iobroker start
                  jetzt muss ich natürlich alle backups einspielen
                  aber es läuft erst mal
                    shaowkahn
                    @wendy2702:
                    Ich hoffe du hast ein Backup !? ` Ok wie kann ich am besten den Rock neu starten?
                    Und warum ist das schlecht?
                    Was mache ich nach einem Stromausfall?
                      wendy2702W Offline
                      ein wegnehmen der Stromversorgung ist für jeden Rechner / Betriebssystem schlecht.
                      Es sind Dateien offen die eventuell gerade bearbeitet werden vom System, Prozesse laufen die ineinander greifen oder aufeinander aufbauen. Deshalb sollte man eigentlich nie den Stecker einfach ziehen.
                      Ein sauber restart ist z.B.:
                      reboot
                      oder wenn du den Stecker ziehen willst zum runterfahren
                      shutdown -h now
                      Dann immer noch ein wenig warten bevor man den Strom kappt.
                      Der Fall eines Stromausfalles existiert natürlich immer, deshalb sollte man sich für "wichtige" Dinge überlegen ob eine Notstromversorgung (USV) Sinn macht. Die überbrückt den Ausfall für einen kurzen moment und kann dann, wenn unterstützt, das System sauber runterfahren.
                      Hast du denn jetzt ein Backup bzw. wieviel hattest du schon eingerichtet?
                        shaowkahn
                        @wendy2702:
                        reboot
                        shutdown -h now
                        Hast du denn jetzt ein Backup bzw. wieviel hattest du schon eingerichtet? ` Ja Backup habe ich.
                        Das Problem ist das ich so was nur mit dem rock64 habe beim raspberry hatte ich nie diese Problem. Auch wenn ich ihn mal vom Strom getrennt hatte
                          wendy2702W Offline
                          Ich habe keinen Rock, aber denke die Probleme kann es bei jedem Rechner System geben.
                          Vielleicht hat auch nur deine SD Karte (nutzt doch eine, oder?) einen Schaden.
                          Ich hatte das übrigens auch schon beim PI.
                            shaowkahn
                            @wendy2702:
                            Ich hatte das übrigens auch schon beim PI. ` Beim Pi hatte ich nie Probleme. Beim Rock jedes mal. Aber erst mal danke für deine hilfe
                              wendy2702W Offline
                              Habe selber keinen Rock aber wenn du das jedesmal hast ist schon merkwürdig.
                              Läuft denn nur iobroker auf dem Teil oder macht der auch nich andere Dinge?
                                shaowkahn
                                Nein nur der iobroker. Mit dem Image von der Web seite
                                  Ich nutze u.a. auch einen Rock64. Bei meinen Versuchen über "einfach stromlos machen" reagierte diese nicht schlimmer als ein anderer SBC.
                                  Je mehr Daten geschrieben werden, desto größer ist die Wahrscheinlichkeit genau einen Schreibzugriff zu erwischen.
                                  Hatte dein Pi und dein Rock EXAKT die gleiche Installation?
                                  • auch gleiche Anzahl history Daten
                                  • auch gleiche Anzahl flot Charts
                                    @shaowkahn:
                                    Mit dem Image von der Web seite `
                                    welches?
                                      shaowkahn
                                      @Homoran:
                                      @shaowkahn:
                                      welches?
                                      filename="Rocks.png" index="0">~~
                                      Rainer ` Das 1.
                                      Hatte damalig nen Backup vom Raps gemacht und das bei rock64 aufgespielt.
                                      Flot und history nutze ich nicht
